- Help friends! LT-1 HELP!!!
- Frame diagrams
- TPS Sensor slotted
- Why a 160 degree thermostat???
- LT1 - Gas Pedal tough / stiff
- Engine noises
- 10:1 CR with Stock Cam?
- hypertech power chip!?!?!
- Where is the Service Parts Identification Label on 87 Vert
- My Car Still Ticks
- I have pictures of my $5000 '92
- 160 thermostat?!?!?
- dead in driveway
- driveshaft slip yoke question:
- 2003 Silverado AC problems! - Any help would be great!
- Changed trans fluid in '92 yesterday - did NOT blow up :)
- Automatic A/C Only Adjusts Temp Up, Temp Down Not Working
- Bracket race L-98 cam recommendation
- A/C compressor question
- Best economical tire to replace Goodyear F1's?
- Door Ajar Switch
- Low beam headlights?
- running rich
- Any good vette mechanics in frisco, texas??
- AC Delete Pulley
- Recovery tank
- Service ASR, SYS, and security. HELP!
- Cam shaft oil leak into opti?
- Where to mount a trans temp sensor on the trans?
- Idle air connector wiring problem
- Cam shaft seal leaking - impact on opti?
- Can an LS1 go into a C4 easily?
- 90' L98 supercharged - which spark plug???
- 4+3 throwout bearing problem...need help
- does anyone think that this will work? AIR INTAKE IDEA!!!
- Which oil is best for Florida's heat in a '94 LT1?
- IAC valve question
- How do I replace the thermostat in 1989 corvette?
- Photos...Uploading
- Please help. Ignition and A/C problems...
- Correct fuel pressure range?
- Now I'm Confused...more A/C Questions
- Brakes sticking
- How much lube do you put on a ZF TO bearning?
- Can I use my laptop to scan my vette?
- No power to starter.
- anyone used 255/45zr17 tires w/ 9.5 wide zr1 wheels?
- Ending Today - Race Ramps Group Buy Offer
- C4-C5 Brake change over ??????????
- Another Headlight thread
- OBD-I vs: OBD-II
- Oil Pressure Problem
- R-12 to R-134 ? How Difficult ?
- Yet another 4+3 slipping problem
- Problems
- need help with melrose headers please.
- 86" exhaust set-up???
- 1993 opti vented - piping??
- 88 Rear Transmission mount - 4+3
- HELP! canton road race pan and engine install
- Bose Radio Problems
- 1989 with ac issues
- Toyo Proxes TQ !
- 1992 gas gauge problems
- 92 LT1 fans
- My stumble stutter is fixed!
- Motor Mount bottom nuts coming loose?
- repeat LT-4 just stops running
- 58mm throttle body
- throw out bearing removal
- 1986 vette ac
- AC Compressor failure
- Should the O2 Sensors Be Changed?
- 1987--700R4 Park Issue
- reading codes?
- L98. Removing injectors from fuel rail
- Race Ramps Group Buy Update - Now at 15% Discount
- EWP relay wireing on 92 LT-1 ????
- Knock sensor locations on block ?
- 94 LT1 missing at idle
- Water Pump ball bearings
- Bad Clutch Hose?
- another intake question
- after three months it runs
- Harmonic Balancer for 383
- 1996 Corvette License Plate Lamp Help?
- 1 3/4 headers
- Oxygen Sensor Extension Sale
- Looking for a good high flow cat...
- 87 coolant fan
- how much smaller does a cam get when you go from 1.6 to1.5 rockers
- Rae Ramps Group Buy
- L98 money for mods.. need help
- Clunk at slow speed... single click.
- 91 C4 Clutch slave bleeder screw???
- Why no LT-x Crate Motors?
- NOS regulator from corvetterecycling.com
- Air Pump delete Pulley,68448 Header, brace fitment opinions etc... (Pics)
- Cheap lowering for my '86
- HELP!! computer problem!?
- National Top Flight Award
- Tuner in Georgia
- Driver Side A Arm (Replacment)
- Torque Converter Help..
- Problems with the idling!
- Clutch Compatibility Between 1993 and 1994 ZF6
- Water pump flywheel?
- Engine Question
- She's alive!!!
- What should vacumn pressure be at idle in drive?
- adjusting valves
- C4 Lift Kit? Raise 1/2 Inch?
- '96 Grand Sport wheel offsets??
- passenger window got slow tonight
- vacuum line from tb to under neath radiator cap 91'
- Looking for proven cheap hp gain 1988 L98 auto
- brake light question and vibration at highway speeds
- c4 rear end noise
- Racetronix / Walbro C4 Fuel Pump Kit Sale
- Transmission Shifts odd after gear swap
- Vortec HSR and Holley 58mm are here
- Iddle Drops when AC on.
- 87 vert - seat motor clicking
- new boschIII injectors are in...
