- mid stage engine
- Best way to do tranny fluid exchange at home?
- 1985 Rt headlamp motor
- Single plane and AFR 195 comp installed
- 87/89 alt wiring swap help
- Best trans and rear oil 90 6-spd
- where to buy sport seat support straps
- 1987, Adj. fuel press, IAC, TBS
- 87 Auto Vette/ 92 Dana 44
- Help with 89 Climate Control
- what are some performance for c4
- EGR Elimination
- How to pull the tranny?
- Surging
- Who's installed their DRM Camber and Trailing Arm brackets
- edelbrock runner bolts
- Balancing a rotating assembly question
- 94 LT1 Opti-spark
- 315/ 35 /17 or 285 /40/17
- 700r4/4l60 full manual valve body
- Cant figure out where this connector goes on my 90
- 4+3 shifter issues
- Starters
- Lazy Tach?
- Who sells C4 fender/hood flares?
- Starter clicks but doesnt turn over
- Can anybody recommend a 383 stroker kit?
- Tune Up Questions
- Tail lamp Fuse
- LT1 & Fuel Pressure
- C4 Accelerator Pedal Question
- Who has the quickest stock bottom end and stock heads LT4 powered C4?
- Block Hugger heaedrs for l98
- Any interest in real RACE headers for a C4
- LS1 with Digital Dash
- Hypertech 4050 in your '84??????
- Winter Projects for 09-10 Season
- where to find a 90 blend door actuator motor?
- 1992 LT1 Vacuum Leak?
- The Build Up Resumes PLRX LT4
- Comment on Royal Purple Oil
- L98 Coil Module testing ?
- Wiring A Heated 02 Sensor - Question
- intake manifold gasket replacement question
- radio does not stop with door open
- Factory DM Flywheel question
- 96--No Fan Kits
- 1986 corvette problem
- Brakes going weak
- Question about cluster pinout
- Another thumbs up for Bosh 3 injectors
- How well do polyurethane suspension bushings work for the street?
- Power windows - HELP!!! - Convertible 1994
- Air pump delete on an 84 ?
- Help with A/C system
- Absolute "best in the world" spark plug wires???
- O2 Sensor failure/Running Rich
- Satisfied Pro Brake pads. Discuss.
- Shortie headers
- 89 Hood Release Issue
- degree my head bolts ?????
- 1995 speedometer not working
- Corvette Lt1 the same as Fbody lt1?
- Winter project
- Speed
- 87 Without B4P Option Fan Control
- electrical gremlin woes (and ac/heat)
- which is a better stiffener?
- PLEASE HELP!!!! '84 IAC - 3 types - can't find one anywhere???
- Flywheel Bolts
- reinstalling heads
- Vehicle Speed Sensor
- 87 L98 Firing Order - Wire Routing
- Carb Swap Cooling fan question
- Need some auto trans/drivetrain help!
- Please school me in the latest in Spark Plug wires
- C4 LS swap a different perspective
- EGR Tube Question
- 1986 700r4 issue?
- What Tires Should I buy?
- Mid America C4 Brake Duct
- heads on an 86
- Exhaust removal tips
- 88 aux fan removal proceedures
- Internal motor problem? need help bad!
- Headlight Problems
- A/C Problem
- Quick question about removing the A.I.R. system
- What is the normal lifespan of an IAC?
- 94 LT1 just up and dying randomly...
- Heater Core
- cig lighter fuse blown/cant find it
- Where is the low pressure cutoff switch
- 85 fuel pressure problems HELP!
- Ls1
- Fog lights?
- DeWitts CF group purchase
- Magnaflow exhaust systems...
- Stumped by a jumper wire, feeling dumb!
- Power Chip Question
- Did 95's come with D36 and D44 rear ends
- Beware of finger polish
- $ Head Gasket Kit $
- Maf
- Best Tire Pressure
- ALDL Software
- Jet Performance Tuner for 96 lt4
- 96 lt4, codes P0335 and P0336
- 1993 Corvette - Service LTPWS
- Dyno after mods. Good news I guess
- Made it into Corvette Enthusiast- Dec 09
- transmission switch identification
- CCM Years for a 1991
- Suspension width: early vs. late? & Wheel clearance questions
- 1991 Fuel Pressure
- rebuilt fx3 actuator problem with retainer clip engaged
- Chronic valve cover leaks
- Lowering my 91 vert
- Headlight motor frustration...I've tried everything: bushings, gears, motor, etc.
- Cam / LT1 how big ?
- Coolant leak
- How do I restore my stock C4 rims?
- Internal intake/coolant leak?
