View Full Version : C1 & C2 Corvettes
  1. Shift light recommendations
  2. Need some date help on a rear end please!
  3. Professional Detailers Sampler Kit $25.95
  4. Door glass
  5. Putting Body On New Frame
  6. Survey Says, What else is needed??
  7. Good Experience
  8. Pulled the tank, a couple of questions
  9. Need to find 'head' plug
  10. another brake light problem
  11. SEARCHING FOR 1st BORN, 66# 194674510569
  12. Are Carter AFB (aftermarket) & Edelbrock Performer gasket Question
  13. C2 for my wedding?
  14. Vette Brakes Front Mono Spring Install Problem.
  15. Need help with rim sizes, C1,C2
  16. original Bill of Sale for '65 Vette
  17. Bob Dye 57 Corvette Race Car - Herbie The Love Bug
  18. Early 64 to 67 door conversion on vert
  19. Off Idle Stumble
  20. Anyone Know Of Corvette Country in N.C. ?
  21. One of the funnier comments
  22. Has to be another e-bay scam
  23. Fuel Filter crap question - identify?
  24. any c1/c2 members own this retro 67? (built on a 92 corvette platform)
  25. OT.....A gun with every vehicle purchase
  26. Hood release cable replacement
  27. 1963 color chip chart
  28. "Pinks" Corvette Drag Car Stolen
  29. How do you tighten loose clock needles?
  30. Hydraboost in Big block car
  31. 64 coupe trade
  32. AFB Gasket
  33. Need some info on 63 distributor !!!!!!!!!!!
  34. Need a measurement please
  35. Tail lights
  36. Interesting 66 Trim Tag
  37. What driving a CORVETTE says about you - so they say!
  38. need help on price
  39. Best way to check alternator
  40. Mystery engine??? Can anyone help identify these numbers?
  41. hole in drip rail
  42. New Wheels Question.. again!
  43. Has anyone used Evans Coolant ?
  44. 64 Vette is finally done;
  45. Flywheel inspection cover mods for new bigblock??
  46. 1967 ignition switch source
  47. Checking the front wheel bearings
  48. engine rattle final update
  49. Vibration Problem
  50. Wind Screen
  51. CAUTION: Bolt-On Knock Off Wheels Torque
  52. Booster Recomendations for LS2 Swap
  53. Its Friday,time to share a smile!
  54. Pinchweld cap installation, 66 coupe
  55. barn find 1954
  56. Sway bar help
  57. Barn Find 1954
  58. '57 FI Top Ignition Shield fit a '61?
  59. Rebuilding an Alternator
  60. front sway bar diameter?
  61. What do you call this Fiberglass piece?
  62. Leaking Carb Lines - Help!
  63. by passing my heater
  64. Tounneau covers
  65. Surprise, surprise....
  66. OT: Factory Five GTM Supercar
  67. original hardtop/headliner colors
  68. Insurance
  69. holley carb jetting
  70. Front sway bar question
  71. Recommendations for engine broacher and stamper
  72. STV valve on ebay
  73. Need image of 1966 battery installation
  74. Original owner
  75. leak at water heater under dash /pass side.
  76. 1961 Sebring Corvette
  77. Dash Pads
  78. lowering back of a c2
  79. Half shaft phasing
  80. '62 WS Washer
  81. 66 vert top issue
  82. dash board light intensity
  83. Hey Paulie.....
  84. pins on transmission rods
  85. Neat '62; odd marketing approach.
  86. Moving,need cars transported
  87. Parking brake boot install
  88. would it work?
  89. Tri power air filter screen
  90. Tri power secondary diaphragm
  91. anyone replace a 58 corvette firewall ?
  92. Tach problem!!!
  93. Pursuit of a 66 barn find
  94. Need help! My dad has been a bodyman for 40+ years but never worked on a vette!
  95. New long-life battery reccomend's?
  96. '60.. weird coolant leak??
  97. Bench Checking a Fuelie unit
  98. repairng wire ends
  99. Santa Barbara events
  100. Starter "Fluttering"
  101. installling driver window 1959 Corvette
  102. 59-steering box adjustment-help
  103. STEERING in a NEW DIRECTION
  104. 65 holley
  105. 66 BB two piece idler arm???
  106. '62 Color Help
  107. C1 Al knoch tops - where to buy?
  108. Wheel Backspace For 15 x 6 C2 Wheels...
  109. K-H steel wheel date/ Hubcaps and spinners
  110. This is a good deal on a 64 with street shop chassis
  111. Value of 67 conv. semi-barn find?
  112. Pict request please,
  113. damper ID
  114. 1966 Holley 650 carb machining work - Who?
  115. Ignition housing doesn't match cluster panel - what do I have/need?
  116. HMMMm... NO PARKING BRAKE STOP PIN ON THE 62?
  117. '54 update w/pics
  118. battery ground
  119. 66 leaf spring color
  120. AN fittings and steel tubing
  121. HELP! C1 door latches
  122. Brake Problem...Help Please
  123. Need help with strange screws!
  124. Here's an interesting custom '67
  125. Any One Ever Build A Frame
  126. 63 wiring diagram
  127. 62 white with red n on matching # what's it worth?
