View Full Version : C1 & C2 Corvettes
  1. 1964 expansion tank overflow hose routing?
  2. Chicago Area C1 Owner
  3. Scott Smith N36 Restorations
  4. Muncie overdrive ?
  5. Free
  6. Video: 50th Anniversary for Corvette Racing at Le Mans
  7. Off-set Trailing Arm Question
  8. Bees' Choice for Best in Show at the Winstar Casino in Ok. 5.22
  9. requesting photo of 1959 trunk area
  10. 1967 427/390 Rad. shroud decals???
  11. Exalibur Carnauba based wax.Do they sell it in the US?
  12. Rust is a good thread lock!
  13. The writing on the expansion tank?
  14. Paint Guard for C2 AC
  15. Guitar Polish
  16. 64 hood alignment
  17. Wheels
  18. 1957 "Experimental Corvettes"
  19. C2 Vendors
  20. Dual Master Cylinder /Instalation problem
  21. Power Steering Conversion Vendors
  22. Thanks BADBIRDCAGE
  23. Help: 67' 427 engine marking mystery!
  24. 1964 coupe headliner picture
  25. Recommendation for mechanic North/Central NJ?
  26. buying 53 vett
  27. How do you know tie rods are bad?
  28. Recommendations for Frame Repair - Dallas/Ft. Worth Area
  29. markings on valve covers
  30. 1966 Hardtop keyhole bracket question
  31. Should I take the body off the frame?
  32. 67 rally wheel trim ring restoration
  33. White smoke timing issue
  34. HVAC Controls...
  35. Vintage Air Heater Hose Routing
  36. C2 OEM hardtop FL
  37. 1961 Jewell Blue, 1961 Ermine White, 1968 427 Yellow
  38. Trailer opinions for C-2's
  39. 65 ball joint boots help!
  40. Very off topic but where to buy drop spindles for a 1971 Camaro?
  41. 1961 Corvette early 270 hp
  42. 53 or 54?
  43. How do I install distributor with these problems?
  44. 1961 Corvette 270 hp
  45. Looking for 5 speed installer in Maryland
  46. Hood Pops Open on One Side
  47. 62 grill bar
  48. 1964 door panel picrure needed.
  49. Thoughts on Running Hot
  50. Removing Gas Tank from a C2 Coupe help!!!!
  51. What am I missing?
  52. Security systems
  53. motor change c1 compelted
  54. Engine ID Hepl
  55. Is it worth anything?
  56. 65 L79 w/ PS WP Pulley
  57. questions about a 64 vette
  58. Engine code HP
  59. Project looking for a home
  60. More Fuel gauge/sender issues on C2
  61. POR-15 or Bill Hirsch engine paint?
  62. steering colunm
  63. Contrasting color on the small block hood
  64. Tool for knock off wheels
  65. 64 master cylinder
  66. Two questions on distributor
  67. 1966 Laguna Blue Paint
  68. fuse ratings
  69. WTB Date code Holley for 327 L79 1967
  70. 1959 tail light-body seals
  71. Upgrades help
  72. C2 Body Lift Question
  73. Fixing prior sins: Window glass siliconed in
  74. C1 convertible top bracket colour ??
  75. window wiper position
  76. Saving a 64..sort of
  77. 67 427 435 Jets
  78. headlights go up but not down
  79. A few questions
  80. Who do i turn to for getting the exact and correct backspasing on V60 wheels for my 1
  81. Shocking problem
  82. Free Bird!!
  83. My Hungry Vette
  84. C-1 Alignment problem - Caster camber is maxed out
  85. Needed to remove a clock now No interior lights?
  86. Replacing Interior
  87. was at the plant last Tuesday
  88. Unknown object
  89. Corvette advice in Oregon
  90. Radio Panel Support Tab
  91. Xenon HID Headlights
  92. austin craigslist posting
  93. rear end # help
  94. 1964 Fuel injection vin?
  95. Air Cleaner Lid Silk Screen question
  96. Custom Machined “Corvette” Center Caps for Torque Thrust II Wheels continued.
  97. 64 Frame Rust Repair
  98. break in oil for a BB
  99. Corvette Center Caps Torq Thrust II Wheels cont.
  100. C1 exhaust are crossover pipes better
  101. What are these Seat Belts worth?
  102. 65 spring broadcast codes
  103. L78 Vacuum
  104. U there? San Antonio Texas "Summer of 74" 3am
  105. Vacuum Advance Can
  106. alum intake cleaning
  107. C 1 ground straps on engine
  108. Anyone Using This Combo??
  109. 1960 engine numbers
  110. Rick Springfield 63 SW Coupe
  111. Knock Offs NOS Center Caps Question
  112. "water spots" on rear windows
  113. Wider rear fenders for C2
  114. C1 Power Steering Braided Stainless Steel Hose Problem
  115. 65 Rear end rebuild
  116. Corvette vs. Jeep .... which would win?
  117. windshield moulding clips
  118. Question GM 383/425 Crate engine
  119. it's friday time for a smile....wake up vic z!
