- Ugly but Solid: '59 Barn Find-A Look Down Under
- 54 interior & dash color
- '65 AFB Carb leaks down
- 65 Corvette model
- ~~~~ St Jude Auction #73 Autographed C6R Corvette Racing Hat ~~~~
- Rebuild of C2 A/C Blower Motor
- Which Red? Please vote.
- The smokin wire
- Electric and mechanical fans in harmony?
- Frame Dollies
- Alternator not working after clocking
- Original v. nos (v. repro)
- Salvage Titles - Cleaning??
- What size drill bit to use?
- M-21 issue
- Help for a C4 guy. What about a 58 project?
- 62 idlier can you explain to me what it was for?
- Keeping it dry for the winter
- Original GM part numbers...website?
- She’s BACK!!
- Midyear California Owners-Title Question
- CQ CQ Vette HAMs
- Need a Carb Diagnosis
- Progress on 64. Pics
- L79 intake on a base 300HP?
- HEI Troubleshooting
- 1967 Corvette. 194677S112557. I have your POP.
- Opinions on the Diff X Member Reinforcement
- Early C1 Hood Pulls
- Price of Thermostat
- My new Race Ramps, good & bad.
- Is there a problem with NCRS site?
- 67' Parking Brake
- Opinions please rusty nuts and bolts
- Gotta Love the Parts Vendors
- 2010 Good Guys at Pocono Pics
- Placement of Window Regulator Seals
- 1959 Corvette Registry gone ??
- Help In Removing My Diff
- setting odometer
- harrison expansion tank 88-L?
- 1954 harness ground question...
- Previous owner says my engine is a 283ci now
- 65 and 66 big block prices!!!
- Correct Block
- Interior Refurbish Questions
- Fast Idle adjustment on a WCFB 1x4 1961
- Adjusting Fast Idle on a WCFB 1961 2x4
- Where to buy engine parts?
- Grand Sport Hood on a C2?
- 1966 Vert Market Price - You make the call - On Target or Off Base
- fuel pump rebuild
- 1965 Corvette - OEM Frame Color
- Where to buy factory stamped steel rockers?
- C2 Manual Transmission
- Mid-year wiper motor rebuild
- Fuses for a 67
- OT: Anybody else think about Craig Barrett getting that Bugatti?
- Fall Fever Pics
- Car Show - August 21,2010
- Auto Tran Leaking (from everywhere!)
- Black '61 Vette at Barrett-Jackson Vegas
- 1967 Convertible Missing Trim Tags?
- PB pedal slow return with engine running
- Finally body meets frame again
- Where to send Glovebox Door for Restoration?
- c1 with ls1
- 58 - front vent holes on both sides of radiator question
- 58 - Rear Axle Vent Tube - no threaded hole for brass fitting??
- 58 -ideas on trunk irons not scratching paint
- Some pics from Carlisle and Radir show, a little late
- Secret Antenna for Secret Radio
- Parking Brake C1
- Pictures questions radiator, support and shroud
- "Crossroad Corvette Show" Morristown, TN
- *** St Jude Auction #72 Autographed Sammy Sosa Baseball ***
- Original Fuel Tank and sender?
- Mother Road Car show pictures
- 59 Fender Molding
- 1966 427 corvette inner fender
- oil question
- Headlight Covers - Plan B
- casting numbers
- 56,57 NOS courtesy light question
- 1965 coupe power antenna
- Radiator fan questions.......new VS old.....
- 1960 .. what is wrong with this VIN
- gold line/ red line tires?
- Z bar rebuild
- k and h rims
- Willcox Fall Forum Memeber Only Sale!
- Raleugh NC Paint Source?
- 1954 Corvettes - question
- The Ardun V-8
- Dust Shield Installation
- Confused about Chicago corvette shows
- Engine Choice...Get your vote in
- Difference between 63 radiator support and shroud from other years
- Starting a restore on 66 sting ray.
- Seat Belt Bolt
- C1 cover recommendations
- MSD Ignition
- ~~~ St Jude Auction #71 Autographed B.balls, Cepeda,Leyritz,Irvin,Marichal,Cangelosi
- Corvette Specialties move to Palm Desert
- Help identifying my heads
- Bumpers need rechrome i think?
- owning a c/1 and many fixes
- Bloomington Gold Survivor Questions
- C2 rear-end seals leaking.
- exhaust manifold porting?
- Finishing up a 56
- 67 Bolt Ons
- Where to find original waterpump?
- 64 327 front end creaks
- Installing roller rockers
- Historic lacquer Paint R-M paint codes-HELP!
- Finally had some good luck with my 63
- C2 Body squeak/ upper sections
- Need help, Rotor will not go on
- 58 - where do I mount the horns?
- block numbers???
- helicopter photo 75 Corvette caravan
- Corvette Authority Wanted SoCal
- tall valve cover recommendations
- LOOK help with history on my 61 from New York do you reconize these pictures?
