View Full Version : C1 & C2 Corvettes
  1. The Hazards of Passing a TR-6
  2. Pic of '58 -'59 glove box in car w/o seats
  3. 283 40 over = ?
  4. 750 Holley problems..........again
  5. ~~St Jude Caravan and Check Presentation Oct 12th Memphis TN~~~~
  6. Steering Column Install Question
  7. Anyone know about the PCV valve...
  8. Another vette for their garage
  9. Will 30k Get Me a '62 Vette?
  10. Amazing $3.95 Corvette Generation Poster Sale at CruiserBlvd.com!
  11. 327 Bolt Hole question
  12. Kee's convertible top
  13. fusible link question
  14. Labor Day Weekend Fun
  15. Any Chicago area folks with a media blast cabinet?
  16. tight fit!
  17. Questions: Wiper Blade and Tail Light Flashing
  18. Passing Gear and Red Line issues
  19. Electric Fan switch location?
  20. changed rim on my car, good and bad
  21. '61 Engine &Trans Placement?
  22. Intake manifold unusual leak help!
  23. "Rubbing" Sound when making hard right turns....
  24. Knock off spinner won't budge
  25. Engine wiring harness up in smoke 65 327-300
  26. chassis
  27. 56 vette body removal
  28. What is correct paint color for 1966 wheel covers
  29. 63 brake booster
  30. NCM 15th Anniversary
  31. Replacement Alt belt for 67 BB w/ PS & AC
  32. Honduras Maroon
  33. Newbe electrical question (s)
  34. door lock pillar cover question
  35. Panoramic view of California classics
  36. OT? Car Collection w/some Corvettes
  37. Vette Collectibles Cruising Sting Rays
  38. 67 Dyno Results - Need Your Input!!
  39. No power
  40. Injection ......Hilborn is nice , but wanted to do this !
  41. points save the day
  42. '61 FI Coil Location Needed
  43. Towing my 62 on open flatbead
  44. 62 Body Shims
  45. Radiator Paint???
  46. Reporting a vendor??
  47. Window sticker
  48. Is there such a thing as a Shark Steering Wheel
  49. Changing the body mounts and need to change the shims...
  50. 66 cold air hood ala 002 GS
  51. Restomod Insurance
  52. c2 want to make a daily drive but I smell like gas/oil
  53. 58-62 Windshield Install
  54. 67 Electronic Ignition
  55. 60 windshield header molding channel removal??
  56. 64 radio goes off when i hit the brakes, etc.
  57. Labor Day Steeroids sale
  58. What are your IR temp readings....?
  59. C-2 inspection
  60. Hard Tops
  61. '58 Heater Valve Rebuild?
  62. Wcfb
  63. From the factory ...
  64. Fuel Tank support bolts!!!
  65. Horn-Airbag Link
  66. Oil Pressure questions
  67. looking for a pic on how to modify the 63-64 front frame cross member to accept a Big
  68. Finally back on the road, 67 Big Block
  69. Went to my first car show..........
  70. C1 window front run?
  71. battery disconnect
  72. Rpm's at highway speed
  73. Went to a Labor Day car show...
  74. Drive It If You Got It !
  75. Recommendation for new 56-57 seat covers
  76. Wilwood Aluminum Caliper clearance problem
  77. Seem to be a lot of Vettes in my small town...yours?
  78. Radiator leak--Seal it?
  79. Missing Body bolt -
  80. Stress crack
  81. 67 Windshield Wiper Stem Repair - Blades Won't Grip
  82. Never had a thermostat fail before
  83. Petronix
  84. OT: WOW... Force vs. Pedregon
  85. fuel line
  86. Big Tank or not?
  87. Reputable Repair Shops in MI
  88. Meeting John Z
  89. coolant flow question.....urgh@#(%% still runnng hot
  90. 63 SHP differential
  91. Can This Head Be Repaired?
  92. C2 vs C5...
  93. Intermittent Brake Lights on my '61
  94. '65 Clutch Squeek
  95. wheel lugnut torque question
  96. Temporary fix for air cleaner on Edelbrock RPM Airgap.
  97. c-2 side pipes
  98. Please Vote for ??? Valve covers .......Can't decide Old school? or Billet
  99. Ralley wheel question
  100. fuel smell in garage
  101. Who makes good torque wrenches?
  102. Timing Chain Cover/Oil Pan Leak
  103. Good body shop for fiberglass fender repair in MA or NH? Pic of fender damage.
  104. Best exhaust sound for 1965
  105. Need ac decal help
  106. Could a 65 have been factory built with a 66 block?
  107. 200 Corvette Posters & Prints at CruiserBlvd.com - Free Poster Offer
  108. 65 Hood Stuck
  109. Holley 3247 Fuel Inlet Fittings
  110. Anyone going to Watkin Glen Vintage Festival?
  111. Who sells a good fuel line?
  112. need help, I'm looking at a 57
  113. Mystery wire on 1965
  114. C3 Power booster and dual master cyclinder in a C2?
  115. Starter problem
  116. NCM "Transformer" SWC...PHOTOS
  117. Yard find
  118. Olcott New York Car show 9/5/09
  119. Interior Light Door Switch
  120. no-hit body.............is your's?
  121. contact details for Doyle Thomas re restomod '66
  122. 427 A.I.R. Bypass hose?
