View Full Version : C1 & C2 Corvettes
  1. research on 67 vettes
  2. What is the replacement light bulb p/n for 1960 speedo cluster lights?
  3. Engine Start Up with Body Off
  4. WoW Looks like fraud to me
  5. Head Light Bucket Pivot
  6. Rubber Fuel Line
  7. Advice for renting/leasing 1962 corvette
  8. OT: markup on ZR1
  9. C1 throughout bearing noise
  10. Date code Exhaust manifold
  11. NOS, C2 Off Road Exhaust
  12. C2 radio re-install
  13. What's a good rrice for a Sun Distributor machine?
  14. L88 vs LS7 from C6Z06 forum?
  15. Source for coil
  16. Tach Drive Distributor
  17. Powder coating
  18. TI Amp (voltage regulator) part number
  19. Dash Pad - Best to use for 1962
  20. Sorry!
  21. 67 Rally Wheels and Trim Rings
  22. Carburetor Cleaning Tips From Edelbrock
  23. 7" rims on '65 rear back spacing ???
  24. Silver Interior
  25. Vinyl adhesive
  26. MISSED a 67 Coupe tonight by 5 minutes!!
  27. Real wood steering wheel on 1967
  28. For resto-mod owners with coil-over springs
  29. '64 tail lights or lack there of
  30. Distributor Bottoming Out ????
  31. judging a 390/427 fuel pump
  32. 62 dash pad replacement
  33. Identifying Warped Metering Blocks
  34. Pete Hern-Are these the pictures you had in mind?
  35. WIX and BALDWIN Filter number for 67 canister Please
  36. will i ever, ever learn??
  37. I have some parts NOT for sale but gauging interest.
  38. Bradenton Hooters 9/27
  39. Deck Protector Question
  40. 1967 Heater Hose Sizes Please
  41. Jack instruction & positraction notice on 65 vette convert.
  42. 609 water pump question
  43. Fuel pump area question
  44. Fuel pump are question
  45. Space Shuttle Endeavour & Love
  46. WCFB Carb
  47. 67 L79 Coupe Available
  48. Front Bumper Mounting Help?
  49. Pictures of the Sunshine Coast: Last Cruise of Summer
  50. Clutch Fork Question
  51. DC,AG,DFand AZ What are they worth??
  52. Cape Cod event
  53. Progress Photo's of my Hot Rod 54
  54. Holley carb list 3367 rebuild
  55. Mid-year oversteer?
  56. Wiring Harness on EBAY
  57. Nice-looking 63 SWC...
  58. A Call out to any super RARE "65" M22 owners or somebody with mad knowledge...
  59. Body mounts
  60. 1963 Rear end
  61. rear body mounts
  62. Super Chevy Show - Bristol, Tn
  63. Headlight Motor Re-Install Issue 65'
  64. Fiberglass Front End Alignment
  65. Kelsey Hayes Knock Offs
  66. O/T- 86 Silverado
  67. Is this an old person's hobby?
  68. Last saga of "need wiring expert"
  69. Vent glass part crossover.
  70. Saturday Night in the Archives
  71. Trans linkage adjustment
  72. Tranny to Bellhousing bolt torque?
  73. oil capacity of a 1964 muncie 4 speed???
  74. Another angle on the "snob" question...
  75. What is this intake?
  76. rear sway bar use with offset trailing arms?
  77. Anyone using different rotors on their C2?
  78. Anyone using different rotors on C2
  79. Engine Question - Non Vette
  80. 62 Tachometer
  81. tpi linkage
  82. Stinger Hood
  83. Maiden Voyage
  84. Starter Trouble for 427BB!
  85. Routing of heater and defrost cables?
  86. Looking for picture of Jute in seat area
  87. One year later.
  88. What's my resto-rod weigh? - Poll
  89. Looking for picture of Jute in seat area
  90. A-Arm bushing press
  91. Green Capped Dash lights - where do they go ???
  92. Radiator cap
  93. Radiator cap
  94. Radiator caps
  95. I need a website link.
  96. C2 to C3 Frame question
  97. I can't wait any longer!
  98. Visiting after long absence!
  99. Nose bra for a '58~'62 ?
  100. Why no ebay links?
  101. Which Intake?
  102. Favorite Color Survey update... and C1 history
  103. How Do I Keep It Looking Nice?
  104. 1966 Corvette L-72 Fuel Pump
  105. Clear Paint Protectant
  106. Need picture of 67
  107. front suspension rebuild
  108. Engine ID help please?
  109. FunFest 2008 - PICS
  110. Rear antenna
  111. Looking for C1 aftermarket AC vent pics
  112. Side exhaust noise revisited.....inserts.
  113. Bearing cap torque
  114. Alternator restoration
  115. Aaronz28's L76 Restoration progress: SHE's ALIVE!
  116. 1967 Ignition Key
  117. Frosted Hubcaps for a 64
  118. Throwout Bearing Alignment
  119. Stuck clutch???
  120. Best ways to track down docs,build sheet or protecto plates?
  121. 2 Day Corvette Show
  122. Voltage regulator VR715
  123. 65 396 "962" block
  124. Ron Fellows to attend 2008 Corvette Toys for Tots Run!
  125. 1965 intake manifold advise!!!
