- HEI Distributor and Ballast Resistor
- Brittle Fiberglass?
- 63 booster
- 2nd.Annual Strictly Corvette Show
- 58 window frame repair
- New Vendor in the house
- Question on resto of 66
- New C5 Driver Needs Mechanic Near Palm Springs
- clutch boot and retainer
- Corvette Hospital, Des Moines, IA
- 64 Seat frames rebuilt as described below
- Throwout bearing question
- 66 Frame markings
- 1962 Vette: Enclosed Car Trailer
- Hot Rod Magazine's 289, 302's, 327, 350's and 351's Dyno tests?
- was this 61 a good deal?
- 62 Door pulls...white or chrome?
- 1963 headlight bucket adjustment
- L88 startup short video
- Original Hazard Lights
- GS roadster versus coupe handling
- Clutch Adjustments (66 Coupe)
- The best way to redo the undercarriage of a C2 frame on?
- Lowering a c1? How?
- Water Pump
- classsic engine co.
- 1967 steering wheel hub?
- Red 67 BB Coupe in Elmira, NY Please Contact
- Still Drivin in The COLD!!!???
- Virginia Vettes Free Shipping on BO & DBO Wheels
- 283 specs needed
- Trailing arm shims, and location water temp. sending unit.
- Z28 manifold and holley
- '61 bucking from idle
- 60 front stabilizer link length
- Anyone from Scottsdale, AZ?
- The real Small Block
- 4 + 3 Transmission?
- Ot clay bar
- My 65 restoration of Vettezilla
- 67 engine wire harness question
- speaker grille fit to dash c2
- Spare for my 64?
- Attaching point for 63 roadster seat belts?
- 63 u-joint viewing hole?
- Gas Additives
- Timing Light Recommendation
- Snap in Radio
- Dash pads; restorable or too far gone?
- 1963 wheels and spare questions
- Door lock knobs
- A.I.R. Vacuum Line Question
- Starter ID
- Happy Birthday to my car!
- Parking Brake/Firewall Insulation
- VAC calibration way off
- 62 decklid weatherstripping
- 45 new Corvette T-Shirts @ DD MODS including 12 for the ladies!
- 1964 Battery Location
- Coupe rear door gap and body shims question
- '66 BB exhaust manifold gasket ?
- When looking for correct parts for my 1964 Corvette.Date?
- fuel/air adjustment on AFB 3460s
- anyone know..
- 66 BB fuel Pump
- Frozen lug nuts
- 67 435 HP Coupe Project
- 1963 HP question
- Soda Blasting a '65 body?
- New Conv Top !
- dash components install order c2
- Pics of the new C6 with my C2
- For those who were interested in our A-26 progress
- It's Torch Red!
- 61 rear end...what's wrong with this pic?
- To Manual or Not to Manual
- What is correct finish for C2 hood catch assy?
- Cam ID
- Took the 62 for first drive since this past Summer
- 64 gauge cluster and transistors?
- Do you ever convert your Corvettes from coupe to convertible?
- Vacuum Advance for a 350HP L79
- Gear Ratio Change
- 64 Intake Manifold Question
- 65 frame numbers
- Parts 500 brake lines?
- control valve lubrication?
- What a day!!!
- c2 66 dash pad clips question???
- Anyone ever see photos of the 63SWC with jump seats?
- Power steering leak...
- 67 Transistor ignition board repair - parts?
- fuel gauge
- gas gauge
- Finding an old car
- I'm installing new seat covers in the 56, anyone need pictures?
- Soft top bow spacing
- Need picture of an early 63 Sparetire tub lid
- Bought another Corvette Yesterday!
- Restored Dash Pads Today (pics)
- Race car pics thread?
- Holley 4160 Rebuild Question
- C1 Positraction Axles
- Windshield Trim Not Fitting
- parking brake pulley
- Question about knock-offs
- Pressing brake pedal illuminates turn signal indicators on 59
- 63-67 Hood Measurements
- dash pad insulation c2
- •• 2010 Short Block Special ••
- Dropping Steering to pull oil pan ???
- 1957 Dash Knob Letters
- Epoxy kits on garage floor?
- How many oz of posi additive needed in rear, 4 or 8?
- early 1960 block !?
- 67 factory ac parts value
- How Much??
- emblems
- For those with Race Ramps...
- Its Friday:Time for a smile
- Happy New Year! Any Corvette Resolutions?