- IAT Sensor replacement
- Installing a manual fan switch anyting I need to know
- Tech article- How to correctly install C4 roofs
- Power Antenna Rebuild
- questions for those who have lowered their cars with the spring wedges?
- what wheels will fit an 84
- how do you get the governor cover back on?
- Nothing works in my dash ?
- Callaway
- injectors
- Broken Window Stop Guide. Again!
- 90 climate control issues ????
- wheels
- sleeving the crank at timing chain cover
- Remove and block plate EGR, will it throw a code?
- 85 vette, superram, 219 cam, vortec intake, which vortec heads?
- What is involved in changing to a roller cam?
- C5 A/C problem /Power window issue
- Engine hoist question
- C5 Guy with Question about C4 Gas tank and water problems
- why would a airbag car die when you pull the airbag fuse???
- How to stop the leak!
- Tranny trouble 4+3 experts?
- So my Dana36 grennaded...not even racing!
- 1993 Alignment
- Patch or plug tires?
- front end alignment question
- 91 vette/ TPS voltage
- Need Cheap Rocker Covers for '93 LT1
- Find used D44 ??
- '92 LT1 - IAC problem
- Carbotech Now Offers Brakes Pre-Bedded!
- Magnaflow install problem
- shifter cable question
- 88 with no horn
- AC fuse blows - 91 L98 manual air
- loose tilt wheel
- Teach me how to port a plenum
- 92 Instument Panel / CCM question
- Will C6 Z06 2009 Q44 Spyder rims fit on 96 C4?
- AC Schrader Valve and Ball Valve Repair
- 91 cluster interchange
- Tire/Wheel compatibility?
- Brakes!
- 85 speedo and tack LCD
- l98 timing cover oil seal
- Anyone using a Detroit Locker Truetrac Diff?
- Fuel Problems
- 4+3 to ZF6. What parts do I need?
- 86 centerbolt heads
- 1986 corvette performance!!!
- stock '88 TPI air filter box? Or go to K&N?
- pulley
- 1992 Hesitates Violently on Acceleration
- radiator fan question
- Headers for 96 LT1
- INVISICORD for C-4's ESCORT RADAR DETECTOR
- Hypertech Programmer
- Need wiring Diagram
- Shake & vibrate
- Winter project - rear trans seal
- Stock crank question
- What size is Oil Pressure Sensor on 89?
- 383 advice
- '84 Vette, blown engine, what next?
- 95 lt1 water temp sensor
- is 45* total spark advance too much?
- Speedo off
- Glue for Plastics
- 1984 ???? Problems
- Header Install/Prep Work (L98)
- Need help!
- c3 guy with c4 question
- Another Crate Engine Thread
- Exhaust help/opinions needed
- ATTENTION: $40 mod to lower temps 30F in an '84!!!!!!!
- Loose steering wheel
- Begginning Fastguy Method - Heater Core
- Creak, groan.
- 4+3 Coolant Line Replacement
- 85 with 87 heads...the saga continues
- 1989 corvette wiring diagram
- fuel line pulsator
- What Engine to Build?
- Is there any way to make my LCD numbers darker
- 700r4/4L60 Build Up w/2004r Ratio's
- ZR-1 Fuel Pump
- Broken water pump stud - 85 L98
- Paging Corkvette
- am/fm cd bose help
- Lt1 exhaust advice needed
- Hard start when warm
- Fiat Headlights
- RPM changes at higher speeds
- Heading to Pburgh Raceway Tommorrow!
- Water Pump Bad? '93 LT1
- Leaking brake booster...
- Cam is done......video inside
- Timing check on an 89
- Coolant Overfill?
- sensor on cylinder head
- Need electrical wiring!! Please!!
- Torque converter upgrade?
- Heater Core Restrictor with EWP??
- c6 calipers on a c4
- ABS question
- 91 shifts too soft
- No Cats, True Duals now what Muffler???
- 92 clutch master cyl. fill level ?
- Intake suggestion. Single or dual plane
- Nitrous kits
- Cam swap help
- Where did my MAF sensor go?
- intake on 86
- 58 Throttle Body Cable
- Which Distributor for 87
- 89 springs and sway bars.
- 1988 4+3 Stopped Shifting on Road
- Twin Turbos
- Service ABS and Service ASR
- 90-96 Gauge cluster repair - Tach reads high
- L98 T/B Coolant Bypass Hose Question
- Vbp is driven
- Autocross Numbers
- PLEASE HELP! 85 - new brake pads are "narrower" than what is on there now!?!
- Billet LT1/4 oil pump drives
- Cruise control accelerates
