- My LT4.........fluke?
- Well Bad News for the motor
- Squirm in rear end when accel or dec
- Question about a '91
- Looking for a 95-96 Lt1 engine
- TPIS or Edelbrock intake, which is better???
- More Power
- LT4 Hot Cam
- Now Tach is totally dead?
- New aftermarket block for SBC
- ANGRY!!! Broken Weld on Nut inside Frame, Rivet Nut a Solution?
- Tachometer reading way low 0-700 rpm???
- Dana 44 Options
- L98 Early Valve Covers
- 87 climate control
- Those of you with PCVs and Breathers: Step Inside
- Pulled the heads today and......
- 1994 wheel bearings
- Clutch fluid leak.. on passenger side?
- How long is the stock TPI throttle cable?
- Afr heads
- Cleaning Throttle Body - etc.
- How good are Nitto drag radials on the strip??
- **** 8th Annual Corvetteforum St Jude Fundraiser****
- Left Half Shaft U-Joint Problem
- Granatelli MAF - Anybody have experience with this ?
- LT1 Help
- I know you need to see this but - Damper bolt threads damaged
- I need one solid lifter.....ASAP!
- Somebody please tell me something
- Someone please help me
- I traded my vette for a chevy aveo....
- Help please, 1992 Corvette Wont shift unless gas pedal is released
- AFR 195 heads
- Window stuck full down: '88 Vert
- 1987's LED dash cluster dead; smoke can’t be a good sign!!!
- 85-87 front sway bar on a 84?
- Replacing the opti.
- oil temp sensor
- 700R4 trans problem
- Window/Door Water Leak
- 86 Master cylinder reservoir replacement
- Proof that fram filters SUCK!
- How do I upload Pictures ?
- Need input on rotating assembly
- Vortex Rammer Cold Air Induction: Do they work ?
- Anybody who has rebuild a LT1 - Please take a look at this picture
- SLP 3 cone filter cold-air induction, how does it work ?
- 88 coolant temperature low
- Noise from brake system when car is stopped
- Headlight motors not stopping.
- Check engine light briefly this AM
- Bose Radio Question
- code 34 forever
- 3.54's or 3.45's?
- Best electric Cutouts that wont leak over time
- 93 vette spkr ?
- 1987 interior lights
- Play in ZF6 yoke and a driveshaft question
- Cold-Air Induction Systems: Which is the Best?
- steering column swap
- 89 ran hot 90 runs cooler
- Bose receiver amp get-to? '90 convertible
- Where to find
- Header bolt length for Aluminum L98 Heads?
- Rusting hatch strut bracket
- Engine Scan
- Gas question:
- What intake for high end 383?
- Engine Temp Sensor
- Knock module
- 9th injector or cold start injector for a 87.
- code 42: fixed
- can the center cat on the L98 serve the some function as an X or H pipe?
- Help-no start/radio/speedo dead!
- Who makes the best cams?
- 87 Valve Covers
- Ran out of gas tonight range said 20mi
- Power Steering Pump Install
- $75 Opti Spark? Who makes 'em? Any Good?
- Cruise control
- Break reservoir change
- abs ars computer
- Power Seat problem 93 - C4
- Gas only good for 2 weeks now???
- One thousand not so troublefree miles
- C4 Lt1 longtube headers
- What is too much torque?
- Astro top re glued tonight
- 4+3 4 speed overdrive???
- Tips for separating Old Exhaust components
- Seafoam, safe?
- Connector for VSS into ZF-6spd
- swepping from L98 to LT1 intake!
- msd opti has oil in the optical area,how much play is this bearing supposed to have.
- Engine noise
- Help With Suspension Codes Please!
- chip burner? for 1986 corvette
- Converting from Manual to Power Seats
- Found unconnected power behind dash, early 86 coupe
- 383 engine kit help
- Smog pump eliminator for '87 corvette
- Where is my fuel filter (1995)
- Couple of questions while I tear down the motor
- Stupid question about a belt
- Need your help
- door panel removal 95 coupe
- Fel-Pro part number???
- C5 rims on a C4
- Need help - Halfshaft u joints frozen to wheel side yokes
- Help Help !!
- Pull a Part Delco Radio Advice
- McLeod Street Twin clutch question
- Need info on felpro ms98000t gasket set
- Wanted: Dana 44 rear suspension for sale
- shield
- 1987 electrical
- Trouble shooting web site
- Corvette Part Numbers
- Burnout contest
- How Do I remove the battery ?
- 86 Vette Air Damn Question
- Battery died. Jumped car and let it...
