View Full Version : C1 & C2 Corvettes
  1. C2 headlight motors
  2. Reposted Pictures of Jack's Visit to Park City, UT
  3. '58 C1 Overheating Solved
  4. 67 Bolt Ons
  5. Head Question
  6. C2zr1
  7. Comp Cams kit lifter problems....?
  8. Selling 1957 corvette fi best offer
  9. [Toys for Tots]It's the most wonderful time of the year...
  10. KUDOS to VINTAGE AIR
  11. Tire Preference Advice
  12. C1 clutch pedal shaft bushings
  13. 66 Keeps blowing stoplight switches
  14. Original Radio removal from a 67
  15. Its Official!!
  16. 55 Pic's
  17. 1960 Hood change
  18. 1st Timer at Carlisle !!!!!
  19. Info needed - compressor date code
  20. A couple of C2's escorting a Pantera out of town!
  21. 64 short when ignition "on" - how to triage?
  22. what are the differences in the rear exhaust panel between a 63 and a 64?
  23. Inside of 3-spd, eewww
  24. 1965 Convertible -- Bodywork? Pictures
  25. 65 Distributor Shield - Is this one?
  26. 65 - installation of L79
  27. 8-31-10 * * f a m i l y - n i g h t * *
  28. Does anyone know what Vette this emblem went on?
  29. 1966 headlamp alignmrnt procedure
  30. New C1 and C2 Fan
  31. Check your rear spindles!
  32. 66 vert windshield removal
  33. Ammeter connections - my diagram shows they are same 12v source both sides
  34. vin supposed to be riveted on or srcewed?
  35. 1966 steel wheel question
  36. 67 POP Decode help
  37. 63 327 build L 79 cam head choice ???
  38. c 1 water pump bolts
  39. So who took home from Corvettes at Carlisle any of these weekend project C1 and C2s?
  40. What is hot and what is not from Horn relay?
  41. 1111263 ball bearing ti race distributor parts
  42. Wire Gauge for Glove Box Light
  43. Carlisle, C2's and 3's and 4's etc
  44. gas caps, Carlisle
  45. Corvette Fun Fest Is Next
  46. Corvette Specialties Of MD is Relocating!
  47. Red 54 Restoration with MANY photos of the process
  48. 1956 Operations Manual
  49. Pictures of Jackfit and Gary63 in Park City, UT
  50. The Corvette Gods – some good, some do so good!
  51. Ameter on 67 going radical
  52. Battery Disconnects Must Really Work
  53. 65-66 seats
  54. Inner fender skirt
  55. Distributor Value Needed
  56. looking for any info on rex osteen chevrolet in south carolina
  57. 327 Water Pump
  58. Orginal Female Corvette owners
  59. 327 Wrong Date Code
  60. Mid America Motorworks Museum
  61. 62 Power Glide kick down linkage
  62. Diameter fo the stock C2 wooden steerign wheel?
  63. Thanks for the Carlisle Advice
  64. More Carter Carb ????s
  65. 62 Aluminum PG Torque Converter
  66. Need help with timing my '61....
  67. Pickling an engine
  68. some Carlisle pictures
  69. 57 Radio: 'Wonder Bar' ?
  70. Carter wcfb carb
  71. stopping the heat/exhaust fumes from the rear of a 1960
  72. looking for correct 1960 water pump #'s
  73. To the thief stealing gas caps during Corvettes at Carlisle - THIS MESSAGE IS FOR YOU
  74. FW Rally Wheels w/4.25" offset won't fit 65 coupe
  75. Need a jack
  76. Goodbye Centerforce!
  77. carb jets & spark plug color
  78. L72, 427 engine
  79. L72, 427 engine
  80. OT: Vintage car record players
  81. How do you add power brakes to a 57 Corvette?
  82. 66 327/350 Engine Knock
  83. C1 at Carlisle with Alaska Plates
  84. valve cover gasget
  85. 1962-1972 Corvette Shipper Information
  86. What to buy Classic Chambered
  87. Venders at Carslie
  88. What I didn't find at Carlisle....
  89. 65 L79 Motor Mounts - Recomendations for
  90. Found Most at Carlisle....
  91. C1 rear axle specs - quick question
  92. C1 vibration on acceleration and deceleration
  93. Photo Carlisle on Friday...
  94. Do not touch sign......
  95. Frankie at work....
  96. Clutch Peddle Rubber, How Can You Keep It From Coming Off?
  97. Steering turns hard to the left went I started the car?
  98. 1962 Intake Manifold Number??
  99. C2 Registry
  100. I can't believe this has could happen
  101. Ignition shielding kit 64 and 66
  102. Deleted
  103. 905 dist question
  104. c2 w 18"s on the front
  105. An official THANK YOU to you guys
  106. hood latch help!
  107. Seat Belt - History
  108. 56-60 trunk latch...
  109. carlisle dealers...
  110. A Few Carlisle Pics
  111. original owner
  112. 350 CI Block
  113. Updates on 53 #18
  114. Carlisle Thefts already
  115. Tie down loops found on 1953 #18 anybody now ?
  116. Car cover recommendation-'64 coupe
  117. 56/57 hood front alignment blocks
  118. 1963 Corvette still around
  119. which polylocks clear stock 427 valve cvrs?
