- 7/16" rocker stud length question
- SOCAL GUYS Supercharger Help
- TPS Install
- power steering pump install
- Which clutch for 95 LT1
- 1995 lt1
- Dyno Tune LT1
- Tire sizes?
- Fuel Pressure Gauge
- digital dash problems?
- Best Valve Springs for a 383 LT1?
- What Sensor?
- title info
- Heater box removal, firewall cover plate, take 2 (PICS)
- Intermittent no start (diagnostics inside)
- Fresh Air Intake
- Got the dreaded 4l60e no shift into 3rd or 4th thing
- Torque Spec
- TPI Gaskets
- oil pressure sender
- What parts do I need from a 95 Z/28 to convert my 94 opti 1 to a vented opti 2?
- Loose Tilt Steering wheel!
- 91 Oil Temp Gauge Always Cold
- 1995 "C" and "H" codes ???? battery drain
- 1992 no electrics at all
- LT1 TPS on an L98?
- How much are they worth? because I'm clueless
- Gear ratio change
- 90 engine codes
- Broken Shifter
- transmission stuck in park
- trans fluid
- Exhaust manifold gaskets - 1 3/4" long tubes
- engine temp. erattic 1996 LT1
- Corsa exhaust Leak!
- C4 LED & LCD Color dash upgrade kit
- PCM Connector Pinout OB1 Cars 94-95 from FSM
- Smog Pump Bypass?
- Crossfire to single tbi
- Front tire size for 9.5" wheels
- any negatives to heim joint sway bar links ? 93 lt1?
- 96 LT4 4.10 Rear End Final Preperations for Install PART 2
- ride height
- Valve spring pressure?
- header compatibility on my 86?
- Two questions for you guys today about newly acquired 94
- Cluster question
- 86 needs new shocks: KYB or Z51 shocks?
- Dana 44 steel cap source
- 87 L98 Superram Intake Swap - Worthwhile?
- LT1 Header bolt and gasket recommendations
- Waves in front bumper: solutions?
- which oil pressure sensor do i need?
- Overheating issue:::cant get system to purge
- Here we go again....
- High RPM's
- Headers are glowing???
- should I keep all four tires the same kind??
- Del Tech Coil Conversion???
- Wierd Vibration - Bearings, Ujoints, clutch?
- L98 Intake Manifold Question
- Afco aluminum radiator?
- Solid roller cam questions...educate me.
- Do Dymags break?
- 1985 stock oil cooler hose replacements
- SPC control arms
- Optima Gel Cell Batteries
- 89 range calculation?
- "check gauges" light is on now?
- Aluminum Chrome valve covers on ebay: will they fit a LT1 Corvette?
- Red Thread Lock
- Timing Case water pump drive shaft seal leaking oil Bad!!!
- Backfiring, rough, rich
- Heat removal and firewall cover plate
- Throw out bearing removal
- C4 Issues
- need to buy opti # 10457702
- 95 LT1 upgrades
- Front license filler - mounting question
- Reverse shaft slides out
- digital display issue
- performance for a 1984 question
- Add this fuel pump issue to the archives....
- -84 Th700 -> ZF6
- When cold fuel injectors are reading 12.0-12.2 on all 8 on my 94
- 86 tuned port surges & stalls
- radiator fan
- C5 exhaust Bypass mod
- cam shafts
- Do you think 92 octane gas will work?
- Erratic Idle
- lt1 head????
- Coolant temp Issues
- Running problems with my 93
- Squeaky Rear End - Ujoint? - VIDEO
- LT1 Flowmaster catback vs stock
- Complete C4 - C6Z06 brake conversion (How to and pics)
- Anyone Done a Pioneer Radio Installation?
- 1992 headlight no go down
- Lesson learned.......
- Found my o2 woes (H64 code)
- HELP!! 87 auto vette no rear brake lights
- No fuel pump voltage at start-up...
- 1987 Strange Electrical Issue Brake Pedal
- How should C4 brakes "feel"?
- Cooling issue with a car that has not run in 5 years 1994
- 88 motor pics
- 1985 cyl head opinion, what are you using
- HELP !! brake problem
- 1988 sport seat
- I just can't get rid of it.....!
- Wiper Adjustments?
- Used Racing Parts Websites
- Track videos
- Wheel offset question
- Grant Steering wheel in a 90-96
- DCS - Renegade Manifold Problems
- Engine Listing to Port?
- Anyone Ever Replace Ignition Switch ?
- Long tube headers surge
- TB bypass
- info needed-specs for 85 corvette heads
- Air in cooling system...again!
- 89 C4 Oil leak in back of intake somewhere
- oil pressure
- wiring problem 1993 convertible
- Sounds Like a Bomb Going Off
- just finished.....
