View Full Version : C1 & C2 Corvettes
  1. Cooling System-Thank You
  2. Progress Pictures
  3. A great SF Bay Area machine shop to keep in mind
  4. open hood....destroy paint
  5. Friday Funnies
  6. can someone tell me the value please
  7. How much will it sell for?
  8. how much
  9. 63 327 PCV Grommet & Hose
  10. VIN tag painted over
  11. 63 temp gage reads hot
  12. 61' Fuel Guage Dilema...
  13. A.R.W, Torque Thrusts.
  14. Do you use 10/40 or 5/50 oil? What do you recomend?
  15. Newman frame C2 and carpet
  16. Parts that need to be painted. Black interior coupe
  17. Disc Brake Kits
  18. Fuel Pump Outlet Fitting ID Question
  19. I just can't do it !
  20. Hey So. California - FIBERGLASS DAY at the Petersen Museum!!
  21. Father and son carb rebuilders
  22. would you still fill mechanical lifters?
  23. Polish or can i sand the windshield trim?
  24. Door weatherstrips
  25. 65 327/350HP by-pass hose
  26. Rocker panels and side pipes.
  27. Rustyparts check your private messages
  28. Window invoice vs. car shipper
  29. Best conversion from points to elec. ??
  30. A First - iPod Plays Thru 53 Corvette Original Radio & Speaker
  31. 60 for Super/Stock (project update)
  32. BIG problem with oil leak
  33. Guys need some more help here fast
  34. Resto progress pics
  35. Ci windshield assembly
  36. 62 AFB jetting for 300 hp/340
  37. Another paint question
  38. Opinion on trim tag please
  39. changing rolling chassis on 67 sm. block cpe..
  40. 56 Corvette rear axle shafts
  41. new corvette owner but not a c2
  42. 58 Gas Door Hinge to Body screws ?
  43. Big Block help
  44. C2 6 blade fan and A/C
  45. 65 Glove box dor
  46. Progress in Arizona
  47. Steering Dampener?
  48. The blue Corvette at the top of this page.............
  49. plug wire routing
  50. Edelbrock carb question
  51. Insulation set and carpet set for 64 coupe. To thick?
  52. Window Whistle
  53. C2 A/C Compressor, Original GM vs Sanden?
  54. What does "carb leaked off" mean
  55. original shock rebuild?
  56. Uh, No
  57. My speedometer on my 61 goes crazy once I reach 45 to 50 MPH
  58. Notice of a Workshop by Gary Ramadei
  59. Motor mounts locking vs original
  60. **&%$#@!** windshield molding!
  61. Broken Exh Manifold Studs...
  62. CR calculators
  63. C2 gas cap leak
  64. What gas cap is this?
  65. I cant figure out where to put the radio side panel support clips?
  66. down draft tube
  67. What are these fasteners?
  68. 57 complete engine?
  69. Photos of Progress On Car With Special Guest Who Assisted With Carpet
  70. Mystery Jack! OK, So What Are We Looking At Here???
  71. Changing the ignition and doorlocks so i can use 1 key on all
  72. '65 Vent Window Wing Pivot Repair
  73. Schematics
  74. Free auto ads and brochures
  75. 870 block stamping
  76. Need smaller sized starter for 64-327
  77. Window Regulator Issue
  78. Looking for ball joint dust cover
  79. What does this regulator fit???
  80. C1 a/c
  81. Fullcontrol's not nuts, sidepipe spears needed
  82. Alternator Bolts TR or C ??
  83. 1966 nassau blue/black coupe in Freeport for sale,has anyone here looked at it?
  84. seat mounting bolts 65
  85. Fuel Gauge
  86. Body off
  87. 555"- 2500 mile road trip with EFI
  88. 66 coupe rear glass
  89. why only powerglide
  90. Where to go for parts?
  91. Steering Connecting Rod "link" C1/solid axel?
  92. Wich and what kind of wax do you use?
  93. How to fasten staples on new inner dust shields?
  94. Is the winshield frame on C2 coupes usual this good?
  95. Criswell car show when?
  96. steering column overhaul kit
  97. drivability of a b28 versus b26 advance can in an L-79?
  98. A/C Car with Stuck hood
  99. 1964 convert rear wheel squeak
  100. Fathers Day Present??????????????-
  101. My friend Karl bought a coupe but wanted a convertible so here is the result
  102. Holley power valve---- yea or nay?
  103. shock replacement
  104. cost of Vintage Air unit and a fair price to install
  105. Spare Tire size for the C2 tub ?
  106. Shock absorbers for rear composite spring?
  107. 64 327 solenoid replacement
  108. Anyone recognize this transmission?
  109. Powerglide owners
  110. Stripping of thy paint........
  111. New radiator shroud and electric fan combo
  112. Car people (gear heads) make up for the others
  113. Looking for Cleveland folks with good memories!
  114. V wire shields
  115. Powerglide owners
  116. Carpet does not fit tight
  117. Dynamat and jute
  118. A few questions about the wipers and fuses on a '65
  119. Corvette Fairy visits me!!! Again!
  120. Wheel studs same front and back ???
  121. Painting
  122. Wwii is over ! ! ! (ot)
  123. Product Report - Percey's Wheelrite
  124. Shortened Spring, 8X15 with 5.5" Backspace - Possible?
  125. 67 SB won't start without starting fluid
  126. Be in prayer for my wife.
  127. Temperature Guage
  128. New radiator
  129. bonding adhesive problem
  130. off topic,need help with electrical issue.
