View Full Version : C1 & C2 Corvettes
  1. 67 Number on firewall above heater hoses?
  2. Like to DOODLE ?? Any Artists in here to design my interior for my 62 restomod ??
  3. Oil dipstick question
  4. Low speed stumble
  5. Need some input on '67
  6. paint for water outlet 67 327-350 L-79
  7. 67 Trailing Arm
  8. "Not sure on working condition...
  9. Black 1954 Corvette ~ Photos
  10. Any Fiberglass Tips?
  11. Conv. door gap
  12. New Shoes on the 65
  13. Original Upper Radiator Hose Repair?
  14. Dual carb 427 car?
  15. Red 67 roadster 427/435
  16. 3M sealers for 66 windshield and hardtop
  17. No Tire Spin..Say bye to Motor Mounts!
  18. head light aiming
  19. C2 restomod body done!
  20. Documented Proof That Only Sexy Folks Drive Old Corvettes
  21. Short haired Bondo vs long hair
  22. Frame paint
  23. Fire Extinguishers
  24. Restoring 56-57 dual quad air cleaners
  25. Couple easy questions on a 65 for you midyear guys
  26. whatever happened with the C3 that was being blended with C2 body parts?
  27. Anyone visiting the Trinity Site Sat Oct 3?
  28. Balky Forum
  29. 3866963 intake coil mount ?
  30. OT - IR Temp gun
  31. 59 color question
  32. a good laugh for sat night
  33. Glass Coding 1966 Rear Plexiglass (Hardtop)
  34. Bennie "The Wizard" Osborn
  35. Anyone have experience with LEDs?
  36. anti rattle spring clutch linkage?
  37. 66 rear leaf spring???
  38. "Easy Install" Yeah right!
  39. Pick the "purge"
  40. Chassis dyno in Houston Tx?
  41. OT: What eBay category gets parts for sale in C2?
  42. Mecum Bloomington Gold
  43. Correct color battery caps
  44. thinking about a huge interior fan (no A/C)
  45. Does this look about rite?
  46. Frustrating interior door levers ?
  47. Underbody gel coating - good or bad idea?
  48. 15% Off Detail Supplies @ www.detailsupplyonline.com
  49. Wayne's Corvette Corner near Trenton NJ
  50. Gas Leak Solved
  51. Opinions on painting the 62
  52. 62 front disc conversion question
  53. Scam ad for my car
  54. Wheel tubs in a 64 'vert
  55. Small block intake under a stock '63 hood
  56. 454 Miles of Coast and Mountains: Pictures and Video...
  57. $325,000.00 1965 Corvette Convertible
  58. C2s steering damper
  59. 64 "Factory Original" Wheel...NOT
  60. Flared fenders on a C2?
  61. Overheating is not an issue anymore !!!
  62. need quick answer- front exhaust hanger, does clamp go over this???
  63. Purpose of the reinforce plates behind the C1 seats
  64. Insurance- common garage
  65. How Did I do it?
  66. real mid year for sale
  67. 67 Emblem paint
  68. 1964 Restoration Completion Pics
  69. 1963 VIN numbers
  70. C-1 Door Hinge Bushings & Pins
  71. How much weight can '62 deck lid support?
  72. knock-0ffs
  73. 54 update pics
  74. Its Friday:Time for a smile :
  75. My car is the September NorCal Vettes centerfold!
  76. 64 rear on jacks
  77. My car is on the cover of Musclecar Enthusiast !
  78. My hood keeps popping open?
  79. The C7 Corvette will be split window
  80. will my tranny leak?
  81. Air leak thru door pillar/hinges
  82. 65-66 Repro Brake Master Cylinder
  83. Distributor Rebuild
  84. would like to reduce door gaps
  85. Lower control arm
  86. Distributor End Play Question
  87. Anyone ever shorten a rear spring ??
  88. Gauge overheating not motor C1
  89. Shimming C1 body?
  90. C1 w/straight axle
  91. I'm losing to a FORD!! Please VOTE!
  92. I'
  93. What a Deal on a 67 Coupe
  94. Black soot on rotor, what is it? 64 327
  95. Be careful where you send your parts for chrome
  96. Rebuilding 66 Rear Trailing arms
  97. Replacing a battery in 63
  98. Fuel Injection Fuel Float repair
  99. Guys I need some used or core Prices
  100. Any 63 340HP topflight owners out there?
  101. Is a 427/425~435 actually drivable?
  102. Stripper Questions
  103. 66 window sticker
  104. Ground Locations - 1965 Convertible
  105. Four post lift
  106. 59 Hardtop rebuild
  107. Breakerless Electronic Ignition Conversion
  108. 1962 front suspension rebuild advise
  109. Early generator value
  110. clutch push rod seal and retainer
  111. 64 AM/FM radio schematic
  112. 63 Electrical Question about HORN
  113. How Were 67 Door Panels Constructed
  114. ignition keyhole on a 65
  115. door window regulator removal
  116. 64 - 65 Seat frames
  117. correct water pump and crank pulley size?
