View Full Version : C1 & C2 Corvettes
  1. 1965 Front Disc Brakes ID numbers?
  2. What do you think of these plugs?
  3. Temp gauge not working
  4. 1966 Stock Rim
  5. Hubcap spinner rattle
  6. A/C trouble shooter.....need help with compressor noise.
  7. did not see this in FAQ thread
  8. Brake pads...organic or semi-metallic ?
  9. Who Sells Rear End Gears
  10. 1963 roadster
  11. Bolt removal
  12. Progress on the ’66… first primer on
  13. Where's JACKFIT?
  14. Leather or Vinyl???
  15. Which knock off wheels?
  16. Heater delete fittings for intake & water pump
  17. Early 4 speed shifter question
  18. 1961 Clutch Push Rod Bushing
  19. '67 Owner's Manual Question?
  20. Blower for a 64 with a BB hood
  21. Blower Assy Firewall 1965
  22. 1957 Fan Blade dimensions
  23. 30-30 cam specs
  24. TireRack delivered today - JohnZ - Don't look!
  25. C2 Oil pump torque specs
  26. Alternators
  27. Suspension Tuners - Swaybar Size?
  28. Mid Year Hard Top Assembly Question
  29. Gauge Cluster Lights:
  30. OT, 67 BB big scale model colors
  31. Carb. Help / Rebuild?
  32. 65 tires
  33. vacuum can 1116163 gm
  34. So who rebuilds/restores carbs?
  35. 670-15 tires?
  36. Ron Kimball Photos Of Our 59 C1 And 300 B
  37. Lunch with John Neas on Saturday
  38. 1960 Corvette Power Top Diagrams
  39. Car show pictures
  40. 66 Front Bumper spacer question
  41. Install new clutch in a 60 with centerforceII
  42. Rhode Island show today
  43. The car is packed 48 states await
  44. Exhaust Manifold Repair
  45. Early C1 Generator # help
  46. C2 Radio problems
  47. Good to go.
  48. Which type of hood is this ?
  49. Tail light bulbs
  50. Tail light bulbs
  51. Anyone repair a torn fender?
  52. weatherstriping
  53. painting door strike
  54. help- 6 volt to 12 volt
  55. Whew! New electrical and Mods!!!
  56. Vettes 4 Vets-Talladega Track Day video
  57. Can someone tell me what this hose is?
  58. C2 Suspension help
  59. Jim's Corvettes Carbondale, Illinois
  60. C1 Header options
  61. seatbelts
  62. Temp gauge c2. Sorry
  63. Local car show in Cannon Falls, MN
  64. ac/delco battery
  65. Horn Relay...where to get one?
  66. 1958 questions
  67. Jerry Bramblet - Where are you?
  68. '65 front power disc brake rebuild questions.
  69. 1954 chrome top door molding
  70. Distributor Bolt ???
  71. Courtesy light help:
  72. Best spot to get accurate RF gun reading?
  73. Sunoco Racecar Anyone?
  74. Great Cruise Night
  75. Clutch Linkage improvement mod (some pics)
  76. total timing
  77. Help! Can't get on CFOT
  78. Volt Meter vs Batt Meter.
  79. FINALLY - Da' Hookers are hung
  80. 365 HP vs. Fuelie engine
  81. 1957 & 1958 head bolt markings
  82. Questions about buying a '65-'67
  83. Resource info
  84. Heater Switch Mounted on Cable
  85. decode rear axle help
  86. Determing When to Replace Rear Spring
  87. Carlisle attending list & forum happenings there
  88. Chuck Smith
  89. vacuum reading
  90. 56 Glove Box Items
  91. clutch / brake pedals
  92. clutch / brake pedals
  93. '65 Vette Thunderhill pics & video...whew!
  94. Help on ID'ing my 2x4 carbs please...
  95. C2 Battery Tray
  96. Holley carb float problem
  97. Clutch pedal linkage
  98. 1958 voltage regulator
  99. Brake Pedal Return Spring
  100. National Corvette Museum Called Today!
  101. Part two; Charlotte and back to NCRS National in my '62 (PICS)
  102. Friday Funnies
  103. Is 195 too hot?
  104. Newb Q, how to remove hub cap on my '56?
  105. S/Top removal
  106. Project 396 Sidepipe Questions
  107. Did all C2s have splash shields?
  108. C1 arm rest & cup holder
  109. 60 brake hoses
  110. Mounting Differential Crossmember Question
  111. C2 Weights
  112. Can a Roller Cam be added to a 396?
  113. oil pick up extension part number for a Melling pump "Select" #10553
  114. 1960 C1 underside of rear body - messed up
  115. What constitutes an original car
  116. Calculate the speed with this rear end calculator
  117. how can you tell original or not
  118. 205/70/R15 Tires Falken?
