View Full Version : C1 & C2 Corvettes
  1. '57 harmonic balancer wobble, slides off!
  2. If Jackfit had a 5-speed..........?
  3. Ignition lock turns without the key in?
  4. 1966 Tilt Tele Column Conversion ?
  5. C-1 Cross Member
  6. 1961 Clutch/Brake Pedal Removal
  7. Question about a T-56 in a C2
  8. Kirby Puckett Corvette
  9. C1 tires on a 5 1/2" rim
  10. '67 L79 Exhaust leak at muffler inlet
  11. Goodguys Blue Suede Cruise Norwalk, Ohio
  12. Horn Button
  13. Cast Iron Powerglide Help
  14. manual steering box fitment
  15. Coming to Carlisle from Atlanta?
  16. X-member fitment
  17. Rad Cap Question for Tom DeWitt.........
  18. For a non Corvette project need some names of good quality radiator builders
  19. X-member fitment
  20. Is this a 63 or a 68 engine?
  21. OT- trailer bearings
  22. C1 (1960) Coil Springs
  23. sat in a 54 for the first time today
  24. Lifting 65 coupe off frame
  25. 53 Corvette #169 Update Photos
  26. 66 Tuxedo Black-KO's or hubcaps opinions?
  27. Original 1964 Corvette A/C dash
  28. Need help identifying these parts for my 57
  29. Car Show Pics
  30. 56 Front Disc Brake Conversion
  31. Where to find 8 awg wire?
  32. 63 to 67 Registry/SACC at Carlisle
  33. how do you tell an origional 1965 grill
  34. Kingpin replacement - 1962
  35. Follow up - Cooling system flush after 30 years
  36. C2 Roll Bar- What ya think?
  37. Pics of 670 X 15" Goodyear tires 1" white wall on C2 Coupe?
  38. HELP!!! Seasching-----------------
  39. Toad Suck Car Club Show today
  40. C2 door handles all the same?
  41. 1956 Eska Ertl Corvette Pedal Car
  42. Minden, Nevada car show pics
  43. Picture of a original heater water shutoff valve for A/C cars
  44. Ignition Switch
  45. Hood ledge weatherstrip questions- C2
  46. C 1 interstate driving & 3;08 gears
  47. C 1 shifter boot over a hurst shifter
  48. DeWitts on Facebook
  49. 327 block weight?
  50. What about these rims?Do they fit my 64 coupe converted to disc brakes?
  51. Power brake install questions
  52. C2 inspection in Claremont, GA- can anyone help?
  53. electric fan causing idle fluctuation
  54. rear main leak..........disappeared?
  55. Problems with Tremac in 63'
  56. tremec oil leak
  57. Any interest in a 58 project
  58. Steering box lubricant
  59. Bolt spec.s for L79 waterpump
  60. 66 327 no start. Crank, no fire. Suggestions?
  61. 67 Coupe, What Is It Going To Cost Me? Tags, Title, Registration Florida
  62. Carlisle Weather Looks Great!
  63. 62 Corvette back on the road
  64. Would these wheels fit my 65?
  65. Reverse Lock Out Question
  66. C2 radio help needed - no reception!
  67. Black smoke from the tail pipe...
  68. C2 Vintage Air- Spal fan power connections
  69. Ammeter Fuse Size ('65)
  70. 67 muncie trans issues..jammed
  71. 1960 windshield removal ?
  72. 58 - Question on hood support on Passenger Side
  73. New window glass
  74. Put DeWitts on that Carlisle list
  75. 1960 #3 Le Mans Corvette Historic Return Documentary Trailer
  76. What should I budget for side pipes?
  77. 63 wiper motor
  78. Alternator bracket bolt question
  79. rear main seal is seeping oil
  80. Check this out.
  81. Need housing (shell) for brake stop light connector
  82. Help with door weatherstrip ???
  83. how do u tell a real 66 grill
  84. 65-66 Steel wheel-how to identify?
  85. 66 hub caps. how to identify original
  86. 65-66 Steel wheel-how to identify?
  87. Pertronix failure? I need help!
  88. painting oil pan
  89. 67 rally wheel ?
  90. Corvette Specialties Of Maryland is Relocating!
  91. Any Pics of Northwest Regional
  92. 62 Resto. New Body or swap?
  93. insulation side pipe covers
  94. Mid Year Expert Needed
  95. FRIDAY SMILES, the good, bad, +the ugly
  96. C-2 Hood Shocks
  97. A Note to Our Valued Customers
  98. #3 Body Mount Insert
  99. "Corvettes on Woodward"...Pictures
  100. paint center caps
  101. snoping in carlisle
  102. Monterey Historics Weekend And A Couple Of Interesting Corvettes
  103. 50th Anniversary at Le Mans VIDEO enclosed -->
  104. C2 Pre Purchase Check List !
  105. Clutch pedal adustment ??????
  106. So who here is doing this?
  107. Need some hood help
  108. Poll: How many Corvettes have you owned
  109. Anything odd stand out with this ad, before I go look at the car?
  110. Threaded Crankshaft
  111. 67 4-Speed Shifter and Rebuild Kits?
  112. Compression and cam overlap
  113. '65 interior door lock thingy
  114. Side pipe location
  115. Brake caliper machining / sleeve installation
  116. 1964 roadster windshield replacement
  117. 1962 master cylinder
  118. Hot Rod Air vs. Vintage Air
  119. 1956 posi
  120. wheels
  121. frame dipping???
