View Full Version : C1 & C2 Corvettes
  1. C2 Small block Chevy 427 & 454 shortblocks
  2. A&W Edmonton Friday, Sept. 17th
  3. Progress on Affordable Fuel Injection for 63
  4. '59 Barn Find
  5. Bob McDorman's Collection to be auctioned
  6. hydraulic clutch and master cylinder source
  7. Mecum on HDTV tonight.
  8. Spring install ?
  9. generator charging rate/ grounding...
  10. best carb set up for 327/365hp 65' c2?
  11. Sales tax buying corvette out of country
  12. WCFB idle by-pass screws
  13. Dash restore
  14. there would be soldiers alive today if they had had the Stingray
  15. 1964 pontiac concept similar to c3 vette
  16. Big block springs
  17. New Frame-Vette Products of MI?
  18. Good article on AN vs. NPT fuel lines / fittings
  19. Thanks to Mark at Vintage Air
  20. Anyone live near Paulsboro NJ?
  21. Rebadging my C2
  22. Long Island Corvette Supply
  23. 1960 Front hub color?
  24. 66 big block sidepipe question..
  25. T.g.i........friday funnies...!
  26. It Friday:Time for a smile
  27. lower molding clips windshield vert 65
  28. Off topic - Dr Vinyl repair service
  29. Fuel Problem (?) with Split Fuelie
  30. magazine cover
  31. 63 rdiator, support and schroud differences
  32. timing cover crank seal install
  33. *The* Daddy 1957 Corvette SS (PIC)
  34. 1957 Tailpipe Length???
  35. Insurance FYI
  36. live drag racing video from the Pure Stock Drags
  37. Project car VINs
  38. Ouch!
  39. Superperformance GS to be at SEMA show
  40. >> St Jude Auction #66 * RARE Autographed Baseball Joe Torre and Rudy Giuliani
  41. 1954 LL Wiring harness question #2...
  42. AC Hoses
  43. need picture on 340 hp c1 top of motor
  44. Wheels for Painting
  45. Ed Hoffman from Camarillo CA, Please Open ASAP
  46. 67 Headlight Bucket Removal
  47. L79 Ventilation Baffle (or cannister)
  48. O/T WWII airplanes
  49. Livin's 57 Corvette 1st Body off Restoration, Progress Report #???
  50. 66 Power Window Problem
  51. Interior Paint 1965 Coupe Black
  52. '64 vin#114722 motor found
  53. Valve Cover #'s help please
  54. *^* St Jude Auction #65 "The Mystery Donor is Back!!! Autographed baseballs!
  55. Installing a Dual Point Distributor
  56. hood hinge repair
  57. C1 Auto dismantlers
  58. Sterroids on a C2
  59. 54 blue flame six vs a regular 235
  60. A good reason to own a Kwik Lift
  61. c1 headlights
  62. Help with replacing Tach cable....
  63. Shipping whls/tires who'd have best price ?
  64. How do I fix having to pump gas peddle 10 times to start cold engine?
  65. Prescott az. Historic all corvette show
  66. Anyone have any info about this car?
  67. Vette Vues Magazines 1983 1984
  68. Question what MPG will my 66 BB get ,after Tremick conversion
  69. To the member who wanted long tire carrier bolts
  70. valve stem seals
  71. I need a good rivet tool. Wich to buy?
  72. Grand Run in Pigeon Forge
  73. Who will be at the NCRS meet next weekend in North Carolina?
  74. 1963 Corvette Restoration...
  75. Restoration Rookie
  76. Assembly Manual Article
  77. Adirondack VetteFest pics
  78. Need help finding metal Strips on PILLAR
  79. preventing hydro-lock 58 f.i.
  80. Vette on magazine cover.
  81. New 63 vette owner - Input Needed
  82. Where can I find a set of steel wheels
  83. How to install a new upper distributor bushing tach drive
  84. 63 rear wheel bearing clearances
  85. 62-72 GM Delivery Data Available
  86. url for wheel thread
  87. Somewhat OT
  88. Teak Steering Wheels - The REAL thing
  89. 56, 57 wiper transmission cable
  90. Hints on fiberglass repair
  91. Removing the light switch
  92. cleaning 340hp aluminum intake help please
  93. Carburetor Question
  94. My 64 327-300 seems cold blooded to me
  95. Need Picture of 66 rear taillight Harness...
  96. 67 B/B Hood
  97. water pump question.....?
  98. Gas tank sending unit for 63
  99. Amazing Cast Iron Repair
  100. Help with a Vin
  101. 1963 master cylinder question
  102. After market mirror for C1's
  103. 67 Front Grill
  104. aluminum intake 340 HP 62/63 difference
  105. 461x heads what size valves?
  106. Sidepipes question
  107. Ot -an observation from these old eyes
  108. how to clean my intake?
  109. My -64 black coupe
  110. Anyone ever used the Jag IRS in their C2's?
  111. 67 Clutch Adjustment
  112. Route 66 What a Blast
  113. Hot August Nights
  114. Side of car lift?
  115. 63-67 Original Bumpers
  116. 67 B/B Stinger
  117. Am i crazy
  118. Downside to going to a car show
  119. Rear end question
  120. 1961 engine serial number question
  121. 64 test shots
  122. All N.Y. Corvette owners
  123. Removing 61 seats
  124. Two very famous racing Corvettes will be in the same place
  125. 54 corvette parts resouces ?
