- '62 Hubcaps - need a measurement
- hardincorvette
- 2 questions abought me '54
- '54 "corpalla" update (pic heavy)
- An HEI distributor for my '66 BB
- Front Suspension Alignment cause shimmy?
- Rear Spring Bolts
- 63 Z06 brakes
- Sad day in Watkins Glen! A Historic Corvette story !
- Yard Find
- Please help a forum member on a purchase
- Bluestripe
- Reverse Hurst Shifter problem
- Questions: 64 Conv Body Back on Frame
- Replacing a CE block with correct block ?????
- High Beams Not Working on '65....Dimmer Switch?
- windsheild wiper help
- Anyone tint their back glass on a C2 coupe?
- Master cylinder bleeding
- Drop axle for 67
- Oil leak at distributor
- Another 20% Off Microfiber Towel Sale!!! Stock Up Now!!!
- to sleeve or not to sleeve
- power steering cylinder and valve rebuild kit?
- How to turn off the heat
- blinker trouble
- 62 air cleaner filter
- Barn find 1956.........
- Grinding Going into First
- To those getting to go to Carlisle..
- I won 2nd Place!
- What have others used For Milano Maroon?
- Finally found one
- Packed for Carlisle
- Flexible Fiberglass Repair
- New C1 dash cover: Which vendor?
- 71 Big Block Rear Spring to 65 Small Block?
- 1954 Antenna connection?
- 3rd update on water in the oil
- 1965 396 3124 carb replacement
- need a pic of your C-1 door post
- Early weather report for Carlisle
- Cornering with SRIII Frame
- Restomod: GM LS Engine Drive assecory kit
- Paint question-body seams swelled
- Help with borgeson PS Conversion. . .
- Anybody know this corvette from Portland
- It's a fuelie!!!!
- Michelin Symmetry
- Good Place to Get 67 Hood Latches Replated
- Oil leak Question
- Random shots.
- C1 Key Chain
- I want to find and owner of my Vette went to Vietnam
- Hydraulic Lifter problem I think
- 67 bolt on wheels
- Free Race gas Your kiddin
- 65 Coupe antenna access?
- Guages
- Pics of People Sitting on Your Corvette
- Converting '64 to '67 Dual Master Cylinder
- Electric fan set-up what do you trust? Goodies to be added soon:
- '82 disc brakes
- This is disturbing!
- CC..............pepper spray?
- Go over to the SOUTHWEST forum and read the below topic
- cooling, 67 350 hp
- Firestone fr380 205/75/15.... will they rub?
- Still overheating in summer. What now?
- Back Up Alarm . . . Right Price
- potential source of interior heat in a C1
- Its Friday:Time for a smile !
- Went to fire it up the '57 for cruise night...
- Good By Baby
- Windsheild washer and wiper knob question.
- Help with engine ID
- 1 turn signal doesn't work, Brakelights do - ideas?
- H-beam rods vs I-beam rods
- M22 Z Transmission Installation 2.98 1st with video
- New Leaf Springs
- cutting the speaker hole in a '58 dash pad
- Ignition interference
- '63 SWC - whitewall vs. blackwall
- Question Re roller rockers
- Mid Year Paint Color Production Numbers
- Bad Petrionix?
- Broken stablizer link on LCA
- barn find
- C1 hardtop question?
- Tires
- Standard exhaust question
- c1 replacement steering column, which one?
- Spark Plug 43N please explain this
- 68 thru 72 interchangeable parts
- Supercharged GeigerCars 2010 Camaro Churns Out 568 Horsepower
- Newbie doing homework
- stamp pad
- after market fuel pump installation
- Hello! I took the plunge!
- Quick change fan experiment-more power?mpg?
- Any use a later GM Metric style P/S pump with stock hoses/Control Valve?
- AfterMarket BB Intake ? - What Fits under the hood?
- carb/manifold question
- Need Proper Dimensions and Markings for 67 9-Leaf Rear Spring
- Borg Warner T5 In A 59
- C2 Coil Spring Questions
- 62 Speedometer gear color-code
- Blower Motor
- Steering Column Removal...
- Vac can ident
- Kinda Corvette, need advice.....
- Hdlite Motor - How to Access Lower Bronze Bearing/Retainer?
- Build date
- Heater box AC or no AC 64-67
- C1 front air dam installed
- Check out C1-C2 Parts at Carlisle
- Remote oil filler installed
- '61 Wire Identification Needed
- 1961 Bumper Woes
- 1963 Zo6 Power Brake Ques
- Corvette spread in Life magazine
- Any Canadians with an early Solid Axle?
- Hump day chuckle ....
- 1954 Motor Trend Mag - Interesting Classified Ad
- Differential Cover Bolt -Black or silver?
- Monterey Historic Races
- Another tire question...15" high speed tires for Diamondback's white wall conversion.
