View Full Version : C1 & C2 Corvettes
  1. air pump diverter valve be rebuilt?
  2. heat riser
  3. Tremec and engine in one piece
  4. 1967 Wiring Fuse block
  5. 1962 Rocker moldings OEM or Reproduction
  6. Dyno sheet, dyno sound, 383 stroker motor pics
  7. MY6 O/D Transmission Help Please
  8. Temp question
  9. Base Clear or Lacquer for a fresh frame off
  10. 62 Window Regulator
  11. First Spring Ride - 87 Degrees and AC/Love My Bias Plys
  12. SR-1 - New (old) one identified
  13. C1 & C2 owners who have a C4 also
  14. 64 front end alignment
  15. Coolest American Car contest
  16. Is this the proper toe measuring method?
  17. Rear deck spring on 66
  18. Virgina Vettes
  19. Firestone 775-15
  20. 1956 Corvette undercarriage
  21. 1962 Corvette timing
  22. Zora's Legendary EX87 Corvette Test Mule Offered at Mecum's Spring Classic
  23. Long Travel Hydraulic Lifters ???
  24. Anybody Have Pictures of This 62?
  25. 1965 big block historic racer
  26. New 2010 Grand Sport To Premiere At Cruise-In X!!!
  27. 350 Ram Jet
  28. C2 Window Sticker
  29. Fire or Fuel ??
  30. What size belt /pully
  31. 62 Air Cleaner
  32. To install sidepipes or not
  33. 1958 Rear Harness (tail light) question
  34. New 61 delivered, Some problems...
  35. 2 Questions & 1 Advice
  36. 63 pcv valve
  37. To Sleeve or not to sleeve
  38. Rear main seal ?? leak!
  39. Wiper transmission question
  40. 66 bb manifold question
  41. My 383 DYNO at T&L
  42. Proper Jacking Of Midyear Frame?
  43. need help in San Diego: 1960 C1
  44. High beam headlight issue on 1960
  45. "Vettes Doin' Charleston" C1 and C2 Class Pics
  46. Dropping the Oil Pan
  47. Bolt torque needed
  48. Are this wheels from a Vette?
  49. Best tube chassis for a resto rod?
  50. Help Need Picture of 64 Drum Brake Line Routing
  51. Bench testing C1 fuel and temp gauges
  52. Will this Hooker header/exhaust system from a C3 fit my C2?
  53. 1963 door jam/dash panel paint question
  54. SS vs steel fuel lines
  55. C1 cup holder
  56. New-Old plate for the 67
  57. Finally!
  58. Cast intake for 66
  59. Motor Mount Source???
  60. Reproduction Window Sticker - need help
  61. Parking Light Wiring Harness Connector Question
  62. Ignition switch removal
  63. Chevrolet's 1953 Corvette
  64. '61 Corvette Starter
  65. Help with body shims and tranny issue
  66. Transferring dash pads................
  67. Cruise-In Badge Reminder...
  68. Frame strength question - 67
  69. 67 L79 intake color at the runners
  70. Some coupe door questions
  71. Orginal Fiberglass/Primer?
  72. Need some info on the console on a 63.
  73. another track 1 belt question
  74. 1964 Sold to ROBERT (BOB) KELLS OUT OF VA?
  75. Radio Delete Option
  76. Any Corvette owners up for Cruising?
  77. bolt torque question
  78. New Guy needs help
  79. Anyone interested in a Pacific Coast Road Trip?
  80. Speedo Needle Removal
  81. What transmission is this?
  82. NCRS Judge in Augusta GA
  83. 61 and 65 Rocker Arm Stud Size
  84. correct Ign timing for 1958 vette?
  85. C-2 Gas cap questions
  86. 1964 Wiper Switch Removal?
  87. Good progress, a few minor snags
  88. Non Power Disk to Power Disk
  89. ram horns without hear riser valve ?
  90. Tightening Back-up Light Housing
  91. Track 1 belt on 66 BB
  92. Forum Speed
  93. Strictly Corvette..Thank You!!
  94. engine noise
  95. Driveshaft removal
  96. Hibernation over!
  97. Hibernation over!
  98. Jay's 53
  99. Progress
  100. 66 Vert Deck Lid Latches
  101. I need one Valve Cover for a 65
  102. Balancer installation tool for early Non threaded Crank
  103. Suggestions for a car cover?
  104. Do Any of the Major Vendors Sell Al Knoch Carpet
  105. Star Trek 2009
  106. 1965 396 Engine Compartment
  107. 1963 300hp Dieseling after shutoff
  108. Won at Super Chevy today!!
  109. Looking for some help with a dual quad problem.
  110. Dallas Swap Meet 1981
  111. Headlight problem
  112. Leaking Fuel Inlet
  113. Another Corvette Numbers Query
  114. Anyone have problems with reproduction weatherstrips?
  115. First ride on the 61 this year
  116. 53-54 Positive Battery Cable - 6 Volt
  117. Summit racing corvette fron the 1980s
  118. C2 Dash Removal
  119. Original Owner Found
  120. Hooters Corvette Car Show
  121. Intake / head mismatch?
  122. Help re 1963 value
  123. I found out original owner on my 67
  124. Tom
  125. Radio Speaker Replacement
  126. Variable H pipe?
  127. Radio to Speaker connection
  128. Anybody near Cadillac, MI?
  129. What in God's name it it going to take to get rid of the crapin C1, C2, C3 etc??????
  130. A C1 was the best car at Pinks all out
  131. Clutch Tick
  132. Flywheel info for 64 fi
  133. 1966 427/450 Fuel Pump
  134. 1965-1966 Spare Tire Wheel
  135. 1966 Correct Engine Color ?