  126. Opinions on exhaust smoke & crankcase ventilation
  127. Weird Trim Tag Question 1967
  128. great car show this weekend next sunday NY
  129. Anyone have a automatic trans.
  130. weekend c1 break down airtex pump !!!!
  131. Convertible leak at Windshield Header?
  132. Identify these wheels
  133. 67 Muncie Shifter Levers
  134. inner fender seperated from upper fender
  135. Distributor lube
  136. For 55copper
  137. What do I look for on a 67, half-shafts rubbing the body?
  138. p/s belt route for 67 big block
  139. 64 Wiring Harness Swap
  140. Car Show Pics
  141. Mike Terry is in a Mid America Ad
  142. Best Military Pit Crew Around
  143. C1 Windshiel Woes
  144. Pre-sale inspection needed: Atlanta area
  145. Midyears ranked #1 amongst coolest cars ever made
  146. Knock-off came off @ 70MPH - need body shop in MI
  147. C2 Vert top near Houston Tx
  148. Speedo, rebuild or just a cable?
  149. Antique Gas Pump Prices?
  150. K.O. wheel ?
  151. Found a vin tag, is it yours?
  152. Just Back From Corvettes at Carlisle
  153. 58 Firewall Hole Identification - Is this correct (see picture)
  154. people are funny
  155. Differential Strength???
  156. 67 427 425 hp
  157. Can You Say Vented Gas Cap Needed
  158. Repro fender mouldings
  159. 63swc vette rod w/ knock offs
  160. Dash Number 2 ?????????
  161. Best Spark Plugs for 1967 435hp BB?
  162. Update Pics
  163. Got my new baby home today
  164. ball park estimate on a 62 steering box rebuild
  165. 55 Powerglide transmission value?
  166. St Jude Auction #63 Calendar Girls * 2011 Corvettes and Curves Calendar
  167. Hinge pin replacement
  168. 1962 Wiper Switch Cable Adjustment
  169. Look what I found
  170. First drive in almost 28 years!!!
  171. Bad Fuel Pump???
  172. 1967 BB assembly date of TO223JE
  173. [pics] Santa finally came!
  174. Roller Rockers under stock valve covers
  175. 235/60-16 Tires
  176. 1961 side emblem templates
  177. Original corvette warranty books
  178. Help Needed, Water Leak
  179. car transport in florida - miami to nj
  180. Oil Filter Mystery
  181. Electrical issues
  182. TPS Motorsports on Facebook!
  183. matching numbers, how to check?
  184. Repairs started on the 66 - but you HAVE to see this picture
  185. Gas Tank Plug on a 65
  186. Who sells wide fender flares that looks like original?
  187. PG to Muncie swap, and so it begins....
  188. Gas tank mounting
  189. BW v. Muncie
  190. 1954 new LL wiring harness installed...
  191. Clutch fan question......
  192. Does any one check the cam to distributor gear engagement when replacing intakes??
  193. Horn Relay Heating Up
  194. what would you do?
  195. 65/66 vette in lowes parking lot pictures
  196. My 1st run down th 1/4 in my 67 10.87!!!!
  197. ***Rules and Tips for the Calendar contest***
  198. Not corvettes, but nice rides :)
  199. distributor advance plate question
  200. St Jude Auction #62 A Day At The Races (HPDE) Putnam Park
  201. What's happening at LS Fest?
  202. inner windshield moldings and screws - can't find vendor parts
  203. Frame off update
  204. Cool old ad
  205. So You Think That Your Corvette Is The Most Beautiful Car Of All Time ?
  206. 1960 rear end set up problems.
  207. 1964 Corvette on Display at The National Corvette Museum
  208. fi nozzel blocks 58
  209. Air bag in a C1
  210. ? for fi experts
  211. 1965 Power Brake line routing
  212. 63 Side and vent window installation. Help Please!
  213. Clock Schematic
  214. Buckshot--More Photos
  215. Hole for toe shim cotter pin?
  216. C1 Body mount kit
  217. Never forget!!!!
  218. Photoshop experts
  219. B-17 and SWC
  220. 53 @ cruise night
  221. Help! 66 wont start
  222. My 64 is entered in the calender contest
  223. tail lights, brake lights and signals
  224. Windshield Shims C1
  225. Does anyone know what this is
  226. what was the name of that new web site to post pictures
  227. PCV versus draft tube
  228. Generic air filter for 1956???
  229. Calendar Contest Has STARTED!
  230. Looks like a 54 Vette...
  231. Value of WCFB carbs ?
  232. 63 Fan/Shroud/Alternator Alignment?
  233. Know their business
  234. Powerglide Trans and TC revival
  235. Roller Clutch Pilot Bearing
  236. and now...the famous...FRIDAY FUNNIES!
  237. 60 for Super/Stock (project update)
  238. 60 for Super/Stock (project update)
  239. Spark Plugs - C2 - Factory Air
  240. block & tackle safety question
  241. 66 is in the mail...
  242. Radiator problems.....
  243. rebuild '63 instrument cluster with modern inputs?
  244. c1 center wiper transmissions
  245. Restore Rocker Panels?
  246. 1961 Clutch Z-bar
  247. 64 electrical question
  248. Part # For L79
  249. Tricks for installing exhaust bezel?
  250. Help on C1 outer heater cover mounting
