- Need Help Please!!!!!!!!!
- buy modified trailing arm and camber brackets or could you make your own?
- High Fuel pressure
- Help!! Fuel Pressure Nightmare
- 1986 tune up
- The truth about Nitrous
- 87 Carpet Padding
- Loose drivers side window 1995
- The curse of the sort! Any ideas?
- '95 Water Pump Replacement Help
- ECM? Buy New Or Remanufactured
- Engine pulled
- My 91 throws code 44, here is a challenge
- Brake Booster Replacement - Any Advice?
- Coolant Flush - Just water???
- Weird A/C Problem
- Short WOT raises Oil Temp Fast!
- Another R134A Question...
- Lost brake fluid in 2 months
- headlight will fold out but not back in?
- Drag on battery while sitting-someone out there who knows wiring help!
- Help: Running bad
- the giant dash pad
- Roll Bar Bushing Replacement 96
- Callaway TT TPI Wrinkle Paint Finish
- Have to hold key down for about 4 seconds to get it started?
- help code 21
- Intermitent Low Idle - Stall
- 94 Radiator removal, nope, it ain't easy
- need some help !!!
- crankshaft breaks
- How easy to upgrade window regulator?
- l-98 performance
- Camshaft rear bearing plug
- 90 vette upgrades
- moates adaptor,need to know what way does the chip goes in?.
- Hurst knob
- Just bought new rad and exhaust for my 87!
- 1985 Map Sensor Location
- Oil residue on valve covers and intake manifold???
- 96 LT4...stumble under load until 2k...no codes.
- A/C drain problem
- Fuel line disaster
- Need help. Pilot bushing install for Zf6 spd.
- Today Is The Day
- Rear Spring Cushions came off
- -88 not going into closed loop
- F.A.S.T. Wiring Harness
- Radio Measurement with pics
- Tips to get better MPG
- Getting Rid of all the emissions BS...Need some help
- service engine soon light
- Tire Question
- O Rings for 88 Center Cap Rims?
- who changes their own oil versus who have it changed?
- Anyway to get better ride from 84 with Z51
- adjustable coolant fan temp switch ? where
- installed my rod end rear toe kit today
- C4 w/ 4+3 Gas Mileage?
- factory shift nob removal
- 92 radio install questions....
- GM Adapter for new CD Deck with Stock Bose?
- Can heater hose survive next to engine block/heads?
- Wierd dipstick reading
- 89 engine removal help
- Heater core question for those who have replaced
- Would 3.07 gears get better MPG than 2.59?
- Ground or Power Problem
- air pump eliminator bracket question ???
- 1986 alarm system
- ICM keeps frying on me ....help hurrryrry
- Whish is a beeter way to read wide band?
- 1990 zr-1 low tire pressure light (on)
- A/C circut relay
- C4 my story
- Connector location ?
- Brake fluid reservoir crack-94
- Replaced my rockers and AFPR
- Despite spenting over $800 and being full of feon my A\C dosen't blow cold air: why?
- Can anyone name this part? (PIC)
- 93 LT1 window motor
- shakey at high speeds
- What are the two voltage regulators behind the power steering?
- what long pipe headers for a 84
- Repairing Plastic Trim
- wheel adapters for 86;trustworthy?
- Right fan not coming on...
- Upgrade advice on 93 LT1?
- Wtb. Gold bose emblem driver rear speaker
- Does anybody know how many.....
- 1990 zr-1 vin
- Rough idle ?
- Suspension Guy in the SF Valley?
- Cooling fan problems
- Dome light timer location
- Is anybody using a PROMinator?
- Rubber bushings
- problem after a long drive
- Where are the vacuum diagrams
- Now that is what I call customer Service! PowerMaster rules!
- Temp gauge stopped working
- plug wires ? question
- buying opti
- Replacing Carpet in ’87 coupe
- AFR Eliminator 1039´s and Edelbrock intake
- motor shuts off at 202 degrees
- 10.4 Taylor Plug Wire Clearance Issues
- Base idle way high (1400rpm), help needed.
- LT to LS1 ECM Wiring Harness
- LT4 timing chain
- 1990 5.7 300hp 350
- Fan Relay Location
- 89 stalls
- A/C issues
- 1987 Hawks brake pads
- Code 33 - MAP sensor on a 1990
- confused aussie needs advice
- aftermarket Clutch and flywheel
- Wish your C4 Frame was Stiffer?
- Callaway TT Corvette Driving Experience
- Old school "Classic style" shifter knob pictures?
- How easy is it to add a 2nd fan to a 85
- 88 calipers loose and jiggly??? rattling???
