- Rear abs brake sensor?
- Runner Dings
- wheel hub assembly question?
- Suspension Overhaul
- 84 Instrument Cluster repaired!
- Fuel Rail / Oring / Crosstube questions
- 94 Fuel filter location
- Help, please -fuel filter
- Install alarm in my corvette???
- Water Pump?? 89 convert
- 1990 dash cluster
- Optima Battery
- 85 Dash Cluster Microprocessor
- No luck on the C4 general discussion forum
- No tail lights or dash lights ?
- Frizbee checked on beam scale
- Thinking of freshing up the 92 LT1, what do you think of this build?
- Need new rotors and pads
- 1994 lt-1 warm start??
- Question on Rear Axle
- Opti spark removal problems, help!!
- Engine will not fire
- When to replace the optispark???
- computers talk
- Falken Visa Tire Help
- Powersticks or Cobrapacks?
- OIl/Coolant Mixing
- Targa Repair Idea
- DRM Brake Bias Spring.....
- Vacuum pump for brakes with low vacuum from engine.
- VBP 32mm Sway Bar bend question
- emergency brake cables
- 1987 Corvette 700R4 Reverse Input Drum Question
- advantages of monoblade 58mm throttle body??
- 86 Instrument Cluster Lights (Bulbs?)
- 86 Headlight Problems
- whats involved to swap a lighter, t56 in place of the ZF?
- how off will I be if I need a 42 tooth but used a 39 tooth on my vss
- will rotating the vss 180 cause premature failure?
- anyone running 1 7/8" primary headers?
- 94 Roadmaster into a 92 C4...?
- this is what i got from my mods(video)
- How the hell do I turn off my change oil light?
- how important is the size of the transmission cooling lines
- ZF rear seal and bushing
- what type speed sensor should go in my 700r4
- Engines dies, full throttle restarts
- 195 heads
- another intake question but somewhat different.
- New guy with a question
- Another 4+3 question (mainly)
- Another question, a comment and a little brag
- Started repairs on my right rear quarter panel today
- Need help 1993 theft deterrent system -
- Spacer ?
- climate control issues
- 93 LT1 popping through intake.should i buy?
- Value of a 3.73 D36?
- no power under load??
- Rear wheel bearings
- dual mass flywheel
- Another Super Ram Install Question
- Help with antenna
- Digital Dash problem
- Super Ram installation and Runner question
- where can I find Superram runners.
- Latest on the C-4 rebuild - Engine is in and suspension is out
- want spare tire for 96
- anyone have regrets going with 3" dual exhaust?
- smog pump help
- 1988 EGR Temp sensor
- Sanity check?
- 1990 sputters after a week long of rain
- Temp Gauge sensor
- Replaced Trans now an Oil Leak
- Going 4l80e
- Alignment Guru's please check in!
- H.P. Capability of stock LT1 Intake
- MAF, how do you know if it's bad?
- striping question for custom painting experts?
- LT4 knock module install in a 92 LT1?????
- 84 Corvette AC Condenser/ cover / Sealant???
- Oil leak
- Failed NJ emissions high hc
- Need help with U Joint ::Urgent::
- Battery passive load switch?
- What plugs to use with AFR 195 1031's
- LT1 questions
- C4 a4 to m6 swap ?
- One to Four..shifting..
- check this out give me your imput.
- Clutch grabs 1-2 inches off floorboard :/
- Does a "complete hardware kit" exist?
- SCAT rotating assembly.
- Idle issue solved
- Tricks/Tips/Time to remove exhaust manifolds
- How to remove a power antenna 86 vette
- Plug Wires, How do I know if I need to change?
- Engine stalls then catches up 1987
- convertible clear protective tape
- X Pipe from Summit Racing
- c4 corvette seat covers Leatherlike or Leather
- restoring wheels
- 1994 oil leak front of vehicle
- 1994 automatic vibration noise
- Aftermarket front speaker pods?
- help picking cam
- transgo shift kit
- Small trans leak:
- Clutch Question
- Smoking Brakes
- Need Help Please 1994 C4 Idle Issue
- Hard start when warm/Idles high
- $1000 to spend, fix 4+3 or upgrade?
- Oxygen sensors....
- Spark Plug Wires: Colors
- New Converter. I cant wait.
- How to remove a dash air vent ???
- Lightening Hood, Taking the Plunge...
- Spark Plugs: Looking to Upgrade for More Performance
- High Performance Catalytic Converters?
- 1989 350 4 bolt or 2 bolt
- gear oil and additive???
- chip flashing?!?!