- Does the primary fan run when the engine is off?
- 1986 Convertible Documents ?
- 86 Corvette with climate control
- Don't remember this ground. What is it?
- Rear end sound
- 1986 Bose Wiring
- ride height - autoslalom
- Anyone here race West Palm Beach Dragstrip?
- Air/fuel ratio gauge question
- 1995 Fuel Pressure Regulator
- What controls engine firing at idle?
- 96 LT1 AC Vents
- Should I get a Hi-Flow Water Pump for '91 L98
- What offset for drag wheels for c4?
- Fuel pump relay? or something else?
- Hesitates/stumbles at idle a little
- Help with a hard starting '85 please!
- Large Tube TPI runners
- Z51 rack on a 94?
- C4 Inspection Sticker ?
- Dash lights/fog lamps issue
- Loud noise / Backfiring Problem
- (94LT1 C100 and C 207 pin outs
- gas gauge
- 84 Catalytic converter Air pump attachment
- Goodbye Friends
- Is this Valve seal, PCV or Head gasket Problem???
- Header fit: Success or not?
- Cured Horrible LT1 Miss
- 84 Corvette – Power Steering Work II
- Has anyone EVER heard of this issue? (Transmission)
- Where can I buy new multecs or earlier bosche injectors for my 1990
- Fuel Pump help **PLEASE**
- Buget build please pick one acording to difaculty level and price
- need help with alternator.......
- No fuel !
- swirl marks????
- 1987 z52 Vette Wheel bearings bad!
- Pics from my LT1 Build
- Guacamole in my engine!
- FYI 84 Air pump removal
- 84 Valve seal Replacement w/Pics
- LTFT numbers way high
- Where is the "low end pressure valve" to recharge the air conditioning
- Now won't start
- Torque Convert lockup Question.........
- rearend mounts ovaled out?
- Motor moving FIXED
- A/C clutch
- High HC question - 85 L98
- Replacing rotors, pads and lines - trouble codes popped up for ASR & anti-lock brakes
- 86 irregular idle
- Is it hard to change valve covers on '92 LT1
- How long will the LT1 go?
- whyyy is my car running sooooo bad >:[
- Can you Read the Codes on a 94 with a Paperclip?
- Sorry for so many questions but where do I put...
- 86 Valve Seals
- Help! AC Problems and Questions
- what size chase/tap
- 1989 HVAC digital problem
- After 10 months ...im seeing the light again...
- Low Coolant Light On
- Help Fuel Rail Oring ID size (Regulator base to rail)
- rear gear swap
- QA1 coilover problem
- 1990 runs rough and lacks power
- Mobile 1 High Mileage 10W 40
- 1991 replace radio with after market
- More Problems...
- 96 LCA Enrg. Susp. Bushing
- Question about a head and cam swap procedure
- Long or Short Block
- Brake booster
- daytime running lights
- Thermo fans ok?
- 1986 AC - correct compressor clutch cover gap???
- Does the tach filter need to be grounded?
- does anybody know the diameter....
- Fuel injectors ???
- Weld C Beam on 92
- lt1 melrose headers will they fit l98 with an HSR?
- Where can I buy rubber bushings?
- 1.6 to 1.7 rockers= what gain?
- Black Cube on Wiring Harness
- Sealing the intake...
- Acrylic top repair
- Feedback request for ZF/CHS/Clutch prep
- Heads/ Cam/ Intake
- Transmission Issue? Help Please big issue.
- SM Flywheel with DM dampening, cant find the thread
- Bad Vibration with AC on? A more direct question.
- Torque converter?
- No Speedo or Info Guages
- EGR solenoid question
- 84 Vette Power Streeting
- AC Question
- 92 Vette_best dollar/hp gain?
- why batch fire? it would have taken .0001% extra effort, for GM, to make sequential?
- Dashhhhh-ouuuttttt
- looking for a good/reasonable (C4) mechanic in the sarasota/bradenton fl area...
- Retorquing head......question
- Miss at 12-1400 rpms
- Need clutch help !!!!!!
- 89 head light prob
- Best torque converter for street and racing
- New rear wheel hub/bearing question...
- Distributer ??
- 87 abs issue
- CorvetteHID.com closed down?
- ground location
- 93' LT1: Engine stalls out when hot.. HELP!
- Fastener delimma (Did I forget something?)
- oil leak
- 4+3 over drive relay
- Made a little video of my '86
- 84 crossfire won't start when it's hot
- how to set idle for 88, l98 help
- H72 speed sensor
- 85 Rear Window Hatch Replacement
- Valve Seal Install attempt
- Longer Banjo Bolt??
- AC Project -- Getting Prepared what do I need?
- Damaged rocker update - A/C question
- 1989 700R4 Leak'in
- C1 Restomod with C4 suspension