  128. Bolt on Knock-Off Wheels Torque??
  129. Under body paint choices
  130. 327 Oil Pump - Screen - Oil Pan??
  131. How important, really, is a deck torque plate for bore/hone?
  132. Date Coded Parts
  133. No Flight - Guess it didn't like being neglected
  134. Mecum @ Monterey list
  135. ID this Master cylinder
  136. roller tip rockers 365 hp recommendation
  137. Header setups? Wanna show me what you've used??
  138. how do i tell originals
  139. Keisler Engineering and Car Craft Summer Nationals
  140. gear ratio id
  141. Ncrs ??
  142. '61 Electrical 'Mystery' - Ignition Switch/Headlight Switch Crossover?
  143. Ncrs manual sources
  144. Steering Column "Pop" or "Snapping" Sound . . . .
  145. Todays Birthday
  146. Estimated Value for a 69?
  147. 1965 corvette side exhaust cut out
  148. Chevrolet Hall of Fame Museum and car show
  149. Good front shocks for 62
  150. 67BB - Non-Slanted Valve Cover Question
  151. need help to ID this master cylinder
  152. OT-Happy Bastille Day
  153. Radial Tires
  154. Broken wheel mounting stud...
  155. 66 Vette 427 - Coil/Firewall/Ignition wires
  156. Going to San Jose Convention Tomorrow
  157. What's the weather like where you live
  158. 1962 Fuelie Car VIN #20867S101530 INFO
  159. High pitch whistling sound from carb?
  160. Jay Leno video on Tremec TKO 5-speed install
  161. Cut front springs 1/2 coil get me 1" lower ?
  162. Moving Day For The Old Cars
  163. RE: 67 Stinger Hood
  164. GA State Advalorem Tax
  165. Pulley size
  166. Shipping a bare block?
  167. outer flange half-shaft bolts
  168. A Arm rivet tools
  169. Rear sway bar questions
  170. Looking for tips on how to fix enlarged screw holes.
  171. 58 fuelie progress
  172. My 66 vert's steering wheel dropped 1/3 inch ??
  173. '61 Front End Alignment Question - Caster
  174. Parts OEM?
  175. Almost a disaster!!
  176. 3 X 2's - 427 -400 - 1967 Roadster
  177. another stamp pad opinion
  178. Sidepipe Tips
  179. Best fiberglass info?
  180. Battery and Recharging Question(s)...
  181. 327 Exhaust Manifold Identification
  182. Too Good To Be True ??
  183. The 61 FI runs great!! Thanks to the Forum
  184. 1957 License Plate Bracket Number
  185. 63 Starter Question
  186. Tahoe 41 "Racin' to Tahoe"
  187. Cast date missing?
  188. Fuel percolating (vapor lock) problem
  189. More engine info
  190. I won - I won - I won
  191. 64 327/350 increase in fuel pressure
  192. Good Guys Columbus, Oh
  193. 750 holley rebuild kiy
  194. Did something happen to Barry's tech article collection?
  195. how much HP is 'enough'?
  196. Maybe a silly ignition shielding question 67BB...
  197. spark plug wiring diagram
  198. "show your signature"
  199. I need a fuel tank - which one
  200. Amp gauge charge question
  201. Adhesive suggestion
  202. back-up lights
  203. New half shafts for a 56?
  204. C1 Clock
  205. water pump pulley question
  206. On the road again!!!
  207. ID a Carb ?
  208. 66 427 / 425 BelAir vs 66 427 / 425 Corvette?
  209. 61 starts but dies quickly
  210. side pipe inside rattle
  211. Rock Valley
  212. Engine rebuild "Oil pressure saga" update
  213. astrdokks car, it is finished.
  214. Lucas flame throwers
  215. Could this be a survivor?
  216. Flow numbers Allens vs SweetThunder side pipes?
  217. This '62 is Goodguys Street Machine of the Year
  218. Best power steering? Original VS Internal VS Rack
  219. Took the 62 back to the track
  220. Unusual Vintage Goodyear Tire
  221. Silicone brake fluid leak
  222. Percolating?
  223. Memphis- Barry Grant carb help
  224. 1965 C2 Vert 327/365 car, Red/black
  225. Arizona Vettes!
  226. 65 250HP WCFB Carb ?
  227. Scam 57 corvette?
  228. Finally Back on the Road
  229. Edelbrock Carb... running rich.
  230. John Z sunvisors
  231. Sharing frustration
  232. M/C bench bleeding question
  233. is this spam/phish or virus?
  234. need a picture of...
  235. Can you identify this electronic ignition for me
  236. Need engine info
  237. Restore seat backs or buy new?
  238. 56 vin question
  239. timing my grandpa's 59 vette
  240. Hood Alignment
  241. Connecticut Show
  242. Help any reason to NOT shrink wrap your pain?
  243. 54 firewall pic please
  244. Annapolis Corvette Show
  245. Transmission brand
  246. My Grand Sport is about 2 weeks from the road
  247. Birdcage pop rivets
  248. 1967 Engine code decals
  249. LADY Turns 46!
  250. Tranmission # Brand
