View Full Version : C1 & C2 Corvettes
  1. Repairing windshield tabs on 59, must I rechrome mouldings
  2. 427 crankshaft runout and main clearance
  3. wiring diagram for 59
  4. B-W T10 4spOD
  5. dewits rad. w/elec fan
  6. Pics of new engine
  7. What a day
  8. Lost fitting frustration
  9. '66 vert inside windshield molding -can it be polished?
  10. OT: El Caminos
  11. Chambered Sidepipe Rear Hanger?
  12. Engine Mount alignment - 66' vette???
  13. CWC Camshaft info needed
  14. Over drive.
  15. A/C question
  16. hesitation help
  17. '65 starting problem
  18. 63-67 small block
  19. 1963 z06
  20. C2 ID Alum Tag 460LB
  21. Project No Flight?
  22. C2 Headlight Bucket Allignment
  23. Blowing radio fuses
  24. sealer recommendation for paint
  25. Door key won't unlock
  26. Which Holley Carb?
  27. Any thoughts on this one on ebay?
  28. 59 60 tail lights
  29. how does this connect?
  30. Looking for 67 Marlboro Maroon pics
  31. Restoring 67 steering columns
  32. Gauge cluster questions?
  33. 1967 Corvette what's it worth?
  34. Borg Warner Question
  35. Sebrig Historic Races Today.....Some Youtubes for you
  36. Willcox New Wiper Motor Testing Video
  37. My '5 turns approx. 45 years tomorrow
  38. power antenna problem
  39. knock-offs' vs repro's
  40. C-1 road trip milage limitations
  41. 100 amp alternator in a C-1
  42. C 1 aluminum radiator coolent
  43. 66 vert weatherstrip
  44. Nice Weather Today
  45. knock-offs
  46. 1960 Resomod Seat Options
  47. Just out of curiosity, does anyone let their hood just drop for closing?
  48. Where to buy fuel sender?
  49. Press Release MTI Racing Machine Shop
  50. Installing after market radio
  51. engine info
  52. Dynamat Question?
  53. Table of contents for AIM on a 60
  54. Antenna bracket...which bolts?
  55. portland swapmeet?
  56. Its Friday:Time for a smile
  57. LIC 1965 Wheel Covers NCRS Judging
  58. Will a 66 differential work on a 63
  59. C1 "alternator" brackets, drivers side ?
  60. 1966 clock knob removal
  61. Attaching the Hardtop
  62. Question about 63 wheels & Jack
  63. 56-60 hardtop restoration - update
  64. L-79 head specs
  65. whats it worth a C1 Soft top
  66. Best Trailer Deal I've seen...
  67. Wiper motor rebuild for 66 vette ???
  68. OT: Tie rod ends
  69. Clutch Fork, '62, vendor recommendation?
  70. 1963 hood alignment blocks
  71. 65 N11 Exhaust?
  72. 1964 corvette
  73. My Exhaust search is over.. :)
  74. C 1 corvette owners on SINY
  75. speedo gear for C1 source info
  76. Our Modified 65 .....
  77. Feeling Less than "Manly"?? Solution!
  78. Atlantic city all vette show 2010
  79. '62 VIN # location(s) ?????
  80. Radiator cap TOP gasket leak
  81. Comical lack of directions for parking brake kit from Van Steel
  82. markings
  83. Ignition wiring for 65 Fuelie
  84. Whats a good torque for tie rod end bolts?
  85. What goes in a C1 drip rail?
  86. B-Pillar seat belt install
  87. Looking for Goodwood Green Pics
  88. Power Brakes for Custom 58
  89. remove and cut coil springs 1961 Advice?
  90. GE 257 bulb cross reference number for a 60
  91. Is There An Easy Way to "Aim" 67 Headlights
  92. advice on '66 resto/resto mod
  93. Cuting the excess off of the dash pad
  94. Need info on oil pan
  95. t 10 speedo gear color help please C1/61
  96. Slot Wheels on C1 or C2's
  97. Michigan residents- ATTN- Urgent action needed
  98. Tach / Cable Adjustment
  99. 65 Tailight operation.
  100. Restmod Manual VS Auto
  101. Smart Struts on 63
  102. I re-installed my rear spring today on 63 and noticed..
  103. How far do you go Restoring your car?
  104. How to Identify wheel for 63.
  105. Muncie M22 capacity?
  106. do you guys put covers on your cars?
  107. SB to BB...the transformation begins...woohoo
  108. 6 tail lights
  109. Swap Meet Steal of the Year
  110. Wo-hoo!!!!!!!!
  111. First Gear could you please
  112. •► ► TOTALLY FREE DRIVETRAIN INSPECTION - at Corvettes of Westchester - FREE ◄ ◄•
