- 92 LT-1 Rods and Mains
- 96 heater blows cold
- Service ASR / ASR Off lights
- How check for bad ball joints vs bad tie rod ends?
- front end loose pull at 3oclock and 9 vs. 6 and 12?
- 89 L98 - What's the correct tstat gasket?
- ARP Balancer Bolt
- Is it OK to jack up the front end from the lower control arm?
- Steering column rebuild
- NGK TR5 on 89 L98?
- steering column missing key
- AFR 195 intake gasket
- About to change valve seals
- figured its about time for another BBK intake thread
- Ez-efi
- Need some cam selection help!
- Radiator drain plug won't tighten?
- Better exhaust sound
- Cam question
- Leaking Oil
- 85 injector question
- Removing roof on 87 corvette
- Changed battery, now no fire
- joined the snapped shock bolt club today
- Tell me about these heads I bought
- Slave not releasing clutch could not shift
- 1984 Coolant Temp Sensor for ECM - part number???
- Oil leaking near distributor + vacuum line found?
- 02 Sensor
- 3" exhaust problems
- replacing throttle body on LT1
- high idle on lt1 6 speed
- ***Houston Dyno day/Car show - May 22nd
- brake control relay.
- pke ? I searched back to 2007
- 1991 ac charge and convert
- optispark problems
- mild cam
- Hesitation/bog at part to full throttle
- O2 Sensor Intermittently Throwing Code
- The "New Corvette Forum Shirt" Giveaway
- Which fuel lines do I replace?
- Very confused..Help
- 1989 Coupe - Fuel System Issues?
- '91 700r4
- Painting license cover
- Distributor Cap wire ring ?
- Driver side Power Window noise
- Rear Wheel Hub Installation
- header install questions
- Tapered rear wheel bearing source???
- 1984 corvette charging problem
- 1996 LT4 CAGS Eliminator Problem
- Are these supposed to be right replacement Bosch III injectors for my '91
- Fan relay code after Meziere install
- LT1/LT4 Timing Gear Drive Q&A
- electronic techs, can you fool the ASR system?
- 91 Rough Idle, Rich Exhaust
- Motor "diesels" after drag race runs?
- How do I replace the lightbulbs in the dash?
- 1995 LT1 California CAT Question
- 86 wiper problem
- Fuel tank foam + sender
- Will Our Clear Tops Block UV's?
- Protecting the brake booster from heat
- c4 cd player
- Distributor Cap wire ring?
- Yet another knock sensor
- Eprom chip
- lower ball joint replacement
- AC Rebuild ?
- cam advice
- HELP! cap and rotor problems
- Cruise control switch wiring diagram?
- Dead battery odometer issues
- Off-board device?
- Something going on w/my brakes... ?
- Prom Truble
- Who had cracked headers welded?
- Bilstein Part numbers for '92??
- Change Oil Light
- Headlight Switch Replacement Help
- Weathered stock 86 wheels
- LT1 Idle is too high...1993
- turn key... nothing happens
- Cold Start Problem-need help
- Pulled P0719 Fault code today??????
- Radio stopped working
- Vaccum line
- Realy Dumb Question from new owner
- What would it take to convert an early TPI plenum to speed density?
- 1989 idles too fast
- true duel exhaust question
- Distributor noise
- LT1 dipstick tube ?
- Stock LT1 Exhaust vs With Added X-Pipe
- Oil Leak
- What else should I change?
- LT1 1.6RR Self Aligning - what brand?
- O2 Sensors keep failing on my 94
- Is my 1994 OBD1 or OBD2
- LT1 intake manifold porting........pricing
- ??'s about the 92 LT-1 I looked at today
- Newsflash! Resurfaced DMF(s) on eBay
- Clutch reservoir cap refuses to budge.
- opti rotor issue
- inward or outward mount bracket.... decisions
- High injector D.C.'s
- fluid change and timing chain ?
- High Performance yet quite
- I need help with my dash...84
- Engin shuts off when I take foot off gas, Help
- Anybody ever use this product?
- Will Stock LT1 Valve Covers Clear 1:6 RR's With 0.600" cam lift?
- 1990 Tech Article?
- How do I remove the plenum?
- Vert Brace on a Coupe?
- LT1 intake casting numbers
- wipers,lights
- Coolant rubber "T" for oil cooler
- Question re installing fuel injectors
- 90 Convertible-Bypass Door Theft Switch??
- Distribtor Wires
- Fuel injector clips for Miniram?
- Who is using mineral oil?
- ses light on, how do you check codes?
- C4 Auto A/C Fan Issue
- Failing Fuel Pressure Regulator?
- installed front Penskes with Delrin pintops & dual rate coils
- Headers?
