- Mobil 1 price ?
- Where can I buy NEW torx bolt kit for 89 tpi runner?
- R134a covervion does not blow cold
- what plugs, cap and rotor to buy?
- fuel pulstor 1988 where is it
- Any tips on manifold install
- Muffler
- NEED HELP ! Car wont shift/ engage
- HVAC Blower Motor Won't Start on 94
- Transmission Tunnel - Started a carpet fire!
- Solar powered battery maintainer
- Help Wipers and AC on at same time Blows AC clutch Fuse
- High idle when hot on my 86 coupe
- Console removal on a 87
- hypertech
- LT4 ARH Headers & pipes + Corsa Indy Pace Mufflers. VIDEO
- Brake/wheel/suspension parts
- 1991 air injection control valve.
- 1990 ac vents wont switch
- Teflon Washers
- Weird Headlight Issue
- Recommendations for MILD headers and CAM
- Is it reccomended or not to change from Regular oil to a synthetic ?
- Best L98 High Flow Cat?
- L98 running like crap. looking for ideas
- what lt1 mods to start with?
- Question about front spoiler - NEED PICS!
- oil leaking
- 1996 Corvette Ipod Interface, Any Help?
- MAF problems... 94 LT1
- help with throttle cable 1994 c4 automatic
- throttle cable 1994 c4 automatic
- Where to get exhaust manifold studs
- lt1 engine pictures
- headers for 94 LT1
- 86 won't start
- Miniram and EGR questions
- Ported plenum, runners = won't stay running
- Fuel pressure not holding.
- Hot Lt-4
- Are there insructions for taking out the Radio for a 86?
- Transmission Trouble
- c4 performance
- drilled or dimpled rotors
- 89 Vette with code 36
- help tpi tp carb
- Can the tape player be fixed without taking it out?
- LED bulb issue
- 94 LT1 code 44
- Injector ?
- line locks
- Dana 36 or dana 44 on my c4 1986 vette
- Fuel pressure regulator/diaphram problem
- C4 vacume issue
- Part Number HPS pads
- scanner
- cam replacement
- H72 code thrown..What are causes?
- scattershield for 85
- starter not disengaging upon turning off
- C4 tire diameter
- OBD1 Tuner in Atlanta?
- Help... how do you take apart the window switch from Bezel??
- Headers fro AFR 195 Heads???
- 94 manual trans. Does it have to be pulled to remove engine?
- Mass Air Flow Meter problems....
- more clutch problems
- Can you diagnose this engine problem ?????
- Right front clanking
- help
- Radio Info
- Brake Help Needed, Please!!! - No Brakes
- Corvette starting problem
- Battery fitment
- Optispark question
- Need help,95 vette keeps stalling
- Bearings Best Bang For Your Buck On A Budget?
- Fells like another shop is blowing lies up my butt... opinions?
- LT1 Overheating
- Tranny Guys I need your help!
- Smoke leak tester ideas
- Help Me Choose the Proper Clutch Guys
- TPI Runner part #?
- 1989 vette 136k trans shift hard from park to drive
- headlight dimmer switch replacement 93
- o2 sensor
- Intermittent Code
- 1989 Corvette floods after turning off car
- FI readings on 90 corvette
- help a.s.a.p anyone
- Front Wheel Hub Problem
- Machine Shop Referral SF East/South Bay???
- '93 'vette - Operating Temp Hesitation/Stall Problem
- No Spark, No Oil Pressure, No Start???
- code help
- Bypass/disconnect security system
- 94 Corvette LT1 missing under load when warm
- Seat back retainer clip loose
- What does this sound like ?
- What dies this sound like ?
- Still need help/advice 86 running/idles rough
- C4 Frame Dimensions
- 1996 hard start issue
- scattershield for 85 C4
- A stupid torque convertor question
- Best C4 ride combo
- 1994 corvette will not start, part 2
- How the heck does this happen??
- Radiator Hose
- (84) - do it yourself, exhaust system
- Installing CS130 in 84 C4 - Wiring?
- TAYLOR ignition wires
- 86 wiper switch
- I need help with myTorque Converter choice please.
- Looking for a Torque Converter
- Electrical problems/ car died today
- A/C and cooling fans...
- 87 Fuel Pressure Question
- 91 Fuel Pump question.
- 1993 FSM info needed
- Master Cylinder - rebuild myself or buy remanufactured?
- Anyone near Birmingham, AL willing to help me pull 94 engine (6spd) for $? Have lift
- Which steel braided brake lines?
- 96 LT1 tuning
- Have 2 questions,,
- Replacing Injectors tomorrow. Anything I should do while I have it apart?
