View Full Version : C1 & C2 Corvettes
  1. Wiring Harness question. Can I replace just the pins?
  2. can you de-code this engine
  3. Can you check oil level while driving YES
  4. 1953 thru 1955 Key Fob
  5. Oil Pump Question
  6. C-2 Steel Wheel Paint colors
  7. $ 75,000 cash .
  8. Anyone buy a 67 vette body from http://www.hitekhotrods.com/
  9. Conv. Top.
  10. Painting Engine
  11. C1 pwr windows
  12. Like to have PB or a hitch on your C1 "CHEAP"
  13. Valentine's Gifts for Ladies
  14. Stingray Concept Diecast 1:24
  15. I think I'm confused...
  16. Fuel Injection Manometer oil
  17. Old Drag Pics
  18. '63 gas gauge dead
  19. electrical turn signal?
  20. window switch?up forward or back?
  21. Fun in the Sun? Ice is Nicer
  22. c2 switched ignition wire routing???
  23. '67 BB on Craigslist-N. Nevada
  24. Need some clutch advice
  25. 1963 Knock Off Wheel Identification
  26. Help identify an engine.Is it correct for my 1964?
  27. custom plate
  28. Powerglide and the 427 Big Block
  29. 66 bb on ebay
  30. 18" Wheels on a C1 pics
  31. Gold Cad Plating source needed
  32. Another LS Crate Motor Question ?
  33. Pictures of a "perfect" car?
  34. First 1966 Corvette racecar on Display
  35. Midyear decklid spring mount
  36. Still running old tires? You wont after you see this!!
  37. 54 seat hook up question
  38. For those attending SACC convention, when are you leaving/arriving
  39. has anyone advanced the camshaft?
  40. Corvette valve covers
  41. power vs mechanical brakes
  42. Pertronix I And Flamethower Coil Hookup
  43. Pics: 60 repaint and refurb
  44. Best C1 restomod wiring harness/procedure...???
  45. Is there a comprehensive bolt/screw size list?
  46. Yes Another Fuel Gauge Problem Question on C2
  47. 66 390 holly carb
  48. 1965 396 Engine stamp, crooked "F"
  49. So Cal 78 Degrees Today-54,66,96 for a Ride
  50. Cleaning undercarriage
  51. C2 logo/emblem
  52. hdvettes :good guy
  53. Rear Wiring Harness
  54. What are these two clips for
  55. trim tag and vin tag - 1966 coupe
  56. Correct paint for 66 ?
  57. Corvette Fever '63 Cover Car
  58. Aluminum heads - manifold bolt thread repair
  59. 61 won't start????
  60. Interesting garage lift installed
  61. '61 Body lift - frame swap
  62. Glove box door restoration
  63. Trip 48 States map update
  64. POR 15 for undercarriage
  65. Date code question
  66. Rear End (Differential Carrier) Removal Question
  67. Spark Plug Wire Retainer Bracket Location?
  68. 63 vin 107941 motor
  69. Neutral safety switch
  70. 67 in hibernating for 25 years!
  71. Aussie 'Vette Nuts!
  72. C1 resto display
  73. 58-67 Radio/Speakers
  74. C1 grill teeth ID
  75. clutch size ?
  76. Free ( but probably wrong place)
  77. Red 59 Corvette Cove Colors
  78. Garage Envy:
  79. Slower with age
  80. Refinishing face gauges
  81. Anone ever install EFI on and older engine?
  82. Palm Beach Cruise Schedule
  83. Seen this yet? 789
  84. Seats Are Done-Pics
  85. 60 front sway bar bushings
  86. Now this is the worst job
  87. T-56 Magnum
  88. J61 Option
  89. What Year is this car?
  90. 1958 Hood
  91. ### St Jude Auction # 9 Time to shine ###
  92. clock and antenna fix
  93. Wedding day 1969
  94. Paint your car the Amercan way?
  95. Appelen, your 67 Restomod build
  96. Use of lifting strut on a C1 trunk lid
  97. Questions for you C2 restomod trailblazers
  98. Carter AFB #3362S
  99. Dry Cell Batteries
  100. Its Friday:Time for a smile
  101. Brake Bleeders Leak
  102. Photoshop help please on the 54
  103. Bringing an old vacuum advance can back to spec?
  104. Tie Tod ends LH? RH?
  105. So a Chevy T-5 just stabs in? Replace Mr. Muncie
  106. Further backup light questions
  107. Winter Regionals in Kissimmee, FL
  108. Gear ratio
  109. When Vets were DRIVEN
  110. Air Cleaner Breather Tube...Help
  111. I Think My Car is Working AGAINST Me...
  112. Any advice on replacing Carburetor on my 64 Stingray?
  113. Progress Pics!
  114. Update, machine shop FU
  115. Exhaust Sleeve Needed For Both Sides?
  116. Reflections in Glass Show Jan 16th
  117. Motor to gauge oil line. Cone the line?
  118. Forum
  119. Conv. top
  120. Petrox Voltage
  121. C2, has it been in an accident?
  122. What do do with the frame...help?
  123. Recommendations for weatherstrip kit for midyear hardtop?
  124. 1957 Seat Backs
  125. Por-15 frame restoration
  126. 270 bhp 2x4 solid lifters pistons
  127. Info on this 66 in Michigan?
  128. 1953 engine block and head L6
  129. Updated pics of the 54 resto
  130. 65' 396 Holley Carb
  131. Brakes
  132. Do you own 62 vin# 110109
  133. Front springs for for set-up?
  134. cool website old car brochures
  135. Remove Strut Bracket Process?
  136. What is the most desired part ?
  137. '61 Convert Lid Locking Mechanism.?
