- Torque Converter 10" or 12"????
- MAF Nitrous Kit's ??
- nos
- Ghost in the machine!!!!
- Kirkey Intermediate Road Race Seat Size
- What should I do with the optispark
- wiring harness, main junction at firewall
- PYPES users reviews?
- Just bought
- wiring size..
- LT1, Front Cover Seals, How Long Do They Last?
- I need of a new clutch slave cylinder, any suggestions?
- Cyberdyne Gauges?
- PCMforless Adapter to ECM?
- 700r4 blew need opinions
- LT1 fuel problem
- Battery Disconnect
- 1995 kills battery
- My c4 to c6 z06 brake conversion
- 1988 running at 225 degrees in garage today..normal?
- 90 Hood Rattle
- 84 will not run
- Help me build my 350 LT4
- #2 cyl spark plug hole striped.
- Speedometer Not Working!!!! Help!
- Steering rack replacement
- New clutch on '93 c4 w/ manuel , Banging noise from transmission? Help...
- Best oil and weight for '93 c4 w/ zf manuel transmission
- 1993 C4 w/ Bose system cutting in and out?
- Upgrading C4 brakes to C5 calipers
- 1991 Poor Gas Mileage after Injector Swap
- Brake Upgrade
- considering CFI to TPI
- Some rewiring...to do
- LT-1 no fire
- Power loss...Rpm gauge reads high
- 69 corvette side exhaust on a c4?
- Put new battery in and......
- '93 C4 with DRM 400 kit, i think, power cutting out when gas is low?
- Rod end misalignment bushings
- Bose speaker amps powered without radio in car??
- engine wants to die when I move my seat forward or backward
- Miniram/Bosch III injectors
- Sorry, headlight question for 84?
- 85 L98 - cleaned throttle body - every once in a while, idle stumbles a bit
- Cam and header swap
- 18 degree heads
- 84 Intake Manifold Gasket
- No spark? Confused
- Running rich or Cylinder not firing
- Glowing headers (need some help)
- fuel problems on my 96 LT-4... HELP
- RPO option code sticker on 1988 convertible?
- What the dust ?
- Which way do I install steering wedge?
- Which brand shocks are you currently running?
- Running with KYB or Bilstiens?
- she died...
- 1988 corvette..information center service ride select and low tire pressure??
- Corvette EGR Control Valve Relay Solenoid
- My 88 still has this little problem thats driving my nuts!!
- I also failed smog test HELP
- Will C6 rims fit on my '84 C4?
- Top Radiator Hose
- 92 lt1 running rich
- Longtubes or Hotcam?
- VIN number help
- 1994 C4 Coupe .....Optispark or what?
- Remove Standard AC Control on a 95
- wheel Size
- Gear Swap: Upshift Light
- Vette Doctors Performance New Years message
- Buck Banger Poll
- 1984 corvette VATS
- Value of D44 with 3.07's?
- Engine Shake
- What starters fit a 1991 L98? Will LT1 fit?
- Transmission guys I need help quick
- oil preasure
- Lt1 controled L-98
- PCV System Details
- 88 Bose
- LT-1/LT-4 questions
- Damsel in distress! 1992 LT1 and 1994 LT1 engine block
- CD player removal
- Blend Door 1988??? Elect or Vacum
- 1988 Wouldn't start ! Was security key
- LSX Engine Swap in my '90 6-spd
- Need help with TPI set up for engine swap on my 87
- 385 clip
- Zf6 install on l98?
- Fuel Line: replacement options
- LT1 Ping
- The heat wont blow but cold air does in 89 C4
- Dual Mass Flywheel, Solutions and Options
- Thoughts on an Oil Pump for my Race Car?
- Definitive wheel fitment guide
- Question about roller rockers
- Is it time to bump fuel presure
- cam advice, what will this one do?
- MAF Repalcements: Cardone or Micro-tech?
- header re-installation Question?
- Gas in intake manifold.
- Transverse Spring Vs. Coilover Lowering
- MAF compatability?
- 89 convertible top pop up.
- Replacing all new parking brake components, should i have to remove bearings (1987) ?
- wheel bearings
- How difficult woul it be..........
- 1991 L98 won't start
- Knock Sensor. Easy question
- it pays to diagnose, fixed finally
- head removal; bolts blocked by valve cover hold down studs
- changed alternator this weekend
- Heater only putting out warm air
- Another cam thread. Need some suggestions.
- Exotic Muscle and Power Effects - "Lichen" Thank You
- ceramic brake pads
- Distributor problem
- Headlight upgrade - Hella H4 + Osram 85/80
- Slp runners for 85-87
- Better airflow for the l98?
- ZZ4 cam vs 1.6 roller rockers.
