- Lost keys
- Oil spec
- TB Bottom Plate
- Help My nuts are roasting
- It ran fine, rough and died within 5 minutes
- is my opti pin or spline drive ?
- 1986 Idle Adjustment?
- Fuel Vapor Canister location??
- Fuel tank Flush?
- Torque Spec Request
- Full Tune-Up
- Strange Clock Problem
- 84 CFI to TBI
- '90 Bose Radio Back Light Repair
- slick fx3's Superram (lotsa pics)
- Removing aftermarket alarm wiring from car
- Exhaust setup
- BBC c4
- Brain surgery... on a power antenna, who?
- Help please starting probs :(
- turbo 400
- '85 Electrical Issues
- rear brakes drag when rotors heat up
- Where is the oil temp sending unit on LT-1?
- Do I need to replace my Bosch 26lb injectors with 30lb injectors?
- Going from a dual mass fly wheel to a single mass
- A Couple of Problems
- 2002 camaro calipers fit c4?
- ZR1 , parts are worth what he's asking
- Anyone ever encountered this?
- 1995 fe1 to z51 spring swap> spacers?
- Harness bar plans?
- Fly Wheel
- Brake issues
- Uh oh....Lost my motor somewhere...
- A/C Fan low output at times
- AIR pump delete
- Stuck plugs
- 1987 Frame/Engine Ground wire?
- Brake line...hose???
- To Purchase a TC or Not....
- How hot does the exhaust manifold get?
- Iratic Idle after driving on the freeway
- Anyone know what cam profile came in this motor?
- Hot Cam kit, step-by-step how to?
- what stall to choose ?
- questions
- Swapping out My 4+3 to what?? Help
- Cant Get To Reverse Gear.
- lt1 with hotcam
- ABS pump runs when at stoplight.. '86E Auto
- Follow up
- Question: E85 in LT1/LT4
- Oil Change
- 86 abs removal
- Advice please electric , cluster , urgent
- Gas in oil?
- No oil in head
- C4 Buying help
- Got some dyno tuning done
- what is the best mufflers for my 96 vette
- C4 (vs C3) differential question: Yoke longevity
- popping noise from underneath
- max speed
- Redline Fluids
- 84 idle and power problem
- No Start Issue 1987
- Lt1 / l98!
- 1991 cold start problem
- 1987 Corvette custom chip??
- Issues with AC through vents
- Techron
- Cleaning Engine
- Part Number For Flowmaster 40's
- New injectors
- Transmission Shift Points??
- Finally
- Driver Information Center
- Optiless LT1(Picture)
- Help ac fan speed control
- Rear spring upgrade?
- Another Question Re: Air Intake
- Help needed clutch
- Exhaust For 1996
- c5 caliper parts list
- wiring diagram on cd
- Where's my water going???
- 1985 air hoses, vacuum lines & switches
- Brake booster squeal
- No radio sound
- LT1 Head Install - kicking myself
- Fuel smell / valve overlap?
- help !! egr + headers + o2 . questions
- Headers to match magnaflow exhaust?
- 86 Power Steering Not Smooth
- what spark plugs for 93 LT1
- Removing the rear diff - do I need to support the transmission?
- Question Re: Magnaflow LT1 Mufflers - Pipe Diam?
- Tune-Up
- Question on a 92 6 speed
- I will still drop in once in a while. 416 CID Z06 on the way.
- rims for 94-c4
- hard to start
- Dashboard help needed
- HELP NEEDED.. 90 sarts wont run
- Dash Light Repair
- Best complete engine overhaul (stock bore) kit?
- How to protect gas tank opening when removing gasket?
- 1990 Brake problem
- transmission fluid on passanger side floor
- comish4
- Smells Like Burnt Metal
- 84 Coolant Issue
- Head gaskets
- C5 brake install with pics
- Ok new rotors and pads the noise is still there
- what replacement surpentine belt.
- please help!! windshield wiper headache!!
- Shifting too early ?
- Cluster
- 92 - 383 Experience?
- Is my tach working properly ? (87 dash) Video
- Exhaust
- serpentine belt belt question
- Brakes went to floor
- P0151 p0152
- Coolant Leak
- Ready for Help
- Going to Buy Soon
- tpi question
- white cloud of smoke!! help pls!!
