- Move my alternator to the pass side
- Knock sensor, would you run it with THIS setup?
- 96' Drain Plug Question
- L98 Eats Belts
- Blown hose and opti survival
- Look what I got in the mail today, throttle body bypass kit. Pics too...
- Is 300hp possible with these mods?
- Turn signal inop
- taking Emission crap out?
- 88 AC o'ring ?
- Wow, that wasn't hard!
- 84 Digi Dash Blinking with Right signal
- 84 Transmission Problem
- Front wheel bearings? F-body replacements
- 85 L98 Instrument Cluster Scrambled
- Need some help
- brake hoses???
- 3 "Where do these connect" questions.
- Help with Part location
- AC Problems C68 Electronic Air 92 Coupe
- Tranny and rattle prob
- calling Pete K
- Help!!l98 oil pan removal in car???
- what is the thing next to the alternator?
- Car starting problem
- No throttle reponse-will not rev up
- Wont start, barely any spark.
- Spark plug tool for LT1w/ headers
- Question about Rhodes lifters
- what is the best brake booster to buy?
- HELP!! grinding after new clutch and flywheel installed!! HELP!!
- A/C Parts questions
- After the engine is hot, dont start imediatly
- Help from New Zealand..how do I reset computer to fix a/c problem?
- 383 questions
- Bad Vibration at 65 mph
- Looking for Optispark advice
- c5 powerduct airbridge intake (pics inside)
- Okay, what am I missing? Removing cargo shade...
- Have my trans pan off - what can I check without pulling it? Shifting issues continue
- What's the current recommendation for clutches for LT1 cars?
- miss at idle
- Belt tensioner
- 84 Cruise Control problem
- Has anyone had a new msd opti out of the box bad.
- A/c 101
- LT1 steam tubes
- Cold idle surge. +
- Good brake pads for my 94 LT1
- Clearing Change Oil
- Are you running GMPP Fast Burn heads?
- ZF6 lube (NEW inquiry)
- Water Pump Reluctant to Remove
- ever install an AS&M monoblade throttle body on an LT1 vette? If so, step inside
- Throttle body question
- Air Pump Squeeking
- Iron heads on L98
- 1990, stalling, idles at 1500 rpm
- Clutch parts info WANTED
- LT1 Reoccuring Misfire
- Where 2 buy a obd-1 scanner for the vette
- Dipsticks for L98s with headers
- 1990 hood emblem cinch nuts
- Tune-Up gone bad
- Fan motor
- Targa Top Restoration
- Car Running Finally (video)........
- Difference in Vaccum Readings
- aux fan on
- how do I adjust throttle body cable for a new TB install?
- Used CCM Not Working
- Old TPIS header style
- cats poping gas!!!
- getting a skip or a flat spot at idle
- Brake experts, question for you
- LT-4 hose coolant hose blew
- Coolant Temp Sensor Disconnected (?)
- problem with interior lights
- Thermostat housing gasket?
- Where is VATS Key Connector?
- temp gauge and cat convertor help
- Visor repair
- Engine dies under anything but idle...came out of no where
- How do I adjust my hood???
- Well My Friends It Is A Sad Day Today..I spun A Bearing
- Location od Radiator Drain Cock
- RPM's at 70?
- Horn(s)
- 1994 power seat problems
- manual fan switch 86 L98
- cam question
- waterpump
- 1993... front brake caliper retaining pin
- clutch carnage - pics mcleod twin
- Replacing the battery tray...
- 92 Headlight upgrade help
- PCMforless Question
- Backup lights
- Those who have rebuilt their steering column: what am I missing?
- Noisy front brake calipers
- 50w vs HID foglights
- What is the reason ??????
- 88 hood will not open
- Poor acceleration and nothing above 4k rpm
- Something odd happened with my oil pressure
- Ok I got a DTC 24 Code today anyone
- LE3 cam with dynomax bullets (sound clip)
- Bead blast intake?
- Hard start when HOT
- Looking For Cheap OBD2 Scanner/Reader
- stalls w/less than 3/8ths tank and hard turn or launch
- Ball joints are to big?
- Who thinks using silicon on an EFI intake is a bad idea?
- Rear Passenger wheel clanking/squeaking
- Question RE: LT1 Throttle Body Coolant Bypass, plug throttle body nipples too??
- Water Pump Oil seal - How do you install it?