- Any body try this build for L98??
- 84 crossfire driving me crazy
- 1985 Headlight harness length?
- 1985 Neutral safety switch problem?
- Opti-WP-plug wires-etc
- 87 ECM prom code
- lt1 with lt4 heads and hot cam
- Head and Tail Lights
- '90 EGR Solenoid Valve, electrical connector
- Power Steering Pump Diagnosis Install Help Needed
- headunit replacement(bose)
- clutch master cylinder USA!
- Please help! I got the shakes
- Compression test
- Opti spark
- 1993 Plastic brake booster (cracked)
- I feel like an idiot, which Optispark vent tube goes where?
- C4 Distributor
- LT1 Spark Plug Wire Questions
- Single plane too much?
- u joints.., replace proactively or only if they are broken
- timing chain cover (lower half) oil pan gasket where to get?
- what do i need to do to remove halfshafts?
- LED headhlights for C4
- Brake booster ?
- Looking to go 383
- Need safety bellhousing for ZF6
- Vibration Heard/ Felt in Pedal Upon Accel
- Hooker Long Tube Vortec Heads Sparkplug
- Looking for advice on putting Tuned Port Injection on my 79 L82
- New Spicer part #'s for U joints?
- HVAC experts needed for aftermarket FAST install
- Header results
- 96 lt-4 OXYGEN SENSOR
- Poor mileage/rough idle 1990 L98
- Headlights wont turn on
- 1988 c4 - need new heads - help please
- Anyone have PDF, links or other downloadable dimanuals?
- Removing Plenum
- Help, what camshaft should I use in my 91?
- Cooling System
- Nos?
- Just replaced my shocks! KYB.
- C Beam Removal Question
- water pump help?
- oil leak from back of engine...
- Transmission Issues
- Cam info
- A/C removal
- FX3 Codes?
- Back-up lamp switch GM part number??
- LT1 Intake manifold question: any advantage in having my intake manifold ported out?
- was fine when i put it away
- Metallic clicking sound on right side
- Twin Turbo?
- Benchtest a digital dash
- What injectors do I have?
- engine rebuilders: lightweight forged pistons?
- what hiflow cats are best for lt1 exhaust?
- MAF related issues
- Rebuilding 91 Headlight Motor?
- '85 vs. '86 cluster tach signal? Pretty please before I go nuckin Futz
- ECM / PROM Failure 1990-1993 Query
- Throttle body size vs A/F
- Thread size for steering wheel puller?
- igmition start problem
- LT1 Fluids and lubricants specifications
- Need some advice on engine oil weight for 398 stroker
- Cold air intake
- First 383 Build, need advice please.
- Hushmat vs Dynamat
- Header choices
- lt1 single roller timing chain option: cloyes 9-3651x3
- Early C4 Plastic Dash Repair
- 84 need help tilt/telescope steering wheel moves in & out
- coolant expansion tank has a oily ring
- She won't go into gear!
- Alternator voltage ?
- power steering/AC compressor bracket removal
- LT1 stroker crank which is okay?
- Engine swap info, please.
- Alarm issues.
- 1990 problems lays down at 3000 RPM
- Checking fuel pressure
- z06 rims fitament
- 1986 Torque Converter??
- Tuning questions
- Brakes
- Aftermarket Distributor?
- '86 Corvette "No Start"...With Codes!
- Engine builders in here please.
- chasing a short in the horn.
- Has anyone used Elliot Sportworks for porting
- 1986 Corvette Ignition Module
- Anyone Have a PN For Tailshaft Seal/ Gasket
- Ditching the Bose..Need Help
- Exhaust Opinions
- Blowing fuses
- 87 Hvac problem
- 95 LT won't start
- slow start 1991
- 85- how is instr panel bezel removed
- clutch issue, wierd symptoms
- C1 guy needs help from C4/TPI experts
- Brembo calipers questions
- Infiniti Q45 90mm body throttle
- tpi performance
- how to you lower the ride height
- Ported intake manifolds
- 89 seat bolster broken
- 94 Vette Front Bumper hardware
- Cooling Fan Harness for 93 LT1
- Performance upgrades????
- Exhaust Too Loud
- OBD1 or 2 ???
- Tachometer Capacitor Specs?
- Sport seat movement (or non) issue.
- Battery connector stud size??
- catalytic single or dual
- 86 Bilstein Rear Shock Questions
- '86 Corvette will not start! HELP!
- Does any1 know where I can get slp mufflers bullet II that will fit my 91
- LS swap
- 85 idles fine but dies when give it fuel
- 94 vette whats the difference between the Z-51 suspension vs standard suspension?
- upgrade 93 timing chain to LT4 Extreme Duty?
- why and how do you fix my 1993 door panel
