- 94 modified corvette Engine
- Plugs and plug Wires Suggestions 1993
- Who's the Forum's C4 Wiring Guru?
- Hed-68448-Should i upgrade headers from 1-5/8 to 1-3/4 (pics inside)
- what parts combo did you use to make more power with a lt1 350 ?
- eandmy
- C-4 Lower ball Joint part problem....
- What lives under the rockers on a 91 coupe?
- Long tube header install - before / with / or after engine install?
- new guy, 1st. question-motor-
- Stuck on steering column removal (pic inside)
- Tranny output shaft movement ??
- Monroe Sensatrac rather than Bilstein FX3?
- EM Owners: How are your Exotic Muscle Headers holding up?
- Head gasket replacement on 89 vert
- Heater problem 89 vert
- Upgrading my roller rocker arms
- 421 ci sbc, [HELP]
- Clutch Slave
- What Gas to use in a 1991 L98
- Want some Cam recommendations
- 700hr 4 speed lock up diagram /parts wiring???
- Fuel Pump ?
- Anyone using the Delteq conversion
- ball joints and tie rods rob my wallet !!!
- lightweight racing seats in a c4? what seat? where do I get the brackets?
- Lt1 high idle
- 87 Charging Problem - Alternator Fine
- Power window question
- 15 cent Rear Hatch Solenoid Repair...
- reliable radiator
- L98 Water Pump pulley - mount with bolts or studs with nuts?
- '92 Keyless entry install. Any experience here ?
- Replaced my O2 sensor on my 94 now the service light soon comes on how do i correct ?
- LT1 ICM -vs- ECM Failure
- Hawk Pads, Performance Ceramic or HPS
- Low Coolant Light
- Where do these Wires Go?
- Head light will not go down untill cool
- 1991 TPI to Carb Swap???
- No start after Opti-job Codes 42 & 62
- Dynomax VT's
- no start fuel delivery issue
- LT1 Vortech Gearcharger??
- LT1 valve covers to fit over Rockers
- Serp belt lenght 96 LT4
- THROTTLE BODY - Correct Size???
- Driver door contacts hood when opening/closing door?
- Grocery Getter
- New LT Headers for LT1 and LT4?
- I know another question about HEADERS!
- Wipers
- Digital dash 85-89
- 1.7:1 roller rocker arms for SBC, they the same as the for LT1?
- My Dash Lights are Dim on One Side ['88-L98]
- Water Pump Replacement Video
- Stage 1,2, & 3 C4 Turbo kits available complete
- Selling my 94 LT1 to purchase a C4 ZR-1 what differences will i notice?
- 1995 vette with LT5
- 89 Front Spindle Mod for 94 F Body Hub
- Fuel Door Springs
- Not thrilled
- newbie w/ a fuel system problem.......
- 95 LT-1 vats problem?
- Diagnostic Software - shareware??
- ZF Scattershields
- Power steering not picking up
- AIP Electronics OptiSpark??
- Need c4 upper control arm washers.
- GM Wiper Blades for a 93 #12363800 hitting
- c4 start problems
- 91 intake manifold gasket replaced,fast idle
- L98 missing and backfiring into intake
- 93 Throttle position sensor
- GM perf. #10185064 valve covers fit with the Super Ram?
- C68 controls inop
- 99 TPS sensors don't fit 2007 C6 wheels
- Measuring Pushrods - How To...
- New bushings, new ball joints, but....
- '90 rims and Grandsport brakes
- Sparco Harness Bar
- Where to have checked out and repaired?
- Another C4 lowering question
- 1985 Rough Idle tried everything...Ideas?
- Does this look like a Dana 44 or 36?
- Thanks to c4cruiser
- corvette wheels 1985
- Radio Question: Am I Crazy?
- Quick Suspension Question
- Blue High Intensity Halogens
- dampers
- Injectors 1990 L98
- Post 88 Dana 44 on a 86 D36 Car ?
- fair price for 89 vert engine r&r central california
- LEDs in the dash
- engine front belt has lots of small cracks
- DM flywheel question
- MAF Switcheroo
- Alternator/wiring trouble (right hand drive)
- Acessory drive belt
- ECM for a 1993 Corvette: what are we talking?
- Smaller brake calipers
- Some Qusetions about my 87.
- 1993 won't turn off, unless battery is disconnected
- Hardtop Installation problems
- Died Again this Morning on the Parkway....ARRRGH!
- *** 9th Annual Corvetteforum Fundraiser for the children of St. Jude ***
- 1995 CCM / BCM Compatibility
- Throttle Position Sensor Adjustable 1993 ??
- Help wit ecu
- What is the best setup?
- Code 36 : MAF Sensor Power / Burn-off Relay Issues
- Blend Door Adjustment
- will C6 wheels fit on my C4?
- Freezing Door Seals
- wheels off a 2008 Corvette
- Do you like math ? are you saavy with c4 parts and shop prices , please do me a favor
- Alcl diagnostic problem ?
