- bearing/hub question
- C4 cluster problems
- Electrical gurus: splicing in 85 Corvette pig tails on 86 wiring harness
- Glass Top Cleaning
- Never noticed this until today---
- Digital Speedometer Problem
- what sealant on coolant temp sensor?
- FX3 help!!!
- Any secrets?
- 1990 C4 Starting Question
- Guys with the PP 52mm TB
- Transmission fluid type 1986
- An Anniversary yesterday.......
- 3 Years in the making - BBC C4 Project RESTARTED!
- Speedo LCD
- c-68 air mix actuator fix 86-89
- will 17 X 9 1/2 's sawblades fit on 87 vert?
- lowering a c4
- Adhesive Needed
- Clutch Replacement
- Optispark + Ebay, would U buy a opti from a Ebay vendor?
- Can a 1in crack in bottom of #6 cyl be fixed
- Can I jump?
- Help with shock choice please.....
- help with 91 miss fire
- How to replace a the break light above the license plate in a 87 vette?
- help, manual transmission install gone wrong
- Alpine cda-d857
- big mouth air dam problem (urgent!)
- Another track T&T
- opti bolt lenght
- rear hatch light switch
- 4.10's are in and very worth it
- Rpm will not drop
- BFGoodrich g-Force Sport - IF you have them, how do you like them???
- Revamped coolant system (1.5 years later)
- Whew! brake caliper bolt nightmare! ideas?
- Door handle problem
- Parking Brake
- SOOOO Close....
- those with adjustable trailing arms what length would you start with?
- surging
- Need help diagnosing lt1 problem
- Where to buy wheel studs??
- how do you change the pads?
- 96 LT1 Stumbles @ low RPM
- tires for an '84 - best deal around???
- 700R4 ??'s before I buy
- help interpreting data
- 92 C4 LCD digital cluster going psycho flashing etc
- 85' Speakers, what are they?
- window reg. ribbon 85, how bad is it
- Radiator
- Possible Bose Speaker Amp relay problem?
- Legality of Removing EGR?
- redline
- Code 53 (1986)
- Quick Question about setting base idle
- top speed
- Returning L98 Back to N/A?
- Strange problem
- No more check engine light
- 84 Steering Wheel
- trans swap???
- Prestone Bath
- Fitting stripped on my clutch line from master to slave
- Code readers / Scanners
- Missing, Backfiring, stumbling
- misses real bad blow black smoke
- My garage is ready, finally!
- Differential Fluid Change
- Putting the engine back into the car - question
- Running a little warm today
- Shredded serpentine belt
- chime sounding when headlights on.
- C4 Headers
- my 1996 CE will not start
- Stereo
- "How to" videos for engine build
- need help, won't start
- Rebuilding 89 Distributor - How or Where to send it
- Is name of moron who designed 4+3 semi manual transmission known?
- What usually fails after.....
- Those with BBC conversions or experience with accessory brackets - inside plz!
- Midnight sparking...
- 4l60e Help PLEASE!!!
- Soda Blasting for Paint Removal
- installing new 02 scensor and chip in my 84?
- 85 distributor question
- Brake vacuum hose
- ???'s before I buy my 1st C4
- 85 oil pan gasket
- 86 vette starting problems...
- 3/8 fuel line to -6an question!
- need some help
- Coolant question
- TV cable adjustment ?
- Throttle Body Question
- what do they do when they 'rebuild" a steering rack?
- 383 to 406...should I?
- Glass top re-finish using Scratch-Out (With Pics)
- Headers
- Need fuel pump wiring info please
- Nankang tire $63 255/45/17. Are there cheaper tires?
- car wont start.....
- How to reset a code
- Parts Question - who knows??
- My code reader cannot read 94 engine codes. Did anybody say 94 had between OBD1 and 2
- Before Lunch=Ran Great...After Lunch=AAA Tow Truck
- surging
- Cam gurus What do you think
- Slight Fuel Pressure leak....
- do front upper balljoints need a press?
- Some libraries have online access to Auto repair database
- 93 brake wiring problem
- Clutch Bleeding
- Anyone here using Moog Outer Tie Rod ends PN AMGES2231RL in the front?
- Couple of LSX swap questions???
- My tach is suddently inaccurate?
- 1989 Anti Locks
- 1987 C4 engine sensor wire colors
- Radio, DIC, interior 'when headlights are on' courtesy lights... Need fsm wiring...
- HOT cam pass smog in California?
- Staggered tires on C4's?
