- 88 wipers work on and off, what parts?
- Service ASR light
- Bilstein HEAVY DUTY or SPORT??
- Plastic trim repair
- OPTISPARK Prices Quality ?
- How do you adjust the parking brake on a '92 C4?
- Freon?
- Park lights without headlights
- Brass or Roller Pilot Bearing? Which Do You Use?
- I think I have a Headgasket Issue..How Hard to Do.. Any Tips 1991 L98
- Radio Standard Colors for ground and ignition
- Help with choseing Heads/Cam with HSR build
- LT4 Tic
- brake booster rebuild kit
- My so called budget built CA smog Legal Money Pit.
- Strange ABS problem
- What carb intake will clear stock hood?
- Freeze Plug on Drivers side front replacement?
- Bypass of Shifter Button
- 6x9 Rear Speakers?
- Got first vette yesterday! Will not start
- Cold air intake... worth it?
- Magnacharger for Gen 1 SBC
- C4 FRAME TECH. Talk about frame specs and flex solutions...
- Need headers
- Left rear wheel clicking
- What can a stock crossfire short block handle?
- RAM vs SPEC clutch '96 LT4
- 85 Misses and Stumbles
- TPIS vs Stainless Works LT headers
- New Cam Selection
- What offset muffler?
- 88 fuel pump wiring
- Problems with my Vette
- ahh -haa fixed stumble
- Lowering help.....Are Z51 cars lower stock?
- Water in Head
- Replaced bad lifter, now surge tank.
- cut out the screens on the mass air flow sensor ?????
- Brakes not releasing on 88
- Overdrive capacity + wheel question.
- headlight motor problem
- 93 Ruby 80K miles - Code 42
- how much pressure...
- 84 injector installation
- procharger qustion
- LT1 throttle body
- Fuel Pressure Regulator Diaphragm
- MR hard line connectors to stock line
- Are You Overheating?
- 1996 C4 No Tail lights or dash lights
- 86 stalls HEELLLP
- 84 vette crossfire starts-won't run
- 84 crossfire starts, won't run
- C4 LT1 losing power
- 93' starts running very hot very quick any help?
- Electrical problems
- What a difference a Gear Makes
- c4 87 Auto Transmission Issues
- 96 CE Suspension
- Need help with VATS
- keyless entry on 1988 vette
- tired of hearing about straight axle swaps. who can make the IRS work?
- Mavovette Motorsports C4 Insulation kit, what's the benefit
- Hit anouther wall
- TPI to LT1 Conversion
- WTB: Polo Green Front License Plate Filler (for 1992)
- pictures
- pictures of car I hope LOL
- Need some help/info on a clutch slave cylinder
- When should the white area on the front side mark be on?
- MagnaFlow Mufflers
- Need to drop your oil temp?
- 88 idle question ?
- 2 Head lights close 1 will not open ...?
- AC causes check engine light to come on
- Successful 86 Vette EGR/AIR/Emissions System Removal - For the curious.
- ECM wire list
- removing air but keeping egr
- New gauge cluster for my 85
- Corvette Problems
- Advance cam lower rpm peak..
- Need help diagnosing a no spark condition
- If I've got a rear main seal problem (86 5.7 TPI)
- Trw upper ball joint help!!
- Camber tires for better handling
- Problems with my new engine
- Muffler size?
- Rear passenger side marker light. Grrrrr!
- Corvette Vortex Rammer Cold Air System by BPP
- 89 wont start
- RE: Rear Wheel
- Just my luck What oil pan
- I need help!
- clutch slave cylinder
- LT1 throttle body experts; a question...
- C4 Remote Door Lock Problem
- A/C pressure switch
- Using carb cleaner on my '88
- 4+3 jumps out of 4th gear.
- what kind of headers
- Power antenna question on '92
- Radio goofy on my 1992
- CD player broke
- 1991 Pulsating Interior Lights
- replacing the opti spark
- My Vortec Head install w/ pics
- 89 With No AC Cutch Control
- Freeze plug replacement on 1988
- Foglight Improvements???
- How hot are coated headers? (JetHot)
- Exotic Muscle LT's
- Rotors for C5 Swap?
- Driver Side dip stick
- AC wiring?
- Mirror Glass
- HELP Injectors not firing
- electric fan??
- MAF cleaner
- HELP! Oil leak after Opti Change
- Top Plenum and MAP Sensor Fitment Issues
- acting up 89
- Great sounding muffler on my 94 coupe...
- C4/1996 Corvette Chipping: Good or Bad?
- intake and throttle body
- A new one on me
- Timing tape on a LT1/LT4
- C4R spoiler pics
- 89 Caliper rebuild. Help w/pistons, any tips?
- courtesy Lights
- You guys with the 383s, what plugs are you running??