- Any 63 Grand Sports Coups Out There
- $100 Garage makeover
- Fuel pump 350 crate block 10066036
- Now I've Seen It All
- 64 hubcap mistique
- 2 questions on a 67 SB
- Is this an early 57 Posi??
- Bump steer with rack and pinion
- 56 convertible header weatherstrip and wedges
- new carpet install- rear carpet conv. 65 at spring area
- Washer actuator installation
- Limited Time Diecast Sale!!
- 63 interior windshield moldings finish
- This shop delivers correct engines for my 1964
- Kissimmee Meet:
- Rad support help needed
- 1963 fuelie
- ~~~~ St Jude Auction #6 Autographed Corvette Racing T-shirt and hero card~~~~
- Dash Pad Replacement
- Looking for pins that hold heat shield on intakes
- Unbieveable Corvette Engine Story
- Carol Yenter corvette
- 63 motor
- Distributor rebuild questions
- rocker chanels
- Hardtop guide pin
- Throttle linkage travel
- How to, w/c paint
- Cowl, steering wheel shake on 59 resto rod
- 59' Convertable Top
- Non Functioning Odometer
- C-1 paint mod
- Adjusting valve lash - Solid lifter
- 1967 f 41 shocks
- C1 road draft tube to PCV conversion
- Late Model Auto Trans Question
- All Corvettes w/ leaky roof recalled
- Hardtop Weatherstrip Replacement
- chrome shop in TX
- How to repaint my gauge cluster and glove box door?
- Have 2 Wells TU 5's, which one is better?
- tips how to refurbish the gauge cluster for a 1965
- What Was The Best C1/C2 Thread Of 2009 ?
- 1963 Split Window Question
- How to plug the oil by-pass adapter?
- 1960 Body Off onto Rotisserie
- Upper A-Arm removal on 66 BB?
- "bb terror"
- 63 info needed
- Production halt in 66 why?
- What I like about original low mile CA cars...
- Last Ride of Year
- 67 BB Air Compressor Brackets W P/S
- Cam "break-in"? (WARNING: Dead Horse Content)
- 63 swc- for sale??
- Does anyone know this 67 427 roadster?
- 67 427 rdstr is YELLOW should I change it
- Stamped Steel or Aluminum 7 fin?
- Price estimate to have an engine built in the US?Anybody here that knows?
- Richmond Transmission HELP!!!!!!!!
- TKO-600 5 speed in '61
- Dash Harness Install
- Throw out bearing for C1 vette ?
- camshaft for a 327 in a C2
- Id'ing a fuelie without a fuelie engine
- 1.6 rocker clearance
- Paint cracking
- any solutions for hood paint bubbling
- Hubcaps before After
- 64 Disc brake upgrade master cylinder questions
- Liquid Ebony
- Wiper Motor Removal
- Painting parts..
- Retraction
- How to remove rod from Light Switch
- SWC pricing
- Luggage stop replacement
- 64 Barn find
- Exhaust Manifold Paint
- ZZ3 crate de-tune (OT somewhat)
- Tire question- Correct whitewall width for a 66 ?
- A Corvette with a metal body?
- Independent Rear Suspension
- nassau blue question????
- How much for my Redlines?
- LS 3 In C-2 ?
- Help finding 1961 NOS part numbers??
- Shimming body....door drags
- 58 only Bumper seal
- How Do You Recondition Exhaust Manifolds?
- Please recommend shocks for 66 BB
- Ring and Pinion - How to Identify?
- Looking at this 57 on e-bay
- Early 66 seat belt tag
- 63 seat belts
- It is fired up!!!
- 64 Soft top question
- Starter wiring delema.
- door pulls
- How Do You Get 47 Years Of Stuff Off A Grille?
- Corvette factory on now on Speed
- Kelsy Hayes KO date codes
- 57 vette wiper shaft
- Frame isfinally completed!
- Last one
- Hacked Forum!!
- Pulled the Rear out today
- parts clear coat
- is my 1962 center console 1 piece or 2 ?
- Oil Pressure & Volume Tutorials
- Corvette export website... very cool
- High Oil Pressure ??? Way High !
- Who's Reproducing the Holley 3367???
- Ebay car in question
- alternator pulley identification
- Frame swap question??? Is this possible or available??
- Firing Day
- Dark Green Pulleys on 65s?
- tork nuts on exhaust manifold studs?
- Fan Clutch Attachment
- after chemical stripping wash down
- Drive It
- OT, Avenger or ?
- 1966 Coupe Headliner
- front springs for a 65
- Best LS crate engine deal??
- 1 & 3 wires
- 1957 Corvette Survival rate
