- 84 Crossfire HELP!!
- stupid spark plug question
- LT1 ventilation system for modded engine?
- ZZ4 upgrade packages from GM
- E85 in a Diesel
- One last throttle body bypass thread!
- help me please
- ZL1 Corvette
- fuel cut off
- 1/2 fast spring idea
- Rear Wheel Bearings
- 1987 Evaporator AC Line Where to purchase?
- need help identifing material/coating on Targa
- abs
- What to use to remove wheel staines?
- 1998 C68 Electronic Control - no button lights or temperature display
- New Steering Column and Now Car Won't Start
- Change clutch slave cylinder
- Trans leak solved but EXPENSIVE?
- 91, Charging System Light
- front spring rate?
- Radiator-What should I buy?
- C4 ASR service
- 90 corvette oil pressure reading - gauge or sensor
- Symptoms of a going Optispark?
- heater control vacuum tank round ball drivers side front ?????
- Power Steering Pump Pulley Wobble
- Removing VC emblem
- Window Adjustment
- Fuel pressure
- c4 manual transmission!?
- seat switch/harness- part #10161837
- Fuel Pressure Gauges
- 94 and 95 door panels are they the same?
- Fuel injectors
- Ticking under dash while car is off?
- how many quarts of oil?
- Walbro 255 Reliability
- Cylinder Head Porting School
- 87 fuel pump in-tank harness, what is this thing?
- dual-mass == less synchro wear?
- Need Gasket Kit, or gasket materail
- New Electrical Problem
- Calling All Westchester NY Corvettes!!
- HELP : Identify parts Attemp to lower my 87
- Dashboard Display
- Coolant Flush Time...Questions
- (LT4) Air Pump w/ LT headers
- Brake Pad Upgrade
- cranking - no injector pulse
- 86 AC R12 rebuild
- LT1 superram vs tpi superram whats the diff? or is it a typo?
- 87 Z52 Thinking in brake upgrade in the near future,wilwood or C5 ?
- Potential problems on the horizon?? 92-Auto - Chicago area
- Secondary Air Injection Pump Emissions
- Need help with intake problems?
- AFR Eliminators with what Headers?
- Need Help mounting clutch pedal in 86 vette
- 90 engine cutting out problem...
- Will the resin LT4 valvecovers fit AFR227 head w/T&D rockers?
- Oil smell and leaks from my 91 L98
- Help with deciding on which 3rd led brake light to get
- L-98 Valve Cover Cleaning
- how do you adjust the pushrod to the brake pedal?
- Manual Trans Leak
- Vacuum Port what is this one for??
- First Vette
- Valvetrain geometry question
- HELP! Timing chain cover and gasket.
- changing spark plugs.
- cloth seat repair
- Damaged Floor Repair
- L98 trouble
- Plugs, oil, smoke & rattle
- Help Fast! 85 alternator purchase how many AMP?
- 94 Gauge Cluster into a 91
- stroker kit
- Need Cam Guidance for 1987 L98
- HELP! Just need to get by 1 last CT state emissions test
- Tail light sockets
- 87 Transmission Swap
- Got my brakes working, my solution to the hard brake problem
- 700R4 HELP!! or a 4L60E
- Manual headlight bypass
- 86 window regulator upgrade
- 87 A.I.R. Check Valve Rubber Hose
- Low coolant level....now problems
- helicoil ok for rocker arm stud hole?
- Washers for Magnesium valve covers?
- Is there LED halos for the c4?
- Willcox Free Shipping!
- Manifolds
- Vbp's explosive summer sale
- single plane question - victor e
- infl Rest doesn't blink A-K shorted
- voltage draw
- M/T valve covers
- Rear Oil Seal and Clutch Recomendations
- To Wrap or Not?
- crankshaft sensor
- 1991 L98 Probelms
- isn't a high performanace oil pump better for thicker oil?
- 93 vette problems
- Couple of questions - (A Tale of 2 Motors)
- A/C Break down.
- ??? - 84-87 front brakes on an 88+
- Camshaft ID...and suggestions
- Stall Rating for 85 Stock Torque Converter
- Corvette Central Muffler Eliminators
- poor shift quality on 4 plus 3 tranny
- Hesitation Under Heavy Acceleration
- Shifter Knob Removal
- is disconnecting the vacume line to the brakes the same as manual brakes?
- Can I borrow or Rent
- brake hissing, can i drive the car it i disconnect and plug the vacume line?
- Cruise quit
- Stalled and ohm's all over the place
- 89 c-4 tuned port will idle but not accelerate. HELP???
