- Performance Parts you'd like to see for LTX C4
- What is the wing part in front of the radiator?
- Headlights again??
- Best valve seals to get..
- identify this
- Bushings different size (standard to FX3) not fitting correctly HELP
- 88 TPI hesitation dangerous
- building a custom radiator?
- will 86 iroc 700r4 fit a 84 corvette?????
- 1992 starter clicking
- Need help
- Pick me out valve train goodies
- Dash Problems HELP
- Need Source: Rebuilt LCD Cluster
- Any Sacramento, CA area help?
- Melrose roof skin
- Hard starting?
- Targa top vertical adjustment?
- Help installing hood on an 86?
- HELP! 1986 Auto, No Power Under Heavy Acceleration
- idling problem
- Swap cast iron heads for aluminum on 86, easy or not
- LT1 heads on L83?
- Why can I not get valve cover gaskets?
- bosch III injectors
- Driver side mirror part # ?
- Best L98 Valve Cover Gaskets?
- C4 brake upgrade to C5, what do I all need for my 85 ?????
- what is a good, economical, efect stock replacement for my throttle body?
- 3:73 rear
- Replacing "A" Pillar W.S. on My 95'
- Rear End lifting
- 85 vette still runs rough ,, new ecm , new everything ?????
- none of my injectors are working
- How to stop manifold heat shield rattle
- ECM bolts for 84-89?
- SB 2.2Heads
- Hydro Locked My 95 LT1!!
- Bumper mount frame damaged
- TBI to TPi swap w/NV3500 tranny VSS question
- What's this hose
- 93 Auto Trans question
- Swapping TPI to Weiand / Intake Manifold - Performance? From AutoZone
- best value rear wheel bearing-Roller or ball?
- will running richer cause more water to be made by the cats?
- lazy passenger headlight
- New motor. 377 Lt1, any ideas on a nice cam?
- Headlights what a pain.
- does the IAC valve control airflow at any RPM?
- i removed my airfoil and now i hear more air rushing in
- Thank you all!!!
- Head gasket question - 92 LT1
- The truth about 113 aluminum heads
- Water Damage??
- headlight
- 85 tech questions
- Opinions Please?
- Header Installation Question
- Opti life (93 coupe)
- Floor Cleaner
- alternator rebuild kit for '91
- LOOKING FOR AN lT1 MOBLE MECANIC
- Who repairs the electronic AC box
- codes?
- 86 stalls
- Air conditioner
- heads for my application?
- Turn Signal Help
- Getting Very discouraged... EFI tuners please help..
- Anyone removed the front skid bars?
- Brake pad Q
- Cruise control, steady speed kicks off SES light, no code?
- ac causes overheating.
- Code C34
- Dyno results today - Now I am really confused!
- 1993 Central Control Module
- would changing to a super ram help?
- 700R4 Pan Removal
- Tires and rim sizes please help
- Eastern High Performance Catalytic Converters?
- I need a quick answer on heads!!!
- hard cold start - bogs on acceleration
- L98 idle small problem
- 91 Service Engine Soon light code 43
- Need help with Russell fittings.
- Gears for my Dana 36??????
- Front hub bolt size and grade
- Chambered Exhaust
- wieand stealth ram
- What do you think of this crate 383?
- Fuel Check Valve
- Looking for OEM 11.5" corvette Rotors??
- Harmonic Balancer Purchase Question
- New SuperRam cheater tool.
- Brakes not stopping
- What kind of HP will these flow #'s support?
- Magnaflow 16837 installation help
- Center Bolt Valve Cover Over RR's?
- Uh oh, now my top won't go down.
- Change Oil concern
- Hotcam Kit + AFR 195 + Ported TPI + 1.6RR
- Need realigning new opti
- DIC Question
- Whats the most porting that can be done to a 113 head?
- '92 alignment/pulling problem
- Secret to replacing cowl screen?
- How do you reset Down shift cable linkage
- Orginal Grand Sports article
- Question Concerning ZR1 Rear Wheels
- water Temperature Gauges check
- power steering
- What 1.6 rockers and springs?
- welding aluminum heads?
- Stock TPI Ported base is the same as an aftermarket one ?
- 1986 alignment suggestions
- did vettes ever come factory with solid mast antenna's
- Cylinders No. 4 and 7 aren't firing
- 92 AIR pump removal, does it trigger and SES?
- 1996 LT4 code P0300
- Electroni Throttle bodies...any ?
- Need help with lt1 intake casting numbers
- 84 cross fire - vacuum for Cruise control help
- fine tuning
- question on shaking
- New SKF bearings/brake cooling installed...
