- Which header gasket to get?
- any CA legal superchargers available for C4's?
- Front sway bar??
- more trouble
- Uh oh, what broke?
- 4+3 Shift Rod Boot Repair w/ pic
- bolt extractor snapped off
- New Injectors
- loud interior resonance(Flowmater Mufflers)
- Headlights out of sync!
- Rocker question
- Orbital Polisher Recommendation
- emergency brake help on '91
- 13 inch Rotors for an 87
- 84 injectors
- Reading the AC codes
- 5/11 - 5/18 Satin Finish Billet Racing Pedal Group Purchase
- Better idle
- 1987 alternator wiring
- HELP.. new unique build question 89 with non roller cam
- L98 performance help.
- no start
- Wheel Spacers?
- will not start when hot
- Anyone running ProComp head's? Help needed
- Done
- 2006 wheels on a 1991
- 84 crossfire, has some questions on upgrades
- Starting Problem
- ALDL no data fix
- Hooker Y pipe is Junk,Junk,Junk!!!
- Clicking sound on rear l tire ...?
- High pitch noise
- Has anyone used this 4L80E adapter?
- water pump?
- Waterspots on Black
- C4 rear brakes?
- C5 brake adapter kit
- Replacing Rear Bearings Question
- IPod Adapter and Antenna Bypass questions
- Vague steering and large dead-zone
- Engine has been sitting 14 months. Has not turned over... Pre-Oil Question?
- Where to buy Bosch type 4 injectors
- Brake Issue
- jacking rear
- GE Head light
- DeWitts - I really didn't know what to expect
- Air conditioning re-charge
- 89 vert no fuel pressure
- Where is horn relay on a 1988 covette?
- Where can I get O-rings for fuel rail cold start line
- Please help....Roller Rocker question
- difference between overdrive and drive?
- 89 with rough start & back fire
- Spacers for Grand Sport wheels on 1986
- shuts itself off
- Well it finally happened --
- Miniram issues
- Power steering cooler install
- Gas cuts out over bumps...?
- Why the height difference
- LT4 oil pump drive
- 4% speedo correction
- Are these heads supposed to look like this? Pic
- New engine build, water pump question
- how do i get the crank hub off an lt1
- Smoke!!
- 1991 L98 Couple of Questions High Idle
- Front Intake Bolt
- Welder screwed up my exhaust manifold.
- I replaced my valve seals on my 88 finally
- Why is my 89 Gutless?
- Can't get this hose off!
- 86 won't start after replacing battery
- 85 corvette died, code 44
- Valve covers get torqued?
- Catalytic Converter Disintegration
- Trans Cooler line connections
- How does the 4+3 Manual Transmission Overdrive work?
- 88 has instrument cluster flashing on/off
- Rear Lower Shock mount info
- MAF Reading using WINALDL 1985
- Removal of Door Speakers in 85 Vette
- 96 Start failure
- WINALDL Use on 1985 Corvette / O2 Sensor
- 383 stroker kit
- 96 CE starting issue
- Calling all Electric water pump LT1's
- Performance Mods?
- AC problems
- LT4 Rebuild
- 88 oil question ????
- 90 Tire question
- 88 exhaust and intake questions
- 85 A/C Evaporator Removal
- Havc
- 3000 rpm idle after replacing Injectors...HELP
- Installing 89 hardtop on 87
- Transmission adjsutments
- Trans Cooler install question
- Radiator tank seam blew....
- How much hp are the 84/85 iron heads robing this combo of ? Pic's
- How much power are the 84/85 iron heads capable of?
- I am replacing piece of seat cover.
- How important is it to keep stock tire size?
- So a brand new compressor was just ruined
- question about the transmission display gear thing!
- Rear main seal change.....
- power antenna
- Your MSD Opti Status?
- L98 Dipstick solutions with headers
- Mystery rear hub/bearing squeal
- cold starting problem
- 96 LT4 abs/asr ecu Wiring Diagram?
- Optispark for the Umpteenth Time
- Spark plugs flashing blue at night
- full rich, and stumbling
- Help me name this hose?
- 86 steering wheel
- L98 water flow direction
- Confused...VERY CONFUSED
- anybody have any idea on how can I remove the charcoal that is plugging my can lines?
- Trouble starting engine help!!!!
- Parts Not Available - Discontinued
- Tach reading high
- Fuel Injector Problem?
- Help getting the roof lining back in place!