- "SYS" Notification on digital dash--Help
- 96 Corvette 4.10 Rear...Does Computer need Re-flashing???
- Solid roller lifter question
- 700r4 Shifting Weird
- Please help !! Please help !!!
- courtesy fuse draw on 86 convertible
- one cooling fan on at 176F
- Bad idle surge after tuneup???
- Wheel paint!
- Coolant tempswitch?
- Exhaust clamp Help
- C6 ZR1 18in wheels will they fit our 1991-96 C4 Corvettes?
- Camaro Flywheel and Sprung Clutch Disk Review
- Tire help
- Adjusting door latch?
- Seat back cover
- Need pics of under the car ?
- Exhaust Clamps, Lap Joint question
- Header install issues...
- Which full roller rocker arms will fit under a stock 94 valve cover?
- LT1 front cover and oil pan gasket question
- On an LT1 (or SBC) what cylinder tends to be the leanest
- Help..Rear Strut Rod Bushings
- Newbie need help misfires...w/ codes
- 4L60E tranny problem
- Trying to track down small coolant leak
- LS1 in C4
- Beat by cobalt ss ?
- How long for 'learn'
- 88 auto trans. goes thru all gears in a matter of seconds
- "bar pin" and "tie bar" difference on lower shock Front mounts
- UNder Drive pullys ( I know I know)
- dead dash
- 700r4 dipstick tube (help)
- 86 side marker question
- Hydraulic Clutch Master Cylinder R&R Question
- putting in Driveshaft with problems
- Anyone tried RevMax Level 3 torque converter
- Throttle Body Coolant Hose Bypass - Cooling EGR Port Too?
- 94, with 21K, what fluids do I need to change?
- 1986 not sure if the motor has been replaced
- 93 Running real rough
- Fuel Pressure Regulator Install Tips
- Power brake booster
- Exhaust Question
- uh ohhh pics of my coolant :(
- Header Install Q's
- Motor Rebuild time... :(
- Upgrade Mods
- 2" inch primary & 3-1/2- 4" Collector Headers
- distributor large cap to small cap
- 15" on back for drag racing + MT ET Drag Slick
- Are their any negative affects of measuring only 2 cylinders with O2?
- 87 - recommendation on oil pressure sending unit brand?
- General questions for my current project
- c4 (84)wheels fit 97 s10????
- whats involved in switching to 4L60 with 5 prong terminal
- headlights wont fully close, need help.
- MAP testing 96 corvette
- Brake Fluid ?
- A/C delet bracket interchangable L/98-LT-1?
- Does anyone know the calibration curve of the stock 87 oil pressure gauge?
- Autocross set-up questions?
- Antenna Mast Nut
- Turn Signal Fuse Keeps Blowing...
- lights stay on
- 90 L98 1/4 Mile time estimate
- freeze plugs for 350's all the same?
- Dim Dash Lights
- Hood Lift Support
- Installed luggage shade, need help
- Front spring number?
- Rubber strap
- Sound resignator
- 1984 4+3 trans question
- Fuel injecotor wiring harness 'clip' on the injector connector
- Door glass anti rattle felt adjustment
- Can't find oil leak
- Weird noise......looking for some help.
- 86 L98 need a vacuum fix solution
- PLZ SOMEONE HELP ..Will a c4 wheel setup work on a C4? Measurements inside.
- New bosch 3's are in (with pics)
- Hard start when hot
- Removing Corvette Breadbox!!
- 700R4 to 4L60
- jaguar4.2
- Purpose of Callaway Aerobody Fender Vents?????
- Trans leaking cooling lines
- Front Bumber Air Scoop
- Corvette door switch
- ZF 6sp
- 383 Dyno Flat above 5,500 RPM
- Question about Z51 power steering.....
- Do the lt1/4 head and sbc heads have the same accessory mounting holes?
- Used nascar parts? Anything we can use?
- Make it tighter or lossing it up
- R-D Cross-bar, does it help??
- Ever heard of this?
- I am stumped over this.
- Removing the CCM for my race car. Effects/How to?
- Tranny Dipstick seal
- Personal best with new ARH headers
- help!!!!!
- Coolant temp grows quick
- Auto trans cooler. Where should I mount it?
- 89 L98 need tune or vavle adjusting?
- Door Panel cure with S clips ?
- Help please !! Newbie
- Few questions about my 86
- ATI Super Damper question
- Who has lowered their C4 and how is it?
- New Pillar Weatherstrip Problem
- looking to buy chrome valve covers
- Module 1 Code H 54
- How many hours do you get from your H4 Euro bulbs?
- To buy or not???
- Where can a buy a replacement hose online??
- New top end rebuild info ?
- What whould happen if i ran the wrong size release bearing
- Poor fuel economy.
- Updated on my Engine Build
- radio wiring diagram