  123. Anyone know NCRS Bloomington judge Ken Edmonds or Les Gusky?
  124. 1954 wiring question
  125. Looking for a Todd Johnson from Garner NC
  126. 1965 tire brand
  127. Willcox Sale Extended until the end of Sept.
  128. Fuel Pump Dead?
  129. Front Sway Bar install..
  130. How to identify an L79 in a 66 ?
  131. Welcome the newest Chicagoland midyear owner LDB C5
  132. Auxilliary Lighting
  133. 65-66 seat belt coil retractors
  134. Can you tell if it is real from pictures?
  135. 62 turn signal canceling
  136. pickle fork size?
  137. Help Front wheel bearings
  138. Question on 63
  139. 86 seats in a C2 coupe Resto Mod?
  140. C2 door lock mechasim
  141. vettehounds
  142. Hello Illinois
  143. Tele Horn
  144. Transmission Identity
  145. Need illus. of fuel line for 57
  146. Xke vs c1
  147. Dist. Curve, 67 427/400 HELP
  148. Reusing leaf spring U bolts
  149. Shameless car show plug-pics
  150. Electircal Issue (Insight Needed)
  151. 1960 Generator alignment issue - Need help
  152. Temp Sending Unit "Calibration"
  153. C2 vert door window help
  154. C2 high idle manifold leak?
  155. mystery squeak under hood
  156. 1964 Corvette Yenko dealer option back seat
  157. Identify this gas cap
  158. What's the best clear coating in a can?
  159. The ever-elusive N11
  160. Brake Switch Somethingorother!
  161. 1959 fan spacer
  162. Thoughts on Vendor Rating System
  163. coil spring threaded rod help
  164. Upper A arm shaft ?
  165. How do they stay in business?
  166. Its beginning to look a lot like...
  167. mid year owners and driving your car at night
  168. Knock off spare tire
  169. Arlington Drag Strip Reunion and car show
  170. More Rally Wheel Mystery
  171. A few pics from Bowling Green 15th. anv
  172. The 66 is out of the paint shop!
  173. 64-66 Seatbelt supplier
  174. Great Magazine search engine
  175. Smoking Hot Weather, One Cool Dewitts
  176. MaryJo (Vette Gal's) new on-line shop
  177. 15% Off Everything!!! Labor Day Weekend Sale @ Detailsupplyonline.com
  178. Fuel sending unit question
  179. Chassis dyno
  180. Is anyone running BF Goodrich Radial TAs
  181. Lower control stops
  182. question about new convertible top
  183. Question Carpet cuts for seat slides??
  184. 61 gas tank fitting???
  185. Its Friday:Time for a smile.
  186. Holley 2118 vs Holley 0-1850S - Holley Model 4160 Non-Adjustable Float Carburetors
  187. Nice 66 air coupe
  188. Is Gelcoat needed on original fiberglass?
  189. coupe or convertable?
  190. Help inspecting a car in San Juan Capistrano, California
  191. need advice on 57 Vette on Ebay
  192. 67 427 Oil Pressure Fittings on block
  193. Need Some Pictures Please 1960 frame
  194. when do you replace a fender as opposed to fix it?
  195. Fiberglass Crack Repair Product
  196. Congrats to Rich......BADBIRDCAGE!!!
  197. 105 amp alternter
  198. Found:Alignment Shop NW Chicago (Suburbs)
  199. Best wide whitewall radial
  200. Beautiful '58 I saw at Carlisle
  201. LT1 dynamic balance when put into C2 with original manual transmission
  202. Sticky Side Window
  203. WTB 15x6 Aftermarket Rallyes for my 66
  204. 1990 convertible
  205. Directions For Spraying Gelcoat
  206. Pic needed
  207. random funniness!
  208. LS1 in a 59'
  209. 2009 '63-'67 Sting Ray Registry Pacific Coast Road Trip - Vancouver, BC to San Diego,
  210. manuals
  211. non dot tire?
  212. Headlight Motor Schematic
  213. window felt glue recommendation
  214. TI Distributor-Flat or Satin black
  215. Carb restoration
  216. Is it OK to powder coat brake rotors?
  217. Cape Breton bound
  218. Rally Ring manufacturer suggestion
  219. 65 L76 engine paint question
  220. Another overheating question
  221. OT - Don Garlits / Dodge
  222. Dressing up a 350 to look like an L79
  223. Remember the "57 Corvette Factory fuelie, airbox, big brake, COPO Corvette"
  224. Recommended Air Cleaner?
  225. Hump day humor ....
  226. Who knows where I can get a QUANTITY of THICK dist shims?
  227. Carlisle enjoyment
  228. crack in carb?
  229. 4 post lifts
  230. I've never been a fan of flares, but...
  231. What type of grease for the steering box?
  232. C-2 Hardtop Restoration Advice - 1966
  233. Wheel alignment specs for radials on a C2
  234. Wheel alignment specs for radials on a C2
  235. VA Vettes wheels
  236. C-1 Deck lid adjustments
  237. Mity Mounts (Motor Mounts)
  238. QA 1 Front Shock Install - ?
  239. C-1 Seats - Foam or Spings?
  240. Need Some Help!
  241. Braces on rear glass of hard top
  242. Won 2nd place
  243. Wanted: Convertible top installer in Western NC
  244. L88 Racing History
  245. Track fun and TV film shooting of my car at Carlisle
  246. '67 power window motor replacement help
  247. Wiper Blade ?
  248. C1 firewall grommets
  249. 1965 396 cams?
  250. 1960 vette need headers angle plug heads
