- Hood lightening, who has actually done it?
- 1996 standard seat foam replacement
- changed oil last night
- Looking for Corvette electrician to finish car
- Catalytic Converter Problems
- Do I have Magic Injectors?
- replace convertible top
- Corvette Owners Manuals, 1993 - 2010 in PDF Format
- Differential Seal Leaking on a 96...Advice needed!
- Adjustable Fuel Regulators - 2 questions
- MAF sensor High and Low? (code 33 and 34)
- Fuel level electrical connector
- bad injectors?
- new member tech?
- motor mounts...for ls swap.....need help fast!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Intake porting
- 275/40/17's vs 285/40/17's
- Modulator Valve
- Rough idle / strong fuel smell
- To Port or Not To Port...
- Heim joint rear toe links
- Super Ram/219 Cam Are Going.
- what are A.I.R. and EGR on headers?
- Big Block C4s
- seat belt and oil change light problems
- Stainless bleeders
- A different kind of DMF question.
- 1986 Vette Exhaust PLANS???
- Maf 89 c4
- anybody see any benefit to adding additional bracing to the vert x brace?
- Correct o2 Sensors for a 93
- HELP sys on and off on LCD display
- Ignition Control Module Best Prices - for a 1993
- Electric water pump for L98 Reverse Rotation ?
- Best, economical option for replacing '93 engine
- 91 Roadster CCM Problems....
- 91 Corvette courtesy light problems
- want 350 hp at rear tires of a 1990 L98 Help
- One dayit starts, next day it won't. 1990
- ASR sERVICE LIGHT - NO TACH??
- 1990 Corvette Hardtop
- engine vibration
- ASR Unit Black Plastic Tube ??
- FIRST fuel injection phone number
- Dump ZF6?
- Strange Vacuum Problem
- Outer tie rod end blew seals
- 94 Lt1 PCM values. Help!!
- Anyone with 4.27 gears?
- need 88 - 91 L98 A.I.R / Alt bracket stud bolt
- Mufflers or not
- 94 Automatic to 6spd conversion.
- L98 Screw in crankcase breather
- L98 Accessory Bracket Diagrams
- Engine Updates with Pics
- Sensors, switches and valves for the LT1
- Paint bubbles on hood caused by P/S fluid
- Battery Tender
- Updates and a few questions
- High oil pressure?
- Simple ball joint separator
- [87 L98] Idle wanders from 690-900
- Shift light help
- Anyone running a Painless wire harness kit?
- How's this for a w3ird connection
- Msd 6al box
- steering wheel covers
- My engine project
- Measurements Needed
- Steering Wheel
- steering wheel
- Should i replace Master clutch cylinder when replaceing the Slave clutch cylinder?
- photos needed
- INSTALLATION of my WARLOCK 427 with Korvette4u Air Eliminator
- Dissconnect harness at firewall?
- 86 heater blower motor
- Disconnect EST to set IAC ????
- headlight still broke
- Dumb weather!
- 87 harness shot
- Moved up...questions
- 3.73 Gears - Wow
- Cut cats now running too rich
- 85 Charging problem
- Nitrous is Part way In.
- need more hp for 1975 Vette
- Seeking recommendation for 4L60 Tranmission Technicain/Shop in Tampa Bay Area
- 113 stock head specifications?
- Zf-6 speed spacer plates?
- Tightening 92 LT1 Rear Caliper Bracket Bolt's Torque
- When replacing fuel injectors... ?HELP
- Questions ? window and driver seat.
- LT1 New Engine or Rebuild???
- Separate targa roof acrylic lens from aluminum frame
- Lowered too much, have you damaged/rubbed front Lip of hood?
- 94 6 speed
- Pulling LT1 from a 93 auto
- Keys made...
- Easy way to get e-brake springs off
- home for holidays - forgot FSM need fuel/timing diog help
- Big Valves really worth it? (numbers/LTx geeks inside)
- Grease
- LS motor in a '93 coupe
- Sensor question
- Bought NEW radiator and now .....
- lifters question
- 94 no start
- Bed-in your brake pads
- Question about the sensor under the radiator tank. Thank You CF for all the help!
- 1986 vette transmissions..what to change to?
- Roll bar pics.
- LT1 & L98 exhaust manifolds
- 1990 Antenna Failure
- Header stud/dip stick bracket removal
- Magna Flow Exhaust effected throttle response?
- Help with 96 LT1 starter replacement
- A/C issues
- Is This Worth Buying For $1,300?
- Self-Help Literature
- ESC module on 1993 - what does this do?
- Throttle position sensor-84 vette
- Intermittent Tach
- Trouble shooting help
- Changing from 2.59 to 3.54 rear gear and pinion
- horn help?
- Question about '84 gauge cluster lights
- Hawk HP Plus Vs. Hawk HPS
- Super Ram questions...
- Ground points on C4? (RPMs drop when using power windows)
- 92 Vette stalls after warming up. Need help.