  131. 65 underdash duct installation
  132. Just Like In The Old Days!
  133. [VIDEO] Rare 1960 GM Film Documents Corvette’s First Visit to Le Mans
  134. what are the tricks to adjusting door latch - 1960
  135. Wiper grilles 1964 coupe. Not remanufactcured?
  136. 67 Convertible Antenna Location?
  137. 60 temperature sending unit test
  138. electrical problem question
  139. Real 1966 Knockoffs? How do you know?
  140. Agreed value, true unlimited use policy? Does it exist?
  141. Hard to start '66 BB
  142. What brand spark plug wires should I buy?
  143. photos of 60, 37 Ford and 2010 Challenger
  144. Car dies when coming to a stop....
  145. Paint cost - liquids
  146. Soft top latch
  147. Paint touch up, SF Bay Area?
  148. Ammeter gauge does not move?
  149. Headlight motor strange problem
  150. Bent pushrod and a knock???
  151. OK, so what's the problem?
  152. 65 ignition switch problem: I caused a short. DOH!
  153. The "Holy Grail" of Corvette Pedal Cars
  154. New - Hello
  155. steering column hub nut torque
  156. Diamond red lines
  157. Electrical Problem in my 66 Coupe
  158. Polyurethane bushings. Use it or not?
  159. Need help on Trailing Arm Removal, Brake Fluid Mess
  160. Problem, starter engaging when key is turned to ON, not START
  161. New to Vettes (intro and questions)
  162. C1- 59 nose removal pictures
  163. 56'/57' power window conversion
  164. Would you Trade?
  165. What FONT was used on the Midyears
  166. Early C1 radiator question
  167. 65 power window wiring from switch question
  168. Comeback Cruise Story
  169. Very off topic but where to buy tools?
  170. Wilwood calipers vs original
  171. I Put an MP3 Jack in the '64 - WOW What a Difference!
  172. Steel Wheels
  173. Crate engine. Enough power.
  174. Supporting an LS2 engine onto Engine Stand??
  175. vert rear carpeting questions
  176. Johnson/Bergen Corvette Mecum Spring Sale
  177. Thank you for your service
  178. carburetor kit
  179. Cool 57 "Rat" Vert
  180. Engine Compartment Wiring
  181. NCRS Heartland Regional Show 05/22
  182. Windshield wiper arms 64 coupe.Replacement or reproduction?
  183. vinyl finish on 67 hardtop
  184. Is this your engine block?
  185. NOt happy about some restoration services.
  186. Holley electric fuel pumps don't suck . . .
  187. Lowering the rear of a '56
  188. 1956 Vett does 50mph at idle
  189. Had the car judged again
  190. Engine diagnostic
  191. Motor mounts
  192. markings on valve covers
  193. front bumper replacement
  194. '64 &'65 Owners. Parking Brake Question.
  195. Racing the original Corvette racer, 50th Anniv. at LeMans Chip/Lance Miller sponsored
  196. Ebay Hardtop: real or not
  197. 327 pcv system C1/ 63 motor
  198. Late FRIDAY SMILES, saturday too!
  199. New Development - Knocking Sound at Front of Engine
  200. "64 Roadster Vent Windows
  201. 1963 FI Plenum- How Many
  202. WHEEL DUST SEALS anyone using them???
  203. Instrument Panel Restoration
  204. L-79 not happy idling at 750rpm
  205. Humor
  206. Oil in the air cleaner
  207. Need Advice: 65 pulls left...
  208. Has anyone removed the clip from a C2?
  209. Names of Any Good Muncie Trans Rebuilder in Virginia Area
  210. Chevrolet Corvette Tribute
  211. '59 evaluation
  212. Rear Quarter Trim Panel Bumpers
  213. installing 62 water pump
  214. 5/6 speed tranmission
  215. Any reviews of Al Knock Retro Seats for 61?
  216. Save the dates?
  217. Anyone know this 67?
  218. r12 needed this weekend
  219. Does This Photo Really Require Any Explanation ?
  220. High Altitude (over 14000 ft) Question
  221. Front Bumpers
  222. Another Example of Shipping Costs Out of Control
  223. Amsoil v Mobil1
  224. C2 SB top speed
  225. Clips for outer windshield and windshield weatherstrip seal
  226. windshield lower channel
  227. Radiator Core Support, 1960
  228. We lost a member
  229. Jeep Box Install
  230. Muncie Plastic Speedo Gear Fell into Trans
  231. Paint code
  232. Need a 66-67 hood? Only some rust and dents!
  233. Installing Vintage AC and brackets DON"T fit!
  234. coil capacitor?
  235. 57-283-270HP Stalling Problem..Help
  236. 58-60 Side Spears
  237. Long shot.. any old timers from NY, NJ, Philly area remember a brown 1966 BB conv??
  238. Looking for my father's '59
  239. Please Take 57 Seconds to Read This For Memorial Day
  240. What is considered running hot - BBC
  241. Spare tire question 1960 corvette
  242. Theft prevention
  243. Painted bumpers?
  244. Hello everyone!
  245. Need someone to look at Vette in NewportBeach Cal.
  246. Fuel gauge calibration
  247. L79 Build spec.s
  248. Noise from rear end
  249. Holley Idle question
  250. 63 dash guages
