- 84 steering column help! unidentifyable part
- Porting my plenum with pics
- 700R4 To T5 Swap Successful
- Rack and Pinion Bushings
- Ac bracket support
- OBX Stainless Header Install
- Injector o-rings
- FX3 shoks
- refrigerant refill
- what is that ?!
- process of opti replace + wires..pics inside
- my 1994 opti has no drive gear my new one has
- Rebuilding my LT1 fuel rail, O rings what size do i need? where to purchase?
- siezed ac line fitting...need some help
- "Normal" oil temps?
- Oil level sensor ?
- help with 1994 corvette AC Hose
- It's 95 degrees and NO A/C!!!!
- gas tank empty car reads 1/4 full... how do I fix?
- Heater hose that goes to manifold
- Fixing Bose Amps one more time.
- Tis the season for A/C problems
- 1995 stock
- Battery Voltage at Idle
- Speedo quit working
- 90 coupe intermittent hesitation.
- A/C Control panal
- help please no start after headgasket replacement
- half shaft - bearing wear ?
- Temperature gauge reading wrong
- C4 brakes question
- 4l60e Super Harsh 1-2 Shift
- Are these shocks
- What suspension do I have?
- Is Driving with a "Knocking Flywheel" OK?
- Ball joints, Upper and Lower, help.
- 95 Vette boggs then stalls out
- Fuel pressure needle bounces?
- #3 and #4 exhaust ports clean??
- Running Rich/Off.. headers?
- I finally got a Vette!!! But I could use some help with a few bugs.
- Anybody in the Denver area with a single mass flywheel?
- fuel rail question
- 94 Coupe Auto bogs in 4th
- 93 won't stay running, intermittent overheat.... Help!
- Runners & plenum
- 1987 head removal
- vettaid dash kit?
- Oil Pan Install Tricks
- Officially Frustrated with my '90
- It's ALIVE!
- wheels
- mis-shapen rear bumper? can i re shape it?
- 1994 lt1 asr
- Fabricated Sheetmetal Valve Covers
- 92 wont start intermitently
- 1987 no start.
- ... wow my username still active? - so I am starting up the '91.
- l98 idle surging
- Exhaust System ?
- headlight closes but won't open
- Super Ram Question
- ?'s about the C4
- Tach problems-89 readout bounces around
- Electrically challenged in need of help...
- Fuel Filter Replacement
- PKE programming help.
- Coolant loss problem
- brakes sticking on 84
- Not another headlight question!
- c4 mechanical fuel pump ?
- Difference in oil pan dimensions from L98 to LT1 ???
- Removing engine from 88 vette
- tbi to carb
- ideas for fitting intake duct on 58mm tb
- 1987 head removal
- 86 TPI - Location for Water Temp Sender
- Help me order the right MSD wires please!
- car shuts off
- Trying to temperature sending unit for my 1990.
- anybody know where aboatguy has been?
- who makes a bump steer kit for c4's ?
- Some questions 92 LT1
- 1993 Corvette
- AC - Fix my stock R12 system or convert to 134a?
- Ron Davis Racing Radiators 2 Thumbs Up
- torque converter question
- should i get pcmforless tune?
- T56 install & modifying the "C" Beam
- Can't get gear out of headlight motor on 89
- fuel injectors leak
- LT1 Engine rattle, bad cat?
- socket to get opti cap off
- 93 corvette new opti won't start
- 90 Fuel injector Issues
- Trying to solve idle surge problem, somehow created new ones
- McJacks Long Tubes
- Suspension rattles
- 91 Corvette L98 No Start
- Radio Woes
- Gasket removal
- Pulling Fuses
- A/C blowing hot air
- Use of permatex thread sealant
- Stock crossfire intake manifold ports.
- Superram or a first TPI intake
- A/C Not Moving Air, Broken Blower Fan?
- 1986 Corvette Ignition problem
- fuel pump
- 1993 issue
- wont start
- 1994 corvette water pump bolt problem
- Where is the Fuse Box
- new booster - passenger brake lights out
- Which scanner for 1985 Vette
- Should I remove Fuel Vapor Can and relay
- 1987 emergency!!!!!
- 1996 Starter help
- Reparing & Replacing parts on lower center section (pics needed)
- You Won't Believe What I Found (Optispark)
- Plenum removal
- Shifter knob
- 90 L98 Intake Manifold Torque Specs
- F.A.S.T wiring & Mount spot
- '93 Lt1 A/C Compressor not running
- 1986 MAF relay part numbers
- 85 runs HOT with aftermarket fan, switch, and 160* stat!
