- Wiring Harness mods for swap to Carb
- Questions about this damage....
- Akebono Ceramic Brake Pads
- Booster or master cyl
- `87 turn signal flasher location
- 86 Distributor Bar Code?
- Repairing Bose CD
- Black soot
- Loud intake air sound
- LT1 water pump,BCOOL radiator,MSD opti
- 86 auto trans problem. no second
- interior lights and convertible switch out
- Power antenna question
- Urethan bushing install
- 2 pc rear seal?
- Engine mods
- 95 Vette
- Changing '85 throtle body, should I upgrade to '91?
- 1986 no spark
- 1984 Clock in Radio won't turn off
- 1994 vette prob HELP!!!!
- TPIS headers, and TPIS front Y-pipe.
- Service Engine
- better cam than 306? Heads?
- dead battery
- Camaro flywheel
- California smog & TPIS long tubes
- Loose Steering Column
- Anyone gone back to stock oil pan after Canton 7qt?
- Th 700 rebuld suggestions
- Blower motor issue.
- Security Light Won't Shut Off
- Power Steering Leak
- Need rebuild kit for left headlight on 84 Vette
- 92 LT1 A4 Electric Fan Question
- Voltage regulator on 87
- 95 weather stripping question
- WTB Clutch
- Header Help Please
- Happy holidays from vbp
- LT4 HOT CAM vs CA Smog, the results are in
- 1994 corvette tunercat bin file
- Somebody Help Me Out With a Tire Chioice!!!
- Any good Corvette Painters on Long Island?
- New here, need advice please
- 1993 C4 Rear End Question
- L98 Exhaust - Whats worth doing for stock motor?
- 92 LT-1 wont crank over?
- Yet another digi dash problem (88)
- Radio Knowledge ?
- electrical help needed: what circuits are on the LH courtesy and RH courtesy fuses?
- Noisy valve train at startup
- Cruise servo question
- Willcox Christmas Sale
- DM Flywheel Rebuilds
- Sick 84 in need of help..
- 1989 cooling fan
- 1989 cooling fan
- Don't know what fuel injectors to buy - need help
- Does the G-tech work?
- Shaving door handles on an 84
- Putting new heads on, need help with gasket choices
- Hard Starting Problem possibly Solved - FPR
- AFR 195 spark plugs
- Having that issue of hard starting/ thoughts please!
- Trans Speed Sensor leak
- 94 won't start
- C4 Rotate engine to TDC
- 4+3 Question
- Not a lot of choice for LongTubes?
- Help needed diagnosing/repairing cruise control
- ASR Vacuum
- Car starts fine but won't restart
- New GP on long tubes started
- Headers for an 84??
- Where to buy LT1 TB Gaskets?
- Winter projects - all at once or piece by piece?
- Idle Issue
- CCM Woes
- Removal of Dana 44 Differential
- Odd Acceleration Problem / High Idle
- Code 15 Problem!
- Converting a 92 to new ac system
- Z-52 suspension??
- How often do you recommend to replace the differential fluid?
- Cold Start Valve
- Front hub vs. Rear hub ?
- Horn GOT STUCK NOW I HAVE NO PWR LOCKS AND RADIO DOESNT WORK ?
- Flywheel bolts
- TPI aftermarket runners
- 90 Convertible-Window Adj, Air Leaks
- Previous Pop Hot Rodding article
- water pump swap
- How hard to add LTPWS to my 90
- What exhaust options have LT1 tips?
- 84 and Cross fire guys, need help please
- turn signal on steady w/ lights on
- Burn off relay..?
- Omnivecs Ls1 Build thread
- Loudest Exhaust For an LT1
- heat/air only coming out when off??
- Go back to GM Opti after Dynaspark?
- Looking for a part number
- Getting ready to pull the trigger again...
- 86 Vette - Top End Noise - Need Help
- Corvettemechanic.com
- Need opinions on cylinder heads
- putting in 4+3 transmission need info
- How to Replace Oil Pressure Sender on 95LT1
- program cooling fans
- rebuild kit for 88 Master Cylinder
- How hard is it to change the starter
- Need Link to Disconnect Service Engine Light !
- Prepping for new paint job: Removing old clear and filling chips
- Brake question and smoke trouble shooting.
- Reverse Rotation of PS Pump
- dropped off my AFR 195's and spare intake
- Really strange things happenz...on my 1990
- 86 vette - cast iron or aluminum heads?
- EGR valve, Where?
- 9th injector replacement
- help with 4+3 od UNIT LEAK
- Where can I get Capistro exhausts?
