View Full Version : C1 & C2 Corvettes
  1. Dynoing a 66 327/350. What to expect?
  2. Rocker offset question / problem
  3. exhaust fix and overheating for 65-67 big block
  4. After three years, the engine cranked... and backfired
  5. What is involved in replacing the rear spring?
  6. Can you identify this bracket?
  7. 66 Vert Slow/No Power Windows
  8. '65 Jack Storage Compartment Paint
  9. Tank sticker help
  10. Build Your Zo6 or ZR1 Engine
  11. Battery Voltage Problem
  12. 1960 vette gremlin
  13. Best deal on car covers?
  14. 65 wiring harness shorting issue
  15. rochester 4bbl i.d.
  16. Trans shop in NJ needed
  17. Head Help
  18. Ign. Shield install help
  19. Door Adjustment
  20. OT: Back to my 87 El Camino
  21. Stinger hood questions
  22. What is the Strangest part or repair you have found on a Corvette
  23. UPS "Careful Service".....
  24. Help with '57 Cowl Vent - Screen is torn
  25. C2 trade?
  26. Upgrading Voltage Regulator
  27. Beautiful day for a ride
  28. Toyo spring in 66 Vette
  29. Differential doesn't line up
  30. What's your favorite C1 reference book?
  31. reproduction 1963 Grand Sport Emblems
  32. Looking for 1963 FI assembly
  33. 1965 Tach Mechanical Drive??
  34. Got the two redheads out today, Italian and American
  35. Need a Rust Removal Facility for my (2) C2 Frames
  36. Ongoing Electrical Problems
  37. Restoration standards for non-conforming cars
  38. New to C2s. Helping out with a 66 327/350, had some questions
  39. Mid-Year at Mid-Ohio Vintage Grand Prix
  40. Anyone see this '56 for $14K ?!
  41. pics of 390 hp 427 motor
  42. Race Ramps Group Buy
  43. 1967 tire manuf.
  44. '65 door panel replacement
  45. original 76 actual mile 1954
  46. Car show and cruise pictures
  47. garage storage high temperature effect?
  48. 65 Overview
  49. Valve adjustment symptom
  50. Rear Diff Removal questions
  51. Backfire through carb
  52. 63 67 a/c
  53. Help - Rollaround Stand for a '66 Removeabke Hardtop
  54. Coolant hose
  55. little help needed
  56. Almost ready to depart for the SACC Natls
  57. advice on engine rebuild.
  58. WTB 63-65 inner fender
  59. >>>>>>> St Jude Auction #47 One of a kind fixed blade knife <<<<<
  60. Fair Price for 1966 BB exhaust manifold set
  61. Ringo Starr
  62. '67 Hardtop weather strip set
  63. Brighter lights for C2 instrument cluster
  64. Shorty Headers
  65. Super-Newb needs some help on possible purchase
  66. Fuel gauge troubleshooting:
  67. What to do with undercarriage
  68. Brake lights don't work!
  69. 1965 L76 engine 365hp/327 cam spec
  70. 63 327 turbo fire valve cover decals
  71. Sidepipe Upper Trim Attachement
  72. Wipers and windshield washer not working
  73. First timer at Thunderhill 3 mile open track!
  74. Update on misaligned pulleys & thrown belts.
  75. Carter carb help please !
  76. How to check rear end bearing play
  77. Head gasket
  78. new member wiw 57 f.i.set-up
  79. Front Suspension Make Over
  80. Back to electrical question/problem? C1
  81. Alternator took a dump, which one to buy?
  82. Bought new parts, installation blues
  83. What do u do w/your dash plaque collections?
  84. I can't believe it's gone
  85. Outboard Carb Flooding on my '67
  86. 1962 factory tach rebuild
  87. 1960 Dual Carbs
  88. Rust Prevention on C-1 frame ...Kroil?
  89. Rust Prevention on C-1 frame ...Kroil?
  90. Corvette enthusiest....we are very lucky!
  91. 1963 Coupe Hood Question?
  92. seat installation - guidance
  93. C2 Stainless Steel Windshield Mouldings
  94. C1 Engine/transmission
  95. Pin Up Photos
  96. Rebuilt 58's
  97. Barn find Corvettes
  98. Hitting the road for a little 2000 mile drive in my '62 :)
  99. Weber 4 side set up for Vette
  100. By-pass Hose removal??????
  101. 67...Opinion, what would you do?
  102. Installation of lifters - L79
  103. Picture of BB rad support A/C seals?
  104. Correct date engine block
  105. Windshield Post Seals
  106. Watch that first Turn
  107. New to forum & Need some advise
  108. Tank Sticker
  109. satisfied customer / CC
  110. Fuse size amperes for cigarette lighter
  111. Newbie needs help with possible 67 C2 purchase
  112. Alternator powered in "Accessory" position
  113. 1953-54 distributor, vacuum advance
  114. Heater box and bolts for battery access panel
  115. help 327/300 hp postive crankcase ventilation
  116. Keys and Locks
  117. C1 Steeroids installation with many photos
  118. 327 exhaust info
  119. Door Fit – Need Advise
  120. Battery Drained...
  121. Alternator/voltage reg wiring
  122. what is your C1 floor temperature
  123. Anyone in Orlando who could check a C6 for me?
  124. AC centre bezel
  125. PG, Turbo Glide, Turbo Hydramatic
  126. 61 wiper transmission saga...