- 89 conv rear pin latchs won't release
- running rough...
- Anyone with a 1984 FSM, I need a little help
- 96 in diagnostic mode
- Trouble jumping the A / B pin
- 89 L98 - Replaced distributor - lost correct position to re-install - help!
- L98 fuel issue
- Broken headlights - HELP please!
- Cabin filter
- 1985 c4
- Shocks
- How to measure piston size?
- ASR Light
- 1985 supercharged
- Click While Turning
- Overheating?
- 94 No A/C out front vents
- L98 Head Gasket
- C6 Wheels For 88 Corvette?
- 88 front tires
- Step on gas and no power
- Reset Memory on A/C
- egr
- Cat question for those in the know?
- where to get rear bushing kit?
- Hood jammed tight a Richards hat band
- 1987 Pre Cat Plugged. To Straight pipe or not to Straight pipe?
- em longtubes 1992 lt1 vet oxygen sensor question
- '88 FI problem
- Steering Column fix (Tilt)
- Thread sealant
- Stub shaft seal kits
- leaking front seal
- fuel
- Stripping Powder coated wheels
- intermittent stalling, I'm stumped and need help!
- A couple of questions
- New fix for rear hatch defogger...
- Abs module relay test
- Please help! Going crazy. 92 LT1 Engine problem once heats up
- New 1986 Corvette owner with questions
- why won't anybody help me
- Pke
- 90 A/C issue
- Please explain to me the concept of fuel pressure
- is the 89 vette a long or short water pump?
- Idle is rough 1986
- 1990 corvette car turned off/car wont start
- 1986 Engine Replacement
- 93 lt1 engine oil temp (analog) on instrument cluster doesnt work..how do I fix?
- '86 L98 injector size for a modified engine?
- Replacing a 96 LT4 with a 94 LT1 (Temporarily)
- FAST XFI 4 barrel throttle body
- bilstein with or without z51?
- How much material should be on new aftermarket clutch? (pics) new one seems thin . .
- intake port design
- Thump, thump, thump,...
- 1989 Corvette w/L98 TPI
- New Corvette owner, have ????
- Battery disconnect ?
- Another Fuel Gauge Thread
- optispark keyway not working, timing is off wtf
- replacement shocks for 93
- Another Back_Light Problem
- Looking for a Dash bezel. Around speedo
- Help! No Start
- '86 seat belt - stuck tensioner
- Crank after air bags deployed ?
- L98 plenum and runner question
- A/C compressor squeals when first turned on...Help!!..WW
- HAL/QA1 shock make squeal/chirp noise
- 85 manual to carb no overdrive
- Help me read my plugs
- Pete K
- Great News..For those looking for EGR temp switches..
- Recommend a Dana 44 rebuilder.
- Knock Developing
- Miniram Results
- 88 vert.
- What are you running in your crossfire?
- Troubleshooting Opti Codes
- opti spark components
- Need some input
- Stock vs .....
- OIl smells like gas
- Did a tuneup, now it misfires (94 OHV)
- Coolong fan
- 1985 Heater core bad - Radiator next?
- 1992 with base brakes, front runner size help
- My Mosquito repellent
- Header Bolts
- 93 fuel pressure problem
- Belt for UD pulleys Part 2
- do i need a re-tune with these new parts?
- Positive battery connections on a 96'
- How much front suspension travel
- Loctite those opti rotor screws
- Starts then dies every time
- Intake Air Temperature High....
- Distributor
- externally balanced 383 and 6sp flywheel?
- 1989 _All smog removed....HELP!
- Quad Driver Module 1 Code 26
- 1986 Vacuum Check???
- Parts
- ac delco or auto parts fuel pump
- Air Filter
- DERM SIRs Connections
- C5 power steering pump fit early C4?
- Racetronix Fuel Pump Kit Questions
- 1986 Cooling Fan Switch
- Do I need a new ABS Modulator for my 89?
- Do half-shafts and driveshaft need to be balanced?
- FX3 Shock Plastic Gear Source?
- Hesitation during acceleration
- Dust / Moisture Shields inside Front Wheel Wells?
- Lost keys
- Oil spec
- TB Bottom Plate
- Help My nuts are roasting
- It ran fine, rough and died within 5 minutes
- is my opti pin or spline drive ?
