- 63 4spd to Glide
- It's nice when a plan comes together
- need advice - distributor/rotor orientation
- 59-62 top fender trim
- 58 vette seats
- 54 Spark Plugs
- What's the deal with auctions?
- Alignment specs...please verify
- Original Owner of 67
- calling Jackfit
- photo of 1959 fuel drain hose at filler neck
- 54 conv top pics?
- L79 cam questions
- Paint/Body shop recommendation
- best place to restore carb
- Courtesy Light Bulb for 58'
- Car trailer tracking units?
- Need help to install side window
- Overhaulin C2 Chip Foose on Discovery HD Now
- 66 Vert Carpet
- Need a little help on a 1958 price
- Rear diff cover vent tube removal and install how to ?
- need help on speedo gear
- Happy 427 Everybody
- 66 Emergency Brake Cables front / rear HELP
- Air cleaner vacuum hose fitting
- OT: Carter AFB Buick Question
- Re-sleeving Master Cylinder VENDORS???
- NEED HELP! 1962 vin 110665
- Can i use these wheels and backspacing on my 1964 corvette?
- Question about 1959 front wheel hub
- Corvette restorers have it made
- Tuneup or adjust valves ??
- Comments on this 1967 convertible
- Ever heard of a Corvette Lola?
- Testing Posting
- Fat spare tire on 63
- Need help identifying mystery part
- 327 hesitiation
- GTO Seats ?
- Buying a newly restored set of complete trailing arms on ebay?
- Chevy billboards
- Need a good carb parts source
- Off Topic
- What should an alignment cost $$
- E-Bay never stops amazing
- Small V8 ignition shields
- Passed a midyear on the way to Port Arthur, Tx today
- Binding Clutch Pedal
- 65' convertible...electrical questions
- Chrome pieces on...
- 64 Hubcaps Polished and Painted, when did it change?
- Painter in Western NC
- Fan Clutch-C2
- Question0 About Insurance
- No returns
- engine hoist to pull 65 convertible 327
- MHVCA American Icons Show
- S/S brake lines leak
- Car heats up when turned off?
- Who makes the best 1957 Corvette kit?
- C1/C2 ironbutt........how long can you last?
- More ?'s On my rear end problems.
- 61 F.I. Fuel Filter Cannister Question
- Rear seal break-in 57 fuelie
- Shifter reverse lockout causing linkage to lock up
- Ford Logic
- please check out this pic & advise- steering
- 64 interior
- Coil kill switch for my '65
- Normal Coolant Temperature?
- Painted the calipers
- Original Windshield?
- Interesting '53 at a show in NC this weekend
- source to rivet hubs to disks?
- Cool newspaper ads and clips
- Ball Joint Rivets
- Cluch go boom
- Electrical help needed
- I am stupid
- 66 gas cap
- *****Please take a minute...
- Side Exhaust Spear Molding Too Long
- 62 corvette
- Correct Advance Springs To Use?
- Specialty tools
- Dim clock & heater control lighting?
- Self adjusting brakes (part 2)
- Help Me Rid My Gas Tank Of Rust Flakes
- Strictly Corvettes AC
- Muncie 4 Speed Linkage Adjustment Question
- How to clean C1 talilight housings
- cam shaft question, need some ideas
- VIN 194377S103954 "Documented" 67/435hp Possible FAKE
- Wiper motor wireing
- Battery disconnect
- FINALLY!!! Pictures.......
- Speedometer making noise!
- generator ok?
- Cluster light bulbs
- Carter 3461S parts needed.
- Pic Needed of wiper refill arm
- May 1st - Less than a week away for Crawfish & Corvetes for St. Jude!
- Temp Problem
- VIN #'s, where do they say.
- 66 ignition switch
- A/C Question
- Checking the differential lube
- Suspension ride height
- cruise control
- opinions on exhaust coating
- 63 brake booster restoration questions
- 64 Corvette vs a 1971 Camaro with a 383 Crate engine
- 1958 hood release cable
- Oil Gauge
- c1 SPINDLE STUFF
- Can't anyone do anything without screwing up
- I found something better to do today besides car (Corvette) stuff!!!
- Looking for decent speaker recommendation
- BAll joint
- Courtesy light bulbs
- Radio Wireing
- Tire press what psi are you at.
- Assessment of 1967 Corvette birdcage and frame
- car shows cruise nights NJ redbank freehold
- My bad luck with new parts lately
- loose outside mirror on 63 SWC
- 65+66 Big block hood design
- Need pics of triple black hardtop '61 with silver coves..??
