View Full Version : C1 & C2 Corvettes
  1. Radiator Hi efficiency Re-core
  2. What's it worth ?
  3. Dog dish hubcaps
  4. trans/clutch woes
  5. speedometer drive gear install.
  6. 1956 sr-1
  7. Put the Torq Thrusts on my '66 Today!
  8. '61 hardtop front weatherstrip
  9. Motive Bleeder Help
  10. connecting speedo cable
  11. A big thank you to DeWitts!
  12. Pate Auto Swap Meet, Texas Motor Speedway, April 29th-May 2nd
  13. K/Off problem
  14. Hardtop weatherstrip treatment
  15. '63 headlight rotate switch question...
  16. 64 #2 body mount
  17. Carb. Spacer - 65 BB
  18. C-2 transmission removal
  19. 65 headlight harness question
  20. Carpet Help
  21. graigslist scam
  22. First Drive This Year
  23. Capacitor - what does it do?
  24. He who hesitates......
  25. Master cylinder wont fit. HELP
  26. Carb rebuilder in So Cal
  27. hole in manifold
  28. Finally set the body back on and.........
  29. Is there a list of authorized Chevy dealers that were in business in 1965?
  30. Need some help with MC/ power booster
  31. Trim Code and ECL question
  32. Question on knock offs
  33. 62 afb gaskets and spacers intake to carb
  34. stamp pad font
  35. Supercharger kit for 56-61 2x4s??
  36. Any body have an accelerometer?
  37. Alternator short??
  38. Engine component cleaning before assembly
  39. 4th Annual Corvette Party at MacMulkin Chevrolet COMING SOON!!
  40. Correct Early 58 FI Crankshaft damper
  41. Power disc brake conversion- 65 Corvette
  42. PS steering box conversion kit
  43. windsheild wiper motor restoation and install
  44. So my Muncie won't go easily into 1st gear
  45. Puzzled about Engine Decoding on '64
  46. Pictures of the Hot Springs Corvette Weekend
  47. Best repo trunk mat for '60?
  48. A classic Japanesse Corvette
  49. An ugly custom - 1960 Chrysler
  50. I bought a 1965 396 Convertible
  51. Protecto-O-Plate
  52. Steering wheel position
  53. youtube video 1961
  54. wheels and tires options opinions please...
  55. Shopping For Parts, And Ways To Save $$$
  56. 1953-54 corvette at malcom konner
  57. Carburetor MIA
  58. 65 Carter AFB Rebuild in VA?
  59. Hood original or not?
  60. Why do T10 pop out of gear when getting old
  61. BFG Silvertown Radials from Coker
  62. C1 Seat Track Repair - How to website...
  63. 63 /340 Hp 4 speed rear ratio??
  64. Saw this on the auction site.
  65. Steering box/wheel/alignment mystery (kinda long with lot of pics)
  66. May 8th Show in Las Vegas
  67. 63 SWC update
  68. changing motor on C1
  69. Restoration Insurance
  70. Heat Shielding the Trans Tunnel ?
  71. Bouncing Speedo (Engine & Trans are out)
  72. How many or what Color for different years
  73. Wheel alignment - Getting tough to find a good shop
  74. Centering Steering Wheel ?
  75. What to do if my hood won't close ?
  76. Spring Woes Continue
  77. Borgeson Power Steering Conversion Help
  78. Condenser on coil goes?
  79. '66 fuel,batt, and temp guages dont work anymore
  80. Fried wire!!
  81. New Ebay low
  82. 65 Corvette Hubcaps $150
  83. Grand Sport (replica) Vs C6 Z06
  84. 17" wheels any regrets?
  85. Corvette Friends Helping Veterans
  86. Any pics of a C1 with a Big Block
  87. VettPacks Installed - Video!!
  88. 327 cam/head selection.for 300 + hp
  89. C1 283 heads
  90. Long Beach Grand Prix Corvette
  91. Radio problems...
  92. Mongoose Tool needed
  93. 61 Dash Pad Question
  94. can a fan clutch do this?
  95. How many made with........options
  96. Ring/Pinion Question
  97. License Plate Screws
  98. How do you know if your carbs are percolating?
  99. first time on the highway today.
  100. Finally Back
  101. How can an engine with a 68 block be called a 63 Fuelly???
  102. 4 way flasher wiring diagram??
  103. Fuel Pump issues (another story)
  104. Vent window regulators
  105. Anybody running a zinc plated Holley?
  106. Some Pics of the 66 Garage find
  107. stud
  108. 61 balancer: to paint or not to paint
  109. Distributor install question
  110. 64 Tire size
  111. 62 die cast key chain
  112. Paddles 4 sale
  113. Tunnel insulation question
  114. Battery 101 re-visited..........
  115. 17" Torque Thrust II's for a '67?
