- Aftermarket woes
- clunkin and click 96 lt1
- so i just replaced my opti-spark
- Locating PCV Valve?
- Time for a new ECM?
- How do you check fuel pressure while driving?
- POLL >>> Crossroad choice..... Maggie or Head/Cam
- help with harmonic balancer
- Any A/C gurus out there?
- Lag at 2500 RPM
- 1988 4+3 Transmission Question
- Shifting Problems
- Potentially buying an '88 4+3...good idea or not?
- antenna help please
- should you grease spring ends when lowering by cutting spring rubbers?
- What can I do for $2 to $3k for best results?
- Brake pedal soft after bleeding
- getting to the t-stat housing on an 88 L98
- 0 drone turbo muffler
- starter relay location??
- HID kits and lights
- Replacement Starter Motor For 87
- rear end trouble ?
- Pink and Purple wire above the Brake Switch?
- 93 Clutch Slave
- LTx engines with LT headers, how do you keep your dipstick in ..
- Auto transmission
- temp gauge
- Code 44/13/16 bad plug wire
- Ignition Module Replaced and...
- engine temp
- Serpentine Belt Life on a 95'
- 89 Vette - Steering wheel off now how do I get it back on?
- Frustrated 89 owner - will not run
- 383 Engine build on a L98
- ZR6 Skip Shift
- Billet Valve Cover Oil Breather Question
- Camshaft ramp percentage
- 3 Row all Aluminum radiator: will it fit?
- Bought The New Block Yesterday
- 100k+ Mile LT1 + Head/Cam, Will It Self Destruct?
- Pwnage's 383 Build (Pics!!)
- 450CI/AFR235 New Best MPH
- 1991 Cooling Fans are Pulsing
- idle relearn
- Cam wore out
- Need to reduce exhaust noise
- which cam ??
- opti spark options today for 92
- Brake line fitting sizes
- Railroadman needs info
- Interior Air Vent Question on 90...
- Paper Clip Trick for Resetting Chrysler ECM
- Roll cage
- I need the Blue Print
- Throttle Body question.
- HELP needed with my 94 LT1 issue. (Please?)
- Optispark questions and advise needed lt1 94
- How do you pull codes?
- BBS Wheel HELP needed
- window has gone nuts
- 1990 derm repair
- Intake manifold bolts?
- Intake Question
- 4+3 OD Unit doesnt engage? 3k rpm @ 75mph?
- Dimmer switch issue
- brake and ignition problems 1990
- Anyone know if Camaro TPI L98 engine acc brackets are same as Vette?
- 91 needs 8 injectors
- 1986 350 TPI - Sealing the Head Bolts & Rocker Studs
- Is Greenwood Corvettes Out of Business
- stupid spark plug question
- Ls6 in 1992 6 spd - trans assistance
- Coolant bleeder valve
- ---thanks---
- 1986 TPI Engine - Screw-in rocker studs?ks,
- 94 lt1 lugs at speeds over 30
- Winter Mods...91 L98
- Cat Back vs Muffler Eliminators
- under dash relays?
- computer.
- GM Weatherstrip Part Number for B-Pillar?
- More wiring problems under the dash!
- 87' SS Choo Choo Camino Vs. 91' Z07
- Full Roller Rocker Arms
- Installed new fuel pump, now running rough...
- LT1 in 84....Help Needed
- zz4 cam into 89 vert
- ABS delete on 89 convert.
- rear end noise
- Lost my diagnostic codes book. Is it online?
- What To Do To Get Steering Feel?
- Just got Renegade # 0009
- tranny adjustment
- Do you know how much your car exactly weight ?
- ZF6 fluid
- Roller Rockers for center bolt L98 113 heads
- C4 Performance/Tech Issue
- Can't figure out my idle problem
- I need harmonic help!
- Heater fan speed control
- Ecm da2l blm locker
- Installing Accel Thruster on 85 / Harness question.
- VATS module shortage ???
- Stock Muffler
- Transmission Question (4L60E)
- History
- Cooling Fan Wiring
- Evap box and pullys, what do you think?
- plug wires/distributer cap?
- Steering rack input shaft leaking
- Please move my post "Cruise to the Woods with lots of pics to C4 General
- pointers and opinions needed: how do i replace my lt1's water pump?
- Best Way to Clean LT1 Idle Air Control
- My vette hops around when I hit a bump
- Carbon fiber C4 targa top skin
- Poly Bushings
- hard starting
- weatherstripping
- 92' C4 Leak
- automatic transmission linkage adjustment c-4
- Service Engine Soon light on
- Misfire after Opti replacement
- AFR 210 w/hooker 2149
- Oil Filter Adapter Cross Threaded
- Pass-Key® Help
- How to ID a 1987 Corvette 350 TPI Engine
- fuel pump
- HELP: 94 power antenna replacement. Working on it now.