  127. Its Friday:Time for a smile
  128. Borgeson Steering Hitting Lower Control Arm
  129. Tank Sending Unit '64
  130. HELP!!!! Hard to crank when hot
  131. C2 Radio upgrade.
  132. Corvette at Carlisle 1st time to show vette
  133. Brake fluid leaking
  134. 1961 Clutch 'creaking'
  135. AAARRRGH - Part Inventoring SUX
  136. 61 From Above
  137. C1 - Resetting Rear Leaf Springs
  138. Sources for deep groove pulleys?
  139. Trans jack from Harbor Freight
  140. parts fair value SWC
  141. NOS 327 crate short block - photos
  142. Considering front disc conv need advice.
  143. JET-Hot Coatings Sale!!!!
  144. NOT Corvette, but very interesting.
  145. 25 amp fuse in 20 amp socket
  146. 1963 Corvette from Harry Mann
  147. The journey begins 48 States
  148. Changing door glass rear and upper channel 64 Coupe
  149. spark plugs
  150. Anyone deal with Harborvette in PA.
  151. Project 396 Road Trip
  152. Vinyl seats are horrible....ya think!
  153. Question about Carlisle
  154. 67 steering damper bushing
  155. C1 carb questiion
  156. Spicer U-Joints - How To Install?
  157. Cutting Corners Does Not Pay Off
  158. Need help with Suffix Code
  159. C2 audio
  160. C1 corvette painter NY area
  161. Race Ramps Group Buy
  162. How can I tell if Power Steering was factory original?
  163. Which Thermostat is best for South Florida? 160 or 180?
  164. Looking for Joe Fisher, or an answer to charging problem
  165. Radiator Hose
  166. Radiator Hose
  167. 66 Electrical Help Please
  168. Jay Kline Chevrolet
  169. Gravity bleeding the brakes
  170. May be an old question on tach drive dist
  171. NHRA Drag Races @ Infineon 7/3/10 fun pics
  172. Throwout bearing problem?
  173. NCRS National Meet
  174. what is a fair price for clutch replacement?
  175. Control Arm Shaft - Backwards??
  176. 66 under hood insulation?
  177. Hollander Manual anyone?
  178. Pic of heat markings on my hood at Infineon Raceway
  179. Front coil over conversion
  180. Flops Then - Collectible Now (No Corvettes)
  181. do you have a puke tank for your BB radiator?
  182. Verifying previous ownership of 64 Vette
  183. Body lift straps
  184. AFR Tuning
  185. How do you remove the shifter arm from a Hurst shifter?
  186. new brake lines C1 front disks and rear drums
  187. Any Experts Near Chicago?
  188. 1972 Chevelle Help
  189. Car polish / wax
  190. Casting dates and broach marks
  191. Heat sink issues on 64' 327-365?
  192. C1 with power steering, Thanks Speed Direct
  193. Spare tire fit question -
  194. Body Mounting Diagram
  195. Thanks Tom at Wilcox
  196. OK, so what's the weather looking like for Bowling Green next week???
  197. 1967 Baldwin-Motion, You know the drill on "barn finds"...............
  198. Long tube headers and ground clearance
  199. WIW 1960 Corvette
  200. What and Where Are The Rules ?
  201. Would like picture of panel behind 66 seats
  202. Front to rear brake line
  203. Hooker Sidemount Headers & Sidepipes Installation Complete
  204. Starter armature
  205. Typical mpg for a '57 with 2x4 carb.
  206. painting sidepipe covers
  207. My Vette - The Early Years
  208. Blue Flame short blocks
  209. L79 Fuel Pump
  210. Help 1959 Wipers wont turn off
  211. Head Lights on a 56/57
  212. I give up
  213. Muncie tail housing leak
  214. The expected 5 can answer any question
  215. Removing Rear Rotor Rivets
  216. 67 Turn Signal Switch Help
  217. BB starter heat shield
  218. My 62 in Church
  219. 64 Coupe partial car cover
  220. C2 Hood Removal Question
  221. I agree with Al
  222. Should I need a claw puller to remove the crank sproket?
  223. headliner fell
  224. Ballast Resistor Measurement
  225. Fan blade and spacer on a 62
  226. Pacific Northwest Historics pictures
  227. T-350 question
  228. Vintage Races (photos)
  229. 327 in my 59 runs hot
  230. 53-54 Speedo Drive Gear Help
  231. used 1960? door arm rests - FREE TO GOOD HOME
  232. Cerv1. Did Corvette almost enter Indy car or Formula 1?
  233. 1958 fuel tank install
  234. start up after long sit...?
  235. This year's B/G Auction
  236. Ignition Shielding
  237. C1 - steering box "I feel that tingle down my leg"!
  238. Here's the Blue.. Who's got red and who's got white? Cool Picture of my 67 Sting Ray!
  239. Help...I cannot find the cause for missing
  240. 6 Tail Lights
  241. 1967 Windshield gasket replacement in Chicago
  242. 1962 front parking/signal lights - Repair or Replace?
  243. how to lead a proper parade
  244. Master Dave, I disagree.
  245. New owner of an old Vette? Please buy these books...
  246. Corvette Expo in Houston tx.
  247. coil
  248. Happy 4th
  249. Console Cup/Junk Holder
  250. Carburetor Replacement Recommendations
