- Is there any way to make my LCD numbers darker
- 700r4/4L60 Build Up w/2004r Ratio's
- ZR-1 Fuel Pump
- Broken water pump stud - 85 L98
- Paging Corkvette
- am/fm cd bose help
- Lt1 exhaust advice needed
- Hard start when warm
- Fiat Headlights
- RPM changes at higher speeds
- Heading to Pburgh Raceway Tommorrow!
- Water Pump Bad? '93 LT1
- Leaking brake booster...
- Cam is done......video inside
- Timing check on an 89
- Coolant Overfill?
- sensor on cylinder head
- Need electrical wiring!! Please!!
- Torque converter upgrade?
- Heater Core Restrictor with EWP??
- c6 calipers on a c4
- ABS question
- 91 shifts too soft
- No Cats, True Duals now what Muffler???
- 92 clutch master cyl. fill level ?
- Intake suggestion. Single or dual plane
- Nitrous kits
- Cam swap help
- Where did my MAF sensor go?
- intake on 86
- 58 Throttle Body Cable
- Which Distributor for 87
- 89 springs and sway bars.
- 1988 4+3 Stopped Shifting on Road
- Twin Turbos
- Service ABS and Service ASR
- 90-96 Gauge cluster repair - Tach reads high
- L98 T/B Coolant Bypass Hose Question
- Vbp is driven
- Autocross Numbers
- PLEASE HELP! 85 - new brake pads are "narrower" than what is on there now!?!
- Billet LT1/4 oil pump drives
- Cruise control accelerates
- seat bolster motor,HELP.
- Partial spark plug firing.
- Code 26
- Rear suspension swap?
- 84 fog lights
- Hesitation:
- Activating ABS Improved brakes
- C beam location
- L98 vacuum mod - cap the manifold, evap can. tube, add oil breather...
- anyone give me tips on replacing my own ball joints?+
- what direction do the pins face on the caliper
- Anyone switched from double grooved belt to single grooved belt like later c4's ?
- Ampimillizener resistohms?? How do I measure my ign. coil performance?
- knock sensor removal
- Code 42 poping and misfire
- Oil cooler question
- Harmonic Balancer R&R Question
- 500 hp Fuel pump
- transmission automatic - manual
- Engine installation question
- Harness Bar
- Headlight covers - removed headlights
- Brake lights draining battery voltage ????
- Dual Mass Flywheel Questions.
- cat air tube question
- Need Help Removing Brake Calipers
- Blown head gasket??
- Speed sensor auto 91
- Why wont my radiator cap come off?
- C68 HVAC system – Mix door problem - 94
- Rough idle. MAF?
- LT1 shuts off while running
- MSD box location
- Advise on buying a 88 c4 needs heater core
- 1989 corvette convert idle
- another cluster question
- High flow cats?
- Fuel sending unit problems?
- Runs Bad in Open Loop
- WTF GM Oil Pumps HP Vs HV
- What Size Slicks and Wheels to Buy?
- VATS No-Start on 1996?
- Car just died. '93 LT1
- VATS Bypass Module
- L98 Fuel Lines
- How many 02 sensors?
- Lowering front end advice
- Rear Wheel BEaring Failure - Not even 300 miles covered!
- 84 tail light panel - removal, upgrade?
- New headers on the market (L98 and LT1/4)?!?! JVT?!?!?!
- Fuel tank weight?
- LT1 Pistons and compression ratio question
- Valve Cover Gaskets...The good ones
- oil pressure sensor - leaking?
- Heater Core!! AWESOME.
- RHD Bleed order?
- hot cam into an lt4....
- DIST CAP Removal
- what is the difference?
- need shiftlight wire help
- 1988 A/C and Heater Digital Display
- dim headlight
- Where is the Tach Filter on '93 LT1
- headlight question?
- Need longtube headers?
- ABS/ASR Codes
- hood come unlatched from drivers side - but cable still good
- 1.6 rockers...simple bolt on?
- Cruise control and A/C problems
- What's causing a vibration in my 88?
- Changing antifreeze
- 1992 ZF6 manual to TH700 automatic swap?
- Is this ground by the horn used?
- what would a bad knock sensor do?
- where can i find a new gas tank??
- AFR for LT1 install things to remember.
- Front motor plate
- 4+3 overdrive filter cheap
- New eaton truetrac posi
- 84 700r4 trans cooler ????
- 85 Overheating Problems!!
- help 15x8 weld wheels What size tires on c4???