- C5 brakes dilema/question/possible solution?
- Gasket part number
- Horn/anti-theft fuse keeps blowing
- Car shut off while driving
- first corvette l98 4+3 motor rebuild
- 96 Door Locks
- AC-Delco oil filter superceeded?
- best oil for 87 stock tpi engine?
- HEADERS, 1986 C4. Have Hedmans NG>`
- Drive-train rating?
- 1993 Backfiring Mistery
- Polishing Ceramic Coated Headers
- Youtube Corvette transmission university
- 3" Exhaust on a 90 convert??
- 1993 Sport Seat Inflation Pump Diaphram
- 1993 IP Cluster Bulb replacement
- 85 injector question HELP
- going back to 180 from 160
- 96 LT1 Water Pump Rebuild
- Things that go THUMP!
- Clutch/FW trouble again; saga continues
- carbed vette is down and so am i
- shift knob removal - How to?
- Help me spend $1000.00!!!!
- Is car running rough?
- Very Hard Brake Pedal and 1500 RPM Idle 92 LT1 6 Speed
- Spark plugs for AFR's
- quick AC question
- Dynomax VT Mufflers
- Battery Tray and holder for '88
- Suggestions for Head and cam combo on 85
- Source for C4 to C5 caliper bracket adapter.
- '87 Plenum and Intake
- 1984 - anyone know where to find an EGR solenoid???
- Aftermarket bellhousing for -85 Corvette??
- k&n filter part number?
- Coilovers Installation (Front)
- I got my First 1991 L98..Some Questions I have like setting timing
- Is welding of cast exhaust waste of time and money?
- No low Beams
- Changing convertible deck piece
- 88 EGR Solinoid part #
- adding a 3rd brake light on a 85
- Here's a new one. Passenger window
- high idleing on 1989 corvette
- AC gone crazy. Hey, Corvette mechanics!!!!
- 87 vette stock rims, fins go forward?
- ATE Super BLue in my 87
- TV Cable problem
- What is spec temp. for 94 thermostat? I couldn't find it in FSM.
- pulling codes service abs
- Name That Squeak!
- am i going nuts!!!!
- borla part number
- aluminum radiator
- need help
- How many temp coolant sensors 94 has?
- SA Versus NSA? Steel VS Alum? 3/8 vs 7/16?
- cold start issues
- 1984 rear end
- 1990 Dist - Advance Direction?
- which opti is best
- does the button on the automatic shifter knob do anything?
- Brake Motive Drilled and Slotted Rotors?
- 1986 corvette wont start, was perfect then nothing no solenoid click, or anything!
- Best brake pads.
- what heated o2 sensors are you running for those with them?
- which headers on 1994 corvette?
- Hood release problem
- 86' Rear hatch release not working!
- Corvette cluster fix 1985
- 1995 LT-1 4 barrel/hei swap question !!
- replacing factory antenna wire color help
- I replaced headliner.
- In about a month........
- C4 Torque Specs
- Refreshing tail light harness and a few questions
- 1984 - TPS and rough idle - happen to you???
- Where is 94 water pump hole?
- 86 Rear Suspension problem.
- Wow look at the difference in these converters!
- I think this counts as a wtf.
- EnduraCool Header Coating Sale!
- Brake master rebuild completed.
- Coolant leak on LT-1
- cold start valve leaking?
- changes to CFI - computer still ok?
- Auto Trans. problem on my 87
- 1990 l98 vacuum diagram
- I need floor mats!!
- Coolant sensors?
- New cam, ported manifold, new wheels
- Why are no '93 LT1 clutches out there?
- Anyone going to C4 bash at Corvette museum that wants to troubleshoot a 86 L98
- engine combo with miniram?
- Finally Drove It! 4.11s, MezHD, Big Sticky Tires
- code 32 EGR faillure
- 1988 L98 exhaust compatable with 92-96 LT1?
- dana 36 to dana 44 with 3.55s
- 1994 starters on EBay
- loosing battery power
- 89 Horn Will Not work
- 92-93 gauge cluster specs needed
- Anyone replace resonator with X pipe on LT1?
- HELP loosing battery power
- max Compression on 93 Octane
- Loosing brake fluid.....
- 1991 Error Codes C41 C51
- Would increasing the octane value decrease the knocks
- Any Shortcuts to replace 87 Driving Lamp Assembly
- Accelerator peddle travel.
- need your input
- One Piece Oil Pan Seal
- Exhaust upgrade
- hot start blues!!!!!!!!!!!!!!!!!!!!!!!!!!
- 87 Corvette VATS question/problem
- Power Chip
- Power steering repair
- Can someone post some measurements for me?