- Changing the side window seals on a 64 coupe
- Need to see exploded wiew 1964 front brake shoe assembly.
- 66 427 ign shield question
- 62 rear axle ???
- Award Winning 62 Corvette
- Wheels and tires for a 1962
- 63 SWC pulling to the right
- Just changed my front brake shoes today and what an improvement
- Warranty Period in the 1970s
- Life after the Midyear - Track Photos
- Value impact of Restomods's
- Indoor cover recommendations?
- Hyd. roller question
- Exploded Gage Cluster
- 65 power brake booster
- Quick question Re Air Cleaner assembley 66
- 65 exhaust manifolds
- Winter Fuel?
- pitman arm question
- 62 wheels
- Honor Flight Pics
- Corvette Stingray - Greatest Ever Sports Cars
- 1967 Teak wood Steering Wheel questions
- Does any here know this C3 in ENGLEWOOD FLORIDA
- Anyone in Carlisle today?
- 66 license plate bracket
- Cobra kits cars vs C2s
- New '61 hardtop is on!
- Happy Birthday
- Sermersheim's Corvette
- E-mail 48 state Trip
- EnduraCool Header Coating Sale!
- Anyone use the Corvette Central Glass Springs?
- 2010 Monterey Historics
- cigarette lighter connect
- Happy Birthday
- Drum adjustment
- Bleeding brakes ???
- body not fitting frame
- ~~~ St Jude Auction #36 Drive it like ya stole it ! Piloti Driving Shoes ~~~
- 67 Tele column
- Door Gap
- Harley Earl's 1963 Corvette
- Deciding on a ring gear
- Crazy Idea - Bolt up Trailer Hitch
- C2 Jack
- Its Friday:Time for a smile
- Instrument Needle Colors
- 572 exhaust
- Date coded windshield source??
- 67 with a one wire alternator Q.
- I met Eric Gill today
- 65 66 original knock off wheel paint
- Early Big Block Distributor
- I Need Fresh Ideas for Corvette Show Awards
- 1966 Exhaust Panel with side exhaust
- paint formula for 66 nassau blue?
- Turn Signal sometimes does not cancel on C1
- Here's a link to C2 parts on eBay
- 65 brake booster date
- Another new Corvette Forum?
- Paint for Steering Column
- Ca. Plates
- Wich vendor delivers the best leather seats?
- air filter part # for '65 327/300 ?
- '64 Clock Lens Removal
- Good News About GM
- Electrical upgrades
- How to ID a Repro Shop Manual Supplement?
- Changing '63 Vert Vent Windows
- 3300 rpm at 70mph
- C6 guy lookin fro some help with a 66...
- Shift Knob Thread Size? Not Near it!
- History 1966 Corvette Coupe
- Grant 791 leather steering wheel
- 67 value?
- trip and odometer stopped/stuck.
- No Radio C2 Cars
- Find of the month- z06 master cylinder
- Fuel Guage troublshooting
- Complete restoration services
- Anyone know what the best El Camino forum is?
- CAM Selection
- heads 62/63 896 vs 461
- Spring Carlisle
- 1961 Generator-To-Alternator Conversion
- Guess what I just heard!!!!!!
- Delaware sales tax question - 67 vette
- Who is the resident C2 rear end/differential expert?
- Torque Specs - rear drive & suspension?
- body panel alignment
- Looking for old parking light pigtail ends
- Correct finishes for fasteners-1966
- 1962 FI Big Tank Race Car
- Opinions on eBay '63 SWC
- anyone have photo of 62 dog dish hubcap ??
- !965 Fuelie Timing Chain Cover
- What is this motor??
- The 67 Getting Closer
- Headlamp switch repair
- Delphi 600 Borgeson Steering Gear Parts
- Caught with my pants down aaahhh
- Strictly corvette show in Atlantic city?
- 63 327 short block brand new .rare find !
- Old Corvette Drag Cars
- '64 rear bearing assemblies - which side is which?
- Bench bleeding master cylinder
- shock absorbers
- wiring/radio controlled
- instructions to rebuild generator
- Low Vacuum Help
- Radiator Hi efficiency Re-core
- What's it worth ?
- Dog dish hubcaps
- trans/clutch woes
- speedometer drive gear install.
- 1956 sr-1
- Put the Torq Thrusts on my '66 Today!
- '61 hardtop front weatherstrip
- Motive Bleeder Help