- service abs and asr light came on????
- Quick question about IRS....no not taxes!
- 4+3 OD has a mind of its own
- 1986 wiper motor gear stripped
- FX3 Shocks, Retainers and Bushing Question
- Give me a cam
- tpis adj fuel press regulator for an 85
- change over
- Idle Air Control question
- whats the best size injectors to run with my setup?
- 400 small block damper
- need to get a new key need help
- U joint replacement
- LT1 Timing Chain Slop
- Sys flashing..new question.
- Ruk Industries headers?
- Need help with the other car
- She's Alive !!!!!!!!
- Using synthetic Dextron 3 in your T56?
- common bushings failure
- Balanced or no?
- Speedo gear ?
- 1984 Horns won't work
- Rear end ?
- any way to tune ECU for no-lift-to-shift?
- Cant see!
- Coolant temp sensor and Cambar Brace ?
- rebuild kit for the L98
- Need help with my '86 Headlight removal!! I Tried to follow the links above!!
- Should i FIX/BYPASS/GET A NEW Tach Filter ? (Pics)
- Wheels
- 4+3 throw out bearing
- Need pinion and diff seal numbers........
- C4 Steering Columns 90 - 96
- Gray seats in 89 the same shade as 92?
- help for hub removal 94 vette
- is this a dana 36 or a dana 44 rear
- Can I put 285/40/17 tires at all four corners of an 88 Vette?
- Timing Tab Missing
- Help Breathless performance AIR Delete + AC Delete Pulley delete pics needed !!!
- A?c problem
- coolant hose bypass
- New Engine
- Black Box
- Motor Build
- Auto meter elec fuel pressure gauge/LT-4
- Picture request - Polo Green C4 with Black Z06 wheels
- Looking for input
- Has the engine dropped?
- REALLY dumb question. Batt. disconnect.
- F-45 shock & articulators
- Strange noise
- Whats the right size TB to run with my setup?
- C Beam Removal
- Exhaust paint
- 1990 Starter
- Anyone on here do porting themselves?
- Progress on C-4 rebuild - engine going in, and fog light rebuild begins
- Put yourself in my shoes ... had any luck with header paint?
- TPI base fit problem
- Stuck in Open Loop
- Clutch master and slave replacement
- brake line to rear of intake plenumn
- pros & cons of running no thermostat
- IAT sensor location "91" 5.7L vette
- Duplicating the Seldgehammer Callaway Corvette.
- 2.02/1.60 valves in #113 heads
- Results of best dyno pull
- 1989 Transmission slipping?
- No start 93
- Battery
- Fuel Pump Question
- LT1 rocker stud size?
- [Pic] '88 eClimate Control panel hot spot
- Buying HSR! Can anyone help me make it fit?
- fuel pump relay
- w/wiper blues? Any sugestions? 89 vert
- Which aftermarket parts are crap?
- SoCal Axle Shop-Guide me----~~~~
- Re: C beam question
- Climate Control
- Oil in the Intake Plenum
- Motor Mount Problems, need help
- 93 No Start
- Another 383 build question
- Will 87 wheels fit my 92?
- VB&P sway bars
- C5 Z06 Rims on '91 question
- Head Gasket :(
- Poly Urethane bushings, not all are equally made.
- Lockup Torque Converter Problems
- Clutch Change 96 LT-4
- Shifter buzzes
- Miss Dead?
- shift kit?
- how does one 'test' a dual mass flywheel
- Cold start problem
- Anyone here go back to a carb?
- Edlebrock LT1 intake
- weather striping for 87
- Oil Temp.
- question about 4+3
- LT1 open spring pressure?
- Re: Brake Problem 1987 C4
- New HiFlow Cats & Pacesetter ceramic short tube for my 93 LT1 6speed?
- replacing odometer in 87 vert
- Damaged FlexPlate
- Electric water pump/timming gears?
- What are Gas Ported Pistons? How do They Compare to 4032?
- 383 harmonic balancer?
- How Many here have AFR heads
- AFR/113 pics
- Need help with headlight on my '86!!
- Pics of AFR 195 Eliminator LT1 heads
- 700R4 replacemen; maybe
- 89 Vette No Injector Pulse
- My block rusted, what's this going to cost me?
- EGR on LT1 Intake
- Need Tuneup...Where to start????
- Soft Pedal on my '86.....need help please!!
- Can it still be a Fuse? 92 LT1
- Is this an LT4 Hotcam?
- 96 lt-4 flat bed ride home
- Trouble light - bulb
- Cheap HP mods