  138. TKO transmissions
  139. Can someone help me with this?
  140. Amp gauge failure on C1 Resto Mod
  141. Optima "blue top" battery Question
  142. 1st Close Out Sale Lund Bug Shields
  143. New Camero 6 Speed Restomod question
  144. N11 Exhaust.... Thoughts?
  145. 58 flywheel
  146. Attaching rear bumperettes to frame ('58)
  147. Steering Column Coupler
  148. 1954 fuse panel?
  149. Headrest Tension Spring
  150. Route 66 redux
  151. Whats it worth- Modified 64 roadster
  152. local funny auto parts story
  153. Wheel Cylinder Rebuilders
  154. HEI Distributor and Ballast Resistor
  155. Brittle Fiberglass?
  156. 63 booster
  157. 2nd.Annual Strictly Corvette Show
  158. 58 window frame repair
  159. New Vendor in the house
  160. Question on resto of 66
  161. New C5 Driver Needs Mechanic Near Palm Springs
  162. clutch boot and retainer
  163. Corvette Hospital, Des Moines, IA
  164. 64 Seat frames rebuilt as described below
  165. Throwout bearing question
  166. 66 Frame markings
  167. 1962 Vette: Enclosed Car Trailer
  168. Hot Rod Magazine's 289, 302's, 327, 350's and 351's Dyno tests?
  169. was this 61 a good deal?
  170. 62 Door pulls...white or chrome?
  171. 1963 headlight bucket adjustment
  172. L88 startup short video
  173. Original Hazard Lights
  174. GS roadster versus coupe handling
  175. Clutch Adjustments (66 Coupe)
  176. The best way to redo the undercarriage of a C2 frame on?
  177. Lowering a c1? How?
  178. Water Pump
  179. classsic engine co.
  180. 1967 steering wheel hub?
  181. Red 67 BB Coupe in Elmira, NY Please Contact
  182. Still Drivin in The COLD!!!???
  183. Virginia Vettes Free Shipping on BO & DBO Wheels
  184. 283 specs needed
  185. Trailing arm shims, and location water temp. sending unit.
  186. Z28 manifold and holley
  187. '61 bucking from idle
  188. 60 front stabilizer link length
  189. Anyone from Scottsdale, AZ?
  190. The real Small Block
  191. 4 + 3 Transmission?
  192. Ot clay bar
  193. My 65 restoration of Vettezilla
  194. 67 engine wire harness question
  195. speaker grille fit to dash c2
  196. Spare for my 64?
  197. Attaching point for 63 roadster seat belts?
  198. 63 u-joint viewing hole?
  199. Gas Additives
  200. Timing Light Recommendation
  201. Snap in Radio
  202. Dash pads; restorable or too far gone?
  203. 1963 wheels and spare questions
  204. Door lock knobs
  205. A.I.R. Vacuum Line Question
  206. Starter ID
  207. Happy Birthday to my car!
  208. Parking Brake/Firewall Insulation
  209. VAC calibration way off
  210. 62 decklid weatherstripping
  211. 45 new Corvette T-Shirts @ DD MODS including 12 for the ladies!
  212. 1964 Battery Location
  213. Coupe rear door gap and body shims question
  214. '66 BB exhaust manifold gasket ?
  215. When looking for correct parts for my 1964 Corvette.Date?
  216. fuel/air adjustment on AFB 3460s
  217. anyone know..
  218. 66 BB fuel Pump
  219. Frozen lug nuts
  220. 67 435 HP Coupe Project
  221. 1963 HP question
  222. Soda Blasting a '65 body?
  223. New Conv Top !
  224. dash components install order c2
  225. Pics of the new C6 with my C2
  226. For those who were interested in our A-26 progress
  227. It's Torch Red!
  228. 61 rear end...what's wrong with this pic?
  229. To Manual or Not to Manual
  230. What is correct finish for C2 hood catch assy?
  231. Cam ID
  232. Took the 62 for first drive since this past Summer
  233. 64 gauge cluster and transistors?
  234. Do you ever convert your Corvettes from coupe to convertible?
  235. Vacuum Advance for a 350HP L79
  236. Gear Ratio Change
  237. 64 Intake Manifold Question
  238. 65 frame numbers
  239. Parts 500 brake lines?
  240. control valve lubrication?
  241. What a day!!!
  242. c2 66 dash pad clips question???
  243. Anyone ever see photos of the 63SWC with jump seats?
  244. Power steering leak...
  245. 67 Transistor ignition board repair - parts?
  246. fuel gauge
  247. gas gauge
  248. Finding an old car
  249. I'm installing new seat covers in the 56, anyone need pictures?
  250. Soft top bow spacing
