- Bosch III Install Started
- Need Some Info on Front Sway Bar Bushings
- 84 crossfire oil temp vs coolant temp
- AC Blower Experts--Step In
- taking the EBTCM apart
- C4 Battery relocation
- Spicer/Acdelco U Joints?
- 1990 idle issue
- Removing Crank Hub on LT-1 w/Auto
- Where do these wires go?
- Exhaust
- 1990 ignition module
- 1990 C4 U joints
- 85 No start problem
- Are there any fuel injector cleaners that work?
- can anyone expain
- Heads are off....
- No voltage to a/c compressor
- motor stability?
- TPiS Heads?
- durlast/power torque master clutch cylinder results
- acdelco spark plugs
- Opti/water pump advice needed
- 92 with Z07 want to conver to non-FX3
- Comp Cam RR's
- 1987 fuel pressure/pump test please.
- Nitto 555 extremes and Eagle F1 GS-D3
- Fog Light Issues...
- Running into problems again (Timing Chain)
- Steering column rebuild Q's
- A/C Heat Programmer Vacuum Feed???
- Rebuild sepentine belt tensioner?
- Stock Rear Leaf Spring Bolt Specs?
- 96 LT-4 Trans Gear whine/rear diff groan
- c4 frt hood need help
- Original Tire Size for 96 LT-4 Collectors Edition?
- Help With Distributor Gasket and Possible Vacuum leak Any Help Appreciated
- Need suggestions for head change!
- Motor Guru Please teach me
- Injector question..
- I need your help to find this part or I can't drive my corvette :(
- Heater Core...
- OBD1 Data Cable
- 96 lt1 air intake upgrade?
- Cold Start Injector
- My Hard Starting when hot thread - 95 LT1
- Bolt Size. Bellhousing/Clutch Cover to Block
- Code: 33 wtf????
- A/C Recharge
- How to read 86 Vette engine light codes?
- Clutch Fork Question
- Engine stumble? Help.
- my 383
- my 383
- Finding Vacuum Leak
- HOW to ELIMINATE VATS Secrutry???
- Pitted cam lobes
- Fuel Guage Not Working
- PKE just stopped working!
- Code 43 Scare in my 87 yesterday!
- Remove frisbee and change pullies? How much HP gain?
- steering column play, '91
- correct oil pressure
- 2.59s vs 3.45 in LT1 with A4
- stamped steel vs. cast slave cylinder
- L98 starter parts?
- Darn dog jinxed me, no joy rides this weekend
- Steering wheel MOVES!
- 87 vette new maf and 160 thermostat
- brake fluid flush
- Problem setting idle
- Dual Magnaflow vs Stock 92 Vette
- New Radiator
- adding engine oil cooler
- Is a 224-230 .540lift cam to big for Older Trick Flow heads?
- How hard to put on front clip?
- Doin' my Halfshafts
- Underdrive pulleys + AC & AIR Delete ...BELT ?
- HELP CODE #33, stubble on acceleration
- Jet Performance Chip...OBDII issues?
- Down Under Insulation Opportunities
- 90 corvette cutting out
- 93 corvette headlight dimmer switch
- 1986 Corvette No Horn
- trans cooler/PS cooler install questions
- Trans cooler/PS cooler install questions
- valve stem pressure sensors
- How to change cooling fan on setting
- LT1 6-Speed Engine/Trans Worth
- wtb maf
- Your shorty Header opinion is much needed: which one do I buy?
- Where to find headers?
- LEDs in Interior Question
- knocking from engine area bearing?
- What next??????
- 95 Crank but no start
- Brake pads, 93 c4
- Changed the Battery, now the Radio only plays static
- 96 Fuel Filter Replacement
- 96 Ball joint greasing
- Starter issues...again
- 89 L98 throttle body vacuum line (emissions) help
- torker 2 carb intake maniold
- First intake?
- Power Steering, increased effort
- CD Player
- What is the clack in my differential ?
- Door Panel Fix...L Bracket
- Just about blew my engine on the interstate!! What happened?
- Am I crazy? Stalling problem
- Spec Stage II and Steel Flywheel
- Ball Joint Grease Question
- 85 L98 seems to be running rich
- Accel 26# Injectors
- C4 caster adjustment? how?
- 427 maiden voyage - 5/26/10
- C-6 wheels on a C-4
- Good vette mechanic in chicago suburbs?
- Original Injectors
- 383 Stroker opinions
- location of second temp sensor?