  120. Block found at Carlisle. ID Please?
  121. front bumper install 65
  122. dumb question
  123. 65- Installing both L79 & Muncie
  124. Sidepipe covers and insulator question
  125. 200R4 in 63 vert
  126. 67 light behind ignition switch
  127. steering column paint
  128. Doc Rebuild at Carlisle?
  129. looking for stock ls7 eng. wiring harness
  130. 396 Vette
  131. Oil Filter for a 67 427/390hp
  132. rag joint interchange
  133. 908 dist question
  134. Did Any 1968 Corvettes Have Sidepipes
  135. Holley 2818 sources
  136. Al knock vs Corvette america 67 Soft top
  137. Shifter Linkage very tight
  138. 53-54 Corvette at Einstein's funeral
  139. Anyone familiar with my car?
  140. 67 door latch pic
  141. Its Friday:Time for a smile
  142. Can any good Photochoppers out there...
  143. DASH LIGHT/ "lights" and "Brake"
  144. New Jresey Vette owners
  145. what did this distributor come out of? 111069 5B1
  146. C2 fuel sender ohms?
  147. Calling all C1&C2 folk in or near Olympia, Washington...
  148. Carlisle?
  149. Help! Need details on matching Laguna Blue paint formula
  150. How to whiten white walls.Scratches
  151. Painting my 58
  152. 66 Power steering pulley
  153. Help decoding a block stamping.
  154. Chevy still using Chevy??
  155. front & rear window installation
  156. 65 L79 oil filter mount installation
  157. sold 01 for 67
  158. Brakes....HELP?????
  159. C2 Front end - easier or harder?
  160. 1953 Picture thread
  161. Leaky Winshield Problem
  162. PG to Muncie swap, the parts are rolling in.
  163. Steering Column
  164. Grabby 64 drum brakes
  165. Take a look at this front end...
  166. L-79 replacement piston question
  167. Turn Signal Cancellation
  168. 1964 inner AC heather box. Have the previos owner cut it?
  169. Small stero amp
  170. Front clip at Carlisle
  171. Stainless exhaust - for my C1
  172. '65 Rocker Panel Gap
  173. Car Show to Benefit the Nevada Paralyzed Veterans.
  174. how do you find
  175. Drive shaft U-Joints
  176. Rebadging a de-badged C2
  177. open or divided plenum
  178. 3846180 alternator pulley
  179. POP and Warrenty Book Found
  180. '60 Serial number location
  181. Paint blisters
  182. Race Ramps 10% Discount at Corvettes at Carlisle!
  183. Where does this wire connect?
  184. Why can't people keep their hands off stuff
  185. What year frames are interchangable?
  186. Question about exhaust manifold 3733976
  187. Need a few new parts for my 59, where to buy?
  188. Carlisle on Thursday
  189. Phil Hall Collection: 1962 Corvette Fuel Injection
  190. Spare Tire Cover 61 on a 58?
  191. 63 vert 327 300hp head question
  192. diamondback redline radials Michelin p205/75/15
  193. Found it!
  194. Stupid Question of the Day (C2 Related)
  195. new knock off style wheels
  196. 10% Off 53-67 Corvette Parts and Accessories + Free Shipping - Storewide Sale
  197. Carlisle Motivation
  198. Need help identifying a 57 BW 4spd - casting numbers
  199. License Bracket for a C2
  200. powder coat T arms?
  201. Any of the GS regulars going to Carlisle ?
  202. Battery isolator and thermatic fans??
  203. Carlisle
  204. cleaning seat belt webbing
  205. Steering Box Rebuild Seminar at Carlisle
  206. rear deck alignment on my 66 vert???
  207. Recommend a floor jack and stands?
  208. Hurst shifter
  209. Leaving NCRS
  210. 66 vert deck lid
  211. Aluminum Trailer
  212. C1 clock repair
  213. Smacked up the 66 on the way to a car show
  214. Corvettes at Carlisle - Corvette Needed for Race Ramps Display
  215. My way to hide PCV valve
  216. Anyone with 700R pictures?
  217. 64 Parking brake warning lamp switch?Sits where?
  218. l-88 heads
  219. 67 Clutch Adjustment Question
  220. wonder bar radio 62
  221. Thought you might get a kick out my defroster
  222. Rear End Swap with disk brakes to my C1
  223. 54 resto mod build, need help with chassis choices
  224. Engine change to a 396 ci in my 65
  225. C2 Alignment spec analysis needed
  226. C2 I know OT but must be seen!!
  227. 1st Time Carlisle Attendee
  228. Paint/body in the Kentuckiana Area
  229. Brake lights not working
  230. [Pics] 1964 Questions for potential buyer
  231. Which Goldline tires To Buy ?
  232. Radio light
  233. '64 Antenna Install
  234. Original 1962 Corvette Owners guide....+
  235. Wichita Kansas Black Top Nationals
  236. Help with buying a 59 project
  237. In a pinch is it possible?
  238. New Redline's for '67 427/435hp Convt???
  239. '61 Windshield Gasket
  240. Average rebuild cost for Generator & Starter?
  241. C2 Floor mats
  242. Corvettes at Carlisle - Corvette Needed for Race Ramps Display
  243. 1965 interior
  244. fuel gage and sender problems
  245. 62 vac canister
  246. 58 - Generator Pulley Alignment Question
  247. 63 exhaust bezel question
  248. '57 harmonic balancer wobble, slides off!
  249. If Jackfit had a 5-speed..........?
  250. Ignition lock turns without the key in?
