View Full Version : C1 & C2 Corvettes
  1. 67 Radio Refurbishment
  2. 67 Corvette Brake Bleed
  3. 1961 Clutch Push Rod Bushing
  4. How much of a price premium does a '67 bring?
  5. Anybody here have an original black 67?
  6. Cragars on 65
  7. I Survived a Rear End Collision
  8. Z-28 intake vs. L-79
  9. O/T: Air Compressor Oil
  10. Tire Info
  11. Who makes the most accurate gas tank sending unit
  12. `58 rear spring
  13. Inspection cover flywheel interference
  14. •► ► SATURDAY JUNE 26th LUNCH @ CoW ◄ ◄•
  15. Spare tire cover V brace
  16. need help
  17. Chevy Orange Engine Paint
  18. ARP main bolt torque spec (1965-L79)
  19. Guess I was Lucky
  20. new look for the 62
  21. Early Vette used part source-turn signal assy.
  22. afb L79 combo /vacuum advance ???
  23. Nice looking 65 Resto-Mod Mecum Bloomington Auction
  24. C1 seat belt anchors
  25. disc brakes without a conversion kit?
  26. Glove Box Light
  27. Trunk Hinges
  28. Does 80w90 GL-5 Gear Lube deteriorate with age?
  29. 53 Corvette Restoration
  30. It's done! Pics of my "new" L89...
  31. 1956 - Tranny/Rear End/Brake Fluid Q?
  32. New SACC chapter in the Carolinas
  33. Brake Line Green Clip Orientation / Installation
  34. power steering in C1
  35. Generator with A/C on a C1 (61)?
  36. last 67 big block convertible ?
  37. Radiator Hoses - Special ?
  38. 63 shifters/4 spds
  39. Car Carrier
  40. Can you post a power point?
  41. Help with dads present
  42. 8" Wide wheels on 62 Corvette
  43. Distributor Housing Lubrication
  44. disc brake conversion
  45. Real money price check
  46. C1 Air Conditioning
  47. Wiring diagram
  48. Stolen cars
  49. '63 Speedometer Cable - Thread Size?
  50. Voltage problem?
  51. 1960 - rear view mirror
  52. Corvette Central Power Outage
  53. Picture need. 66 AC box.
  54. C2 front end fiberglass
  55. Emblem locations 66 Help
  56. Weekend Car Show
  57. Old Vette dudes? Started driving when?
  58. Max Lead 2000 use
  59. Fathers Day Drive-66,96GS,01,06Z
  60. What a great Father's day!
  61. Front brake squeal
  62. Wrong gas door
  63. Baffled by brakes...
  64. Only in Kaliforniuh
  65. Fiero seat for my C2 part 2
  66. color of rear diff. cover
  67. 2 1/2" Corvette Mufflers
  68. Frame work done
  69. Cost to rebiuld 327/300
  70. correct ride height
  71. The Devil Made Me Do It
  72. Questions and value
  73. Wich intake manifold is the best for a 11:1 compression engine?
  74. A.i.r.?
  75. Happy fathers day!
  76. here we go....help needed
  77. Timing for a 1960
  78. Car show Pics: Some Vettes and some not ;)
  79. Question about this 327 motor and what I should expect from it.
  80. Pulled the Trigger on the 65 396!
  81. Vintage Air "Front Runner"
  82. Hot Rod Reunion............
  83. updated information on my 65
  84. All most there
  85. New member need advise
  86. 55 Bubble Top is this one of your Roy
  87. 66 Corvette questions
  88. Dash Cluster Install...
  89. Add A/C Yes or No
  90. Can't Stop Exhaust Leak !! Ugh...
  91. 1960 Clock removal - Help
  92. Age
  93. torque thrust wheels
  94. Replacing 4 spd shifter
  95. A&W Friday Night
  96. carb issue?
  97. Another 53 Lives Again
  98. need master cyl. info for my 63
  99. What's a good thermal/noise pad under carpet
  100. FI block, "make it matching number to your car"
  101. Shocking horn problem solved
  102. C2 vin location on a bare frame ??
  103. Question for those with Torq Thrust 2 Wheels
  104. Need Help With History Research On Southern Cal. 64 Convert
  105. VIN# Question
  106. Rear Change Out
  107. c1 posi rear end
  108. Durability of dynamat type stuff without carpets?
  109. Semi-On Topic: What's the oldest vette you've driven/ridden in?
  110. Judging Question
  111. Best Of Show
  112. Question on certain conversions for better driving and safety
  113. Bob Kunz
  114. 62 corvette under dash wiring clips
  115. Alternator Rebuild Kit?
  116. 66 questions as i go thru the tear down
  117. C2 with LS3 Swap-Tech Info
  118. Jeep Guy Needs Helping Buying a 63' Stingray
  119. Vertical Gate Shifter - Anyone with Experience?
  120. Aluminum Heads
  121. earlybird gets the FRIDAY SMILES.........