- just another cam question
- why am i running hot
- 1995 Corvette Gas smell in crankcase. WOnt Start.. need help
- ATE rotors installed
- ZF 6 Transmission part 2
- bent a tie rod, need a new one, where find one?
- TCI 6x 6 Speed Auto
- Poor Brake Performance in my 1992
- Cam Play
- FAST classic tuning help
- Bizzare Coincidence
- Anyone local have this ECM???
- 160 thermostat
- trans cooler filter
- Son's 96 LT1 Needs An Opti
- lsx in an 89 vette
- Ffff coolant leaking
- solid rear axle - with spool question
- EGR/AIR delete question
- Where can I put a jackstand under my vette?
- HID in an 89 fog light
- Spark Plugs and Wire's Brands Hint's
- engine service light
- LS1 from 96ss/Z28 into my 89 vette
- I want to do my own oil change, first time.
- TrickFlow camshaft on an L98
- 94 vette won't start - Need Help
- plexiglass top 1991
- Racetronix web store
- Racetronix Fuel Pump
- Traction/Coil Overs
- Racing Fuel ?
- Bad fuel pump?
- Vacuum Question 94 LT-1
- Easier Clutch
- Erratic outside climate control reading
- Does it affect engine cooling…
- Serpentine belt?
- Big Bang theory
- 383 with stock LT1 heads?
- LT1 Emissions Delete
- Muffler eliminators
- Cant get my targa top off...HELP
- Front brake issue....
- please help 1984 running too rich
- Hard to start, won't idle and oil coming out the dipstick
- and the clutch is dead...427sbc
- I think I fried something :O
- Are these Melrose headers are not?!
- mastercraft LT1??
- slp
- Added pics to my garage
- Anyone got pics or describe the Idle Speed Screw?
- Tag light replacement
- Wheel question
- trans kit
- My '84 Vette doesn't start!!!
- Blower fan troubleshooting
- HKX Spring Rate
- Weak AC performance fix
- 1991 L98 stalls when hot
- Will LT1 Heads Work With Hot Cam ?
- 1989 6spd Rebuild to 396
- Corsa Outer Tips Functioning Video Proof.
- 1989 Losing power here and there
- ZF6 Transmission Question
- Got any new (or old) C4 mod/repair etc. write ups?
- how do i retract the IAC pintle when installing it into a new throttle body?
- Fuel Canister Purge Solenoid Question???
- Which is the Better 6spd ZF6 for a Swap in a 1991
- looking at crane RR.. would you buy these?
- rear gear change performance question?
- Disable upshift light?
- Rear Hatch Won't Open
- Adjusting idle speed?
- Cooling Fan Problem
- No Power to Fuel Pump 85 Help!
- Intake manifold gasket
- injectors??????
- MAF Question
- A chunk of my alternator just...fell off...?
- Supercharger Support Upgrades.
- something shady
- Mystery Connection
- AC problem
- Replace 1990 FX shocks Help
- 700R4 shifting issues
- 383 tunning ???
- Turbo or SC?
- Where can I get IAC Gaskets?
- Balancer clearance?
- Low voltage readings on bank 2 02
- ratios for D36?
- What is a good replacement distributor?
- Exhaust flange vendor?
- Radio died, drivers door loss of power.
- Is it easy to take an LT1 to a 383?
- Which msd dist pn needed
- Wilcox weatherstripping with stench of insecticide - anyone else?
- 89 c4 radiator fan prob
- 89 L98 hard start when engine is cold
- need break pressure advice
- Pictures of my super fine looking '84
- 1994 lt1 corvette need engine pics
- 1989 C4 Brakes are toooo good.
- Mevotech suspension parts any good?
- Here is my C5 up a tree
- vett leaving too soft...
- Running Rough (idle)
- Need help from someone w/ FSM - ASR TV adjustment
- Loss of all Power - Car just quits
- MagnaFlow Resinance
- How would C6 wheels look on a C4?
- shocks
- Oil Sending Unit
- Vette dropped the cat-back while cruising
- Evaporator or heater core?
- A/C yesterday, no A/C today
- Temp questions from new guy
- Where does this part belong??????
- Heavy Steering in my '96
- 1996 C4 Corvette unlocks by itself
- ignition problems and code 41
- Cam Size
- 96 NO electrical power
- Dyno tune
- head gasket question
- Turn signal question
- C4 A/C intermittent problem
- DeWitt's early C4 fan upgrade
- LT1 regulator o-ring size?
- 88 4+3 whining
- Targa top bolt?
- throttle body