- 87 Hard starting all of a sudden.
- Trans cooler location?
- 85 running on 3 cylinders
- Edelbrock 3860 hi-flo intake
- Msd 8366
- Sweet Thunder Exhaust
- 1993 Opti purchase option
- what is this plug for? ('84)
- StarDrive "Push to Start" Review
- how to lower the front and rear of 1989
- Measurements for 88 radio bolts?
- Datamaster
- creaking in front end 1984 corvette
- Ignition Control Module
- CCM code 41 No serial Com... O owes is me.
- Well, need new rings for the '84.... While I've got it open......
- Good way to dress up wiring inside engine bay?
- VettAid Dash Replacement Experience Anyone?
- push rods how long
- service ride control 93 c4
- 1990 srs light
- power drain from alternator on 95 lt1
- GM parts
- Bad Opti? Part 2
- Engine Running Hot? Check This! (Tip)
- Are spacers required for dual-pattern TPI intakes?
- AFR's...did I gain anything?
- LS Hybrid
- TPI removal made easy link
- A magic bullet.....
- Installing Manual Tranny
- Pic of dizzy clamp on TPI?
- A.c. Question
- performance chip question for late 86
- Clutch problems of some sort
- NEED HELP, ASAP!!! 700r4
- Clutch Hydraulics - Need a new hose and Questions...
- Installed a 3.75 ring and pinion and...
- 700R4 Input Drum. Pete K. ?
- PKE Deactivate?
- manual transmission leak..... need help
- stealth ram on zz4 engine
- Crank and sync trigger setup Lt1
- Fuel pump? Stalls on accel.
- RENEGADE has arrived (Crossfire)
- 88 twitches to the right on highway??
- Shifter cable
- Steering wheel swap help
- heavy duty cooing?
- 89 L98 No engine start
- that was interesting to find out
- Spark Module-Ignition Module ?
- Lowering question. Lowering just the rear?
- clear coat on C4 rims...
- Clutch Master & Slave -cast or stamped steel?
- Weatherstripping from a vendor named:Lonestar any opinions, or experiences to share?
- Interior Lights - No Shut Off
- Shifting problems on 84 vette
- Door hinge repair
- 1987 Coupe Dash Area
- What cam to upgrade to on a 91? Is it worth it?
- Anyone know how to adjust side windows?
- parking brake cable length
- new CFI-only forum
- rear XF oil seal speedisleeve?
- Rust Remover?
- Wide Band O2
- after a pillar weatherstip replacement sieds leak! Help!
- What grade Aluminum are the upper control arms?
- Any tutorials or stickys on how to change rear gear?
- Intake gaskets differences???
- where do i get a mail order tune for a 92 today?
- Is a '92 Vette OBD I?
- MINIRAM install vac questions
- opti bearing question
- Need the name of a good metal polish for rims
- Water pump leaking; replace Opti spark?
- 1990 zr-1 TO BRAKE LIGHT
- air pump removal question 88c4
- Water pump killing opti question about cure
- eliminate emissions
- Day time running lights on a '92
- '92 4L60 tranny question
- jerky, erratic reverse w/ stage III+ clutch and ZF6
- Aftermarket/Custom air filter setup for 85?
- oil
- tb coolant bypass question
- Clutch & Flywheel question
- Clutch Hose Fittings
- steering rack for my 86'
- SR runner help ASAP
- Whats everyones opinion on the latest head gasket repair/stop leak?
- Rebuild stock trans or ?????
- homemade injector testor
- Valve Cover Grommets
- Where to find a dizzy gear?
- A Tough Question
- ramps for 96 vette?
- Base manifold bolts???
- 89 rag top replacement parts are available where?
- No Spark won't start
- 86 won't idle
- 90 corvette zr-1 ltp light
- Where to find DM Flywheel for a 1990 6sp L98
- ZF rear seal leaks
- Best place to buy fel pro gaskets?
- 1984 Vacuum Diagram
- 1995 Convertible LT1 Vacuum Line Routing Diagram
- COMP CAMS, was wrong. Always degree your cam.
- Is it hard and expensive to upgrade a '92 to a 3.07 gear?
- Soft Brake Pedal
- L98 intake manifold bolt part number?
- new 86 vette owner:please help
- HEI plug wires - which brand do you use?
- clutch problem
- 92 stereo wiring diagram...help
- Which Lower Radiator Hose?
- 87 surge issue. When cold.
- Ars
- Is the LT1 reliable?
- a couple of Thermostat questions
- Intake changes next
- Adjustung Valves
- Steering Rack Update
- Time for some fun: NEWBY here!!
- code 41 in the CCM and no start