  113. Bloomington Recognition
  114. Parts Discounts
  115. Long shot for paperwork on a 1958 #7111
  116. Where did my $#@#$ elec go ?
  117. Restoration
  118. Difference in vendor hoods
  119. Body work on the frame
  120. Corvette Montage
  121. Tips and Tricks For 63-67 Headlamp Assembly Rebuild?
  122. Our 63 Coupe going to a New Home.....
  123. Fuel Line
  124. Ohio car - need evaluation
  125. Who Manufactures C1 Shifter assemblies
  126. Cost to install a 56-62 Hardtop Headliner?
  127. Underbody
  128. Does anyone make a repop spring...
  129. C5 Door Handles on a Midyear
  130. Help on info for tire and wheel size
  131. C4 Seat Install into C2 Photos
  132. C2 Body, Flowing or Angular & which BB Hoods matches body styling?
  133. Gear oil
  134. Vin # question
  135. Fixed Gas Leak on 63
  136. 327 Head Selection
  137. Door Hinge repair
  138. Capacitors on C2 guages
  139. e-brake light & lighter questions
  140. Corvette Club Mtg in La Plata, MD (3/1/10)
  141. Do you torque it?
  142. Just another horror case !!!!!!!
  143. 60 black round wire connect location from harness
  144. Terry cloth seat protectors
  145. amp meter help please
  146. '54 Corvette V-8
  147. Hidden radio antenna for C1 resto mod
  148. accelerator ground strap
  149. Rack and pinion width?
  150. oil pan gasket leak fixed!
  151. Trailing arm and spindles
  152. Gas Gauge Calibration
  153. Replacing welded rear exhaust on a 1963
  154. Any Feedback on the RediRad?
  155. Someone just got a great deal on eBay
  156. Ignition switch
  157. Winter Project(s) --- Completed
  158. oil pressure line advice
  159. What Intake is it?
  160. Looking for Silver Pearl Pics
  161. Does anybody know this 1966 BB Corvette?
  162. C2 what's the paint color for the inside of instrument cluster?
  163. Best prep advice before paint needed..
  164. Top O' the pillar to ya! Hinge that is
  165. Hanging nose and quarter on '66
  166. 66 power steering
  167. 66 Roadster non power steering
  168. Disc brake torque specs
  169. pilot bushing help
  170. 67 Turn Signal issues
  171. POP 116211 396-425HP on flea bay
  172. Lubricated my vent cable w/o removing from the car
  173. Casting Mark Ques on 2.5 Inch #901 Ex Manifold
  174. 66 knock off center caps
  175. heater box finish
  176. 59 hood release cable repair
  177. 63 dash question - vinyl on center section?
  178. Tight Screw and Straight or Curved?
  179. The C1 driving Experience?
  180. Tire Recommendation...
  181. 1960 gold emblems in hood/truck
  182. 870 Block
  183. 1963 Coupe #117307 - It's your lucky day!
  184. 300 vs. 350 hp engine in a 66
  185. Got the seats & belts installed today
  186. Idler Arm. Heavy duty?
  187. better pay your bills!
  188. Power steering fluid; which one?
  189. Any Stories of C1's in Fuelie Fires?
  190. Tie rod end replacement procedure?
  191. Whats the DUMBEST Bubba-ism you've seen.
  192. Here is headlight relay wiring diagram
  193. C2 candidate for a FUGLY award.
  194. 66 tele column
  195. Last month of service here..
  196. Hesitation or Dying on a Hot day!
  197. Hardtops on craigslist
  198. Side Exhaust Question
  199. Correct factory idle RPM on 65 L-79 with A/C
  200. Mother Nature does it again.
  201. 1960 VIN decode help!
  202. lunch with Frankie the fink
  203. 1965 Corvette - TSB #774
  204. 1964 ignition shielding
  205. Need some help with door 63swc
  206. '61 Hubcap fitment
  207. Body rack feeler
  208. Power steering or not?
  209. Body Finish
  210. C2 Distributors
  211. 64 Fuely on Fee Bay Question on Dates
  212. it's friday time for a smile...vic z
  213. Pulling winshield posts on C1, time required to do so
  214. new tranny doesnt work
  215. How do you remove swivel stud from mirror base?
  216. "Awesome" Grand Sport Custom on Ebay
  217. Need "real" 67 427 Scoop
  218. Pics of my restored 63 gauges
  219. Cluster capacitors for a 64? Wich and how many do i need?
  220. Free Shipping Offer from Corvette Central
  221. '56 Rearend question
  222. Door alignment... or the lack of it
  223. 1961 grille cover Chrome or Black?
  224. Temp guage problems
  225. C1 Tail light Assembly Re-Chrome?
  226. 64 Trip Odometer
  227. interesting trade
  228. Help requested decoding engine VIN number
  229. Mounting doors ???? on a 63
  230. C1 big block?
  231. Seat Belts ( Almost Absurd)
  232. C1 (1960) Deck Lid Problem
  233. Replace or rebuild brakes
  234. T and L Engine Development
  235. Exhaust Flange
  236. why do we work on our vettes ?
  237. Are These Heads Cut for 2.02 or 1.94 Valves?
  238. 65 Coupe Resto-Mod
  239. ~*~* St Jude Auction #26 Bart Starr Autographed Football ~*~*
  240. ~~~ St Jude Auction #25...Another one for the baseball fans ~~~~~
  241. Cockpit Cover
  242. Can anyone ID this chrome piece?
  243. Installed new tank in my 63 today.
  244. Charity Autocross - Saturday March 27th - Grissom AFB
  245. Corvette Walker
  246. What to powder coat
  247. Thinking about long tube headers...
  248. 63-64 front grill
  249. I never sausage a thing.
  250. Shipping a rolling chassis.