- Question on brake fluid reservoir levels
- Cat-Back Exaust Systems
- Cooling System Issue
- A.I.R. Eliminate ?
- 406-409 ci thread
- 86 c fan constantly running - Problem found
- Still having starter issues
- 86 Throttle Body Sticking
- Dash pad squeaks.
- Turn key nothing happens
- 84 corvette brake problem
- Front spring removal...shortcut?
- tpi
- It Worked! $0 spent
- Plugging the AIR tubes at the Manifold
- ARP Head bolts
- Complete Steering Column
- Installed my new Corbeau A4s
- lowering/half shaft question
- Lighting Problem
- Floor mats
- hood prop
- Clunking Brake Noise
- Super quick Q spark/knock module for a 94
- anyway to make my throttle cable extend more for an aftermarket TB (93 lt1)
- Thought I was going to have to replace the opti…
- Hypertech Ignition Coil
- Any one had this problem before?
- C4 88-96 IFS Spec Question
- 96 style carpet for an 89?
- Tips wanted: Rebushing front lower control arms/sway bar
- HELP ecm kept buring out #15169278
- What is this?
- 93 LT-1 Running Hot
- Price of parts
- Want to polish intake, alternator and air pump.
- lt1 Fuel Pump Replacement (with LOTS of pics)
- AC will not turn off
- EGR failure code 32
- CODES acting wierd, please help!
- 1993 corvette had Booster replaced....failed in 4 months..
- Loud Boom Clunk Noise Came from Rear
- Rocker Arm falling off valve problem ...
- Passive keyless entry
- SMF/DMF balance questions
- Headlight module?
- Noise coming from rear of car
- Engine Rotation / Rocker Adjustment
- Dex-cool lawsuit. DANGER! FYI
- Headlight covers stop a pellet gun huh?
- Seatbelt light won't go off.
- engine missing and backfiring
- Timing done. Reset TPS?
- 94 alternator support brace bolt size?
- Head Gasket, Rollers etc......which one?!
- pke
- Rebuild L98 ?
- 96 Vette,..red or green coolant?
- Correct Spark plug , muffler and head gaskets for Supercharged 86
- those with lowered c4 cars what have you done to prevent bottoming out?
- Dana 44 pinion and axle stub oil seals - Need Part Numbers
- Fixed a really annoying squeak from my 92
- Fixed the Horn and then...
- 1994 LT1 OBD code 42 ARGH!
- Luggage rack remoival
- Converting Factory '90 Guage Cluster to Aftermarket Gauges - Help
- Dash lights, are they fiber optics? Help please!!
- Car starts idles for a sec than dies?
- 1987 Z-51 4 + 3 Overdrive wiring??
- diy headlight motor replacement
- Brake Booster going bad - Brakes still good
- Clutch pedal on 94
- Hood Release Cables
- got some new lights
- '89 starter makes really loud sound
- Exhaust
- 85 corvette will not start
- Enigine missing badly. Need help. 3 codes.
- Left over support bars
- 84 back on the road
- 86 auto coupe emission removal
- Wheels
- Anyone gone carburated and still fit it under the hood?
- 96 LT4 fuel pump problems
- leds
- 288 rwhp = 12.75 @ 110.27
- Thinking to swap to 16" or 15" or rear for dragracing - suggestions?
- No start, 1996 LT1
- Forged or Cast Crank?
- L98 roller block-Flat tappit block
- 1994 Vette shut down at hiway speed
- 91 maf sensor location?
- Question on ZR! wheels and Tire Size for my 1993
- Won't crank when hot.
- Need pics of L98 spark plug wire looms
- Silly main seal question
- C4 Corvette Exhaust
- Air bag sensor test
- Auto trans to Manual swap question
- parting a 90 vet
- 1993 with a 700R4
- 96 CE Front Lower Control Arms & Ride Height
- dash cluster
- Cruise Diagnosis
- Would this motor work in my 89?
- CQ CQ Vette HAMs
- Finally swapped exhaust out! w/pics!!!!
- AC Delete (using a TPIS delete bracket) then back to AC!?
- New Opti Installed and Now NO Fire!!
- 85 adjustable fuel regulator question
- injector help, fuel oder afterr parked
- fuel gauge issues???
- HORN HELP (still) 1986 Coupe
- Service Engine Soon?!! '87 coupe
- LT1 to LT4 conversion question
- Brand new key fob rattles inside...is this normal? *ebay vendor related*
- shes gotta couple issues
- Upper RPM miss?
- BCM Question
- Help with 91 that cranks with no spark