- half shaft/u joint problem
- looking for a vette mechanic
- Need instructions on rear wheel bearing replacement
- need help-no start 85
- 92 zf won't go into any gear
- Engine Miss!
- need some help beforewife kills me
- 92 base rear wheel question
- 85's U-Joints, the shop wants to soak me i think.....
- Horrible noise!!
- How many OZ of R-12 does the c4 hold
- new stereo/SYS flashes on the cluster now
- 84 if i take out the cross fire system just use a quadrajet wld my cluster work...?
- Alignment
- engine surging at idle
- anyone know what these wires go to??!!
- Be aware of Rain-X Latitude wiper blades!
- Do I need a new stat?
- Vert Vs Hardtop
- 1987 HVAC blower
- PKE Security Issue
- Still missing. Now two codes.
- Guys running Brake cooling ducts help please
- Looking for a 383 TPI/SR BIN file (small cam)
- Zf 6sp use the black thing in master or not?
- MAF Screen Removal
- 96 oil psi gauge
- 1984 corvette
- I need some help
- super ram/ 4+3 TV cable problem
- Door Panel upper lip Repair
- 88 , water pump question
- weird gooey film on windows?
- 255/50/16 Tires
- Window Going up to far?? Help
- Corvette painting instructions. Who can translate?
- dome light relay buzzing
- 92/95 intake questions...
- 1986 Won't stay running. Code 34.
- 1989 fuel injectors bad?
- No AC
- 88-95 shock actuator
- LT1 Fuel Rail Cover Question
- Ignition switch
- Royal Purple
- Seat removal to expose parking brake?
- C4 Carbon Fiber Front License Plate Cavity Insert
- Front brake pad reassembly- pin and circlip
- loss of brakes, then breaks
- 1991 fuse diagram
- Headers/exhaust for L-98
- 1985 Gear Oils + Capacities?
- Ported Heads, Stock Cam - really bad idea?
- 1990 intake options? need help
- Recommendation for alignment shop in CT
- Stuck Pressure Plate?
- Where's the Ground Wire??
- Need Advice On Possible 383 Build For An 85
- How to calculate RWHP to CHP
- Deep puddle, now surging and 2x idle RPM???
- Why I hate Bose
- 1994 ignition key switch removal
- Cool solution to the ugly breadbox
- Spark plugs for L-98
- want to build a 500 or 600 hp lt1...
- Help!! I'm Roasting Alive!!!
- will not start
- Spring Identification
- 89' Emergancy brake question
- Horn Relay
- 1989 stalling
- How well do you know your C4? What is this part?
- ATF for TH700 and brake discs for my C4
- Effects of retarded timing
- Stainless Exhaust pipes
- Power Steering leaking from the shaft
- Vibration when flooring it
- 95 LT1 hard to start
- 1986 won't stay running! Flashing Instrument panel! Computer Mod?
- Is there a proper procedure for installing your T-Top?
- 92-96 S/C work on a 90 l98??
- 245 degrees temp on a 96 Vette with a 383
- Engine not completely mating to transmission dilema.
- idle issue, just got my first vette,
- OEM C5 wheels on a C4 - Anyone running spacers?
- brake light switch help
- Whatever should I do?
- no vacum to heater controls 85 vette
- SuperRam -- Programming
- block off egr valve 87 vette
- Grand Sport Brake Rotors
- Thread sealant
- RE: Taylor Distributor Cap&Rotor
- Suspension help needed - 1995 vette
- Confusion over ecm numbers, need to change ecm what gives?
- help help help!!!!!
- Is this the right oil
- 95 Clutch Spongy and hard shifting
- C4 problems: Heating
- Rear Wheel Bearing install tips or write up?
- Accelerator Pedal Broken
- High idle at startup
- Flooding problem
- U-joint Lube?
- Help with my center break light (1991)
- Let us see who is the best Corvette mechanic here.
- '88 Starts, Stalls, then Runs OK
- Changing the belt on my 94.. Holy smokes
- Transmission problems..
- It's the little jobs that take all the time!
- Trouble finding the ECM on '89
- What header gaskets are you using on L98 ?
- Intermittent starting problem on my 87
- Relays in the dash and a no Crank condition
- Need help identifying this dash connector 94 LT1
- distributor gear
- Convertor lockup switch?
- Corvette Expo
- Wanted: injectors for an '84 crossfire
- replacement carpet mats - where to buy???
- Summit 383 block...good?
- Removing Front Bumper
- 58 mm throttle body air cleaner
- Some ZF6 clutch hydraulic questions
- Harsh Vibration @ 3000 rpms
- World Products Head #'s
