- Number of O2 Sensors?
- LT4 Injectors: Where to Buy?
- For you guys using Hedmen headers
- Questions about coilovers and sleeves.
- Simple Bearing question.
- Replacing the fuel filter....
- Under hood lights 1993 Corvette
- Tire width
- EGR tube sensor?
- Help a greenhorn?
- Cruise control goes on without prompt.
- changed valve cover gaskets, oil change?
- 91 vette vs. 91 5.0
- Where to get front hubs for my 96?
- Cam swap...is it possible this way?
- ZR1 wheels, clear C5 brakes? weight?
- How Do I Test Injector Leak w/ Bosche IIIs
- Sledgehammer video!
- OK, What's the trick!
- anybody have any experience adjusting throttle cables inside ASR box, if so, step ins
- Need Help with Stumbling Problem
- Budget 383 Part2..... LONG STORY.....
- code 22 help
- transmission experts: '93 A4 TV cable setting
- HELP..A/C does not work with FAST XFI computer. Any idea how to fix this??? 93 LT1
- Wont start 2nd time!
- Anyone know of a 134a Condensor Source?
- L.E.D. bulbs
- Trip Monitor Controls
- SBC TPI question - Why is there a small heater hose going into my TPI manifold?
- SES/ASR lights
- valve cover torque?
- New Battery installed but still Low Voltage and Stalls?!?
- Advice for oil changes on ZF 6 speed
- 93 to 87 hood replacement
- Need Help-1st time vette owner-Ignition switch rod
- 1991 L98 runs rough at idle
- Clean Hatch Switches in the door panel
- Thanks Forum members, installing my LT1 injectors occured without a hitch
- Clutch Install Labor Rates
- Help me find a hose, Please
- Question for the 4l60E Pros
- Courtesy light failure, '88 Vert
- What do I lube my antenna with??
- window issues
- Need help in locating new master cylinder for 89
- Undecided on wether to change to a carb
- 96 LT1 help!
- Replacing motor mounts. Advice/experience
- Hurst shifter C4 6 Speeds
- Which way to go?
- 93 headlight swap
- Looking into a programmer
- Yet another LT-1 ignition question.
- Car Wont Start
- 91 AC Issues - programmer help
- Looking for some info on an engine swap
- Occasional misbehaving at cold start
- 1988 4+3 transmission problem
- 89 corvette oil pressure
- 1986 350 Choke Riser Tube Hole in Exhaust Manifold
- Early C4 Antenna wtb post
- what does this pigtail go to on my 1990 ?????
- LT1 swap?
- This is my Chip, what do I have?
- 1993 z28 ecm
- Serpentine Belt Issue
- Car intermittently stumbles with a code 33..
- Broken hood cables. Anyone changed them before?
- Trimming on my IAC housing
- Bringing a C4 Back to Life
- 1995 Parking Brake Won't Latch
- How quick should engine stop when you remove the fuel pump fuse (LT1)?
- ignition failure problems
- Rotor direction?
- decals
- What scan tool?
- Help with rear pumpkin
- how can i get my 1987 corvette into 13 seconds?
- Renegade is on & I dodged a BIG bullet
- What causes the loss of injector pulse?
- Quick question about the TB bypass...
- Roof Panel Hold Down Bolt Size
- dowel pin length ZZ4 cam swap ok?
- clock
- Not my day... forgot how to reassemble a headlight bucket (little help)
- Just picked up an '84, couple of quick questions...
- How do I remove a broken antenna mast?
- Oil Filter Adapter Assembly
- C4_0-60
- x-pipe or straight pipes?
- What part is this ?
- Reman Engine ID???
- Rotor temps?
- Please post solutions :)
- Blue Ford Orface tube in 90 A/C
- 89 overheating problems
- 1996 LT4 Upgrade Questions..??
- Used opti install
- Headgasket Repair done!
- Ars
- Dash Cluster DIFFICULTIES!!!
- Is There a Lingenfelter Counter-part on the West Coast?
- Ride Control Question
- Recommendation on shocks to purchase
- replacing my LT1 fuel injectors this weekend: can you share any pointers with me?
- door handle rod clip replacement - anyone have an easy way
- Let's lose some weight under the hood
- 93, manual, rear end sound! (I did search)
- sputters when put into drive
- My LCD display is faded.....
- TB part 2
- How hard is it to replace rear window?
- 84 Clutch Replacement
- '85 c4 electrical problem
- Removed ac, now the blower doesnt work
- To Chip or not to Chip, that is the question!
- Tire pressure sensors
- sport spring from VB&P
- Anyone have an electrical FSM ('91)
- BBK Performance Products 5014 - BBK GM TPI SSI-Series Intake Manifold
- Help!! Push Start Ignition
- My budget 383 track numbers!
- 1990 runs rough
- 383 Stroker - L98
- Headlights Wont Work.
