- Painted 62 coves
- Cash for clunkers
- Carlisle swap space
- attn Florida residents
- Innovate LM-2 “basic” group purchase
- Carlisle rooms..................
- Woodward Avenue
- Rear brake fluid disappeared
- 1960 X-member rear body mount points
- 097 Duntov question?
- 64 Ammeter reads backwards
- Its Friday:Time for a smile !
- Godman's in Memphis
- Any idea what its worth...
- econovette
- Original NON DOT goldline tire values
- Resto-Mod.......Seperate Forum???
- No hit body?
- Need gauge repair
- Electrical question on a 57
- Anyone staying at the Carlilse Holiday INN
- Anyone have a picture of a 63-65 FI distributor?
- On your way to Woodstock 40 years ago?
- Opinion on these scripted valve covers?
- How smooth should a 427/400 3x2 idle?
- Difference Between 66 and 67 Coupe Carpets
- Looking for 54 Chevrolet Powerglide
- Why does it seem that a 1964 Corvette is bad
- '54 VIN 3469 I have paperwork for your car
- Running Rich - 65' L-76
- 54 ring bezels
- Close ratio or wide ratio?
- 54 gauge bezels, gauging interest
- Fourth time is the charm?
- Mile Terry/ 56 vette
- Opinions on '94 stock LT1 in C2?
- Great idea CF Admins!!!
- Knock Off Wheels
- What to do After a Complete Restoration
- Early Corvette Sales Brochures
- 327/300 waterpump
- Rear Brakes Locking Up On 65
- Electrical Problem!
- Looking for a good C-1 door man
- Restomod question - ABS
- 67 Interior Lights
- 60 restore slide show
- *****A Refresher course on Dispute threads****
- 63 frame info
- Steering Radius C1
- Engine Numbers
- Repro or GM, C1 hubcaps..how do you tell?
- One More IR Question
- vapor lock??
- Moog ball-joint problem
- tr-arm rebuild carlilse
- Mystery Vette (Help?)
- New to CF, New member introduction.
- Monterey Historic Races - Free Ticket
- Tires for my 67 coupe
- Mid Year Clock Removal with Air
- Bowtyeguy Floats Another Photo
- 65 Coupe rear carpet
- another stamp pad? restamp?
- BB water pump
- Axle tube leaking oil down backing plate, bearing shot?
- 54 Corvette
- correct water pump for 327 350 hp
- Pass Power Steering on 53-62
- 61 Differential Codes
- Amarillo TX. anyone?
- Average Age
- Powell car show columbus ohio
- Door mirrors on a C1
- 1966 Survivor BIG Block body ready to come off
- Pulling steering hub
- Headlight Motor
- More Oil Info.
- Front rotor run out
- Going to Nashville
- Your thoughts on a theoretical
- master cylinder ID 63 SWC
- All brake lights will stop working because.....
- Transmission Numbers
- intereor code
- Corvettes at Carlisle - Keen Parts
- WCFB Vacuum fitting for power brakes
- EVERYONE knows what a tach-drive generator is, right? Well how about a dist-drive gen
- trim tags
- 1967 BB parts prices
- Question on 66-67 Wiper Arms Finish
- Beauty Ring Replacement
- O/T: Sign Sign everywhere a sign
- Anti Theft Device Ideas:
- 1957 corvette speaker grill
- Mufflers
- 1957 vette fender scoops,molded on?
- 67 steering feel
- 65 396 Engine Rebuild Need Help
- Corvette Central Off Road Exhaust
- frame question
- High rpm waterpumps
- Any one familar with Crane's Performance in Florida?
- antenna
- C1 ideal running temp
- Craigslist motor
- Change Pinion Seal While in Car? C2
- 67 corvette 427 "321" block usage
- C2 with Dayton wire wheels
- Body drop-w undercar mufflers on??
- How to re-assemble a C2.
- Which engine paint? Vote now...
- Corvette Parts Rebuilding & Restoration Services Vendor
- T-Arm drain hole - have you checked yours??
- Temperature Question
- use of synthetic gear oil in Muncie
- decoding an 870 block
- 59 available
- Clock question
- Differential Stub Axle side play question C2
- LS motor in a C1
- ZZ4 coolant flow on 62
- 66 Original Wheels
- 1966 Corvette 427 BB 390HP
- Tach Lense installed Concave or Convex?
- Fuel cell in C-2
- Long tube headers with side pipes?
- Lock Knob Removal
- C1 headlites/taillites too dim??