  136. Nice site for some tech info
  137. Fuel pump question
  138. Brake rotor minimum thickness?
  139. C1 deck lid snap straps
  140. Tail Light out need help
  141. 1961 prices
  142. Rear wiring harness routing question
  143. Opinions on Flywheel and Clutch assembly...
  144. Memphis corvette lovers...
  145. A true barn find. Actually a garage, with pics.
  146. Took my 66 BB out for 20 mile run , food for thought
  147. 64 4 Speed Trans Upgrade ???
  148. Rear End HELP Needed
  149. fuel line magnet
  150. Any advice on bolt on knock off's
  151. Es car go
  152. How rough is rough
  153. NCRS timeline pics try #2
  154. Forget your big block, this is it
  155. Just the Right Brake light does not work!
  156. experienced corvette softtop installer, Spokane Wa area
  157. Birdcage Advice Needed
  158. NCRS Regional #2 - timeline pics
  159. NCRS Regional - lots of pics
  160. which tires for 65 coupe?
  161. hiolley 4160
  162. Build Tag on a 66 Coupe
  163. '62 fan switch wireing question?
  164. Chambered Exhaust... should I or shouldn't I?
  165. 62 Engine Problem
  166. Carburetor rebuild ???
  167. 327/350 running still at 220
  168. Tremec Question
  169. Richmond 5 speed............another question
  170. 1965 Antenna Switch
  171. 1958 4-speed and Muncie M20 Transmission
  172. Another E-bay deal
  173. 10% off Speed Direct, Steeroids, etc.
  174. Insurance
  175. Question: 4 Speed Console Repair Kit
  176. Chassis dyno results
  177. Help?..Engine stumbles upon hard acceleration
  178. Console Assembly in 65
  179. Hard accelleration uphill
  180. 1966 fuel door
  181. Flares are just a memory. Final pics.
  182. 5 speed richmond question
  183. How to remove Calyx?
  184. 62 Radio
  185. C1 window sticker. What did it look like??
  186. F41 Special Front and Rear Suspension
  187. Test fitted new tires for my C2, these are huge!
  188. Holley Carb rebuild
  189. Another VIN tag question
  190. Convertible Soft Top Frame suggestions
  191. Midyear Hi/Low Switch Alternate Solution?
  192. Pics of 3 mature ladies posing in the sun
  193. Have you missed me? MOTOR BACK IN
  194. Polishing Chrome
  195. Mid yr with a 9
  196. More on C2 lighter
  197. 62 tach to MSD setup
  198. Videos of my 69 Z28
  199. "M" inside a circle in blue in windshield posts
  200. Going to paint my exhaust manifolds
  201. fixing rotor runout
  202. Another Wheel Thread
  203. 63 cigarette lighter
  204. Happy Birthday
  205. Well Look Who's on the Cover...Do You Know This Man..You Should
  206. Do these numbers match?
  207. Intake manifold torque specs
  208. Lost vin tag
  209. Is this an NOS fuel door?
  210. $3000 in Gift Certificates
  211. New Product!
  212. Learn About Your Corvette
  213. OT - Moving to Houston.....advise please
  214. '65 main brake line sizes
  215. NC residents notice
  216. Starting her back up
  217. is blooming worth it anymore?????
  218. Another 1961 top question
  219. Hood rear weatherstrip question
  220. I'm either dumb or something is wrong with `62 rear lamp
  221. 58 dash pad question and color powder coat
  222. new windshield for 66 convertible
  223. Classic Chevrolet Sugar Land Grand Opening!!!
  224. speedometer gear..number of teeth
  225. 67 clutch poblem
  226. Coupe to Convertible?
  227. what size belt?
  228. Broach Marks
  229. Getting my car painted
  230. C1 Conv top question, aftermarket
  231. 61 Corvette Racecar?
  232. Dynamat, Hushmat, Fatmat, etc. or Not
  233. Hydroboost brake tuning....
  234. 66 327 Clutch Question
  235. Exhaust is on the frame.
  236. C1 Leaf Spring Help
  237. Gardner Exhaust System on 65
  238. power tour???
  239. '67 Clutch Issues
  240. Center Dash & Dash Pads Reskinned
  241. An historic eBay offering!
  242. An historic eBay description!
  243. Front spring install
  244. Heater Hose shutoff valve...need help
  245. Headlight motor clamshell grease to use?
  246. 63 big brake vette
  247. Myrtle Beach Car Show
  248. what's that grease???
  249. Speedometer Drive Gear Install
  250. Confused about fan clutches