  122. 56 gauges...
  123. Why the heck would the original belts...
  124. Linkage adjustment
  125. Has Current Economy made suppliers slow in getting you your parts?
  126. C2 Hardtop Original
  127. 66 Transmission Swap
  128. Wiring assistance
  129. How long is it?
  130. How can I fix my upside down parking brake handle?
  131. Fuel and brake lines ?
  132. 1960 Seats
  133. HELP!!-Carter AFB for '62
  134. The book about the build of my car......
  135. Fluid Film Rustproofing
  136. Swap a volt meter for the amp meter
  137. ammeter
  138. Glad I Don't Own
  139. AACA Meet
  140. Sorting out the orig 462 on 67 327-350
  141. opinions on removing fender flares back to OEM
  142. HP question
  143. FI Running Inconsistently
  144. Adding temporary radio to '65...how's wiring?
  145. Control arm/ rear diff rebuild services
  146. The Count Down Is on For Carlisle
  147. 63 headlight switch
  148. ==> The CHUCK CoW Carlisle COUNTDOWN CLOCK - COOL FREE DOWNLOAD <===
  149. Try to make the show in Destin FL Oct 23
  150. 64 FI Stalling
  151. Magnificent '58 at Montery...
  152. Back on the road again.
  153. Look who we met at a cruise night tonight!
  154. 56-57 courtesy lights option
  155. Fel-pro 1204 head gasket for L79 build?
  156. will a 365hp dizzy fit a 350 hp motor
  157. Big Block '57
  158. 56-57 wonderbar parts?
  159. JOIN US IN MEMPHIS*** 2010 St Jude Fundraiser Check Presentation Info***
  160. Carlisle forum member - Help
  161. Vettes at Woodward Dream Cruise???
  162. A question for JohnZ...interior vent?
  163. 67 brake lights not working.
  164. Any C1 owners from Bakersfield, CA???
  165. Valparaiso Corvette & Chevy Show
  166. 61-2 VIN relocation - DMV
  167. Inspection Wanted C-1 Inverness Fl.
  168. Alternate solution to header bar top leaks
  169. I hat to ask again, but- any new opinions on this?
  170. Let's say you had one of these...
  171. Carlisle fun field really?
  172. L-79 What Spark Plugs
  173. 1964 Hood Ledge Weather Strip
  174. Sidepipe Heat
  175. NoVa, Corvette Cruise Photos
  176. wanting to trade 08 for 61,62
  177. Member Usage
  178. So what killed my coil?
  179. What Motor Combination's for a small block...
  180. COMPLETE 63 FI unit for sale------NOT me
  181. 1966 Vette rear problems
  182. 1964 Side Pipes ????
  183. 097 Duntov Cam LSA
  184. If you had the opportunity
  185. This guy owns 3 L-88's!
  186. NCRS Regional Bend Oregon
  187. Bolt Sizes for 67 AC Brackets
  188. Lets Try This Poll Again
  189. HELP!! Need pics of '62 heater hose routing
  190. Compression test results, and #s -how does this look?
  191. Fuel sending unit
  192. seam sealer
  193. C6Z owner needs C2 buying advice
  194. A word to the wise.
  195. What Do You Own
  196. '63 driveline length
  197. 67 power brakes & booster
  198. '61 Inner Skirt Dust Shield
  199. How many are left?
  200. Going Insane? Computer Glitch?
  201. Oil Filler Tube....
  202. noise under car.
  203. Learning the hard way: Broke original axle strap
  204. fiberglass question(s) 1962
  205. 66 with a 67 BB hood
  206. HDR Photography
  207. Father of the Corvette
  208. 29969 Master Cylinder Question
  209. That hurts
  210. Coil theory question
  211. Best Source for a 67 Turn Signal Switch?
  212. Jacking up the 64
  213. 67 starting issues - no high idle
  214. Help: Need a pic - cowl vent area
  215. Blinker mechanism broken
  216. 60 question
  217. 54 body rivets
  218. battery disconnect switch
  219. Heat riser question.
  220. Radio for a 67 keeps crapping out
  221. 56 body work....
  222. And a queistion on numbers matching cars
  223. Corvette Fever - Final Issue
  224. Did You EVER
  225. Did You EVER
  226. Color of water pump fittings on 67 327/350
  227. Debonne Vineyards Classic Car Show Madison, Ohio
  228. Mecum Auction 66 Corvette M-22, 36 tank
  229. 64 clutch cross shaft
  230. some one should check this out
  231. Recommended harmonic balancer installation tool
  232. 67 L-88 Goes for $1.25 Million at Mecum Monterey!!
  233. What is my 66 convertible worth? Info and Many Pics
  234. Cleaning Underbody
  235. Hurst
  236. Did Mid Year Vettes Come with a Wonderbar Radio?
  237. 66 rear apron bolts
  238. Pace Arrow trailer ???
  239. Does anyone knwo what's going on under this car?
  240. How safe is it?
  241. Remember the 1 millon Dollar speeding ticket
  242. Does anyone make a decent.......
  243. What gear ratio is it?
  244. Jeep Steering Box Loose?
  245. Tailing Arm Spindle Assy
  246. Lifter Noise?
  247. C1 Softtop install
  248. Valve adjustment
  249. Timing
  250. Kirby Pucketts 1961 corvette on ebay!