- FX3 Codes - 13, 14, 31, 32
- wont start security lockout
- C-4 steering rato
- Rebuilding & Replacing Motor Mounts with Polyurethane
- Vac Leak solved, I'm stupid.
- 96 lt1 air intake system?
- steering column parts
- 86 C4 with an 89 L98
- C Beam Bolts
- manual transmission failure
- 1989 Vacuum help
- Vacuum help
- Repair manual
- c4 rack and pinion - question
- master cylinder
- driver side fan not turning on
- Good thing Optimus Prime had the All-Spark and not an Opti-Spark
- Rebuild A/C compressor?
- Steering Column Issue
- Clutch Reservoir Cap?
- Engine missfires after 4000 rpm.
- VATS Problem
- No fuel
- Hood lift assists 90?
- 90% sure I just figured out what is wrong with the fuel supply on my 84
- Help!!!!!!!
- Difference between and stock TC rebuild and a heavyduty rebuild
- Need a good trans expert-4L60E
- Which shift kit do I have?
- Wisdom of powering down fuel pump?
- 4 +3 to ZF- 6 speed question for the experienced
- Transmission = Toast?
- A/C Leak Issue
- The future is.... well, ugly
- long block choice with tpi system
- Dana 44 case material specification
- C4 Instrument Cluster lights out & both turn signal lights on
- FX3 into a 1986 Vette
- To the GM engineer responsible for using the Oeitker clamp
- 93 idle issue
- Vortec engine block replacing a L98 engine??
- 1990 Cruise Control won't maintain speed
- Information for Charging A/C on 86??
- Hedman headers part #
- '92 Fuel filter removal problem
- Lazy Left headlight assist.
- TV cable issueson a 92
- Do electronic battery desulfators work? Has anyone used them?
- Source for AC clutch?
- A Hotchkiss Link Tale - a heads up - beware
- Atten Jesse Azzato
- Problems with rear hatch open button
- engine & trans oil question ?
- cooling fan questions ?
- Looking for UD alternator pulley only (LT1)
- OBX Exhaust
- Looking for Quiet aftermarket mufflers
- Just Bought A 1996 Corvette
- Top for coupe - What do I have?
- Inner tie rod
- Looking for tips to help duribility of 94 LT1 - track engine
- Master Cylinder rebuild question
- electric exhaust Cutouts
- Cold starting issues
- Dead dashboard after rainstorm
- My 1990 VS California smog
- Optispark type
- ls1 compatibility with 700r4
- Why do you need a tune with 30lb injectors?
- Automatic transmission banging and missing shifts
- I need an experienced C4 mechanic
- AC High Side Valve
- Starter Relay
- Transmission Time?
- AC Recharge Success Story!
- hydraulic clutch failure
- Planning Ahead Perf. Upgrades
- Back Pressure
- Where does this gasket go?
- 85 corvette running rich, black smoke and wont idle.
- Knock sensor location
- LT4 intake ?
- 4+3 overdrive troubleshooting fun
- Morosso 22101 Oil Pump
- MPG dropped after new injectors...
- changing weather stripping......Help please
- need help desperately
- New ECM or Not ??
- Loud Clanking Metal Sound When I Accelerate Quickly.
- Head Milling
- digital dash question 84-89
- 4+3 to ZF6 for the 421.
- 1986 Fuel Problem??
- Those who run 4.10s (Dana 44)
- Bosch 111 Injectors Question
- 90 front one side sits lower then the other
- difference between 84 and 85 bellhousing
- Sensors from my old Edelbrock heads don't fit my new AFR's. What do i need????
- runnung hot
- Tall Valve Covers for LT1, is Canton the only Option?
- Delphi pump sending unit
- ABS light 1990 coupe.
- 1984 Corvette headlights quit working
- Headlights
- Stand alone engine harness L98 tpi MAF wanted
- stalling 1992
- Need advice on PS pump and Rack/pinion
- Difference between an LT1 & L98?
- Has anyone modified a stock T-56 shifter?
- Can headlight motors install backwards?
- Info on factory zr-1 wheels
- 1996 LT4 Will Not Crank
- Headliner replacement
- Odd fuel pressure on a 1990
- Antenna Cable Replacement
- Any one put IPOD adapter in 86?
- Just got my 1st Vette & need some advice.
- hi idle dies when put in gear
- 1986 tranny cable
