- ? for guys running EWP in LT-1
- Hedman Longtube headers in an 87
- 4L60E More help
- which brand crank for a 383
- compression and leak-down test results
- Tires
- hard start and will not idle
- Anyone seen or run this particular front spoiler?
- how many miles before lt1 rebuild?
- '92 Turn Signal Stalk
- 86 rough running - lots of starting points
- 1986 clutch and idle question
- Violent Shake
- Waterpump stuck on LT4
- What is this on the engine? Doesn't belong?
- Scored damper hub
- opti Q
- shattering tranny
- Headlight bushings (1996 style)
- Anyone installed this 1985 Corvette Throttle Enhancer Calibrator part
- oil in intakerunners
- Alternator tests good battery still loss's power
- Searching for oil leak
- trouble finding electrical connectors' mates.
- 85 Corvette using an 86 and up base manifold: questions
- Carone parts - Rock Auto
- zz4 short block dart pro heads
- Oil drain plug allows drip
- Trailing links year change?
- muncie m-22
- How much power will these add
- Tach guage flux
- Intake gaskets
- Code 16?
- Power Steering
- CHEAP wheel bearings?
- I adjusted rack and pinion, I'll do it again. Who did?
- Please school me on the 1994 Neutral Safety Switch
- gunned it now dead?
- Fuel in cylinders...hydrolock
- intake manifold
- engine dyno cost?
- Open Loop....
- Looking to get A/C compressor
- 4 SpeedTransmission Switch
- HELP!!!!!!!! Loud Backfire and no start
- Should fuel pressure regulator hold vacuum?
- Clear Distibutor Cap
- 92 to 95 Opti complete "but"
- Idle drops low, allmost stalling
- open loop
- Power Steering Pump?
- Rocker Stud Loosened
- Heads for lingenfelter SR
- Stock air intake systems?
- Broken down in the middle of the road (pt.2)
- 86 Heater valve rebuild
- I need measurements of rear wheel bearing. To mechanics.
- Used Dart Little M for $1200???
- Poor running '94
- 92 cranks stops like it hit a brick
- do I have 3.55's?
- fist time vette owner question for yall
- shift light on my 90 vert AT comes on
- 91 dash problems
- 1985 is now a classic. What can be removed with no emissions test
- HELP! I need instructions + tips on replacing my O2 Sensors
- Fuel Injectors
- Lower A-arm installation help needed...
- IAC is it good or need to be replaced???
- Does rear wheel hub fits another car? Who replaced bearing in it?
- Strange vibration
- Looking for ALDL pin locater wiring diagram
- Engine fan inoperative
- Quick Cam question!
- Will not start?
- Front spoiler pics needed please
- 1988 C4 Battery Replacement
- Cooling Fan Wring Problem
- C4 Hood Alignment
- 91 ZF 6 spd Replacement Clutch Process
- Will a 96 ac controller work on a 94?
- Need advice!
- Need to replace clutch slave cylinder
- What is this parts for?
- Tailshaft failure or damage?
- Does connecting rod have oil squirt hole in 94 engine?
- A/C - Heater Blend door loose...
- c-beam bolts
- Crossfire....
- Mid America front spoiler ?
- TIGHT u-joint
- What is converter stall speed?
- Rearend Issues!!!!! C-4 Auto with 2.59 code GM1
- Wrong clutch bearing?
- HELP!!! Tranny trouble stock '84
- 1989 alternater
- A&A Corvette Brings You: A Discussion About Belt Wear
- Did GM steal 383 engine idea from you guys?
- To 92-96 owners. Please look under hood and...
- My 94 AC is fixed, thanks, guys. 4 problems.
- Translation to english please
- wheel rotation question
- Torque Converter Question
- How do I remove the shift knob. 94 6spd
- Compression test?
- At my wits end - Failing sniffer test, High HC, Rich idle.
- Weatherstrip Installed
- Standard metric conversions
- 86 dash lights
- Off the Shelf Gear Lube and Trans Oil?
- re-gear or not?
- Fan Trouble?
- L98 valve cover paint
- Tune-Up Partially Done
- Hedman Elite quiestion!!!
- TPI cable bracket?
- While I'm in there
- Decking the Head Surface
- intake manifold bolts.
- interactive gear ratio calculator is online now
- What kind of mods would you suggest?
- Headers on a 95
- '84 - air cleaner gasket - can't find one anywhere???