- Retro fiting C3 seets into a C2:
- Tire advice
- Stolen Classic Corvettes
- Shifter question
- Third seat in C2
- Great video on how a differential works
- Sheff's stolen Corvette photo.
- Changing a 2 speed pg to 700r
- hot 67
- Knock off spinner lube?
- Cam's
- C1 with Magnacharger?
- 1965 Popular Mechanics Vette article ??
- Edelbrock Dual Carbs
- Need Help.....ID Block
- Good Cruise Night pics
- 3873858 Heads - What are they worth?
- 67 seat back latch
- 1966 Vents blowing hot air
- Buying 63-67 Coupe need your input..........
- NASCAR Wannabees: A Test
- Will you be on "Steeroids" while at Carlisle???
- Corvette Won Monterey Historics
- Best Place to Buy TT II's
- 65 Master Cylinder
- 10% Carlisle Savings-Instrument Restoration-
- 1967 vette
- "61 X Exhaust Hanger Mount Photo Needed
- thepartsladi/Fan clutch
- Does Size Matter?
- can you put 66 seat foam and cover on 63 seats?
- 1960 washer bottle & canester mounting
- 54 Fuel Pump Presure
- Used Goldline Tires
- Flaring Brake Lines 63 Resto Mod C4/C5 Suspension
- Sometimes it DOES pay to shop around!
- Frustrating Shifter Linkage issue
- Steering Ratio Change
- Mid year differential lube
- Project L89 - paint and final assembly
- Knock-offs: hubs w/spinners
- 65 Close ratio transmission fluid
- I guess the 56 was in an issue of Corvette Fever
- ? on speaker grill color
- Canister oil filter
- Clutch Fans
- changing wheel cylinder size? larger=less locking?
- Radiator Support Question
- C2 Guys... **Carlisle Specials!**
- Anyone not use a thermostat?
- Stolen Vette
- Motoring in Finland...
- WARNING. Urgent notice!!!
- No Vette Auction at Carlisle this year!
- Sorry sack FI unit
- FINALLY!!!!!!!!! I got a copy of the service letter for steering box lube!
- A great 66' weekend...with pics
- Which LS engine for a C1?
- 555" Build for Bruiser- My first try at Magazine Article Writing!
- Heater box turn off valve
- 427 # Check and questions about 435 intake
- Junk Braided BB Plug Wires
- Has anyone used a Walter Prosper air cleaner on a 66 vette?
- Weird powertrain vibration under load, U-joints?
- '61 Off Road Exhaust TailPipe Help
- '61 Resto Mod..Dash and front end removed. Wiper installation, A/C, wiring, etc
- gas tank pad where do they go? C1
- Dyno run...not too bad
- hardtop for 59
- Fired up the 67 for the first time in 3 years
- Mass free 60 corvette
- Spedo needle bouncing and ticking?
- Newbie - pics posted
- how many things can I get onto a C1 body while on a body dolly?
- QA-1 semi coilover a-arm mounting alternative, (see pics) need opinions please!
- Air Cleaner for Holley Street Avenger
- Radio help
- Antique Automobile radio
- Spare Tire For My '60
- Dual Carbs
- 1966 tire rub on front
- 1/2" (8 AN) fuel line - does it fit on a C2 frame?
- Uneven exhaust temps at manifold
- 1967 FRAME OFF & Dipped - What's the best way to PROTECT against RUST???
- Anyone in Charlotte area good at vynle seat cover repair?
- Original Sidepipe Car??
- F.I. scripts #3746457 value?
- Coffee with the Aussies
- Carter or Rochester - which is correct
- NCCO all vette show
- Removing rear spring - safely (pics)
- familiar sight?
- five finger discount
- THanks BuBBa
- Can you identify this rear spring?
- VAC gage/ picture
- Radiator Removal & Replacement, '65 A/C Car
- local car show
- Which shop manual
- Anyone from Sarasota Driving to Carlisle?
- 67 Corvette PCV and A.I.R. Smog Intake Manifold Fittings
- 64 rear leaf spring question
- back up lamps
- Fighting gas percolation
- ** DFW ** Blue Thunder Corvettes Picnic, Sat Sept 26th - Arlington
- Which vacuum port do I connect vacuum advance to?
- Took the 65 to see the past, and future, of space travel
- Tony Nancy "Sizzler" AA/FD
- Ebay question about 63 corvette parts
- Corvette restorer in Naples area help
- Huge Car Cover Sale
- 64 Power Brake Master Cylinder Leaking Brake Fluid From Weep Hole
- What Temp is Your C2 Running At?
- Oil cap question.
- AussieJohn this Sunday the 16th at Starbucks
- C1 strut rods
- The cars we drove
- Repeat of converting 56-62 NON-posi to posi
- Mini Starter Bell Housing Gap
- 54 weatherstrip question
- control arm colors
- Big block hydraulic roller lifter noise
- Mecum: 1967 Ed Cole 427/435 L89 Sells for $205,000