- Paging Pete K: your inbox is full ...
- U Joint Replacement
- Won't idle below 900 rpm
- "Gluing" intake gaskets?
- Rocker Arm: Full Roller VS Roller Tip
- Roller Cam Motor?
- Brake calipers
- 86 Passenger side window motor spins, but wont roll up!
- Whats the best Cam for stock tpi ?
- fuel guage not reading
- 87 no start problem
- OK mechanics, why do I STILL have a rough idle on my ’84 crossfire???
- Corvette Muffler Eliminator yes or no
- 84 Clutch release problems
- Non working horns
- Remove 88 Automatic Starter?
- 1992Seat Bolster Switch
- 383 build question
- Can my '85 transmission be saved or junked?
- Considering moving uo to 3.73 rear end gears, what's your opinion
- Found something similar to the Bosch Mystery Plug: Brisk Spark Plugs
- solid rollers ... is it so bad
- Shift points on a 93
- Dimming Dash & Headlights and more....HELP
- Adjustable Fuel Pressure Regulator 91 Vette
- Rev/tach question
- Suspension Set-up? Caster, Camber, Toe
- Emmisions
- Pilot light
- Easy computer repair.
- Question About Heads
- AC fan will not shut off.
- OBD II reader
- glue giving way on hatch weatherstripping
- Manually Positioning FX3 Shocks
- Dead Battery LCD #38 fuse
- Dealer can't diagnose
- need ELECTRICAL help!
- L98 Distributor barcode?
- Need Help with A/C Compressor T/S
- Hotcam running rich at idle
- Trying to repair power seats 95.
- Heads, Cost, HP increase Q's
- Solar Load Sensor Short
- Opti question
- I Need 20-30 more HP!! Help Please
- have i cured my problem?
- Clutch Questions
- Code 23
- do the lights in the gear indicator turn on with the lights?
- low oil, new vette owner question
- Question about my Headers
- Tired of getting stranded
- Trim Panel
- Service Ride Control came on today.
- $107 stupidity tax. How to use condom to diagnose engine, how to use engine to ....
- running lean
- Fuel Injectors bad
- 1994 LT1 downstream o2 sensor...
- roughty idling
- TPI Turbocharger
- Replacing power steering pressure hose
- 1986 Clock/Display Question
- AC Compressor Bracket question
- ZF throwout arm pivot bolt fixed
- Comp Cams 286H-14 Cam
- Door chime is on with healdights.!!!
- 86 vette door panel recovering
- What needs to be done to weld on an Accel cast aluminum intake base? Help
- Drivers Information Center
- Spark Plug wires are 16 years old and OEM are they still good?
- Need Info
- Will a R-D Racing X-Brace installation solve this problem?
- LT4 Running Rich
- All Back up lights are out (automatic)
- Any Recommendations on electric water pump for $200?
- Roll Cage? Does anyone make a kit??
- Cruise Control no worky...let's discuss!
- License Plate Ram Air
- Hot air coming thru vents
- Lower radiator hose
- 4+3 trans making a lot of noise
- need some help selecting the right cam
- Battery Drain...Problem with ABS/ASR ECU circuit
- C4 1986 Vent Fan Stays On
- Need help with ses
- Will C5 wheels fit a C4
- Injector swap
- Where to find aftermarket water pump sleeve for 95?
- L98: Significant Power loss at high temp, and open throttle?
- No muffler
- Drove it hard, Now I got a rattle... help
- 92 LT1 Oil Filter adaptor
- Evaporator core removal in 1985
- Wow! Dosen't this look like fun!!!
- Operating temps
- Little job = Big job
- 1984 - fuel pressure regulator rebuild???
- Rough running until warm
- Hypertech Programming ?
- clutch fluid & question
- LSX Adapter Plate LS1001
- LS monster sleeper
- 1994 Corvette - Metal Brake Booster ???
- D36 Question
- Speed Bleeder Size
- engine rebuild
- which cam?
- Would this work for adjusting valves?
- Question about replacing Trans filter on 86.
- 1995 LT1 DTC module 9 codes H65, H71, H73
- 1993 ruby red
- Please Help diagnose this MAF? issue on Supercharged C4
- Headlight stops in the middle position like something holds it.
- loosing battery power update
- Who repaired radiator?
- 95 overheating
- Dynoed today
- Sound coming from rear drivers side
- Very Short Video
- Key Removal
- Intake Center Line