- Strange Master Cylinder Problem '89 Coupe
- 1987 Passenger Kick Panel
- Spark Plug Replacement Question
- Spark Plug Dyno Shoot Out
- How long does it take for PKE to arm itself?
- 1985 catalytic converter
- Fuel Tank Replacement
- Clicking Noise from Wheel Area?
- fuel pump?
- Mayday ....in Columbus, Ohio
- Possible vacuum leak LT1
- 85 Won't Start - Code 12 - Low Oil Presure?
- Picture of broken vacuum hose. Where should it go?
- has anyone polished their suspension pieces?
- power steering hose
- Oil leak close to oil filter.
- Do you have to remove antenna to replace mast?
- Low air flow output from vents
- 88, invisable coolant leak help !!
- Wheel not centered in wheel well
- is the hotcam too small?
- cold start problems
- No Spark
- OBD1 to usb software
- fan switch
- Original Dana gears?
- Brief report AC repair. Where is vac hose going to climate control?
- Wiring Harness Removal
- Tranny Guru's
- Cargo area carpet.... and it's original mount ?
- 1987 Door light
- No Brake Pedal On My 87
- What's a 383?
- Bluetooth OBD II scanner
- Windshield Wipers
- Oil Temp sender
- How to test ignition coil?
- 91 C4 engine trouble
- Cap and Rotor recommendation?
- start then stall but runs with feathered throttle
- Oil Pan Gasket Seal
- Brake Rotors Stuck
- Sway Bar?
- Performance Water Pump
- need help c4 engine removal
- Help me find a cam - 383 6speed
- Engine starts and idles good but stumbles if you really get on it
- a.g.t. fog lights
- Testing Fuel Pump & Relay Questions
- Stabilizer shaft link
- Possible Future Setup?
- Alternator replacement
- 92 won't start...looking for direction.
- Rear Defogger Removal
- Time To Start Modding The C4 HELP
- Porting TPI Intake Plenum
- help removing coil
- Advice on Torque Converter
- Who can recognize this engine sound?
- '85 Starter Opinions
- Drive shaft causing vibration?
- cigarette lighter
- squeaking noise on 94 coupe
- 84 runs too cool
- dual mass flywheel
- Bad ECM?
- Wanting to change rear end gears. please step in
- Electronic A/C Problem
- Advice on Gear Ratios for Autocrossing
- Loud Aluminum Flywheel?
- Tire & Wheel size
- Rear O2
- 92 up. NAPA has AC high pressure valve, dealer doesn't!
- POP.... stalled and wont start.
- Gauge cluster
- Our Corvette parts: if their MFG overseas do you stay away?
- Photos of Car this weekend 10.03@134MPH
- magnaflow s/s mufflers
- Need help dialing in ride height/stance with PICS
- Who remans climate control heads - 90+ C4?
- Direct C5 amps into C4 - which year works? There is only one
- 86 loose steering column - bushings? Whats the common cause and fix?
- Bosch III injectors
- anybody use this cam?
- LT1 / LT4 intermittent fuel pressure
- Repairing AC on 94
- Stalker Wide Body Kit
- Fuel Tank Liner Cracked
- Best bang for buck mods on a stock LT-1
- 1996 Lumbar air hose is disconnected - any ideas?
- Body disassembly help needed
- bearing/hub question
- C4 cluster problems
- Electrical gurus: splicing in 85 Corvette pig tails on 86 wiring harness
- Glass Top Cleaning
- Never noticed this until today---
- Digital Speedometer Problem
- what sealant on coolant temp sensor?
- FX3 help!!!
- Any secrets?
- 1990 C4 Starting Question
- Guys with the PP 52mm TB
- Transmission fluid type 1986
- An Anniversary yesterday.......
- 3 Years in the making - BBC C4 Project RESTARTED!
- Speedo LCD
- c-68 air mix actuator fix 86-89
- will 17 X 9 1/2 's sawblades fit on 87 vert?
- lowering a c4
- Adhesive Needed
- Clutch Replacement
- Optispark + Ebay, would U buy a opti from a Ebay vendor?
- Can a 1in crack in bottom of #6 cyl be fixed
- Can I jump?
- Help with shock choice please.....
- help with 91 miss fire
- How to replace a the break light above the license plate in a 87 vette?
- help, manual transmission install gone wrong
- Alpine cda-d857
- big mouth air dam problem (urgent!)
- Another track T&T
- opti bolt lenght
- rear hatch light switch
- 4.10's are in and very worth it
- Rpm will not drop