- Which is best cat
- 1989 cam or crank sensor?
- [1985] low voltage when in reverse and at lights
- Best Coil Over Kit
- Found Problem (*WITH PIC*) - Now how do I fix it?
- Look what santa brought me!! (lots of pics inside)
- Plethora of Issues, Need Help!!!
- Fuel Gauge Problem
- Ported MAF ends.
- Catalytic Converters
- catalytic converters
- Service ASR
- Clacking or Clicking Electrical? 1990
- Manual fan switch
- Heater/AC & Radio went out
- L98 Bracket Position???
- Slight noise, maybe pulley?
- L98 engine advice
- Slop in tilt steering wheel
- 93 lt1. where does the other end of my battery '-' cable hook to?
- K&N flat air filter?
- problems with replacement ECM
- power steering pump pulley
- Is that 3" or is is just cold in here (exhaust)
- Carrols Rod And Race Craft Conversion??
- Greasing Throw out bearing- ZF
- FIXED: paint, engine and interior!!!
- 6-speed shifter boot question
- New to the forum and need help!
- '86 headlights driving me nuts!! Help!
- 1990 seat belt light on
- Digital Dash to T/A conversion
- JAKE - Fellow C4 Forum Member -Doing OK?
- 96 LT4,..195 degree thermostat or 180?
- Seat belt
- What is better for strength? lt1 corvette or lt1 camaro block?
- 85' LSX 700R swap back on track
- 1990 passenger headlight repair....what'd I do wrong?
- Instrument Panel Issue
- Code 44 = Lean Exhaust Condition/Please Help Diagnose
- upper ball joint problems
- Help me out please
- Oil Specification
- Rear LED's still not working
- 84 engine replacement
- Third Brake light
- TPS voltage check/adjustment
- where do I find the tools to remove and install my WP oil seal?
- Caloway B2K engine specs
- Lost Link to "Idaho Corvette Page" for C68
- 4+3 to ZF 6 speed cost
- new to nitrous....
- mass air flow air-foil
- Wheel/brakes fitment help please!
- Valve Cover gasket?
- Headlight wires, positioning?
- No check engine Light Code 42
- dash instruments
- 84-87 Headligtht Motor Runs Backwards After Gear Repair
- 91 transmission, won't shift out of 1st
- LCD Dash Affect Idle?
- Almost seeing the Light
- How do you remove CHMSL (Center High Mounted Stop Light)?
- Merry Christmas to ME...Look what I got...WW
- Lifter Preload
- Please recommend a dyno tuner for a L98 in Central Florida area
- 2151 hooker with AFR1040 l98 angle plug
- Wiring Harness?
- 91 convertible, flutter noise from driveshaft or engine when chassis is flexed
- Exterior engine accesories HELP !!
- Difference in '84-'85 and '86-'89 Dash Gauge Bezels?
- •► ► MERRY CHRISTMAS & HAPPY HOLIDAYS from CHUCK CoW & CORVETTES of WESTCHESTER ◄ ◄•
- battery/headlight problem
- C4 Compatibility E15 Gasoline coming 2011 Nationwide
- Smog Advice High NOX - Opinions Wanted
- 18" ZR-1 Replicas now available.
- 1994 block for 1990 engine?
- removal of driver side mirror 1987 corvette
- water pump leak
- Happy Holidays to all!
- Viberation
- No electric power,even with charger hooked to it?
- Rebuilding 700r4
- TCC Lockup - Is this really true?
- Rear wheel speed sensors
- 92 water pump drive ?
- Could This be an Opti problem
- Starts right up then dies
- Update: I found the gremlin that was eating my O2 sensors.
- REAR SUSPENSION 1" LOWER ON LEFT SIDE, HOW DO i AJUST IT?
- No service engine soon light?
- EGR Pipe Rattle
- Am I jumping off the deep end? (VATS junk)
- 86 tail light wiring question
- 1984 Corvette Wiring problem
- Carrier bearing cap torque.
- My Digital Dash lit up like a Christmas Tree! - then died...
- Power steering problem
- What is involved in going to a Carb from TPI?
- OMG! WHAT NOW I blew my engine!
- HELP! Something is terribly wrong
- has anyone ever tried Eckler's or VBP ball joints?
- 1.6 roller rockers
- Do I have to align a new steering column before install?
- 94 - Better Brakes Un-Expectedly
- Help me modify a 1/4 to 1/8 mile calculator (math gurus)
- battery relocation to rear storage compt. anyone make a kit?
- Would you run a solid roller on the street?
- C-4 frame questions
- headlights cause fuel pump prime cycle!
- Selected bushings
- BatWing Bushings
- ZR-1 Wheels on 85 Corvette
- Zr-1 Wheels on 85 Corvette
- Max Horsepower thru a Richmond 6 speed ??
- What Ive been working on, carb'd 406 in C4
- Drag Radials talk , help me to make the right and definitive choice