  122. Convertible top leak solved.
  123. California YOM Plates
  124. Mid-year Electrical Question
  125. C1 308 out 370 back in
  126. Stolen PU found
  127. C2 Split Window- make your own?
  128. 4900r fuelly unit worth
  129. 4160 carb.
  130. 57 fuelie or not?
  131. Four seat midyear?
  132. 1110985 Distributor
  133. T-10 tail housing - casting day mark reads upside down
  134. June 25th and 26th FAST and Factory Stock Musclecar Drags
  135. Gauge Cluster Removal in a 64
  136. Question on correct engine date code range
  137. colorado dealers
  138. Is anyone getting geared up for the SACC convention in Bowling Green?
  139. Weighty Question BB v/s SB
  140. Technical Service Bulletin #812 - Big Brakes
  141. Need Help on 56 Value
  142. After 25 years of being my dream car, I bought it!
  143. 1967 Unrestored, mostly original 427-435
  144. Distributor Breaker Plate Removal
  145. Composite Rear (mono) Spring
  146. Fas-Trax Alignment
  147. vintage vette racecars
  148. C2 Vent Window Adjustment
  149. 63 rocker panel
  150. GM asked Coffman to stop making conv top?
  151. opinions abut a 55 engine
  152. running lights wont come on?
  153. Rear view mirror wont stay still
  154. What's new at County Corvette - Pictures
  155. 1958-62 corvette experimental nose
  156. Odd Question: Re In-line Shifter
  157. Does any one have a wiring diagram for a 67
  158. 67 vette 327 NCRS valve guide question
  159. Question on correcting distributor advance curve
  160. Courtesy lights turning on for 63 vert
  161. 66 power window motor
  162. Please help!
  163. Directional tires
  164. Fuel Injection Restoration
  165. Off frame restore question
  166. How many forums do you belong to
  167. t-3 headlights
  168. headlight motor gears
  169. headlight retaining dish? finish
  170. Is a 63,64 rearend the same as 65 and up?
  171. muncie leaking trans fluid
  172. fan clutch 65
  173. bird cage measurements
  174. Mid Year Budget - Opinions Needed
  175. Glass codes for coupe
  176. Split window glass numbers
  177. Need Trans ID
  178. 65 headlight warning (limit) switch hookup
  179. Educate me on mid 1960's motor mounts
  180. "Stock Looking" Radials for my 64
  181. Have somebody cut out a piece on the fan shroud for my 64 coupe?
  182. 427 Rear Main Seal
  183. 63 lower control arms
  184. WCFB carbs what are these?
  185. Jay's Garage - C1 chassis
  186. Anyone recognize this car?
  187. '65 Convertible Quarter Panels
  188. Hans Stuck at the "Ring" Incredible Engine and Brakes
  189. Repo lock retainer clip ? Anyone try it ??
  190. Car show & Doo Wop Show
  191. HOt August Nights
  192. Zr-1
  193. L79 gaskets
  194. ID a 65 Help Needed
  195. Anyone running a 5 speed richmond?
  196. will air cleaner fit?
  197. 65 randomly stalls when driving.
  198. Bar's rear main seal repair ?
  199. problems.
  200. I'm Outta Here...
  201. 1967 Corvette transmission case
  202. Replacement carb date window
  203. Concern about safety
  204. Earliest 1967 build sheet
  205. 1964 wiper part needed.
  206. 1960 - Hood cable release
  207. Bounty Hunter
  208. 66 headed for paint
  209. Muncie Transmission ID Question
  210. Hubcaps
  211. rare color combination, how to research...
  212. Back to the 50's
  213. Correct engine for my 1964 Corvette assembled december 1963
  214. Hesitation/Stumble on acceleration, PG
  215. Vintage Original Air Conditioning Setup -Opinion of value
  216. Bloomington again
  217. Hooker Sidemount Header Observations
  218. driveline yoke
  219. Power window conduit Ouestion
  220. fuel sender leaking
  221. M-22 vs. BW ST-10
  222. Zeroing the oil pressure gauge
  223. Question on engine mounting angle
  224. Canopy cover for a coupe
  225. Clock for a 64
  226. Flasher
  227. epoxy for Holley carbs bowls
  228. Future C2 power?
  229. 1966 J56 Proportioning Valve question
  230. Piston ring compressor- recommendation for
  231. Car show in Maine & baby mice
  232. Stopped looking for a 58!
  233. C1 Oil Pan Maximum Depth
  234. Bloomington Show?
  235. camshaft assembly lubricant - recommendation for
  236. Question about tach cable apperance ???
  237. 54 Color question.
  238. Question on 66 driveshaft
  239. Fan clutch question
  240. What is the P/N for a 58 Bell housing? What is 3741311??
  241. C2 Shoulder Belt
  242. trim tag rivets on 66 corvette
  243. More Advance confusion
  244. C1 brake adjustment
  245. My Borgeson Install- Corvette Enthusiast
  246. Corvette Shop near Peoria IL ?
  247. 1955 Fuse Block Picture Needed
  248. Engine numbers - Success at last!
  249. **LG Motorsorts / GrandAM Mid-Ohio Corvette Corral***
  250. '57 Oil Capacity
