View Full Version : C1 & C2 Corvettes
  1. Any collector value to this block or heads
  2. Welding a stock frame solid?
  3. 1967 Steering column cover ?
  4. Seattle Tacoma area get together March 20
  5. Advise needed-Holley carb Permatexed
  6. So...what are these worth$$$$$$
  7. C1 Article on Line
  8. Need help posting pics
  9. Parts Plant Dealer Tag
  10. Vintage, Classic, or Hot Road Air?
  11. Need advice on correct color paint
  12. Smokey Yunick Son on Power Block/Spike
  13. Need pics. of this part.
  14. Anyone ever regret selling their C1 for a C2?
  15. Pics from Cars and Coffee... Raleigh, NC edition.. dial up be scarddd
  16. Borgeson Install is finished in my '67 BB
  17. Dash Board Install
  18. need advise on wheels and spacers
  19. A couple more smiles Fri eve.
  20. Instrument cluster part number question
  21. Ready to drop the body..........
  22. Small block engine question
  23. Black Hills Corvette Classic 2010 - July 13-18! Registration now OPEN!
  24. Interior fiberglass finish
  25. old nj corvette repair shop mark auto body
  26. car history on a 1961.
  27. Newbie Needs Help !!
  28. Aluminum repro or GM Lid
  29. Reinstall Center Dash in '64
  30. 1966 Wheels Knock offs or Original Steel???
  31. 63 C2 Carpets who makes the best?
  32. Can someone post a picture of 64 parking brake switch
  33. 60 soft tops
  34. I have an L71 motor and would like to find the original car
  35. Going to look at a 66 vert tomorrow
  36. Restorod Brake question
  37. Need more info on a 63 NSS.
  38. SB driver's side battery can someone post a picture
  39. Fiero seats in a C2 ?
  40. Hot Rod Air (AC) in a 66' vette ??
  41. Vehicle Transporters
  42. Trans numbers on the tag...
  43. Is this tag original to my rear diff? and decode ?
  44. Pertronix Coil
  45. Bubba being unsafe ...copper brake line!
  46. VIN and Title/Parts Car
  47. Anyone going to Corvette Mike's in Anaheim saturday...
  48. Corvette Polo for Kids
  49. How to remove steering shaft
  50. Parking brake help
  51. Pulley Picture
  52. Another birthday!
  53. Lone Pine/Bishop scenic tour
  54. Reproduction 65-67 clock
  55. Borgeson steering
  56. Pre-Purchase Inspection Needed
  57. 1967 C2 Article on Line
  58. Cars you've been over 100MPH in
  59. Its Friday:Time for a smile
  60. What is a 64 stock radiator worth?
  61. recent work
  62. 63-67 hardtops
  63. 63 vette
  64. For those who have set up a Superlift SR-7H
  65. 1960 Exhaust manifold questions
  66. 1965 original door panels...saveable???
  67. Bad day for the cmcs household
  68. Pancake air cleaner
  69. off to the Shop!
  70. Please help ID my steering shaft
  71. Noted Drag Racer Seriously Ill
  72. 1966 wheel date
  73. what should I pay for this soft top for a 1961 pics
  74. 461 and 462 heads. What is differerent?
  75. Cost of Adding A/C to a 66 Coupe
  76. Restorod - Need Advice
  77. Pertronix
  78. C2 Alignment Problems - Upper Control Off-Set Kit
  79. power steering pulley and pump bracket
  80. 1968 hardtop value
  81. Back of coupes
  82. 63 neutral safety switch ???
  83. Define 327 with 350 cam
  84. C2 How many still exsist?
  85. paarts diagram shifter 4 speed T0-10 1963
  86. Firewall number?
  87. Brake distribution front rear on a 1964 drum brakes?
  88. Anyone have picks of your 64 coupe power vent Assy?
  89. Midyear's - What % today with Original Engine?
  90. No Gold Tour at Bloomington Gold show this year??
  91. Recommendation for Red line tires on a set of Bolt Ons
  92. Clock points and clock bezel questions
  93. " Appears to be the real deal "
  94. C1 steering column disassembly
  95. New wiring on 60
  96. Windshield gasket help needed
  97. Wich and what kind of brake lines do i buy to use on my 1964 using 1974 parts?
  98. speedo gear for C-1/t10
  99. Which A/C Compressor Cylinder Assembly is correct?
  100. C 1 gas smell in car
  101. A few 66 bolt on wheel questions
  102. NEW vs OLD ????
  103. TEXAS56 are you out there?
  104. Would appreciate advice on cracked steering wheel for '65.
  105. The Lombardo "Buckshot"
  106. No news
  107. optima users- hold down
  108. pictures of stock 11:1 L-79 pistons?
  109. '64 Wider Front Fenders?
