- Disc brakes front on a 64 Coupe with knock offs
- srIII frame and C5
- 64 Cpe Project - Riverside CA
- trim tag confirmation
- Luggage rack for a C2 Coupe?
- 65 Fuelie emblems
- 1967 Bolt ons
- Funky color combo
- 396 BB question - head bolts
- 57 Heaven Museum
- 66' 4spd shifter install question
- 66 frame stencil& paint marks
- HELP - stuck ubolt in differential side gear yoke
- It's that time again...
- Buyer Beware
- 67 Red conv. with vinyl hardtop pic needed
- 66' Pulley Woes ! Help Needed Please
- Removing dents from door panel
- 62 Corvette tach
- rusty bolts and studs in the exhaust manifold outlet
- Plug wires for a 59 283
- Just in case you need one.
- spicer u-joints
- Gauge Repair/restoration for 61
- Clearance Issue
- Best C2 brakes?
- A few '66 Trim questions
- Aftermarket / reproduction hood & trunk
- Not another Oil Thread........
- Long Island Corvette Supply
- 66 head light motors
- Auto transport
- Resto Corvettes
- Tank Sticker/ Build Sheet
- Emergency Brake and Lectric Limited
- Need your vote - '56 Vette vs Ford, Camaro and Austin Healy
- 54 Wiper Switch Rebuild
- C2 owners with heavy modifications
- b-dolly
- Looking for pics of C2s with American Racing 200S
- Looking for acid dip in SE MI or northern Ohio
- Differential Crossmember Question
- Body nearly ready to be lifted, a few questions
- C1 soft top advice needed
- 63 Side Emblems
- Thanks to a Great Forum Member
- Mid-Year Front Bumper Straightening
- new CC door weatherstripping
- Noah Covers on sale - $149.95
- auxiliary weatherstripping 62
- Why Are The C1, and C2 Corvettes Lumped Together On The Forum?
- Looking for restoration work in Northern Virginia
- anybody know the thread size on the 7.5" lg lock out rod for a 66' 4 spd shifter
- RPO 686 on a 61 Corvette?
- Serpentine belt drive in C2:
- Prefer to Paint On or Off Chassis?
- How much loss of HP from drive train
- Doing My Best To Help A Forum Member
- Where do you get 'em?
- 2 people want to buy the car at the same time....what would you do?
- Quiet Side Pipe Option
- thank you DeWitts!
- Info on this 1963 F.I. Radiator??
- KYB shocks ??
- u-joints
- Heated Seat Kit
- SIDE pipes
- Cold air hood on a 66 part 2
- Part ID Help? (pic)
- Survivor Cars and the Judging of Them in NCRS Shows
- Side exhaust size...
- Elkhart blue 67 vert
- 64 Steering Column Collar/Trim
- 55-57 Passenger Car Forum?
- Seat foam for Leather vs Vinyl
- '61 loses dash and all back lights at night
- L79 Intake Manifold
- Vbp is driven
- 66 NCRS Judging manual
- restore voltage regulator and horn relay
- window post weatherstripping clips?
- [VIDEO] 2009 Toys for Tots Corvette Run
- 502 into a 66 BB car
- Question will large cap type HEI dist fir in C2
- Corvette Deprived In Houston
- Method for changing rear spring bolts
- glassworks
- No sale.. Just info
- A decade has gone by fast
- Importing a vehice C1 from Canada in US/Washington State
- stamp decode
- Flatout Imaging Corvette Posters on Sale for $9.95 (while supplies last)
- Exhaust installation 64, 327
- auto buffs
- Frame finish question
- OT - Monte Carlo help
- Rivet tool usage
- Original Shifter Issue
- what's the best method to fill/repair the top gap on the headlight bucket?
- 1958 Metal Finishes
- 64 temp gauge
- Goodguys Corvette - engine pictures - LS7
- I think i found the perfect 327 engine combo
- My 67 At The Body Shop!
- What is a good tach drive performance distributor for my C2?
- Soda Blasting Corvettes
- AutoBuffs ~ November ~ Complete Re-Paint Sale
- 57 Fuelie found
- disc brake help
- Question on `67 L-88 Corvettes and others without heaters
- Where is the Dodge ?
- Winter Storage Reminder
- 63 64 rear end assy. painted or not?
- Summit Racing Oil - High Amount of ZDDP (1800) - Anyone Using it?
- TPI in a 67 question
- Love my C6 but the C2 Vette is still my favorite!
- 63 hood vs. 67 hood
- 1963 air conditioning
- How to remove the seat slides on a Midyear?
