- 1991 ECM Help
- How do you change the spark plugs on a 92 coupe
- 1985 vette
- 1985 Vette TPI into my Truck
- Been puzzled about this for a year now
- 13" Rotors for an 89 Corvette
- Looking for some dimensions
- How grease poly bushings?
- RH Headlight stays open --1986 Vert
- Cruise Control Question
- Short block differences.
- Loose metal trim on glass top
- 4l60e Problems. Slipping in first and Second
- EGR gas mileage question
- A/C and braket delete
- well im back from the desert!
- ICM and code 42 fix...finally
- EGR Error
- Short in 87 Bose Radio?
- 1994 ZF6 Reverse Lockout Rod
- New headers for C-4's
- Comps XR300HR in a 383
- Help Needed... Not sure what to check next???
- No Start, No Spark, Great Info
- Cam recommendations
- How to find Courtesy Delay Timer
- Larger Injectors for TPI, which ones will work?
- Knocking Sound Low RPM
- Confusing idle problem on the 398
- How do you align a waterpump driveshaft?
- 4+3 swap to 6 speed
- cam swap/ top end porting
- O2 sensors?
- Stater motor problem ?
- What have I done?
- Forgot about the E-brake for 2 miles
- My airbox repair and mod
- Need help with central control module
- On to next problem! Tapping noise.
- EGR Gasket Differences
- Armrest Lid wont stay closed.(96)
- Transmission range switch
- No Start After Storage=Starter?
- interior lights delay stays on at times kills batt
- CASE Relearn Question
- third brake light bulb #
- Shifter Recommendations ?
- Fuel line problem on '87 convertible
- c4 newbie
- DIY Steering Wheel Refinish on a Budget!
- Individual cylinder miss on OBDI ?
- Cooling Fan issues
- install new NON-Fluted Pilot Bushing? bad?
- 6 Speed Camaro Auto into LT4
- 95 OBD reader
- 84----ecm who knows
- Key FOB Battery Question
- Budget build.....Lots Of Used Parts
- Automatic Door Lock/Unlock
- Will these Wheels fit???
- Thinking of saving this 92
- 93 Vette COOL Light Comes On
- Reverse Grinding
- torque? rear rod asm
- Mechanical oil pressure gauge
- Wife backed into the '92 with her Honda Accord
- Early C4 Alterator wiring diagram
- Aftermarket Digital Tach ? Yeah or nah ?
- 95 LT1 Vette stalled will not start
- Injection pulse slowly shuts down?
- 94-96 Sport Seat electrical question
- What size is EGR vacuum hose?
- Brake caliper rebuild kit?
- 85 c4 vette losing voltage to fuel pump
- Failed Brake Balancer Test :/
- C4 corvette speaker housings
- Flakey tachometer
- Well it started right up
- 96 lt1 knocking type noise removed oil pan there was no shrapnel
- need help with 92 convertible
- How to improve throttle response
- obx catback experiences?
- Clooged Fuel return line on '86
- oil pressure.. when do you worry?
- trans swap question
- What do you think she will run?
- Trouble Getting My 95 Out of Park
- 1995 pinging continued
- ??? - 85 corvette - location of fuel pump relay
- Check Engine Light on 87
- sensor
- Gen1 400 sb 2 bolt Main stress test
- Rev counter gone a bit haywire
- 1984 corvette lt1 conversion
- L98 temporary loss of ignition electrical power?
- Driveline Vibration
- air filter in engine bay
- problems with my C4 need help!
- 89 Headlight issue.....searched but need confirmation
- instrument cluster everything is lit
- Oil leak above Oil filter somewhere any suggestions
- Cardone ECM Any good????
- Rough Idle And Backfire after degreasing?
- Not ideling correctly
- 86 Instrument Cluster
- Flow # geeks inside
- Willcox Winter Sale! New Sale, New Details, New Items. Plus!!! You still get 10% Off
- 434 cam choice advice
- Need help; not getting spark
- 94 Coupe - replacing clutch gonna re-use stock flywheel 80k miles should I ...
- Which Dipstick Tube?
- 86 headlights and cluster
- L98 Engine Idle
- '92 runs fine then stalls, etc etc.
- What do my C4 bretheren do for....
- 95 brake pressure fluctuating with weather?
- Steam out of tail pipe at idle?
- Cannot get 87 coupe to idle correctly after head gasket replacement
- Pics i give up
- First time vette owner intro and no start q's
- Sound from Speakers quiter on one side
- what intake, injectors for this crazy cam
- Need to replace my antenna
- question been on my mind for a while about codes.