  120. Mid-America Grand Sport on Ebay
  121. Mecum-I think every big block is a restamp
  122. New Home Page cool
  123. Need a 1960 powerglide dipstick
  124. C1 A/C in the desert
  125. What's better, to dye or reskin my dash?
  126. 1967 Hardtop question (restoration)
  127. 63-67 Jack Hold Down Spring
  128. plexiglas scratches on hardtop rear window
  129. Pertronix 12volt source???
  130. whats this intake fit 3933163
  131. Rebuilding my AFB
  132. any info on 57 air box on hdtv 281
  133. Mecum '63 FI SWC sold for $61K
  134. Need to replace windshield - Houston area
  135. C1 tach clock+gauges
  136. Wrecked 62'
  137. Tonawanda 608 water pump
  138. Anybody know actual hood clearance???
  139. C1 Accelarator seal - how to mount it ?
  140. Ebay laugh! N-11
  141. How to take care of rust inside birdcage
  142. 500hp 2 x 4 WCFB ! (well almost)
  143. Does anyone make stock looking electric gauges for our C2's?
  144. still HOT
  145. 1963 Corvette Stingray
  146. Brake Alarm Switch
  147. Cleaning k-o wheels
  148. New mecum 3 day auction now! Hdtv 281
  149. '64 coupe overdoor weatherstrip?
  150. 1966 SB - question on two pink wires on coil + side
  151. windshield wiper cables on a 61
  152. 1961 Corvette - $28000 (Windsor)
  153. 57 FI Air Cleaner - Questions
  154. 66 Jack Mount Position
  155. 1960 fender bonding strips
  156. Dash Insert Instalation
  157. C2 vent window regulator
  158. Opinions: Classic Chambered vs. Sweet Thunder vs. Other
  159. cleaning Gold line tires
  160. Steering Column Firewall Hole Locate?
  161. Borgeson Power Steering Conversion Pitman Arm Question
  162. Corvette Forum Cruise In @ Museum
  163. C1 Steeroids R&P
  164. Hedman headers. Do this headers fit good in a C2?
  165. Weatherstrip glue solvent?
  166. 54 shielding install question
  167. To do in Phoenix?
  168. C2 vent window regulator
  169. Keisler/ Tremec 5spd into a 64 Coupe. Shop recommendations in the MD area?
  170. 1960 headlight switch
  171. Electric oil pressure gauge for 59?
  172. Interesting GS Clone - Sort of
  173. Opinions on a new carb for the 60 w/283
  174. Waterproof Cockpit Covers
  175. Opinions wanted 1961
  176. made my 62 worth more QUICK
  177. Transmission tunnel clips - 61 C1
  178. rear courtesy light socket 65
  179. Hardtop caged nuts
  180. 67 Air pump question
  181. Zora's Home For Sale
  182. L79 - pushrods & rocker arms
  183. C2 Factory AC Blower Motor
  184. What are some C1 "must have" publications?
  185. C2 steering couplers
  186. Rubber seal hood C2?Just at the back on the hood?
  187. Shocking!
  188. 61 dash harness
  189. 1966 center grill
  190. Thanks To Frankie the Fink!!!!
  191. How late is a holley before it a service dated
  192. gauge question on restoring
  193. 0 % Finance For Corvettes What The !
  194. timing
  195. Electric Fuel Pump for Fuelie
  196. Dumb question-hardtop conversion
  197. lady 54' vette owner looking for oil filter screen
  198. Starter Won't Disengage - Found the Problem
  199. 66 BB, would you know the length on this captive belt ?
  200. Lady 54' Vette owner needs engine info
  201. 1961 Corvette Value Guide Information
  202. 65 kick panel installation question
  203. 63-66 Std versus Tele Steering Column Rag Joint Question
  204. body & engine decode
  205. Midyears in the Movies
  206. Sorry, Mickey Thompson and Offset TA Question.
  207. 1959 spark plug wires with ignition shielding
  208. 1967 rear end
  209. '63 Coupe Upper & Rear Window Channel
  210. 4 speed vs automatic different angle
  211. Carter afb 3721 sa blow black smoke
  212. What do my fellow members use painting the engine block?
  213. 327 water pump C1
  214. Need Help From PA Members...
  215. Pictures of my '67 Stingray called "Spirit of America"
  216. Machined “Corvette” Center Caps for Torque Thrust II Wheels
  217. Machined “Corvette” Center Caps for Torque Thrust II Wheels
  218. Oh Great Suspension Guru's
  219. Awesome all black Corvette collection
  220. Corvette Forum Bash
  221. Daytona Parts
  222. 67 Bolt On weights
  223. 66 Mosport 427/390 Before/After
  224. noise
  225. Fitting hood to 1960 Corvette
  226. My Vette photos
  227. I've been looking all my adult life for one of these....
  228. hey guy's need Chromer
  229. Mershon's
  230. Exterior vent fins
  231. Body drop (boom, crack) and alot of cussing...
  232. K66 TI Question
  233. Carlisle..Spring or Fall
  234. Surging at light cruise
  235. •► ► TOTALLY FREE DRIVETRAIN INSPECTION - at Corvettes of Westchester - FREE ◄ ◄•
  236. Generator not charging
  237. brake line replacement
  238. Any free online videos of rebuilding a muncie?
  239. 4 speed vs Automatic
  240. '61 Bumper Alighnment
  241. Temp Sending Unit
  242. Vintage air troubles
  243. Finally drove my car today
  244. C2 Pitman arm
  245. Leaf Spring Question
  246. Trying to ID an ignition coil
  247. Need help with my 64 coke bottle look restomod
  248. L79-870 block - crankshaft assembly spec info needed.
  249. wiper well pictures
  250. frame off help
