- Stuck Key and Seat Covers
- coil module
- 89 Corvette idleing rough.
- Is this brake booster good?
- Rich at idle, what to hunt down?
- Roller Rockers 89 L98
- Line lock, how hard ? Pictures needed
- C4 brake bracket question
- Comp Cams 268XFI HR13
- New guy with questions
- L98 Computer "Hissing Sound"
- Lower Ball joint for 94 LT1
- 1990 stumbles on occasion
- Help: passenger side dash panel R&R.
- 1994 halo toiletry hanger
- Engine replacement recommendation
- C4 air cond issue
- Bose CD section not working
- Update to LT4 Hot cam in 95 LT1
- Need help w/ MSD Opti on a 92
- 383 Engine knock?
- Headlights and dashlights
- Brake Booster Pushrod Screw Size?
- New aux fan switch, how to tie both fans together? And sensor/relay identification?
- Water Pump Length on 1986 350 Engine
- temperture get high when sitting in trafffic
- Doors lock with key in ignition
- 96 Coupe courtesy lights staying on
- where does it go???
- Hot cam kit install with the heads on...possible??
- '89 dashboard problem :(
- AC removers, question about heater
- wanna put c6 wheels on my 94
- 88 Rear speaker grill ?
- Alt bearing numbers
- How do mice get in a c4 interior?
- Advise..Is it Rockers or Bosch 111 "ticking"
- 94 LT1 A/C issues...
- horn doesnt work on my 93. neither button. but does work with pke
- Up and Down Idle
- KC4 Removal *Help Greatly Appreciated* for short filter
- '85L 4+3 OD Bypass Question
- Diy bigmouth
- Toledo Pro Hood Headlight Fitment Issues
- A/C and Heat vent problem.
- Accel TPI Base does not fit, big gap on china wall [PICS]
- 96 C4 Ignition Key Problem
- Anyone ever see/get the front wheels off the ground with a Dana 44??
- 1985 l98 engine build
- EGR Question
- Smoke coming out of catalic converters
- Trouble with SYS warning, please help...
- Ok need 90 model TPI guru
- OMG...you got to see what I found
- Screws needed
- Air Shocks for Rear Lift
- Outer Axle Shafts
- LTPWS issue
- 90 with hard brake pedal- brake light and service abs light on
- 84 won't turn off
- Parking Brake Assembly Rusted/Seized in Hub
- Very strange issue - Modified Firing Order?
- Looking for a tuner in Central NJ
- Clutch system is driving me nuts!
- Bought the 7 piece weather seal kit
- Rear Pad wear
- Ticking on acceleration
- Optima Battery Suggestions
- lt1 crankshaft
- help with gauges plz!
- ?? Resistor to replace Oxygen Sensor ??
- 1984 idle issue
- would putting a voltmeter on the alternator output wire, to test alternator,hurt any?
- ASM throttle body
- Pulled Codes on my 1990 Convertible. HELP with Diagnosis
- C4 Theft Mode Lockout
- Easy way to find you the final gear.
- Clutch Pivot Removal
- Edelbrock elite series 4246 valve covers
- Soft petal and hissing noise
- Tpis bigmouth purchase!!
- Carbotech
- Clutch master stroke length?
- Install Question on ported heads/1.7RR
- Oil Leak behind the Intake
- Clutch pedal stuck, I can't push it down
- Tranmission Pan Removal Convertible
- Complete C4 Engine Hose Set??
- Convertible top hatch opens at will????
- Engine Temps and A/C
- Need help with the 400 small block
- Could the timing marker move..?
- Upgrading '84-'87 headlights/motors to '88-'96 style. Help?!
- Brakelines from ABS system???
- Throttle body question
- Valve Adjustment
- 94 sport seat bladder problem
- cats after mufflers
- 4+3 OD not working
- LOW Fuel Pressure
- 1990 Bad injectors ?
- Trying to find parts for 96 LT1
- Runs Hot and Stumbles
- 5th brake line?
- S6-40 Rebuild
- Free intake but what throttle body
- Installed new water pump with drive coupler when the old one was still in! HELP!
- Shorty Headers for an L98
- Steering Rack Rebuilders
- Temp gauge reading needed for L-98 car please
- 89 a/c low pressure line freezing up
- 94 new door main weathertstrip installed-doors wont close
- Question on C4 front suspension on dimension
- Interior lights
- Something is plugged into my TPS and has a red light
- LS swap into LT1 C4
- service engine soon
- Need help installing keyless/alarm on '89
- Knocking sound in bellhousing
- 1995 Stubborn turn signal
- '94 Vette A/C Outside Temp Reading
- tach help 1996 LT1
- Still having prob. with hesitation/Bogging
- 1990 dash gauge cluster problem. HELP!