  126. C1 Brake lights dim and gas gauge fluctuates
  127. Thinking of a '65
  128. Doing a favorite color survey...
  129. Door release adjustment
  130. Front Suspension Teardown..
  131. WTR 1957 big brake drum
  132. Need some advice manifold help.
  133. 15x6 or 15x7 mags....
  134. Anyone know what became of Byrns Chevrolet?
  135. Need Electrical Help 62 Vette
  136. Seatbelt Restoration - What Again???
  137. Need help near Columbus Ohio
  138. 10% Discount From Mid America Motorworks
  139. 63 resistor
  140. 1965 fact or fruad! please help?
  141. Corvettes Of Houston
  142. Cross Flag emblems - 65 Convertible
  143. C1 Seat Restoration Help
  144. 1962 electrical help
  145. Door Panel Carpet
  146. Expensive, but a gorgeous Mod....!!!
  147. 61 water pump question
  148. anyone have a good schematic/picture of fuel filter at carb?
  149. "Stroker" Con Rods
  150. My car won't run on air alone!
  151. Fram oil filters
  152. Where Does My Brake Fluid Go ?
  153. disc brake wheels
  154. vette body cart
  155. Starter Bracket
  156. Numbers on roof/coupe?
  157. Think I might need a bigger garage!
  158. draining a 64 muncie 4 speed ??
  159. How difficult is it to put antilock brakes on a resto rod?
  160. Filling Tranny Prior to install
  161. Rubber A Arm Flap Cover Things
  162. Radiator
  163. Need some pictures please
  164. 65 tachometer....how accurate?
  165. GM to Pause Corvette Production
  166. Pismo Beach Car Show June 2008
  167. 2008 ST. JUDE CARAVAN - Monday, October 13th. Memphis, TN. -
  168. This is a plug (recommendation) for a Corvette book
  169. Wrecked the 64 :-(
  170. Keisler 5-Speed
  171. Ok guys, lets get the profiled updated with your name!!!!
  172. Hei tach drive
  173. heater box restoration 65
  174. My 64 shot with wide angle lens.
  175. I Survived Ike!
  176. Good Deal?
  177. Clutch Fork install??
  178. Auto Transporters
  179. are my valve covers original?
  180. alternator will not charge, HELP
  181. Cindy McCain & Corvette Drifting-May Surprise You!
  182. Drop base air cleaner..
  183. [PICS] My Dad bought a 64 Restomod Coupe
  184. C1 Buying 1957
  185. Should I sell the C6 for a C2?
  186. Rear HT window rubber trouble
  187. 65 battery change
  188. Fire retardant resin
  189. Chris Ritchie, an Honorable Guy.
  190. steering wheel reconstruction
  191. power steering assist problems for '63 roadster
  192. Frustation set in
  193. Any Northeast guys up for a little drag racing ?
  194. Dipstick Tube Stuck
  195. Muncie M-20 and M-21 transmission question
  196. My Vette, Antique Autos and Vintage Bikes....
  197. Windshield wiper arms
  198. Car trailer storage
  199. upper piece 66 BB fan shroud , is it available ?
  200. GM's 100th! Happy Birthday GM!
  201. Big thanks
  202. whats it worth,whats it worth, etc
  203. Anyone have "elapant ears" I can copy?
  204. intake manifold rivet part number
  205. I need pictures of your Vette...
  206. 63-67 Corvette.......... Buying & Selling
  207. Removing Clutch Linkage
  208. Horn button rattles
  209. Roller cam choices for a 406?
  210. 1967 427 side pipes
  211. Bad throw out bearing
  212. Torque value needed.
  213. VIN tag question
  214. Seems the N-11's are shipping
  215. Showboards are ready!
  216. So I have this riveted 15" wheel that was in my spare well for 35 years
  217. Which 1967 Corvette factory wheel do you like the best?
  218. Need Wiring Expert On C1
  219. 67 with GM fender flares
  220. 1962 questions?
  221. question about black and green a/c o-rings
  222. Tranny help
  223. SURF CITY CRUISE IN - ALL CORVETTE SHOW - Sept. 21 - LINCOLN CITY, OR
  224. What's a "Correct" engine worth?
  225. C2 windshield weatherstripping NOS or reproduction?
  226. What are your thoughts on restored
  227. 62 Steering wheel nut
  228. ADVICE needed for 60-62 vetterod project
  229. NCRS Bolt head marking help 1964
  230. Got my Diamond Back tires yesterday.
  231. How detailed should a "For Sale" AD be. What do you like to see??
  232. Northwest Scenery at it's best
  233. 65 green leather seat covers
  234. hard shifting muncie when warm
  235. CSI Photoshop help needed with frame stencil ID
  236. N. Illinois/S. Wisc Cruise to Galena
  237. C1 Fuel Delivery Problem
  238. 62 alignment specs with radial tires
  239. Regular Sat Nite Cruise Kissimmee, FL
  240. 65 BB Conv., Detroit Craigslist
  241. Do I Have Deep Groove Pulleys
  242. Cluster Wiring
  243. M-22 in "65" Vettes?
  244. My dad's new toy
  245. Restoring Overflow Tank
  246. 2009 Corvette Caravan To NCM Rooms
  247. Intake manifold
  248. hood 63
  249. Sudden loss of power?
  250. Anybody have flow chart for 65 heads??