- 93 ecm
- Cruisin with the new engine
- >>To all Engine Pros>> 'COMPLETE ENGINE SIMULATION'
- KYB rear shock install on 87 convertable
- Remove the ZF s6-40 blacktag to what??
- Sweet deal! Save 15% big purchase
- Rims question
- Bad starter, right? (video)
- targa top replacement comparisons
- 87 Wipers have a mind of their own.
- 1994 Distributor Question
- Oil cooler lines; HELP PLEASE
- Slop in the steering shaft?
- Need brake pedal "cover" that fits C4
- anybody ever get a 'crack' in the nose of their D44 housing. see pics
- OBD II socket replacement
- How about some tire advice!
- upgrade cam
- New convertible top installed
- oil consumption
- relay on firewall
- Has anyone done headers and cats on their LT1?
- CORSA 14115 Cat-Back on SALE @ AutoAnything.com - $777.75
- telscoping column
- ZZ4 and Vortech SC replacement motor!?
- News Allen's Stainless Exhaust on its way
- Lsx motor 1n 88 vette
- C4-- Misfire, occasional backfire- Ideas?
- '85 c4 vette blown fuel pressure regulator diaphragm
- Ok, here´s one...
- '84 blows main fusible link at random intervals
- Cruise control experts
- Building a bare bones 400
- Holley 52mm TB doesn't fit the air intake boot
- where to buy ECT sensor plug for engine harness?
- Help
- Really need help with braces
- Heater core shutoff valve?
- 1985 Theft Deterrent deletion, Courtesy light timer, and connector Identification
- Best Head Gasket Choice
- Is It Worth It?
- 1989 vette stumbles under load
- A/C cluster/horn electrical problems
- Confused
- Failed inspection,,, but i want to pass
- turn sigal issue???
- Fuel pump, agree?
- Hood Latch Handle Loose
- Shock height question
- Carrillo used rods, yes or no?
- How to retrofit a late convertible hardtop
- Engine stalls
- looking for an exhaust system for my 84
- 90 vet no power after warm-up?
- Pics request C6 5 spoke rims on C4
- Anyone replaced that pipe?
- Quick L98 timing question......
- A/C 0n 93 LT1
- can i put a v10 dodge engine
- Gas tank vacumn
- Rear Brake Line - HELP!
- Fixing cracked SMS
- Heat saturation and engine stumbles (LT1)
- 93 running hot
- Dic
- Bolt in Solid Rear
- LT1 Headgasket Replacement, a few questions
- Header Bolts
- Engine Builders: Need opinions
- Rattling in front y pipe
- 1991 L98 performance options?
- New to vettes-have a couple questions
- fuel neck leak
- Anyone Running the XFI 268 Cam
- 1987 4+3 Clutch Problem?
- Help with o2 sensor
- New head Light Conversion
- A/C Blower - not enough volume - anyway to improve?
- Changing bearing in 94 motor - with motor in car?
- Headers ,o2sensors and service engine soon light
- How do you remove the fuel filter in a '96?
- Time for catback exhaust upgrade on 88...best?
- 85 vett 520 lift cam what
- 1984 Crossfire - One injector not working
- 383 is here
- Question on Injector Harness '88 L98
- q: what is the sensor in my oil filter adapter on 93 lt1
- windshield installation instructions for 87 vette
- Electrical/wiring harness
- What are my long block options for 94 LT1 - ONLY want stock set up
- Easiest way to replace my battery
- 94 AIR pump problems...
- Exhuast manifold torque
- Fog Lights
- ASR components
- 8 grand tack numbers
- I need a Hot Cam valve spring, retainer purchase recommendation
- Cruise servo
- 1987 C68 Electronic Climate Control Blower Issues
- Security/Alarm Problem
- altenator fittment
- 1984 Corvette Crossfire Engine Starts, THEN IMEDIATELY DIES
- FX3 actuator rebuild?
- Need part number
- Should I change out the lifters?
- Your opinions on valve cover gaskets - good or bad
- Another 4+3 to T56 Swap For a 1985 Vette
- Help with an 89 TPI please
- Transmission problem clarified time for a rebuild
- 87 coupe - no cruise, brake issue and vacuum lines
- Low battery voltage
- Get rid of mass airfow "help"
- bad starter.
- 90 fuel filter
- Where is oil pressure sender on 94 LT1?
- Tune ?
- 84 Corvette popping through throttle bodies
- 92 Relay ID
- wanted TPIS Mini Ram intake
- poor acceleration
- cod 33, code 42 and code 45
- Leather Dye
- 700R4 questions