- Sandblasting finished check out pics
- Front-end "CLUNK" in 63
- 54 Exhaust Note
- GM Ramhorn Manifold Part Numbers
- Question: Installing body mounts & shims on a 66'?
- Transmission noise in 3rd gear question
- Halloween story - no B.S.
- What do the drive shafts fit?????
- Post Restoration Torquing
- Dash Knobs for a 1957
- metal shavings on plug - is this excessive?
- 1960 Corvette New Owner - Window frame questions
- Spelling
- 1954 3 speed manual trans ?
- Hurst Shifter on a T-10
- Radio Push Buttons
- Corvette frames
- Would Leather be on the Trim Tag?
- 1965 vette Ronald McDonald House
- 57 Airbox Corvette
- I even have sand in my teeth
- Island Dragway, NJ - Pics 10/30/09
- Torquing Covette America Bolt-On Knock Offs
- are these needed
- Front suspension paint
- Advice on Car Trailer Cover
- Midyear Gauge cluster 2 letter codes
- I Need A 66 Judging Manuel
- Gas Sending Unit
- Decoding engine stamp number?
- Looking for 1965 # 1278
- Frame restoration
- Help reading C1 Dyno Sheet
- Engine date question.
- Best way to make payment.
- Thinking of replacing fuel guage sensor
- Its Friday:Time for a smile
- 1967 Corvette L-71 Dyno Day
- has anyone used summits 141series mags in a c2
- Nice E-Bay experience
- Check out this stamp pad
- 1956 Duntov option in pass cars?
- C4 guy needs help on C1 history
- 59Registry
- 63 fuelie crank
- C1 Soft top frame on ebay
- C2 frame question
- How about a seperate C1 and C2 Forum?
- Frame rail end caps
- Any Arizona Members Here?
- Ready to Switch to 5-Speed---Questions.
- Dash Cluster painting problems
- How bad is this metering block?
- Restomod vs. Original
- Is this a bad temp gauge 1960?
- Jacking it up
- Exhaust solution?
- Paint Chrome Finned Valve Covers?
- 1967 327 water pump for L79
- Cool C1 Solid Axle Corvette Posters (and Prints)
- Door Lock Mechanism Removal
- 131 Corvettes Destroyed
- What do you do to your Corvette for Winter Hibernation
- Is Cam Change Possible with Engine in Car?
- Last Dumb Question 1965 327/250
- Natural metal items
- Signode tool
- Dynamat installation
- Squeak is driving me crazy! Help!
- new top installed...have questions
- air cleaner
- 1961 Preservation
- opinions on doing a body off resto on a #2 car
- Why does my exhaust sound different on one side?
- Good Lord-Hemi Vette on ebay
- Cool C2 Corvette Sting Ray Posters (and Prints)
- c2 front frame bow
- Just when I felt I saw the light at the end of the tunnel!
- How can I tell if an ignition switch is GM Delco or not?
- Anyone ever use "Avgas"?
- Pistons for a '64 365HP
- Steering column spacing...
- 1964 z-06
- 1968 Corvette Rally Wheels on 1960 Corvette
- instrument cluster dim bulbs
- Question on side exhaust originality
- 1932 Ford Highboy Hot Rod
- A question for you resto-mod guys with ls engines
- Seat backs
- C2 inspection?
- Call to action
- Electrical Problem - Horn, Wipers, Interior Lights
- major garage and car envy
- T45 RS Transmission
- 65 door restoration
- 275/50 or 60/15's on what rims?
- Video - 427 Engine Test Stand
- 62 Rear Springs
- Gilmer System Complete, Pics Included!
- VIN Question on 1960
- Birthday for another one
- Heater Core Replacement on 66
- pertronix spark gap?
- Convertible top material question:
- Engine bearings
- Toning-Down Chambered Sidepipes:
- EnduraCool Header Reconditioning Sale!!!
- Al Knock upholstery compared to the competition.
- Problems with enclosed trailer TIRES
- More on that 58 Fuelie
- Panel alignment issue
- Rebuild 7 leaf rear spring?
- '62 restomod on ebay.
- Straight Frame and Six-Figure Budget,
- 2 questions...engine painting & what gaskets?
- Soft Top Delete
- More Pertronix Questions
- one of kind
- Vette junkyard closing
- 59 bellhousing?
- Choke
- Does this sound like a weak fuel pump?
- Top Install Video?
- Body mount questions on a 66
- 63-67 parking lamp fender to side louver panel connection
- 1966 clock
- Brick Thru my Garage Window/ Damn Thieves!!
- Update my 63 to power steering!
- Opinion on a price 1965
- Question on early production range in 66
- Like to meet Fl. owners ( keys)