- what is normal operating temp?
- C4 re-born in NY
- Wipers...
- Playing With Fire
- does the 165 computer need a different knock sensor?
- swap to 355 circle track motor low idle and backfire
- Motor PIcs
- Hood Opening Bracket
- Clogged fuel line at tank...HELP!
- code 43
- Home built ram air?
- Who makes a good water pump for my 89 with a 383??
- More Hard Starting
- So obvious, but I have to ask: Walboro Fuel Pump install
- To "X" or not to "X"
- Clutch Fork Dust Boot
- 87 Engine build questions
- A few gremlins I am chasing.....any help?
- Will my diff survive?
- 1985 alternator on 1986 corvette
- Slave Cylinder for 85
- New to the Vette World...HELP!
- Another fan question on a 94 corvette.
- Push button hood opener idea
- Valve cover bolts
- Billet toe bars
- clutch slave 93 vett. 6 spd.
- 6 Speed Automatic in LT 4
- 1994 C4 Corvette Coupe Fuse Problem
- Need Help Diagnosing Knock Sound
- 20 minute LT1 spark plug change
- flywheel neutral ratteling ??
- service ride control just came on?
- Dim Dash LCD Speed Display Help
- throttle body !!
- 3rd time replacing a thermostat...
- running bad
- 91 running very bad
- lt1 96 vette knocking?????? HELP
- Spline will not fit....
- Creaking Steering Rack
- '85 tilt & telescope noise
- On-line source for vacuum line diagrams?
- incopetence at a new level
- L98
- header wires
- hot air in summer cold air in winter
- '92 LT1-C4 to L92/L99-T56 swap started
- Fuel injector failure
- Clutch Question
- 88 C4 has injector and ICM problem
- Good Ol' Mid America
- Fuel Rail Bolts on 89
- 95's Idle Gone Coo Coo
- Gathering parts?
- Fast chip owners
- 88 corvette , flooding problem
- 1994 C4 Coupe AC Control Head Problem
- its been a long time... way too long
- Help w air diverter hoses 1989 model
- C3 longtime owner just picked up a c4...
- Would I benefit from a mini starter?
- newbie needs help..95 is hydrolocked with fuel
- Heater doesnt work
- how do you test headlight motors?-- '85
- So This is why my L98 blew up.
- Obd i
- Coil over shocks
- [Alternator] What's the lowest safe starting voltage...
- radiator cleaning air gun
- Good Gear guy
- chip tuner - 1987 383 stroker
- 85 corvette dana, is it a 44
- Corvette 383 Stroker misfiring like crazy!
- Replacing ICM
- Locking/bleed brakes ???
- Fuel pressure?
- Start Up Vid
- 85 quit running, ideas to cause?
- No heat from vents 1991
- Dash backlight inop 1991
- Ported heads 10088113?
- Starter Engages with Key Off Need Help
- Need Help with my first vette its a 93 40th
- ARH Headers
- Proud Owner of My First Corvette
- cruise control fuse locations??
- 95 LT1 Tone Generator/Chime Module Question
- VBP adjustable front spring
- 1990 fuel regulator question
- 1996 Corvette EMT tires?
- Poly vs. Rubber Bushings vs. Rod Ends
- 92 Door Lock Switch With Bezel
- Patriot 8401 Springs vs. Comp Cams 918's
- Touch screen radio in c4
- 84-85 vet
- 383 stock intake stock exaust HP
- AC code 09
- Track wheel offset question on a '94
- Need help making a decision. Replace components or get a new distributor
- Rough idle, Fouled spark plugs?
- 1989 L98 engine guide
- Clutch master thread/pitch size
- 1994 Main Fan/Secondary Fan on after start????
- Guidelines for removing 1990 water pump
- 88 FUEL PUMP removal
- Male connection to opti
- 1985 LT1 not running right
- automatic shift problem
- Bad rear wheel bearing?
- Rear wheel bearing on my '86
- how do i put in a Passenger window glass???
- hvac vacumn 1984
- 86 4+3 into my 85...HELP!!!
- 1986 Oil Pan Leak
- Cold Engine Idleing
- Split injector O-ring
- vibration when releasing clutch
- Hard/no start, runs rough
- knock sensor issue
- Ls7 in a 87 c4!!
- Crusing speed shudder, 6 speed trans.
- Managed to cloose a hood that's not aligned, now it's stuck
- Oil Type
- batt symbol
- drivetrain trouble