- LS1 Swap...a couple tranni questions
- S6-40 rear seal leak / vibration
- Master Cylinders...What's the differences?
- '92 Idle Problems
- Check out my interior , let me know what you think
- power brake booster
- Custom 10" Speakers and amp
- Installed
- 85 with horn problem
- 85 Cooling Fan Question
- carb size
- How to install airdam on 92' LT1
- Simple and CHEAP mod to lower '84 temps by 30+ degrees???
- stiffer suspension
- Excessive Cabin Heat
- What 4L60E's will fit in 94's
- Recent Opti and WP - questions
- '84 IAC valve - where's the best deal???
- '84 C4 stock - WHAT ROTORS???
- quesstion about trans and drive shaft
- 350 engine tweaking
- Pat Goss, corvette expert or A$$H---?
- '92 headlight sticks "up", a year after the bronze gear ugrade!
- will these headers work on my 85?
- New to Chevy stuff
- L98 1990 C4 Air Conditioning
- Fuel Pump Relay Wires
- Changing a fuel filter on 95 was a joke
- fog light ELECTRICAL PROBLEMS!!!
- Starter install for an 87?
- Opti or no Opti on 94
- Porting ASM Runners
- shock recomendations
- oil filter????
- Help me decide on Injector upgrade ! 24 or 36 lb ?
- How to install 84 power window ribbbons
- '84 - what spark plug?????
- 89 Corvette needs a new engine, options?
- 91 L98 woes
- Both rear roof screws stripped on coupe
- Crazy cutout/dying intermittent problem
- lt1 camaro intake vs lt1 corvette intake...
- newbie observations
- Digital Repair Manuals? Ever heard of them or used them?
- Change oil light came on...want it off...HOW?
- 84 Overdrive problem (4+3) temp related ?
- cooling system questions 1992 model
- need help with head specs
- wanting advice on lowering my 96
- Clunking noise when engine is shut off
- 85 A/C Delete
- 15 Inch Wheels
- LOUDER HORNS WANTED - options for a stock '84 C4???
- What would cause the 5A LCD fuse to keep blowing on '88?
- Rough Idle After Revved
- Tire Size question for 95
- Ultimate DIY cheap cat back to LT1/4
- N00b Targa Top Question
- Two Connectors, not sure off?
- PBM Performance?
- PKE Settings
- Distributor internals brittle
- Adjustable Torque Arm?
- wierd brake problem
- Big cam users..question on reversion
- 93 backfired into crankcase?
- 1984 fuel problem
- LS1 or tunable PCM for gen 1?
- Bypass ESC on 1987 MAF L98
- 84 Crossfire idle too high !
- '86 possible vats issue??
- Digital Dash 1986
- '84 C4 stock - what are the HAWK HPS brake pads????????????
- 1991 PROM question
- Air Pump Pulley Question!
- Best paint ?
- Shorter crank hub....
- My new chambered exhaust video - finally
- 89 stumbling when cruising
- LCD dash display issues (1990)
- no speedometer or rpm gauge
- Gordon Killbrew and his advice
- spherical bearings in the stock c4 trail arms?
- Engine ID ??
- Timing check?
- Traction control??
- 92 Rear Bumper Cover on my 84
- 95, LT1, A4 intermittent starting problem
- $600.00 paint job!!
- Daily Driver Vibration will not go away
- lacs performance
- Chevy Corvette Race Car For Sale
- Need Help with LTCC conversion on '94 Corvette
- clutch talk
- SES light blinking steadily
- Front Speaker Cover removal on 92 vette
- Dana 36 upgrades.
- misses when accelerating - datamaster help
- car not going into gear easy sometimes
- LT1 T/B coolant bypass parts?
- Almost died today!
- The Garage Queens 1st trip to a 1/4 mile Track
- anyone elts having hand brake problems?!?
- asr and abs lights
- Exhaust Raddle
- Couple of questions
- cruise control guru question
- Carb Swappers Step In
- Sidepipes
- Camera
- Lost clutch pedal
- Removed water pump drive gear.....
- Fuel pressure
- Does anyone have these differential cover measurements?
- Climate Control - Auto
- Starting Problem. HELPPPPPPP
- MSD Coil Question?
- Wheels?
- RATS! Blew my upper rad hose! Need P/N's &/or a full hose kit. Ideas?
- Clutch Fluid Disappears!!!
- USM HSR finally here
- Hey all...couple questions.
- car died at home depot, wont start, help????????
- Oil Cooler
- LT1 oil filter