  119. Is this ligit
  120. Any Comments on Patriot Headers
  121. Can someone check a car in Vero Beach
  122. Carb setting by vaccum gauge
  123. Sam Kalmuk GS question
  124. Anybody familar with Dannmar lift
  125. Raceway Park, Englishtown NJ
  126. How much oil.......
  127. Wiper wont park.Think i know why but i need a little help
  128. California YOM License Plate Sequence Help
  129. Glove box door paint
  130. Tremec or Muncie?
  131. DynoSim5
  132. Talk about dumb luck! (original CA plate)
  133. Download C2 assembly manual where?
  134. Mag Wheel Cleaning
  135. englishtown nj vette show
  136. McCleod Twin Disc Clutch: Excellent System
  137. clutch experts help please
  138. C1, C2 photos
  139. NoVA - 7/31 - Purcellville, VA - Annual Thunder Cruise SATURDAY
  140. Free Shipping on Orders over $99 Thru August 3
  141. Need some help 66 vette
  142. Made it home with my new '56!
  143. C2 Half shafts
  144. Rear Spindle Removal
  145. Big block headers
  146. grille installation
  147. Question: Car Cover For C1 Parked Near A Marina
  148. Anyone going to Hot August Nights Lake Tahoe this weekend?
  149. A/C Question
  150. Thanks to Engine Builder
  151. 1963 conv.
  152. Help with interior insulation please.
  153. System Administrator
  154. For us West Coasters
  155. centerforce
  156. 65 coupe windshield date code
  157. Carburetor Question
  158. Engine miss with TI
  159. "Corvette 1965: Youve Heard The Rumors"
  160. 1963 Corvette for under $150!!!
  161. C1 poster
  162. Hood 1965
  163. replacing universal joint on a c2
  164. 67 grille
  165. Stolen - vette, truck, harley from usaf friend
  166. Why was the "Grand Sport" Thread Closed
  167. C2 Windshield Retaining Clip Install Q
  168. Trailering a '62
  169. C2 frame dimples for caliper clearance 63-64?
  170. torque specs on 3810 carb
  171. Looking for C1 gas tank equipped for late model fuel injection
  172. Ramjet 350 hood clearance in C1
  173. F41 Front Shocks NOS
  174. 1964 fuel filter bracket location.Where?
  175. Light problems
  176. Fuel injection lookalike airfilter?
  177. Your thoughts
  178. Dash pad 1965
  179. What would you build?
  180. Help - Stolen Corvette
  181. Do you know these guys???????????
  182. Trimming a Monospring
  183. End Of An ERA - LOVE IS BLUE gone!
  184. Fresh 64 327-250 Overheat
  185. Replacement of 1966 transverse spring went from great to disaster
  186. Another overheating question
  187. Frame Shim -- 65 convertible
  188. Help with 57 fuelie #s
  189. 56 suspension lifting under power
  190. thanks frank
  191. C1 Soft top frame identificatio
  192. Door Latch/Striker Adjustable?
  193. What about having a topic about how to do work on your Corvette?
  194. Evans Coolant
  195. 62 Front Alignment
  196. C2 Cruising Engine, Trans Recommendations
  197. Question: 57 hartop on 58?
  198. Help, can't get gas pedal screws out!
  199. Frame Off Restorations In Your Garage
  200. Ignition timing advice
  201. Differential "C" clips ... again.
  202. Which way to move the distributor?
  203. Power Brake Rod Placement
  204. transmission temp
  205. Replacing Birdcage
  206. Reuse a camshaft?
  207. 66 thermostat housing
  208. Corvettes at Corsa 2010
  209. C1 1957: Help with installing headlight housing bonding strip
  210. Some C2 fun at Lime Rock ALMS Weekend
  211. C2 A/C Compressor Source
  212. O Ring Replacement on Fuel Inlet Needle Valve
  213. What engine is this?
  214. C1 hartop- Questions and advice
  215. Proof Reading....what a concept!
  216. Door window resto?
  217. Help! Carb Flooding out of rear bowls.
  218. NOISE: Steering box vs PS valve?
  219. Restoration costs
  220. Escort G-Timer GT2 software
  221. LOOK!! Anniston, Alabama; Torrance California, Birminham, Alabama; Los angeles, Calia
  222. SPAL electric fan question
  223. Help me verify this muncie ( casting numbers and pictures )
  224. rear end gasket
  225. Who all is going to Corvettes at Carlisle
  226. suspension set up for drag racing
  227. 64 park brake front cable. Wich end is?
  228. Fuse Block Screws?
  229. No rear brake or signal lights
  230. looking at colors
  231. Keeping Cool. Adding Auxillary Fan When Running A/C?
  232. 54 Door Latch Problem
  233. E Town vette day 2010
  234. Battery disconect with original style cables?
  235. Questions about antenna grommet and inner door sides
  236. Question on installing 1966 transverse spring
  237. Need Photo of Engine Wire Harness Looms
  238. project timeframe
  239. Help Identify Unknown Bracket
  240. ANOTHER AC QUESTION/Problem!
  241. Is this the new look of eBay?
  242. Repair Estimates For '60 That Was Idle For 4 Years
  243. Hemmings Motor Cruise In Pics
  244. Need to sell my C2 steering column. Do I sell “as-is” or rebuild first?
  245. question about convertible hardtop
  246. Vert. vent windows
  247. Question about Hardtop Window
  248. Ending Today - Race Ramps Group Buy Offer
  249. Anyone ever use CorvetteGoodies before?
  250. HELP! 66 vette Air Conditioning