  116. McCullough Super Charger Value
  117. Gm wheel part number
  118. Do you have a ZZ4 or ZZ383 in your C1?
  119. Mid year hardtops
  120. Need help with Installing '66 vert front window channels
  121. 1959-Ignition key stuck
  122. Need Opinions
  123. Braille Batteries
  124. Distributor Spring Question
  125. Exhaust question for cars with LS Motors
  126. A friend's unrestored 57....photos
  127. Check out this 1966 427 425 hp on ebay
  128. Help with a grinding noise in brakes, supension bump....
  129. Does anyone recognise what type of plane this is?
  130. dash pad help
  131. speakers behind seats c1.
  132. need a measurement 59 axel
  133. 63 project on craigslist
  134. Heating problem - questions?
  135. 65 break booster ?
  136. '61 hardtop front weatherstrip
  137. Progress on the 65 FI coupe project
  138. alignment shop in ausitn tx
  139. radio reception in my '65
  140. C2 63 accelerator pedal wooden spacer
  141. Michigan? looks like a good buy on c1 windshield $30.00
  142. '65 seat belt retractor
  143. I want disc brakes....
  144. Squeaky Rear Brake
  145. Starter Solenoid "C" terminal
  146. Hot Rod Power Tour
  147. Which would you pick?
  148. Reproduction Steering Wheels
  149. 59 axel width
  150. Restorod C2
  151. What is the ranking of values of C2's?
  152. Need Opinion
  153. Its Friday:Time for a smile
  154. What is the change in RPM's
  155. The 57 Super Sport
  156. Borgeson PS Conv. Pulley
  157. wheel offset and tire size c1
  158. It must be "59" week.....
  159. 1965 Fuelie
  160. replaceing heads
  161. Fiberglass issue
  162. How to pay for a car...Long Distance
  163. New Video of the '67 L89
  164. Bottom line on 63-64 ONLY carpets install?
  165. LED tail and turn lights ?
  166. adding PS to our 66- whats the best approach
  167. Bad Fuel Pump
  168. 1961 Hardtop (cont'd)
  169. '66 question about sidepipes
  170. Muscle Car City
  171. c1 cragar offset and backspace
  172. Carburetors
  173. [66] Clutch pedal
  174. Spray Chrome?
  175. Radio for 63
  176. 62 Gas Caps
  177. Carburetor induction ls1........?
  178. 54 vette
  179. Tail Light Fuse Blown ?
  180. Looking for 1962 corvette owner
  181. TI Problems
  182. headlight wiring and amp meter wiring
  183. 2010 shake down cruise C 1
  184. my birthday gift
  185. Which leaks the worst . . . C1 or C2?
  186. Exhaust starter motor clearance
  187. Battery charger for Gel, AGM, standard battery.
  188. Shipping a Car
  189. where did this fastener come from ?
  190. Military discount- which vendors offer some type ?
  191. Foolish move!!
  192. Bought a '61/'61 hardtop this morning
  193. Corvette America to Carlisle
  194. 63 pricing
  195. Eckler's press molded hood for 1960 C1
  196. C-2 console
  197. Nostalgia Drags In NZ
  198. Wind Blocker on '67 for the wifey
  199. How much torque on ring gear bolts?
  200. Clutch cross shaft stud broke
  201. 63 327 block code
  202. 62 door post question
  203. 4346 Fuel Pump Rebuild Kit
  204. 1964 - Steering loose - Lots of Play - FIX??
  205. 55-64 carrier bearing?
  206. 59 barn find--part 2
  207. Factory correct paint
  208. KUDOS - Virginia Vettes
  209. A little humor
  210. what's it worth?
  211. One of Those Days
  212. People with headers
  213. Memphis, TN Body Shop Needed
  214. Need help
  215. Question about distributor install
  216. Aluminum Intake Manifold Refinishing
  217. '63 C2 ignition lamp?
  218. C-2 Coupe Resto-Mod Coil Over Help???
  219. 1960 power train
  220. Stuck manifold heat valve
  221. Rubber Fuel hose vs today's gas
  222. The caliper piston from Hell
  223. C2 Cluster light problem
  224. shipping a bare frame...who did you use? Wi-CA
  225. HI new to forum
  226. A-Arm cross shaft??
  227. Lower Hood Latches for 67
  228. C1 Antenna Cable
  229. 1960 90 degree elbow for the intake
  230. C1's hood release cable support bracket
  231. Windshield wiper/washer failure
  232. front spring question
  233. Battery quick-disconnect
  234. '60 Water Pump
  235. Steeroids Sale
  236. Price for a 62' posi unit?
  237. Meaning of "Triple Black"
  238. Headlight door opening Switch
  239. Barn Find 59
  240. Mud Flaps On A 1963 Coupe
  241. Correct fan blade
  242. Charlotte Car Show Pictures?
  243. 65 wiper/cowl question
  244. C5 caliper adapters for a 66'
  245. '61 seat belts
  246. Need new engine for my 60 vette...383?
  247. Restoration Battery
  248. Rare 65 & 66 at Barrett Jackson
  249. Help with Horn beeping while turning
  250. Source emergency brake light switch 57?