- Davis Unified Ignition (Distributor)
- TDC dissy removed on wrong stroke?
- 3.73 Yukon Gears C4 1989 Dana 44 - Do I have the correct part
- Some on the forum have questioned me when I suggested using a ZZ4 in your C4
- Your WTF for Today
- 4+3 to T5 transplant?
- Adjustable TPS Questions
- Turn signal relay location
- "Infl Rest" Code
- Radio Exchange
- L98 post rebuild tuning ideas
- Accel Thruster install on 85 - work in progress
- C4 Supercharger kits
- headlight motor electric rebuild
- Why do the Vette 700R4s have a shorter tailshaft than Fbodys?
- first time cam install advice and parts
- Headlight motor keeps ah ticking..
- Best Intake For An 87
- Help!! Damn Lifter problem ! Loose & Tired Lifters ? they get loose by themselves ???
- Interior Lights stay on / won't shut off - FIXED!!
- 93 Air Cond/ Cruise problems
- retrofit C5 or C seats in a C4
- C4 1986 corvette wont start need help pleas.
- 88 C4 L98 build up question
- Fuel Strainer Position: 1995
- 1994 Powertrain Control Module
- Carbotech Performance Brakes
- Transmission shop recommendations -- Sacramento area
- 90 D44 install in 84
- Stainless Braided Brake Lines
- leaky new clutch...help!
- Mass Air Flow
- Resetting fan temp on 88 L98
- My home made porting job
- What is this wire?
- 84 Crossfire - Maintenance Issues Following Purchase
- Need Help Inspecting a Car In New Jersey
- 1993 auto trans wouldn't shift from 1st: you'll never guess what was the problem!!
- C4 Upper Front Control Arms
- Wiring for manual cooling fan switch
- Balancer issue and detonation, aftermarket junk
- How to remove a Steering Wheel with Airbag??
- surges in overdrive
- Can you just hard wire your fuel pump?
- Electrical issue - Amplifier
- 1984 Crossfire Codes 15 & 24
- car runs hot when idling with a/c running
- Po372
- how is the E-brake linkage set up?
- PKE antennas?
- What brand O2 sensor to buy for 88?
- 93 vette idles fine and dies when throttle is pushed, HELP ME.....
- Fuel Pressure "0" when key is off
- Hesitation under hard cornering
- 92-Accelerating problem (clutch?)
- My Current "Hide a key" Solution
- Post Intake Woes
- Spherical Rear Suspension Links?
- 1995 rear leaf spring trouble...
- Cam going flat?
- Why you should always check new parts (vid)
- tranny fluid
- A little engine problem...looking for diagnosis
- LT-4 questions
- Larger Throttle Body vs Stock: A visual comparison...
- [1985] Heater Blend Door jammed
- Weird Problem with Aftermarket Stereo
- cs130-cs144 alternator on L98
- Water pump hose (s) connection question
- Anything to make a car run better when it's cold?
- help me pick out a cam
- How did you remove your LT1's passenger's side O2 sensor?
- More noise
- C5 Brake Upgrade for my '92 C4...
- 94 LTI brown muddy anti-freeze
- Caliper bleeding order for a 94 w ABS?
- Missing some vacuum hoses under the hood
- 1996 will not start after sitting in the rain overnight
- transmiision cooling
- 94 Auto 2-3 Solenoid
- Removing and Re-Using LT4 Engine Harness
- starting a swap soon....dont hate me
- Sound Like a Bad Fuel Pressure Diaphram?
- 94 Has a miss
- 92 Convertible Shakes
- Suspension Grease Interval
- Any Brake Experts That Can lend A Hand Please
- Replacing EGR Valve in 96 LT1
- Qua1 for C4 for dragracing
- Drag Strip launch - what's best ?
- Leaking antifreeze
- Re assembly of 89 L98 top end. Please advise
- Service Ride Control light comes on
- Heater core just started leaking..89
- Failed smog test
- got boared this weekend What do you thing
- Brake Booster -- How to test?
- need help
- sys flashing on my dash
- Vette running like bad gas and then just died?
- securty shade
- Muffler opinions needed
- Transmission fluid change shortcut
- My top lid wont open
- 406 oil recommendation
- Iac
- headlight
- 3+ Years Since Dewitt's Radiator Install and Things are Heating Up Again!
- Retrieving error codes for 96 LT4
- Installed new brand master and slave cylinder
- Radar Run, my 88 is slow
- Best place to buy B&M shifter?
- Power wash (Car wash) suspension?
- Check those rear sway bar bushings ASAP
- FX3 Codes
- L98 Dies after start up
- Brake problems driving me insane!!
- RPO Codes 2002 Z06
- high oil and coolant temps...
- Target AFR At WOT ??
- Fuel pump harness issue.
- Clutch Click, Click, Click
- Clutch Master Cylinder
- Fuel Pump and Starter Relay Question