- Poll: Bullet Cats+Eliminators or Catless + Mufflers
- Sticky
- Parking brake light
- For us with BM shifter cables that melts. Stock cable rebuild
- 4l60e and torque converter
- 58mm TB crowd, where did you get your power couplers ?
- Has Anyone Else Re-tubed a MAF ?
- R134 Conversion Kits
- '85 L98 Exhaust Port Type
- 94 misfired & almost stalled + sis light
- New Issues After Fuel Injector Change
- Test temerature valve actuator 1989 auto clinmate control
- Engine Removal Question
- A/C woes
- Rough high idle after my underhood upgrade project, I am so bummed. Please help me.
- Selecting the best cam for my N/A 383
- Can a optispark vacuum harness be made with parts from local autoparts store?
- 1990 High Idle, is C68 rpm correct?
- radio color code
- Cooling fan problem
- o2 senser problems
- Quick rolling start video
- Ride Control FX3
- Power Steering Return Line ?
- Check Engine LIghts help? Ideas?
- CSR Electric Water Pump
- Electric Fuel Pressure Gauge Help...
- Anyone not used comp cams break in procedure..
- Saturday morning musings---oil pumps
- Where to find 1" to 3/4" molded heater hose for 1991?
- SS Brake Pistons
- Can 1996 and 1995 ICM interchange?
- Clutch is loose after sitting
- Cruise Control not working - I think it's the switch/lever??
- carbed ls1 on c4
- Interesting observation on 94 secondary cooling fan.
- Filed up the C4
- Group discount
- LT1 tempature gague and wiring question
- Perplexing Overheating issue
- Grounding points
- Pass. side headlight motor
- Is the AC compressor shot?
- 89 Falls Flat at 3500 RPM
- 92 coupe code 44 Swap O2 Sensors???
- ZF S6-40 1/2 synchro
- Zo6 wheels
- hit gas and falls flat on its azz
- Another Photo Quiz
- Need help identifying this engine part on my 89
- FSM says bad PCM - code 42
- Mass-air sensor 88 coupe
- 90 Dash Cluster Issues
- '85 Auto box
- LT4 Improvements
- 1984 dash problems, dead but not quite...
- Just about ready...
- Video on Headlamp Motor Removal and Repair 88-96
- '86 stumbles on initial acceleration
- Lower temp T-stat recommendations please
- Recap: My Opti-Spark replacement
- easy no brainer for you guys, question bout diagnostics
- ZF S6-40 shifting problem
- Low oil pressure when warm at idle
- Question about my FSM for my 1994
- Precision (Federal Mogul) U Joints
- how do I check to see if the coil is making spark?
- AC Compressor Self Oiling?
- LT4 in 91 swap
- LT4 with automatic tranny swap
- LT1/hotcam/valve springs
- LT1 water pump rebuild kit available??
- '85 TPI Starting Issue
- 4x3 no reverse
- Water Pump drive seals
- oil temperature sender/sensor
- HELP! 1985 L-98 Stalling Issue
- Zf s6-40
- 1984 TPS issue
- Locating my bearings
- 92-96 fender vent panels what plastic are they made of,what do you use to fix them?
- 92 Vette code 44 left Oxy. Sensor Cir. Lean
- no spark, no start
- High rev vs l-98/miniram
- Fuel Gauge
- Lemme's 350 87 12 sec (350hp) build - Stage 1
- Who sells best LT1 383 w/forged internals
- lt4 engine questions
- Hot Starting Problems
- Hard cold start
- crossfire to TPI
- Ball Joint Q
- <*> The Official DIY, Tech Tips, FAQ and where did my sticky go?? Thread <*>
- LT4 - Fuel Pressure Regulator Leaking
- Heater blower motor not working properly 85 vette
- ECM remanufacture
- what should my idle be....
- tranny trouble
- DO we really need a half page of stickies?
- Water on floor under front of engine 1992
- Flush before switching to synthetic oil?
- Vacuum bulbs???
- steering wheel issues
- Delrin Headlight Bushing sizes
- C4 Bolt In Solid Rear - Reviews?
- 1991 Overheats on highway only
- Heads up - Busted oil pressure sending unit dumps oil quick
- Security light/won't start
- I want it lower
- Fuel pump question
- 1984 corvette idle problem - PART 2
- rjrjs
- Vibration problems
- 89 with a miss
- Aero Turbine Exhaust
- anyone installed the melrose exhaust system?
- '95 Clutch/Flywheel fiasco
- O-Ring size
- New Aluminum Radiator
- My ABS is acting goofy.
- 1985 700r-4 driver gear
- What works best
- A/C Light blinking 1996 Coupe - Blend door fault
- 1984 idle issue
- *** St Jude Auction #34 Retro Poster Prints***