- conv top install 66
- $125k '58 Fuelie at Barrett
- 65 Shift Boot Replacement
- Auto transport recommendation KY to IL Shortnotice....
- Numbers
- block and head numbers
- Speed direct coil overs
- Whose Rotors????
- Tires for the 67...
- Seat belts in a '53, '54, '55?
- 63 tail lights
- Body shop update pics
- 65 hardtop, small or big block
- Friday Funny Smiles........
- '56 Vette-Rod and a few hot rods...
- Need help with patching 2 small holes
- foward light harness question
- c1 c2 registery scam ??
- What weight can a C1 tow
- 1960 windshield assembly
- That rubber piece on a '54...
- Extraction & Clean Up: Barn Find '59 Pt. III
- Anyone from the Roanoke Va. area???
- T Bird Corvette Speedo
- Centering a Body on the Chassis
- New FI Unit has arrived
- ~~ St Jude Auction #70 Real American Heroes ~~
- Parts info for '54
- Stumbled on some cool rides........
- Anybody running a small block tri-power?
- Torque ?
- Thread Size of Stud & Nut on a Traditional Ignition Coil
- FREE Contest, 1958-1962 Reproduction Stant Gas Cap Give away
- parking brake bracket-63
- Odometer not working
- Passenger Car Power Steering
- A 327 - what horsepower
- Horn honks when I pull the steering wheel hard.
- Progress report - repairs to 66 roadster
- Passenger side view mirrors.....optional?
- Tractor Restoration
- Steering column to dash gap
- Sermersheim glass for C1 front end
- 65 Heater Temperature Control Question
- Escutcheon is it chrome or stainless on 59 glove box lock
- '61 Clutch Anti-Rattle Spring Location
- Why r people laughing at my avatar
- headlight motors for a 1963
- Ncrs guys look in
- 63 Electrical Problem
- Reverse lock out pin is stuck.
- HURST Shifter isnt stock
- Numbers Matching Game
- Speedometer cable
- Did you own my "58 in Oregon?
- OT Garage floor tiles?
- She's back on all fours (tires that is)
- 6,956 original miles 1960!!!
- 58 - Spark Plug Wiring Dressing help
- 64 master cylinder/booster
- Brake and taillight fuse keeps blowing
- I found a parts catalog
- Hope to get my 66 Coupe back from the Paint shop soon...
- Need help decoding big block.......
- Behind the scenes at Mecum last weekend
- Headlight Bucket Size
- 53-54 Washer Lid Decal Question
- Clock Hands Sticking
- Can you ID this part?
- Wiper Transmissions Install
- Another numbers question
- Period Photos of '59 Barn Find
- ~~~St Jude Auction #69 ** Perry, Strawberry and Perez Autographed baseballs ~~
- Factory engine restamp?
- Value of 65-67 Coupe
- *#* St Jude Auction #68 Autographed "Jake" Corvette Racing Bandana *#*
- Off idle stumble
- [TOYS FOR TOTS]Leading this year’s run as our Grand Marshall…
- Van Steel's Top Notch! Rear Wheel Bearing Rebuild
- New Issue Vette Vues Magazine
- Good source for 1983 Corvette parts???? Not C1/C2 related but
- Best method/siphon 67 diff oil ?
- Are These Covette Steel Wheels?
- holley check ball
- Big Block and Powerglide Combo
- Electrical problem
- Coolant pressure
- Powerglide problem
- Found two dogdish caps on line
- U joint r & r on a 65
- Question about midyear hardtops (65)
- 340 HP aluminum intake C1
- Rear Main Oil Seal
- Grand Sport #4 pictures (and others) from the American Diabetes Assoc fund raiser
- Van Steel coil overs
- Differential vent question
- Big Block 427 question.............
- need help with parts on install of headers
- Corvettes at Carlisle Austin Healy?
- C1-SPW (Specialty Power Windows) problem
- Has the "wave" been delegated to motorcycles?
- Watch Out Guys Hide Your Corvettes Our Dollar Is Up
- Leave Modified or Not
- 1962 clutch return spring
- Late model suspension on 66 frame?
- '62 engine question
- Anyone know this car? (65 convertible)
- Battery is in.....whew
- Gm only pics
- Looking for help in hooking up power ant.
- C2 small engine fire pix - your thoughts?
- 327 build tips starting next week.
- Fitting Rear bumper on 63
- Quality issues with 59 tail lights from Zip/Trimparts
- Wife out of town "Oh Boy"
- Front fender question
- No power to ignition. No power in interior.
- OT: Nice driving
- How many need the outer AC heather evaporator/fan box? What about have some made?
- What is Correct on 58-60 exhaust
- Ball joints
- Ignition Shielding Cleaning...
- So I bought it.
- Lower Windshield bonding strip question
- Any Experience Out There With CHROME Classic Car Insurance??