- Miniram intake
- MAF issues - any ideas?
- Mufflers
- Z06 wheels on C4
- My solution for mounting support brackets with headers
- Tech 1 scanner,how do I use it?
- What causes engine vibrations?
- 96 collectors ?
- Drivers power seat woes
- Concerns about Valve Covers
- Starter removal
- starting issues
- 89 vette won't start after you turn off
- Suspension Woes - Alignment?
- Weekend performance?
- 1991 L98 Sputtering-then dies.
- 92 instrument cluster problems
- vaccum leak ??
- question on converter
- Clutch Master Cylinder-Check it, Check it and Check it Often
- 90 ZR1 Delayed Start
- Low Side Pressure Switch
- which coil per cylinder conversion is best
- Misfire= No Gap!
- opti spark question
- Rebuild Bilsteins
- 10% Off Storewide Sale Through Monday!
- What is too hot
- How Many Tune vs. Don't Tune After Headers?
- 84' engine build
- Headlight motor question
- Any picture of a short throw shifter on a 91-96?
- Rolling idle
- Blend Door Motor Position?
- Replace original rear FX3 Bilstein shocks?
- Keep head unit replace bose speakers?
- Lt1 swap manifold question
- 1996 LT4 Computer Update
- Double platinum Autolite 3926 for L98
- Fidanza clutch question.
- 94 sputters when i give it gas
- Air Filter Oil
- console hatch release button
- Smog delete
- 96 Door Panel Fix...wish me luck!
- Strange Rumbling on Highway and more??
- Resonance, where does it come from?
- Is 88 outside mirror steel or aluminum? Etching or regular primer
- water pump?
- LS1 swap is running in my 84
- 90 vette having problems
- Pulley Diameter/Size
- How long to change plugs with headers?
- headlight problems 87 vette
- Range Rover Sport safely pull a C16
- Hours for Trans. R & R ?
- Anyone every convert a 95 LT1 Auto to a ZF 6spd?
- How to test an ignition coil ... help
- Cooling System Part Question
- C5 calipers on C4 - all the same?
- Dash Light don't work
- Reverse Gear Grinding.. not good!
- Short Throw Shifter for 96 LT4
- How do I remove the rear hatch latch?
- Black calipers on torch red - pics?
- 92 Ignition Problems?
- 84 owners -help me!
- ZF6 fluid
- Steering Rack -last call!
- Stainless alloy, '89 exhaust manifolds????
- Speedometer problem
- 2 questions
- A few problms
- Easy question
- the parts ladi
- Popping in front end? Help Please
- HORRRRRIBLE shattering
- Car Starting Question
- Dynamax Super Turbo
- Need ideas on 92 that dies when hot
- What's the life expectancy of a LT1 fuel injector?
- Valve Spring Compressor
- K&N, is it worth the money?
- just a simple question
- Thermostat question
- Dash lights don't turn off!
- Engine Detailing
- Painted my valve covers and plenum
- Opinions on DCR 8.44
- LT Motor Running Hot
- LT-1 92 Vette Engine/Transmission Worth
- anyone put screen inplace of center console lights
- Engine oil cooler fan not running?
- 87 leaking oil! BAD
- Accel extreme 9000 ferro spiral sparkplug wires, any good?
- Rebuild LT1 ?'s
- Which timing chain setup for high hp LT1?
- 89 L98 new belt tensioner install- bolt wont clear brace
- low oil pressure
- Accel Gen 7 Thruster DFI on L98?????
- Headers going in... One hickup
- ceramic coating
- Which oil filter do i get for the 89?
- Late model door panels in 86E
- C5 Brake upgrade - cost?
- AFR's ship on the 28th....
- Headman 68440 L98 headers on a LT1 ?
- Cam install questions
- 89 with brake problems, need a bit of help please.
- Air Door Actuators 1986 corvette
- Autocross Videos-1996 LT4
- which exhaust system, or headers for 96 lt1
- Why is is flaking chrome such a problem with Sawblades ?
- drm Rear coil over question
- 6 speed wont go into second gear!!!
- Alternate source for weatherstrip.
- power steering pump test
- Pics? C4 Torch Red with painted calipers?
- vented opti on a 94 LT 1
- Cam bearing removal ?'s
- O-rings needed here?
- Fuel injectors for my L98?
- Shorty Headers?
- Data logging
- 1993 issues
- anybody use this cam
- Custom built C4 analog gauge cluster
- jet underdrive pulley set and Mezirere elec pump conflict