- Best LT1 mods
- 84 Stalling
- Is booster push rod adjustable?
- Fuel-Injection Cleaning And Maintenance How-To
- Seat Belt light........always on!!!!!
- After porting..What are these??
- Dana 44 blow out at the track
- Sloppy tilt -- old problem, new question
- Best width of front wheel for an 94?
- JIC Injector Install
- 85 Z51 oil cooler?
- catalytic converter help
- vacuum brakes
- power windows
- First Vette, What to expect? Few Questions!
- AC Compressor Issue
- So its almost time
- pke remote question
- '96 Collector Edition Exhaust Manifolds
- spaced out wheels man
- Has anyone had there front windshield replaced on there C4?
- Performance and MPG after top end L98 Build
- Feels like bumps on the road bewteen 48&55 mph
- SPARK PLUGS! half way their, pics included.
- Ngk tr55
- Broken ECM mounting bracket -- how hard to replace?
- fuel filter?
- 87 overheating
- Groaning Noise...Rearend
- Head & Intake Bolts
- LT4 w/hot cam; injector recommendation
- my injector stuck open, disaster averted
- LT4 w/Hot Cam; injector recommendation
- Cams for a L98?
- 4+3 Shifter Assy Removal
- Bad Transmission leak - '93 LT1
- Motor question
- what temp does you LT1 run at?
- 1994 C4 Won't Start
- Stiff pedal related to TV cable.
- a/c
- 91 vet starting problems
- how do you wire rad fans to turn on with switch but still run on automatic otherwize?
- 89 Strut Rod Bushing replacement
- Racing Brake Pads - Cheap on EBAY
- 96 brake rebuild recommendations
- Cylinder Heads
- Lower air Deflector Pictures Please
- Any Advise
- So called 1st run SLP runners?
- Fuel gauge inaccurate
- l98 to lt1 swap ...it was time
- Not the way to celebrate finish a build!!
- Header Gasket
- Sticky hydrocarbon smell when idleing
- 90 infl rest light - s/b 90-436-9j
- AC help please
- PROM tune on an 85' can it be done?
- Horn relay??
- LT1 Steam Vent Washers Needed
- Overheating '93 LT1...HELP!!
- Overheating 1993 Lt1..HELP!
- Vbp's explosive summers sale
- AC recharge...adding oil????
- Runs on starting fluid
- Engine ID Help, if you please
- Anyone ever rebuild a 4+3 overdrive?
- MSD help
- Door won't stay open
- spherical Delrin pin top shock mounts
- rims size
- FIC Injectors installed, now wtf.....
- INFL REST air bag warning light stays on
- Headlight question
- short in alternator?
- Clutch master cyl. push rod ?
- C4 LT1 - Is it really worth it??
- 85 MAF Relays...can't find pt# or where to buy, do you?
- Accusump install question (LT-4)
- Corvette in a wreck - need help identifying a part
- 3/4 in. in-line oil check valve?
- location of fuses
- HELP please!
- oil filter? 1992
- Turbo charging a LT1 C4
- Super Ram Torque Curve
- Magnaflow exhaust 92 LT1
- I need some good pictures -- please help!
- T-Boned today
- Rebuilding LT4 with 165k miles
- rearend clutch pack rebuild right away?
- Pick me out Roller rockers
- Gas tank always full
- Steering creaking and clicking
- Steering Problem
- Relearn 1986 computer
- 93 Electrical Charge Question
- HP advantages...worth the time etc....
- Steel Flywheel Experience
- DTC #26: Evaporative Emission Canister Purge Solenoid Valve Circuit.
- Car back from the body shop
- It's Like Clockwork..
- Saving My Supercharged 93, Need Guidance...
- spark plugs
- 91 won't crank over
- Dash lights worked before the jumpstart.
- Performance upgrade
- Bose amp question
- Air Bag Light
- door weather strip
- cam selection for 383 LT4
- Brake Linkage Causing Torque Converter Trouble
- Sensor location ?
- Maunal Headlight lift
- Our latest LT1 396
- 92 LT1 only starts when IAC is unplugged
- outside air temp not registering correctly
- Adjustable FPR, can't get below 46psi. WHY???
- hot cam work well with ported SR intake?
- Red Line Shockproof Gear Oil
- Local Area Programmer
- Looking for a diagram
- LT1 issues need help asap
- ? About an '85 4-Speed.........
- Dual Mass Flywheel Problem?
- Rear Coilover rate
- My Corvette handles like crap and wiggle and nothing can be done how's your beater?
- Schrader valve
- Changed clutch slave cyl
- which heads came on 85'
- stopped chipping the pillar!