  110. C5 Z06 seats in a C2 ???
  111. Adhesive for Rear View Mirror
  112. Paint Prep work?
  113. Dragracers: I'm Beefing Up The Rear End.
  114. Transmission Colour?
  115. 390 HP carb
  116. Are these parts from Paragon NCRS approved
  117. Single to dual master cylinder
  118. $110K Another Grand Sport On Ebay
  119. Vent window rivets.
  120. 66 Carb question
  121. Keen Parts at Houston Corvette / Chevy Expo 3/21-22
  122. Local car cruise montage on youtube
  123. Who sells grommets for the light tubes
  124. Capacitors for instrument cluster
  125. Help Dating Enameled Emblem Please
  126. Duntov Lightweight on Ebay.....
  127. cool video
  128. Jet-Hot Coatings Re-Joins The Forums
  129. Drilling Through Fiberglass
  130. 63 Hood latches and holder color
  131. 104 mon octane
  132. Option, vehicle values and Comparables..
  133. I scratched my bumper and need help
  134. Soft top Frame Adjustment
  135. price for seat covering
  136. C2 Seat Swap Question...improper alignment
  137. info needed on 63
  138. Hard starting Holley on my '66
  139. From Junk to feature car Corvette Magazine
  140. out door cover
  141. Article About C1 on Line
  142. Fuel Pump Pushrod Incompatible with Hydraulic Roller Cam?
  143. C2 1965 Coupe Gas Tank Install Help??
  144. Whats this bolt hole for?
  145. C2 Gauge construction
  146. Changed oil - found this - what is it?
  147. Knock off Wheel Security?
  148. Dealer Window Stickers
  149. Blake RBwamsley How is the car Comming?
  150. Generator #1102828 - Anyone know what it is??
  151. Old Corvette Pics
  152. ***** St Jude Auction #30 Spring Training ******
  153. Cheap Vettes in the Philippines
  154. Identify this air cleaner?
  155. Painters: what primer/sealer for the underneath
  156. Block Cast Dates
  157. who rebuilds wiper motor 66 Corvette
  158. How much to pay for a really nice 62 rolling chassis?
  159. Alarm reset procedure 1988 Corvette?Any here knows how to reset the alarm?
  160. 58 engine and trans numbers??
  161. Wiper Motor is Bad
  162. Russo & Steele Damage Settlements
  163. brake pad fit on 65 C2?
  164. Short Throw Shifter
  165. Harmonic Balancer for 327/300HP
  166. Just bought a 63 split window - need insurance advice
  167. 270HP tune up info
  168. 3 point belts
  169. throttle stick??
  170. Hardtop mounted
  171. 66 Vert Brakes are locked up!
  172. 1957 Dual Fours Airvalve Arm Lenth
  173. Anyone ever buy a power steering kit?
  174. Steering wheel source for my '57
  175. Does your C1 (or any Corvette) seat kill your back?
  176. Installing timing chain and gears on 61
  177. 1964 Corvette Service manual
  178. Need help on 58 hood latch firewall stud plates
  179. jerry bramlet - need fuel inj to restore
  180. Power Antenna Question
  181. 67 Bolt On Centre Cap
  182. Happy 50th to my '60!!!!!
  183. It seems there is a 3rd 1953 Corvette #029
  184. Dyno Day for my 1957
  185. Issue with 454 Harmonic Balancer....maybe
  186. What a birthday present for (from?) my 67
  187. Pully Size
  188. 1953 engine block
  189. Carter AFB info??
  190. 1967 trim tag
  191. O/T Let this be a warning about shaving while driving
  192. Temp gauge question
  193. Replacement of my circuit breaker
  194. A car from the past
  195. Paint Color question Re; Milano Maroon
  196. First start of the season with FI
  197. Holly problems ( Anyone else ? )
  198. Wiper motor restoration
  199. 66 - Corvette Inst. (Fla) Dash Wiring
  200. mountain driving?
  201. Signage
  202. Power steering hoses
  203. wiper motor interchange
  204. Changing Heads on 327/300 HP 1967
  205. reconditioning knock-off spinners
  206. Car Show - How long have you owned it?
  207. No. Cal/Silicon Valley - Car Events
  208. Bad Start to the spring
  209. window upper roller track
  210. 66 Sunfire Yellow
  211. New front and rear end
  212. Repairing windshield tabs on 59, must I rechrome mouldings
  213. 427 crankshaft runout and main clearance
  214. wiring diagram for 59
  215. B-W T10 4spOD
  216. dewits rad. w/elec fan
  217. Pics of new engine
  218. What a day
  219. Lost fitting frustration
  220. '66 vert inside windshield molding -can it be polished?
  221. OT: El Caminos
  222. Chambered Sidepipe Rear Hanger?
  223. Engine Mount alignment - 66' vette???
  224. CWC Camshaft info needed
  225. Over drive.
  226. A/C question
  227. hesitation help
  228. '65 starting problem
  229. 63-67 small block
  230. 1963 z06
  231. C2 ID Alum Tag 460LB
  232. Project No Flight?
  233. C2 Headlight Bucket Allignment
  234. Blowing radio fuses
  235. sealer recommendation for paint
  236. Door key won't unlock
  237. Which Holley Carb?
  238. Any thoughts on this one on ebay?
  239. 59 60 tail lights
  240. how does this connect?
  241. Looking for 67 Marlboro Maroon pics
  242. Restoring 67 steering columns
  243. Gauge cluster questions?
  244. 1967 Corvette what's it worth?
  245. Borg Warner Question
  246. Sebrig Historic Races Today.....Some Youtubes for you
  247. Willcox New Wiper Motor Testing Video
  248. My '5 turns approx. 45 years tomorrow
  249. power antenna problem
  250. knock-offs' vs repro's