  118. C2 Convertible 1965 Top
  119. TI Ignition for 64
  120. Picture of a correct 57 seat belt and buckle
  121. I'm gonna sell my 65...need a little advice.
  122. Posting pic's
  123. Differential drain plug kit
  124. Need to get my chassis to the dipper - Socal HELP
  125. 67 small block side exhaust
  126. wanted -c2 conv top installation place in Long Island, CT or NY
  127. Anyone Used the Corvette Central Differential Drain Plug Kit?
  128. Progress pics on the '54
  129. Convertible top, frame paint:
  130. Raw fiberglass hood is getting spots after sitting for a while????
  131. Best Leaf Spring for the Money
  132. Driver side alternator in a '64 midyear?
  133. Why I missed a shift at the drags...
  134. Repainting 67 Oil Pan - Prime It?
  135. My good luck...
  136. seat belt identification
  137. southern flooding
  138. southern flooding
  139. Car Show in Roanoke Rapids, NC Oct 3 Sat.
  140. c2 front springs
  141. Powder coating aluminum
  142. 1966 BB A/C HORN Quest??
  143. Sponsers Choice
  144. valve cover differences
  145. 67. 427/390 T.I. Dist. Numbers???
  146. Inside bumper starting to rust.
  147. Free FI Calibration Spec Sheets
  148. 1960 aftermarket intake
  149. C2 shirts with a discount
  150. Coil Arcing to Ignition Shield
  151. Mid-year exhaust leaks
  152. Reproduction Belts-Anybody have trouble with them fitting?
  153. Paragon Vinyl Dye=not good
  154. Help-Can't stop !!
  155. Recent C1/C2 pricing and trends report?
  156. O/T Rear Diferrential Question
  157. Learned my lesson at car show Saturday
  158. Are all AIM manuals same quality ?
  159. Super Chevy pics
  160. Fit 62 on a 61 frame?
  161. Vintage race fans, Watkins Glen
  162. 61-283 motor breakup,miss
  163. Heat Barrier Under Carpet
  164. Pretty sure this isn't a 63 part?
  165. What are the possible cams?
  166. Please delete!
  167. How do you remove center console?
  168. Need a transport company in RI
  169. 327 L79 alt /water pimp belt
  170. Wonderbar restoration
  171. Overheating solved for about 30 minutes then O-sh-t
  172. [pics]63 Split Window Fuelie
  173. 64 Owners ???
  174. Registry
  175. Tire Pressure Recommendations
  176. Can I help save you some $$$??
  177. No start/ battery?
  178. got a light?
  179. Ride height with body off??
  180. New C2 Soft Top & Parts in general
  181. Dial Back timing lights - Good or Bad??
  182. 61 Door restoration.....possible power window conversion ??
  183. electric fan wiring to ignition, which part of the ignition?
  184. Tremac-what top plate needs to be ground down??
  185. Body drop with tremac-keisler shift tower??
  186. 1965 brakes
  187. Update on the 54 project
  188. Two issues I need help with on a 66 convert.
  189. dayton concourse d'elegance
  190. need some photos of 63-67 vert
  191. Transportation - Open Trailer Okay?
  192. OT: re '59 BelAire crash tests
  193. Correct Fan Blade for a 67 BB A/C Car Question
  194. I hope you guys don't mind my latest C5 picture
  195. 327 w/solid lifters....opinions on setting valve lash?
  196. High Alltitude Timing Settings - What's your preference?
  197. Silly question
  198. Just got my first Corvette…..
  199. Pinion flanges interchangeable ? 1963 and 1970?
  200. Our Survivor 67 - chance meeting tomorrow with orig owner
  201. Propeller shaft - junk or repair? (pics)
  202. Corvette Day @ Capital raceway
  203. Spring mount plate - a little bit of curvature normal?
  204. O/T: Platinum Plugs
  205. 7 leaf spring vs 9 leaf spring (pic)
  206. Changing C2 Windshield Stainless
  207. Car Show Pics
  208. gorilla spring solved
  209. Getting the most out of my 327
  210. Carter WCFB Jet Sizes
  211. Question about C1 C2
  212. 1966 BB Fuel Issue?? help...
  213. Fiberglass work
  214. Electric fan electrical options ???
  215. Kidz in your Vette Pics
  216. Want a 1954 Nomad?
  217. Mechanic Orange County California For a C2
  218. Adjustment on 1966 Headrests?
  219. Paulywannafly your nutz! Selling the truckster!
  220. cruise surge
  221. Bittersweet purchase of 2 67 corvettes
  222. Newest 1967 L-89
  223. 63 convertible correct ride height
  224. Help With L88 Radiator Tag
  225. Restomod whell and tire options for a 60 corvette
  226. Rims to suit 63?
  227. Fuse Block Repair Kits? Worth it?
  228. Ride height
  229. Oversize crank pulley and lower radiator hose
  230. bobby wants a 1962 Corvett
  231. 63 340hp Detailed engine bay photos
  232. Spreadsheet for part dates and numbers?
  233. Fast idle
  234. 65' Rear ride height
  235. Have any of you ever owned a C4?
  236. Going from side pipes to none?
  237. Daily driver in accident, need insurance claim advice
  238. "How Much Did You Have To Give For It?
  239. Big Block Piston Identification:
  240. Funny story - took my 2 yr old for a short ride
  241. 1962 Value Inquiry
  242. A good day at dale earnhardt chevy today
  243. electric fuel pump location on a 62
  244. Upper Column Squeaking!!!!
  245. Off topic - Browser sluggish when on this forum
  246. star burst gone from oil ??????
  247. Anyone Hunter Alignment Profiient
  248. Coil Spring Installation
  249. pic of mounting holes
  250. Car Show Today - North East Of Toronto