- trunk release cable replacement
- ignition mod on lt1
- high idle i have searched
- Slight rough running at idle 91 L98
- Dyno numbers?
- 96 LT4 EVAP problems
- steering wheel height adjustment
- front upper shock mount?
- AFR195s + Lingenfelter 219 camshaft and 1.6 rr owners,pushrod & lifter question
- Opti spark and water pump done, couple issues and questions.
- Intermittent starting problem
- www.directauto.com - opinion?????????
- Diagnostic Conector Location 1984
- Lowering suspension?
- first time Cam change.. Procedure??
- Help with all my broken things that don't work
- checking codes on a 1990
- making a grinding noise
- need more horses for a crossfire
- I need to straighten a batwing
- Need help w/95 horn,alarm,interior lights.
- Installed AFR 195s and Super Ram - It Runs
- Radiator Removal
- tunning my own car help
- fuel system (91 L98) help needed!
- what type of glue to use on the evaporator core seals?
- 1985 MAF question
- 1996 transmission problem
- Willcox Sale Extended until the end of Sept.
- anyone know anything about JVT headers?
- 96 LT4 coolant leak
- Lil bench racing...
- Help with horn on 95
- Chrome Alternator
- 1990 Coupe CD/Tape BOSE unit
- EGR code 32 DTC problem
- Boot and Shift Indicator Re-Attachment
- just got 84 vet need some help if you can guys
- Which C4 Parts are Interchangeable?
- Diff ratio?
- How to replace back-up lamp in 89 coupe?
- Removing tranny TV cable question
- Cruise control issues
- J55 Front Brake Calipers?
- Transmission filter ino help
- thats what i get for doing it myself
- c3 guy needs help on fixin' c-4
- remove passenger lower dash on a 96
- replacing ECM in my 1989 corvette
- remove 1993 40th Bose radio
- Help Me Pick Heads..AFR? Edelbrock?
- update to ecm install
- c4 PANEL LIGHTS PROBLEM
- Replacing Ecm problem
- 93 Won't Start
- Headlight adjustment
- Need help finding the best 1992 Shocks
- Out of ideas - hesitation
- Droped Spindle??
- Intermittant miss at ALL rpms or temps
- Cleaning out the radiator
- Problems with my brakes.
- Changing 84 spindles to 85
- P/S Reservoir Replacement -- Experience with CC?
- What A/C pressures should be
- Idle will not come down when stopping
- 88 4+3 OD relay location
- Missing Antenna Parts???
- Fan question
- Stainless Steel Header Brand
- LT4 Hot Cam into my Gen I small block. Help!
- 1988 Electric Seat Repair
- Well.....
- l98 Ignition Timing?
- 84 tensioner pulley stuck
- Sensors Killin ECM??
- Squishy Clutch
- stupid question
- Z51 Has Offset Control Arm Bushings??
- Air Intake situation
- Auto wouldn`t shift up
- 1986 fsm??
- 1986 HVAC Heat/Cool fan Wont shut off
- Looking for "tee,htr wat bypass vlv"
- Dyna Spark or GM opti
- Why are rear gears so expensive?
- Fuel Pump voltage
- Tire balance road feel or wheel bearing and how to decide?
- What do you guy's think of these performance upgrades
- Cloyes...what setting to use?
- 1.6 Roller Rockers, worth it at this point?
- 91 Multifunction switch
- Refuge from C2 board re: LT1 dynamic balance w/C2-style flywheel
- side pipes
- Air foil
- ZZ4 who has one
- Sticky weatherstripping!!
- Help Identify Defective Seat Belt under GM Recall
- C5 Brake Upgrade.
- Couldn't find much info... Electric smog pump deletion?
- Derm
- Weird opti problem
- High idle lt-1
- 1986 Tach INOP Need Help?
- What is average trans temperature?
- Installed Magnaflow CatBack '94 LT1
- smoke through the tb
- is this a good 383 build?
- LT-1 Not a favorite for swaps?
- seat swap
- Oil Filter Torque?
- best way to refill cooling system
- 91 erratic tach
- I feel stupid.
- 128 port and polish. Is it worth it?
- convertor lockup???
- whistling vacuum noise
- LT1 Still Running Hot
- Confusion about Fuel Injectors and PCM
- 91 Gauge Cluster Rebuild Person Needed
- help 92 cdm remove
- If your dash flickers, read this
- Wheel/Tire?
- Clutch recomendations or tips
- Throttle hesitation on take off....