- stall speed torque converter
- 85 L98 motor what cam are you running
- Got a New 89 Vette ready for a build, I need guidance!! (Pics)
- Long Tube Runner Thoughts
- Where to buy runner to plenum bolt
- 89 Injector Replacement
- Help me with my LT1 high idle, out of ideas
- J55 C5 16 Einki's
- 87 Auto to 6 Speed: Do I need to change Prom?
- ls6 motor swap l98
- Bad Amps ?
- '91 Shoots ducks
- Some input on HP output with mods (LT4)
- New Injectors - Fitting
- 1987 4+3 sticks in reverse sometimes
- Motor won't match new mounts
- Dexron VI
- Best air induction on a L98
- L.E.D. taillights flasher numbers?
- I really need new rotors ! StopTech, Baer or Powerslot ?
- Car runs bad when A/C or Heater is off?
- Need some help w/ my mom's 93, couple of issues
- Low to no idle - LT1
- anybody ever see a '3 gauge' c4 autometer pillar cluster?
- Nitto NT555 Extreme & NT05
- cooling fan
- Blown Fuses, ABS light and no brake lights
- Need Tips on cleaning injectors + intake
- 1986 l98 motor rebulid?
- Brake System Flush
- HELP! Any Suburban/Yukon owners here?
- Need help with vacuum hook up on Holley throttle body
- Optispark, here we go again.
- 1989 corvette alternator wiring diagram - anyone got one?
- Front Oil Seals Replacement
- Corvette w/ continuous Problem
- weatherstriping
- Car start problem on 94 HELP!!!
- New column VATS issue?
- 1986 vette cranking but not starting
- 1985 vett torque converter stall speed
- 1985 350 L89 -> 383 - torque converter cover
- C4 Battery Replacement
- Keys...
- lt1 timing help
- Window Guide/Stop Installation
- C4 Wiper Blades
- So maybe my expectations where alittle high.
- C4 door panel removal
- Serpentine Belt - Which Way? '93-LT1
- ob2 to ob1
- Vented Opti-Sparks 92-94
- Fuse Panel
- Injectors - Stopping Fuel Flow!!
- What's the best way to change the 700r4 trans fluid at home?
- Wiring issues??? Please help!!
- Discontinued LT1 Engine?
- TPI Question
- Codes 15 & 64.... 93 40th anv.
- 1996 corvette wheel and tire question
- Brake M/C resevoir
- Smog test..
- Steering Wheel question
- knock sensor truble
- Converter slipping in lockup
- W/ one is good on boost?
- 350 build of a different type
- ground straps
- Optispark replacement - '93 LT-1
- Are the 92-96 Bose Speakers/Amps interchangeable?
- Next step on my 87
- Where to buy mem-cal?
- Precision Industries Vigilante Converter Installation : Done !!!
- New to here. Dash light problem
- wheel bearings from a newer year?
- Paging Pete K.
- Thoughts on New 383 Combination
- So I may go with the C5 brakes on my 84 right away
- Difficulty Pushing In Auto Gearshift Selector Button
- 96 LT4 Rear Main
- Which Flexplate do I buy?
- Replacing injectors - other parts
- how about a Injector Christmas sale.
- Headlight Motor Re-Assembly Setup
- 88 hood adjustment
- eandmy
- eandmy
- Are scorpion rocker arms good?
- No air blowing through vents
- Window Ribbon replacement
- Can you test a injector once you pull it out?
- keys
- Clicking in the rear
- Fuel gauge way off....2nd sender
- Flywheel thickness
- 1994 heater core question..almost out !!
- Aftermarket ignition upgrade for LT-1,OBD-1
- fuel pump capcity
- Anyone having done the T-56 swap please step in.
- Heads and Timing Cover Install
- Finally got my A-O Engineering intake on
- Vacuum
- Fault codes
- L98 pistons vs compression ratio
- Takes two tries to start car...?
- Am I purchasing the right kit to repair my headlight?
- Can i reuse stock wire looms with AFR 195 ?
- brake lines
- Cam spec question for my custom build.
- 93 corvette wheel offset...
- Looking for a little help
- New ARH stainless headers & Xpipe have arrived...
- Removing ABS From Drag Racing Corvette
- Non working hide away light motor
- Clutch Hydraulics
- ABS code 31
- Question about '84 fuel pump
- FOG LIGHTS and DASH LIGHTS problem
- Flywheel recomendations
- Overheating 89
- steering wheel removal trouble
- rpm difference
- Headlight Motor Repair......Internal
- How to properly lube the poly bushings...
- change oil light on, how do I reset it??
- TDC & Relationship to Crankshaft Hub
- thump noise in rear
- Cold Start
- C4 Sits = Dead Battery
- Frame clearance & aftermarket oil pan ?'s
- No voltage at tps ???