- 54 Wonderbar Just Hums
- Any tips on how to remove headlight switch in a '67?
- Paint codes online
- Vac line for brake booster
- Adding transistor ignition.......
- 1965 vin# 2528- I have your m-21 trans
- Possible Coil Problem
- Mini Starter Diode Question
- 200 R4 installation results
- Question: Final Checklist for Body Drop
- Fuel pump on a '56
- Measurements on 427 scoop
- Tachometer question
- C2 lower ball joints
- Rare Corvette Carburetor?
- Tapping Noise - Right Rear of Engine
- 1960 Heater Hose Routing Help
- BB antifreeze in the oil
- 66 wheels
- starter
- Few More Photos Manassas VA Cruise
- C2 hitch install
- 1961 odometer gear tooth count
- A few pics from Hot August Nights.
- 1966 Corvette BIG BLOCK - Gas Fouled Plugs - HELP!
- My stolen 66' conv.
- Rear Spring Anti-Sieze?
- Rear Spring Anti-sieze?
- Got the 65' Insulated, now Pad & Carpet
- Medicaide look back
- Willcox New Sale Starts Now!
- Ratio Question
- Suggestions needed: Silver Paint for Sidepipes
- Need Big Block Engine Pics
- what to do with an unrestored 63 split window
- 20th Corvette Cruise, Manassas, VA
- Project L89 - final stages of primer
- Ignition Help Needed
- Need advice on extra holes in 61 body
- 66 vette measurements
- Body on...dolly to go
- Resto-Mod Drivers: How good do they handle/feel?
- C1 1959 Photoshoot (Belgium, Europe)
- Gas gauge question...
- Custom Batmobile Made From 1958 Corvette
- Body Drop Shim Question??
- Small Number
- Lateral steel wheel run out
- Bobby Alloway's '62 Corvette at Goodguys Columbus
- Trunk Weatherstripping...
- Your thoughts on this 65?
- Steering column check
- How can I research the title history for my 65?
- C1 Charging System
- Chicago Restoration
- Headlight Help
- Directioal flasher & capacitor
- Proper way to adhere C1 bonding strips...??
- gas test in progress: how long can it be trusted?
- overhaul manual
- What is a 1961 Pilot Car?
- Interesting article on a 1948 Tucker
- best tires for stock 63 C2?
- Best pistons and cam for a 327/365hp block
- question on my 1963
- Virginia Vettes -Sale on new Direct Bolt and Bolt on Wheels
- EFI Fuel pump question...
- Rebuilding distributor, a few questions..
- hey Ralph...your car is on here!!!
- Crane opens under new ownship
- Its Friday time for a smile:
- 10% off Steeroids sale
- 59 or 60 vette in the neighborhood.
- why no wave?
- 64' 327-365hp choke tube insertion into exhaust manifold -- won't go in??
- c6 member soon joins c2 section
- '62 FI Car Or Not
- Original owner finds my '66 vert 427 thanks to you
- 64' Body Removal
- Suggestions for a rev limiter in my '65 383?
- Weather strip adhesive which one?
- 1963 Gas Door
- Engine stands
- convertible tops on C2's ?
- Spark Plugs
- Using ir gun on a c-2
- wheel cylinder question
- Kiesler guys/help?
- body drop question
- C2 fiberglass ???
- Infra red images of our car
- I have info on these cars..................
- Transmission Question
- AC decals in engine compartment
- Low Mile '65 L-76 at Mecum Auction
- Summer Classic Cars in Eugene OR. U Know Them?
- Do You Know Summer Classic Cars in Eugene Or.
- Odometer stuck ?
- Heads-problem??
- Mystery of Stan Drake's '56 Corvette ???
- factory dual quad intakes ... enlighten me please
- Help with parts Id
- Trophy Blue in Atlanta/Bham
- sealant at bottom of starter gap???
- Vacuum Advance removal
- Radial tire pressures
- Holley Carb Problem
- waterpump
- 62 Correct ballast resistor
- 1961 corvette generator to alternator conversion
- loud backfire thru sidepipe
- What the hell is seafoam?
- Wes Migletz is in Car Craft!
- Looking for a body lift strap kit
- Missing at high rpm
- 57 Vette Rod Finally Done Pictures
- body drop
- Rear parkbrake cable hangers
- C1 Hand laid glass...Who manufacturers it...?
- rear swaybar on a '65 small block car?
- how many kilometers in a quarter mile ??? we're going Canadian style racing