- CFI to HSR
- 86 Vette not starting problem - need help
- Ran my best time in the 1/8 friday night
- 88 C4 Corvette transmission Fluid
- How to remove IAC while still on TB
- LT-1 intakes
- Dana-36 years
- AFR vs LT4 heads
- Muffler elims vs flowmaster mufflers
- Where to locate trans cooler on 89
- what sensor turns cooling fan on, on a 1990
- baseline 1/8 mile times with 2.59 gears in 92
- Winter question, Should I idle my Vette?
- 84 crossfire 4+3 cruise control vaccum routing?
- Code 34 fixed with new battery.
- Coolant Change Questions
- Can't open rear hatch!
- C4 Fog/Driving Light Upgrade
- Passive Keyless Entry Light does not turn off (ever)
- unnecessary anything
- Steam coming in through all interior vents - advice please
- Spent half the day tryng to pull the engine, and it still isnt out.
- anyone heard of a rear bump stop modification that can protect C4's IRS in launches?
- radiator fan relay connector
- Heated O2 Sensor
- Power loss at 2000rpm
- LT1 exhaust system is unnecessarily heavy...wht gives
- have any experience with wideband O2 sensors and C4's? If so, step inside/
- cold engine whine
- Loud lifter
- bad optispark
- New Personal Best 1/4 Times 92 A4 LT1
- HELP: LTPWS Module Location!
- Tough Nut to Crack: C68 Climate Contol
- Change oil light
- I figured out why so many use the LT4 hotcam
- If you smell coolant in the exhaust question??
- Transplanting Z51 steering into a 94
- Project Questions
- i"m new to corvette form
- how long will this take
- *** Error Codes 43 & 54 *** How do it get rid of them ??
- 86 Corvette MPG troubleshooting
- 8'' bolt for rear spring
- Will seat belts from an 86 fit on a 91?
- Finally happened to me - hood not opening....
- Need advise on ZF6 fluid change.
- 1995 lt1 heater stays on
- 500hp na?
- Does this 'turbo' device help in performance?
- Opti Spark ignition experts - am I fixed???
- Rear tire rotation
- engine trouble and QUESTION !!!!
- has anyone installed a Firstfuel inj. system ?
- Header Advice
- For fans of unconventional tire sizes...
- Oil Catch Can for LT engines
- Code 32 problem / question
- 88 Not starting - VATS?
- Not going into gear?
- Need help, valve cover removal and valve alignment
- Help with code 32 and fans come on
- Brake,ASR service, ABS service light on
- Opti Spark assembly question
- Corvertible X-Brace
- what should resistance be across + and - bat cable (w/o bat obviously)
- 1985 heater core R&R ????
- Crossfire Baseline Dyno [vid]
- Want some new rims for my 90
- Changing rear gears .What to channge on Trans?
- L98-no juice to fuel pump fuse
- HD or standard suspension which do I have?
- How to tell if you need new injectors?
- grounds 85 vette
- WTB: delteq parts
- How Do You Diagnose a Halfshaft U-Joint Going Bad?
- Ca smog for c4's, what's different?
- How much can be milled off the deck?
- Oil leak
- Is a High Volume oil pump worth it?
- Long tube header fit and performance
- 1988 L98 Injectors Leaking/ Replacements?
- 23.6mm bushing for 24mm sway bar?
- 86 roadster speaker grille ?
- turn signals slow blinking
- Relay ?'s
- 1988 4+3 OD leaking
- Engine Dyno Simulator for PC?
- 1994 lifter replacement
- 1994 vibration sounds cont
- Autocross
- '94 brake lights will not turn off
- edcmat-l1 tuning in Pittsburgh.
- Cam choice for fastburn heads
- Finally running fine
- Parking Brake 96 LT1
- If it ain't one thing...
- Were Stock 85 injectors the good ones?
- Help with clutch noise...please?
- PeteK: What is the end result of a TV cable adjustment..
- code 1351/1361 96 lt1 auto delteq
- 91 l98 fuel injectors plese help
- Do the screen protectors for the radiator work?
- Can anyone identify this...
- Catalytic Converter Questions for 87 vert
- LT1 from Roadmaster
- lq9 into a c4??
- Weird hesitation Problem
- Visible difference between D44/D36 batwing?
- Secondary Cooling Fan
- Brake master cylinder for 84
- C4 radio replacement
- Port Map/pattern
- C4 Tilt column question??
- Lazy Idle (1985)
- Service Engine Soon question
- LT1 Hits when revved high in park...
- Steering Wheel Click
- electronic module
- TPI to carb setup
- 89 C4; rough idle then dies......
- brake caliper bolt stuck/head sheared off
- Setting idle w/ cam and TB?
- Coil WHAT DO YOU SAY..
- Need a new battery for the 96. What should I get?
- Gears?