- 1991 Intermittant starting issue
- My plans for exhaust- need opinions
- BLACK FRIDAY SALE on Raptor Shift Lights @ KY SPEED
- Need help fixing SMC
- 94 air bag light
- GEARS -how much in the quater ?
- Battery Draining please help!
- Canton Oil Pan Install
- Fob Testing
- 84 CRUISE CONTROL ISSUE - Xcelerates bye itself
- Starting Problem on '90 L98
- Happy Thanksgiving
- 90mm MAF
- Computers/ LT1 vs LT4
- Optispark (what to look for when rebuilding)
- Darkside Completed Pics
- cam
- Motor Mounts
- PBM Cylinder Heads ?
- FIC is Thankful for.....
- Tapping sound in the valve train
- EGR fitting thread size
- new c4 owner temperature question??
- 2 diff headlight problems & Astro top Issue
- new 3.73s now i have a backfire
- Modified TPI, Stall Converter ?
- 94 LT1 running around 230*
- Blew up a DMF, what to do next?
- >>> Corvettes of Westchester - is not just C5 & C6s <<<
- lt headers
- Yesterday I washed my engine this morning it was foggy and
- BPP Black Friday Sale
- 93 drivers side window
- Major brake issues on 98
- Trans Question
- Steep Hill Turning a Corner Flex in Vert
- cold start alternitive
- a way to check gears?
- Confused , need help on ZZ4 intake
- Melrose Headers
- lowered car, not level now How would you even this out?
- Bad Motor Mount Symptoms
- Coolant problem
- Theft relay & Pwr lock fuse
- 383 engine HELP from Austria Tuff Dawg Engines
- I've had a major engine problem for 2 years and didn't know it!
- Fikse USA Out of Business
- Will 94 door panels fit on a 92 Corvette???
- Oil Leak & Stumbling Problem
- talk me out of putting 3:75's in my L98....
- What is height drop of B&M Ripper Shifter vs. Stock?
- GDO No longer works when car is running
- l98 fuel inectors lbs
- fuel injectors help please
- New intake manifold for GM Fastburn heads
- Tire Rotation
- Comp Cam rockers replace the supplied nuts?
- Felpro 1010 head gasket
- sportsman 2 heads
- front accessory brackets
- P0420 Low Efficiency Bank 1
- Purging air from Coolant/radiator
- 4 link coversion?
- Headlights clicking when opening or closing
- Both Headlights clicking
- Loose steering wheel ---> busted horn switch, sucks
- 96 Corvette Muffler Eliminator or Magnaflow?
- Idiot wants more HP from L98
- Injector replacement: My notes and experiences
- Wheeler dealers C4
- Kinda stupid question...
- Weatherstripping Help needed in WI
- 95 LT1 oil leak
- Hard pedal/Very little brakes!
- 1985 EGR replacement procedure advice needed
- 1994 c4 hesitstion problem
- Spring Rate Questions
- Digital Dash Malfunction 87 c4
- 1992 replace the cd player and the ignition key its lock, it doesnt start
- Short shifter for LT4
- 85 TPI starts Idles then dies
- IAC and idle problem
- no ohm value on key?!
- Ok ZF6 experts - name that leak
- New Fuel lines
- 1991 no crank, no start.
- Sterring Issue
- Fan stopped working
- SB 400 4 bolt main...Would you do it?
- Wiring Harness mods for swap to Carb
- Questions about this damage....
- Akebono Ceramic Brake Pads
- Booster or master cyl
- `87 turn signal flasher location
- 86 Distributor Bar Code?
- Repairing Bose CD
- Black soot
- Loud intake air sound
- LT1 water pump,BCOOL radiator,MSD opti
- 86 auto trans problem. no second
- interior lights and convertible switch out
- Power antenna question
- Urethan bushing install
- 2 pc rear seal?
- Engine mods
- 95 Vette
- Changing '85 throtle body, should I upgrade to '91?
- 1986 no spark
- 1984 Clock in Radio won't turn off
- 1994 vette prob HELP!!!!
- TPIS headers, and TPIS front Y-pipe.
- Service Engine
- better cam than 306? Heads?
- dead battery
- Camaro flywheel
- California smog & TPIS long tubes
- Loose Steering Column
- Anyone gone back to stock oil pan after Canton 7qt?
- Th 700 rebuld suggestions
- Blower motor issue.
- Security Light Won't Shut Off
- Power Steering Leak
- Need rebuild kit for left headlight on 84 Vette
- 92 LT1 A4 Electric Fan Question
- Voltage regulator on 87
- 95 weather stripping question
- WTB Clutch