- Any tricks to remove oil filter
- New shocks question?
- 58mm TB question
- Turn signal or flasher?
- EGR Removal
- 86 5.7 TPI oil leak
- 87 vette live in PHX,az do i need the headers with all the smog outlets ?
- EGR pipe caps? AIR system removal...Last questions I promise on this.
- Need Door Key for 1987 Vette
- 86 Roadster Water Pump Replacement Guidance needed
- Quick grinding noise when going into 3rd! ???
- Chugging along at low RPM
- AC Clutch replacement
- Are oversized radiators a good investment?
- 88 Rear pads and rotors
- Measurement Help. THANKS!
- reset idle after TB install
- Murphy's law on taps
- C4 fuel pump
- Confused about turn signal fuse!
- 94 LT1 transmission "clunk" in drive.
- Help need part name
- Any tricks to disconnecting steering linkage?
- Changed Water Pump - Got a little dirt/grime in fuel lines. Can I just let it pump?
- Magnetic drain plug
- Minimum air set procedure?
- Adj, fuel pressure reg. Setting.
- Big "thanks!" to LT1*C4
- Engine compartment noise - belt, pulley?
- C4 LT4 clutch slave cylinder
- LT1 Plug wires from Mid America
- does anyone know anything about the A/C pressure sensor? (ex. range 0-5v? 0 -180 psi
- Front poly upper control arm bushing! help!
- Courtesy lights staying on
- 89 power seat track question
- Where to find 1991 black seat belt set ?
- Long block assy questions
- super t-10 seals
- Willcox Summer Sale Starts today!
- Digital coolant temp vs. Auto temp
- Emissions/Air Pump System/Engine Bay Clean Up Removal W/ Pics - Need some Help!
- A/C Recharge Questions (88)
- If you know ZF clutches, I gotta question
- 4+3 short throw shifter kit
- My car hates me.
- 1986 corvette jumpering Ato B to reaf the codes...
- Hatch popping open -- while parked?!
- fuel injector ???
- 1985 runs good, won't start
- unknown a/c problem
- '87 to '93 seats, are they interchangeable?
- Headlight Motor Question
- Electric Seat Retrofit
- distributor history lessons
- Can someone tell me which wire from the headlight switch dims?
- Where does this brace go???
- Finally Got the New Clutch Assy' Installed
- Alternator installation in my 92 LT1
- 18" zr1 amold wheels?
- dewitts here I come/which water pump
- Big Problem HELP! Seat seized!!
- Strange Coolant Leak...It never ends
- HVAC says Low Freon, but it's not..
- Subframe Mount part # 10203412
- 1.5 intake 1.6 exhaust rockers
- Extension shaft housing seal... Replaced and still leaking, help
- Question- Will the Door Glass From 1984 Fit a 1991
- insterment cluster issue
- Targa to T Tops
- 89 vette wont start when warm
- no Front Brakes
- 96 LT4 Fan Problem, I think
- Fast Burn gasket and pushrod tips L98
- washing/ Flooded engine
- valve cover help
- LT1 help....
- Noise from a 1988
- Pull tranny or no ?
- Gear Ratio help
- new brake booster installed now car runs like s***
- 87 blower motor relay lost
- 02 sensor
- a/c compressor question
- Intermittent Stalling...Need Help
- coolant relay
- C4 roof repair
- 86 Vette Tire Sizes
- 85-89 Power Steering Fluid Capacity?
- front spring purchase for 84
- How much power can I make?
- clutch bleeding method question
- Pete K. 700R4 Alto Red Eagle or Alto Carbon 2-4 Band?
- 5.7 TPI situation...
- 1991 C4 Diagnostic Module Codes
- 1986 fog light lens removal?
- C5 Brake Conversion Brackets?
- Anouther Snag Pulling The motor out.
- emissions: any states out there that outlaw non-stock replacement parts (ie. RT cats)
- Coolant flush...Water boiling...Little help!
- 2.5" vs 3" exhaust
- Clutch Pushrod Retainer Clip
- 85 c4 vss question
- 89 - Need info on possible conversion to carburator..
- Is there a better way to flush my coolant out?
- Instrument Panel Lights
- Another stumle idle problem thread, help appreciated
- Calling Pete K. Assembling 700R4 Trans. Rear Mainshaft-Case Bushing Installed Depth?
- K&N Air filter + MAF problems question
- Roll center heights
- Rough ride with Bilstien shocks
- 84 blowing blue smoke
- opti spark problems
- 5.7 TPI water lines
- 1986 Odometer doesn't work but speedometer does?
- 1986 ECM location
- aftermarket HEI coils
- any need to reprogram ECM for a AS&M monoblade throttle body?
- DeWitts Radiator Questions
- fuel rail changes...any idea why an additional crossover tube was added, lt1
